[Hardware] 220-1201 Exam Cost, Latest 220-1201 Guide Files
85
【Hardware】 220-1201 Exam Cost, Latest 220-1201 Guide Files
Posted at 2/17/2026 04:34:48      View:121 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New 220-1201 dumps are available on Google Drive shared by BraindumpsPass: https://drive.google.com/open?id=1jX81ALA-6NMDtjYOI5lIKDE02q-njgEo
As we know, CompTIA actual test is related to the IT professional knowledge and experience, it is not easy to clear 220-1201 practice exam. The difficulty of exam and the lack of time reduce your pass rate. And it will be a great loss for you if you got a bad result in the 220-1201 Exam Tests. So it is urgent for you to choose a study appliance, especially for most people participating 220-1201 real exam first time.
Our 220-1201 study materials are compiled and verified by the first-rate experts in the industry domestically and they are linked closely with the real exam. Our products’ contents cover the entire syllabus of the exam and refer to the past years’ exam papers. Our test bank provides all the questions which may appear in the real exam and all the important information about the exam. You can use the practice test software to test whether you have mastered the 220-1201 Study Materials and the function of stimulating the exam to be familiar with the real exam’s pace, atmosphere and environment. So our 220-1201 study materials are real-exam-based and convenient for the clients to prepare for the exam.
100% Pass Quiz 220-1201 - CompTIA A+ Certification Exam: Core 1 –Reliable Exam CostThere is always a fear of losing 220-1201 exam and causes you loss of money and waste time on some unless materials. However, these risks will never exist in our 220-1201 exam materials. Your money and exam attempt is bound to award you a sure and definite success with 100% money back guarantee. You can claim for the refund of money if you do not succeed and achieve your target. Our 220-1201 exam materials have a most reliable guarantee. We ensure you that you will be paid back in full without any deduction and you can easily pass the 220-1201 Exam by using our 220-1201 dumps. Moreover, you will get all the updated 220-1201 questions with verified answers. If you want to prepare yourself for the real exam, then it is one of the most effect ways to improve your 220-1201 exam preparation level.
CompTIA A+ Certification Exam: Core 1 Sample Questions (Q42-Q47):NEW QUESTION # 42
Which of the following network services is used to assign an IP address to a network host?
  • A. DHCP
  • B. SMTP
  • C. DNS
  • D. LDAP
DHCP (Dynamic Host Configuration Protocol) is the service used to automatically assign IP addresses to network hosts. It dynamically manages the distribution of IP addresses and configuration details (like subnet mask, gateway, and DNS servers), ensuring no two devices are assigned the same address on the network.
Option B (DNS): Incorrect. DNS translates domain names into IP addresses but does not assign them.
Option C (LDAP): Incorrect. LDAP is a protocol used for accessing and maintaining directory services, such as user information and permissions.
Option D (SMTP): Incorrect. SMTP is used for sending and receiving email, not for IP address assignment.
CompTIA A+ Core 1 Objectives: 2.5 (Network configuration)
NEW QUESTION # 43
A technician is enabling BitLocker. Which of the following is required to accomplish this task?
  • A. ARM
  • B. SAN
  • C. TPM
  • D. HSM
BitLocker requires a Trusted Platform Module to securely store encryption keys and verify system integrity during the boot process, enabling full-disk encryption without requiring user intervention at startup.
NEW QUESTION # 44
Which of the following systems most likely contains ECC memory?
  • A. A file server
  • B. A laptop
  • C. A smartphone
  • D. A high-end gaming console
Error-Correcting Code (ECC) memory is designed to detect and correct single-bit memory errors, increasing system reliability and data integrity. According to CompTIA Core 1 (220-1201) hardware and memory objectives, ECC memory is most commonly used in servers and enterprise-grade systems where uptime and data accuracy are critical.
A file server is responsible for storing, managing, and serving data to many users simultaneously. Memory errors in such systems could lead to data corruption, crashes, or security issues. For this reason, servers frequently use ECC memory in combination with server-class CPUs and motherboards that support error correction.
High-end gaming consoles prioritize performance and cost efficiency rather than fault tolerance, and they do not use ECC memory. Smartphones rely on low-power mobile RAM without error correction, and laptops typically use non-ECC memory unless they are specialized workstation-class systems, which is not indicated in this question.
CompTIA emphasizes that ECC memory is associated with mission-critical environments, particularly servers and enterprise systems, making a file server the most appropriate answer.
CompTIA A+ Core 1 (220-1201) Official Study Guide - RAM Types, ECC Memory, and Server Hardware
NEW QUESTION # 45
An administrator is configuring a SOHO network. The network scope requires static IP addresses for printers. Which of the following must the administrator set manually? (Choose two.)
  • A. Exclusions
  • B. Default gateway
  • C. Subnet mask
  • D. DHCP
  • E. Reservations
  • F. DNS
When configuring a device with a static IP address, the subnet mask must be manually set so the printer can determine which addresses are local. The default gateway must also be manually configured to allow the printer to communicate with devices outside its local network, such as management systems or other subnets.
NEW QUESTION # 46
A technician is unable to join a computer to the domain. The technician runs ipconfigand gets the following output:
Which of the following is the most likely cause?
  • A. NetBIOS is enabled.
  • B. The subnet mask Is Incorrect.
  • C. DNS servers are manually set.
  • D. DHCP is enabled.
Joining a domain requires the computer to use the organization's internal DNS so it can locate domain controllers and domain services. With public DNS servers configured, the computer cannot resolve the internal domain records needed to complete the domain join.
NEW QUESTION # 47
The experts in our company have been focusing on the 220-1201 examination for a long time and they never overlook any new knowledge. The content of our study materials has always been kept up to date. Don't worry if any new information comes out after your purchase of our 220-1201 study guide. We will inform you by E-mail when we have a new version. With our great efforts, our study materials have been narrowed down and targeted to the 220-1201 examination. So you don't need to worry about wasting your time on useless 220-1201 exam materials information.
Latest 220-1201 Guide Files: https://www.braindumpspass.com/CompTIA/220-1201-practice-exam-dumps.html
Who Chooses BraindumpsPass Latest 220-1201 Guide Files BraindumpsPass Latest 220-1201 Guide Files is the world's largest certification preparation company with 99.3% Pass Rate History from 189861+ Satisfied Customers in 145 Countries, Our 220-1201 exam study material will always be your top choice, If you are qualified by the 220-1201 exam certification, you will be outstanding in the crowd, CompTIA 220-1201 Exam Cost Many people have taken the exam but failed largely due to the fact that they have been unconscious of missing the details that may appear on the test.
However, only a very few people seize the initiative in their life, It ensures that you would qualify for the CompTIA A+ Certification Exam: Core 1 (220-1201) certification exam on the maiden strive with brilliant grades.
Newest CompTIA A+ Certification Exam: Core 1 Valid Questions - 220-1201 Updated Torrent & 220-1201 Reliable TrainingWho Chooses BraindumpsPass BraindumpsPass is the world's largest 220-1201 certification preparation company with 99.3% Pass Rate History from 189861+ Satisfied Customers in 145 Countries.
Our 220-1201 exam study material will always be your top choice, If you are qualified by the 220-1201 exam certification, you will be outstanding in the crowd.
Many people have taken the exam but failed largely due to the fact New 220-1201 Exam Camp that they have been unconscious of missing the details that may appear on the test, Thank you for choosing our study guide.
