[Hardware] High-quality Fortinet NSE8_812 Exam Actual Questions - NSE8_812 Free Download
103
【Hardware】 High-quality Fortinet NSE8_812 Exam Actual Questions - NSE8_812 Free Download
Posted at 2/17/2026 05:03:52      View:103 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Actual4Exams NSE8_812 dumps for free: https://drive.google.com/open?id=1P8XRPluisYZLajDUtEjzkSSuMWquLXUD
The Fortinet NSE8_812 exam questions pdf is properly formatted to give candidates the asthenic and unformatted information they need to succeed in the NSE8_812 exam. In addition to the comprehensive material, a few basic and important questions are highlighted and discussed in the NSE8_812 Exam Material file. These questions are repeatedly seen in past Fortinet NSE 8 - Written Exam (NSE8_812) exam papers. The Fortinet NSE 8 - Written Exam (NSE8_812) practice questions are easy to access and can be downloaded anytime on your mobile, laptop, or MacBook.
Fortinet NSE8_812 certification exam is an advanced-level test designed for experienced network and security professionals who aim to showcase their expertise and knowledge in designing and implementing complex network security solutions. Fortinet NSE 8 - Written Exam (NSE8_812) certification is recognized globally and is an excellent way for professionals to differentiate themselves from their peers and advance their careers in the network security industry.
Fortinet NSE8_812 (Fortinet NSE 8 - Written Exam) is a certification exam designed for network and security professionals who aim to showcase their expertise and knowledge in designing, implementing, and managing complex network security solutions. NSE8_812 exam is the highest level of certification offered by Fortinet, which is a leading provider of network security solutions globally.
2026 Fortinet NSE8_812: High Hit-Rate Fortinet NSE 8 - Written Exam (NSE8_812) Exam Actual QuestionsDownload the free NSE8_812 demo of whatever product you want and check its quality and relevance by comparing it with other available study contents within your access. NSE8_812 study guides will prove their worth and excellence. Check also the feedback of our clients to know how our products proved helpful in passing the exam. Actual4Exams ensures your success with money back assurance. There is no chance of losing the exam if you rely on NSE8_812 Study Guides. If you do not get through the exam, you take back your money. The money offer is the best evidence on the remarkable content of NSE8_812.
Fortinet NSE8_812 Exam is intended for experienced network security professionals who have a strong understanding of network security concepts and technologies. Candidates should have at least five years of experience in network security design, implementation, and management, as well as experience with Fortinet's network security solutions.
Fortinet NSE 8 - Written Exam (NSE8_812) Sample Questions (Q53-Q58):NEW QUESTION # 53
A customer needs to create a multi-tier MCLAG set up with the topology as shown in the exhibit.
A1/A2
B1/B2
C1/C2
Which command snippet should be applied to it, to allow active/active links in this topology?
  • A.
  • B.
  • C.
  • D.
NEW QUESTION # 54
A customer wants FortiClient EMS configured to deploy to 1500 endpoints. The deployment will be integrated with FortiOS and there is an Active Directory server.
Given the configuration shown in the exhibit, which two statements about the installation are correct?
(Choose two.)
  • A. You must use Standard or Enterprise SQL Server rather than the included SQL Server Express
  • B. You can only deploy initial installations to Windows clients.
  • C. The Windows clients only require "File and Printer Sharing0 allowed and the rest is handled by Active Directory group policy
  • D. A client can be eligible for multiple enabled configurations on the EMS server, and one will be chosen based on first priority
  • E. If no client update time is specified on EMS, the user will be able to choose the time of installation if they wish to delay.
* A is correct because if no client update time is specified on EMS, the user will be able to choose the time of installation if they wish to delay. This is because the FortiClient EMS server will not force the installation on the client.
* E is correct because the Windows clients only require "File and Printer Sharing" allowed and the rest is handled by Active Directory group policy. This is because the Active Directory group policy will configure the Windows clients to automatically install FortiClient and the FortiClient EMS server will only need to push the initial configuration to the clients.
The other options are incorrect. Option B is incorrect because a client can only be eligible for one enabled configuration on the EMS server. Option C is incorrect because you can deploy initial installations to both Windows and macOS clients. Option D is incorrect because you can use the included SQL Server Express to deploy FortiClient EMS.
Deploying FortiClient EMS | FortiClient / FortiOS 7.4.0 - Fortinet Document Library Configuring FortiClient EMS | FortiClient / FortiOS 7.4.0 - Fortinet Document Library FortiClient EMS installation requirements | FortiClient / FortiOS 7.4.0 - Fortinet Document Library
https://docs.fortinet.com/docume ... ployment-installers
https://docs.fortinet.com/docume ... loying-forticlient- software-to-endpoints
NEW QUESTION # 55
Refer to the exhibit, which shows a Branch1 configuration and routing table.
