Valid Introduction-to-Cryptography Test Question | Real Introduction-to-Cryptogr
Posted at 2/17/2026 07:04:12
View106
Replies0
In order to provide the most effective Introduction-to-Cryptography exam materials which cover all of the current events for our customers, a group of experts in our company always keep an close eye on the changes of the Introduction-to-Cryptography exam, and then will compile all of the new key points as well as the latest types of exam questions into the new version of our Introduction-to-Cryptography training engine. Do not lose the wonderful chance to advance with times. Just come and have a try on our Introduction-to-Cryptography study questions!
All the real Introduction-to-Cryptography questions are included in the WGU Introduction to Cryptography HNO1 (Introduction-to-Cryptography) PDF Dumps files. This file is compatible with smart devices. The WGU PDF Dumps files are portable and printable, allowing candidates to study and prepare for the Introduction-to-Cryptography exam from anywhere, even on smartphones, laptops, and tablets. Moreover, Itexamguide regularly updates its WGU Introduction to Cryptography HNO1 (Introduction-to-Cryptography) PDF questions format to keep up with the changes in the WGU Introduction to Cryptography HNO1 (Introduction-to-Cryptography) exam content, ensuring that its WGU Introduction to Cryptography HNO1 (Introduction-to-Cryptography) exam questions are up-to-date and relevant.
Real Introduction-to-Cryptography Torrent, Study Introduction-to-Cryptography ReferenceIn order to further strengthen your confidence to buy the Introduction-to-Cryptography Training Materials of us, we offer you 100% money back guarantee in case you fail the exam. The money will be refund to your account and no extra questions will be asked. Additionally, Introduction-to-Cryptography exam braindumps of us have helped many candidates pass the exam successfully with their high-quality. And we have professional technicians examine the update every day, and once we have new version, our system will send the latest version to your email automatically.
WGU Introduction to Cryptography HNO1 Sample Questions (Q18-Q23):NEW QUESTION # 18
(What makes the RC4 cipher unique compared to RC5 and RC6?)
- A. Stream
- B. Asymmetric
- C. Block
- D. Symmetric
RC4 is unique among the RC family listed because it is a stream cipher. It generates a pseudorandom keystream and encrypts data by XORing that keystream with plaintext bytes (and decryption is the same XOR operation). This differs from RC5 and RC6, which are block ciphers: they encrypt fixed-size blocks of data through multiple rounds of operations (such as modular addition, XOR, and rotations) using a secret key. The stream-cipher design means RC4 historically fit protocols where data arrives continuously (e.g., early wireless and web encryption) and where simple, fast software implementation was desired. However, stream ciphers demand careful handling of nonces/IVs to avoid keystream reuse; reuse can catastrophically leak plaintext relationships. RC4 also has well-documented statistical biases in its keystream, leading to practical attacks in protocols like WEP and later concerns in TLS, which is why RC4 has been deprecated in modern security standards. Still, from a classification standpoint, "stream" is the distinguishing characteristic versus RC5/RC6 being block ciphers.
NEW QUESTION # 19
(What is the length of the Initialization Vector (IV) in WEP?)
- A. 40 bits
- B. 48 bits
- C. 56 bits
- D. 24 bits
WEP (Wired Equivalent Privacy) uses the RC4 stream cipher and combines a per-packet Initialization Vector (IV) with a shared secret key to form the RC4 seed for that packet's keystream. The IV in WEP is 24 bits long and is transmitted in the clear as part of the 802.11 frame so the receiver can reconstruct the same per-packet RC4 key stream. The short IV space (2²# possible values) is a major design weakness: on a busy network, IVs repeat frequently, causing keystream reuse. Because RC4 is a stream cipher, keystream reuse enables attackers to derive relationships between plaintexts and recover keys with statistical attacks (notably the Fluhrer, Mantin, and Shamir (FMS) family of attacks and related improvements). WEP also uses a CRC-32 integrity check (ICV) that is not cryptographically strong and is vulnerable to modification attacks. The 24-bit IV length is therefore a key reason WEP is considered insecure and has been replaced by WPA/WPA2 mechanisms that use stronger key mixing, larger nonces/IVs, and robust integrity protection.
NEW QUESTION # 20
(Which type of network were VPN connections originally designed to tunnel through?)
- A. Protected
- B. Private
- C. Encrypted
- D. Public
A VPN (Virtual Private Network) is designed to create a secure, private communication channel over an otherwise untrusted or shared infrastructure. Historically and conceptually, VPNs were built to allow organizations and users to transmit sensitive traffic across the public Internet while maintaining confidentiality, integrity, and authenticity. The "virtual" aspect means the network behaves like a private link, but the underlying transport is typically a public network where attackers could potentially observe or tamper with traffic. VPN technologies such as IPsec and SSL/TLS-based VPNs encapsulate packets and apply encryption and authentication so that the payload and session metadata are protected even when traversing public routing domains. Options like "encrypted" and "protected" describe properties of the VPN tunnel itself rather than the underlying network it traverses; the VPN provides encryption/protection precisely because the medium is not inherently secure. "Private" would describe a dedicated internal network, which generally does not require a VPN to achieve basic confidentiality. Therefore, VPNs were originally designed to tunnel through public networks.
NEW QUESTION # 21
(Which authentication method allows a customer to authenticate to a web service?)
- A. End-to-end authentication
- B. One-way client authentication
- C. Mutual authentication
- D. One-way server authentication
One-way client authentication is the method where the client (customer) proves its identity to the server (web service). In cryptographic terms, this is commonly implemented through client credentials such as client TLS certificates (mTLS from the server's perspective) or through authentication protocols layered over TLS (for example, signed tokens), but the defining direction is that the client is the party being authenticated. In a strict TLS certificate-authentication framing, client authentication occurs when the server requests a client certificate during the handshake and the client demonstrates possession of the corresponding private key (via signature in handshake messages). The server then validates the client certificate chain and authorization policy. One-way server authentication, by contrast, authenticates only the server to the client and does not identify the customer. Mutual authentication authenticates both sides simultaneously; while it includes client authentication, it is broader than what the question asks. "End-to-end authentication" describes assurance between endpoints across intermediaries, but it is not the specific "customer authenticates to service" method in certificate-based terminology. Therefore, the best answer is one-way client authentication.
NEW QUESTION # 22
(What is the length (in bits) of a SHA-1 hash output?)
SHA-1 (Secure Hash Algorithm 1) produces a fixed-size output of 160 bits (20 bytes). Hash output size matters in cryptography because it influences collision resistance and the effort required for various attacks. For an ideal n-bit hash, finding a collision by generic means is expected around 2
