[General] C_THR95_2505證照信息 - C_THR95_2505在線考題
107
【General】 C_THR95_2505證照信息 - C_THR95_2505在線考題
Posted at 2/17/2026 02:34:54      View:112 | Replies:0        Print      Only Author   [Copy Link] 1#
順便提一下,可以從雲存儲中下載NewDumps C_THR95_2505考試題庫的完整版:https://drive.google.com/open?id=1jijD5ZEvp9js8oRwOChKVjjooUjLpqZ-
我們NewDumps確保你第一次嘗試通過考試,取得該認證專家的認證。因為我們NewDumps提供給你配置最優質的類比SAP的C_THR95_2505的考試考古題,將你一步一步帶入考試準備之中,我們NewDumps提供我們的保證,我們NewDumps SAP的C_THR95_2505的考試試題及答案保證你成功。
SAP C_THR95_2505 考試大綱:
主題簡介
主題 1
  • Enabling Development Goal Plans: This section of the exam assesses the abilities of Talent Development Specialists in setting up and managing development goal plans. It includes creating goal templates, setting permissions, and aligning development planning with performance and growth objectives.
主題 2
  • Configuring SAP SuccessFactors Career Development Planning: This section of the exam measures skills of SAP Consultants and covers the basic configuration of Career Development Planning. It includes foundational system setup steps required to enable development planning features and ensure integration with the broader SuccessFactors suite.
主題 3
  • Configuring Learning Activities: This section of the exam measures the skills of Talent Development Specialists in configuring learning activities within the development plan. It focuses on aligning learning content with development goals to facilitate continuous skill-building.
主題 4
  • Configuring Career Worksheets, Career Paths, and Opportunity Marketplace: This section of the exam evaluates the knowledge of SAP Consultants in configuring advanced tools such as the career worksheet, career paths, and the opportunity marketplace. These features support internal mobility and employee-led career exploration and development.
主題 5
  • Creating Mentoring Programs: This section of the exam assesses the ability of SAP Consultants to create and configure mentoring programs. It includes setting criteria, workflows, and matching logic for connecting mentors and mentees as part of development initiatives.
C_THR95_2505在線考題 & C_THR95_2505參考資料你正在為了怎樣通過SAP的C_THR95_2505考試絞盡腦汁嗎?SAP的C_THR95_2505考試的認證資格是當代眾多IT認證考試中最有價值的資格之一。在近幾十年裏,IT已獲得了世界各地人們的關注,它已經成為了現代生活中不可或缺的一部分。其中,SAP的認證資格已經獲得了國際社會的廣泛認可。所以很多IT人士通過SAP的考試認證來提高自己的知識和技能。C_THR95_2505認證考試就是最重要的考試之一。這個認證資格能為大家帶來很大的好處。
最新的 SAP Certified Associate C_THR95_2505 免費考試真題 (Q46-Q51):問題 #46
Which text replacement option does NOT apply to Career Development Planning?
  • A. copy-from-my-other-goal-plan
  • B. category
  • C. cascade-selected
  • D. add-existing-goal-to-form
答案:C
問題 #47
What can you see with the Mentoring Program Details icon?Note: There are 2 correct answers to this question.
  • A. The number of mentees and the number of mentors who declined
  • B. The number of mentees who were approved by their managers
  • C. The number of mentees and the number of mentors who signed up
  • D. The number of mentors who are currently unavailable
答案:A,C
問題 #48
Your customer wants you to enable the Preferred Next Move feature in the People Profile and the Career Worksheet.Which activities do you perform?Note: There are 2 correct answers to this question.
  • A. Set the share permission for one or more relative roles in the Career Worksheet template.
  • B. Set the data-field id="title" in the background element from Succession Data Model XML.
  • C. Set the title and relocPref fields defined in the background element as required in the Succession Data Model.
  • D. Set the data-field id="Title" in the background element from Succession Data Model XML.
答案:A,D
問題 #49
Your customer wants to utilize the Readiness Meter in Career Worksheet.Which of the following should you consider when including the Readiness Meter for future roles?Note: There are 2 correct answers to this question.
  • A. The new-role-readiness-calculation switch will set a competency not met to the value of zero.
  • B. The mapped competencies in Families and Roles must have expected ratings and weights.
  • C. The new-role-readiness-calculation switch will weigh proportionally each competency rating as a percentage of the expected rating.
  • D. The readiness_meter field should be defined in the template and referenced in the field- permissions and plan-layout.
答案:C,D
問題 #50
Where can you see a development goal plan field label, which you would NOT see otherwise, when showlabel="true"?
  • A. In the development goal section of a PM form when the plan is synchronized with the form
  • B. In the development goal pop-up window when creating a new goal from the library
  • C. In the development goal block in People Profile when editing an existing goal
  • D. In the development goal plan layout when the field is NOT at the top of the column
答案:A,B
問題 #51
所有的IT專業人士熟悉的SAP的C_THR95_2505考試認證,夢想有有那頂最苛刻的認證,你可以得到你想要的職業生涯,你的夢想。通過NewDumps SAP的C_THR95_2505考試培訓資料,你就可以得到你想要得的。
C_THR95_2505在線考題: https://www.newdumpspdf.com/C_THR95_2505-exam-new-dumps.html
此外,這些NewDumps C_THR95_2505考試題庫的部分內容現在是免費的:https://drive.google.com/open?id=1jijD5ZEvp9js8oRwOChKVjjooUjLpqZ-