In the SD-WAN implicit rule, you do not want the traffic load balance for the overlay interface when all members are available.
In this scenario, which configuration change will meet this requirement?
  • A. Configure the priority in each overlay member to 10.
  • B. Create a new static route with the internet sdwan-zone only
  • C. Change the load-balance-mode to source-ip-based.
  • D. Configure the cost in each overlay member to 10.
The default load balancing mode for the SD-WAN implicit rule is source IP based. This means that traffic will be load balanced evenly between the overlay members, regardless of the member's priority.
To prevent traffic from being load balanced, you can configure the priority of each overlay member to 10. This will make the member ineligible for load balancing.
The other options are not correct. Changing the load balancing mode to source-IP based will still result in traffic being load balanced. Creating a new static route with the internet sdwan-zone only will not affect the load balancing of the overlay interface. Configuring the cost in each overlay member to 10 will also not affect the load balancing, as the cost is only used when the implicit rule cannot find a match for the destination IP address.
NEW QUESTION # 56
Refer to the exhibits.
A customer is looking for a solution to authenticate the clients connected to a hardware switch interface of a FortiGate 400E.
Referring to the exhibits, which two conditions allow authentication to the client devices before assigning an IP address? (Choose two.)
  • A. Ports 3 and 4 can be part of different switch interfaces.
  • B. FortiGate devices with NP6 and hardware switch interfaces cannot support 802.1X authentication.
  • C. Devices connected directly to ports 3 and 4 can perform 802 1X authentication.
  • D. Client devices must have 802 1X authentication enabled
The customer wants to deploy a solution to authenticate the clients connected to a hardware switch interface of a FortiGate 400E device. A hardware switch interface is an interface that combines multiple physical interfaces into one logical interface, allowing them to act as a singleswitch with one IP address and one set of security policies. The customer wants to use 802.1X authentication for this solution, which is a standard protocol for port-based network access control (PNAC) that authenticates clients based on their credentials before granting them access to network resources. One condition that allows authentication to the client devices before assigning an IP address is that devices connected directly to ports 3 and 4 can perform 802.1X authentication. This is because ports 3 and 4 are part of the hardware switch interface named "lan", which has an IP address of 10.10.10.254/24 and an inbound SSL inspection profile named "ssl-inspection". The inbound SSL inspection profile enables the FortiGate device to intercept and inspect SSL/TLS traffic from clients before forwarding it to servers, which allows it to apply security policies and features such as antivirus, web filtering, application control, etc. However, before performing SSL inspection, the FortiGate device needs to authenticate the clients using 802.1X authentication, which requires the clients to send their credentials (such as username and password) to the FortiGate device over a secure EAP (Extensible Authentication Protocol) channel. The FortiGate device then verifies the credentials with an authentication server (such as RADIUS or LDAP) and grants or denies access to the clients based on the authentication result. Therefore, devices connected directly to ports 3 and 4 can perform 802.1X authentication before assigning an IP address.
Another condition that allows authentication to the client devices before assigning an IP address is that client devices must have 802.1X authentication enabled. This is because 802.1X authentication is a mutual process that requires both the client devices and the FortiGate device to support and enable it. The client devices must have 802.1X authentication enabled in their network settings, which allows them to initiate the authentication process when they connect to the hardware switch interface of the FortiGate device. The client devices must also have an 802.1X supplicant software installed, which is a program that runs on the client devices and handles the communication with the FortiGate device using EAP messages. The client devices must also have a trusted certificate installed, which is used to verify the identity of the FortiGate device and establish a secure EAP channel. Therefore, client devices must have 802.1X authentication enabled before assigning an IP address. References: https://docs.fortinet.com/docume ... ide/19662/hardware- switch-interfaceshttps://docs.fortinet.com/docume ... guide/19662/802-1x- authentication
https://docs.fortinet.com/docume ... virtual-switch-for- certain-np6-platforms
NEW QUESTION # 57
A FortiGate deployment contains the following configuration:
What is the result of this configuration?
  • A. Route-maps from VDOM SERVICES are available in all other VDOMs
  • B. Route-maps from the Root VDOM configuration are available in VDOM SERVICES
  • C. Route-maps are not configurable in VDOM SERVICES
  • D. Route-maps for VDOM SERVICES are excluded from HA configuration synchronization
https://docs.fortinet.com/docume ... ration-guide/105611
NEW QUESTION # 58
Exam NSE8_812 Preview: https://www.actual4exams.com/NSE8_812-valid-dump.html
