Well MB-335 Prep | Minimum MB-335 Pass Score
5
Posted at 2/17/2026 07:24:01      View138 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New MB-335 dumps are available on Google Drive shared by TopExamCollection: https://drive.google.com/open?id=1riGv8gGHftOc19x4W1uYYKG2rx185g1r
To help you get to know the exam questions and knowledge of the MB-335 practice exam successfully and smoothly, our experts just pick up the necessary and essential content in to our MB-335 test guide with unequivocal content rather than trivia knowledge that exam do not test at all. To make you understand the content more efficient, our experts add charts, diagrams and examples in to MB-335 Exam Questions to speed up you pace of gaining success. So these MB-335 latest dumps will be a turning point in your life. And on your way to success, they can offer titanic help to make your review more relaxing and effective. Moreover, the passing certificate and all benefits coming along are not surreal dreams anymore.
Microsoft MB-335 exam is a certification exam designed for professionals looking to validate their expertise in the field of supply chain management using Microsoft Dynamics 365. MB-335 exam is specifically designed for functional consultants who specialize in supply chain management and wish to prove their proficiency in implementing and configuring the Dynamics 365 Supply Chain Management application.
The MB-335 exam is a certification exam that evaluates a candidate's expertise in configuring, implementing, and managing supply chain management processes in Dynamics 365 for Finance and Operations. Passing the exam demonstrates the candidate's competency in supply chain management and enables them to advance their careers in this field. MB-335 Exam is highly valued in the industry and is a great way for professionals to demonstrate their expertise in supply chain management.
Minimum MB-335 Pass Score | Valid MB-335 Exam SampleThe TopExamCollection offers three formats for applicants to practice and prepare for the Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert (MB-335) exam as per their needs. The pdf format of TopExamCollection is portable and can be used on laptops, tablets, and smartphones. Print real Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert (MB-335) exam questions in our PDF file. The pdf is user-friendly and accessible on any smart device, allowing applicants to study from anywhere at any time.
Microsoft Dynamics 365 Supply Chain Management Functional Consultant Expert Sample Questions (Q47-Q52):NEW QUESTION # 47
You are using the manufacturing execution module in Dynamics 365 Supply Chain Management. License plate labels must be printed for products in the Report as finished step. You need to use the manufacturing execution functionality that meets this requirement. What should you use?
  • A. Report BOMs as finished
  • B. Job card terminal
  • C. Load planning workbench
  • D. Operations schedules
The manufacturing execution functionality that meets the requirement of printing license plate labels for products in the Report as finished step is License plates. Here is the explanation:
* License plates are unique identifiers that are assigned to containers, pallets, or individual items in inventory. License plates can be used to track and manage inventory throughout the warehouse processes, such as receiving, put away, picking, packing, and shipping1. License plates can also be used in production processes, such as reporting as finished and raw material picking2.
* To print license plate labels for products in the Report as finished step, you must enable the Generate license plate option on the mobile device menu item that is used for reporting as finished2. You must also set up a document routing layout and a document routing for license plate labels3. When you use the mobile device to report a production order as finished, the system will generate a license plate for the finished product and print a license plate label to the specified printer2. The license plate label can include information such as the item number, batch number, quantity, and barcode of the finished product3.
1: License plates 2: Enable license plate label printing 3: Document routing label layouts
NEW QUESTION # 48
You need to configure the requirements for metal fabrication equipment maintenance. What must you configure? To answer, select the appropriate options in the answer area.
NEW QUESTION # 49
A company uses the production control module in Dynamics 365 Supply Chain Management.
Production workers require precise instructions to know which tools and parts to use and how to use them when the workers put things together during the assembly process.
You need to configure the system to initiate mixed reality Dynamics 365 Guides for production workers.
Which four actions should you recommend be performed in sequence? To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.
NEW QUESTION # 50
A manufacturing plant uses Lean processes. You plan to outsource a painting operation to a subcontracting vendor. You create a service item named SP 01 to represent the painting service.
You need to create a subcontracting activity for the painting service.
Solution:
* Create a vendor warehouse for the subcontracting vendor.
* Create a vendor resource and add it to a new work cell for outsource painting.
* Create a production flow transfer activity and specify the vendor warehouse as The target warehouse.
Does the solution meet the goal?
  • A. No
  • B. Yes
The solution does not meet the goal. Here is the explanation:
To create a subcontracting activity for the painting service, you should use the following steps1:
Create a vendor warehouse for the subcontracting vendor. This step is correct, because you need to create a warehouse that is assigned to the vendor account and set it as vendor-managed1. This way, you can track the inventory that is located at the vendor's site.
Create a vendor resource and add it to a new work cell for outsource painting. This step is correct, because you need to create a resource that is assigned to the vendor account and add it to a resource group that represents the subcontracting work cell1. This way, you can assign the subcontracting activity to the vendor resource.
Create a production flow transfer activity and specify the vendor warehouse as the target warehouse. This step is incorrect, because you need to create a production flow process activity, not a transfer activity, for the subcontracting service1. A process activity represents an operation that transforms material into products or semi-finished goods2. A transfer activity represents a movement of material or products from one location to another2. You also need to specify the service item (SP 01) as the product of the process activity, and select the Generate license plate option on the mobile device menu item that is used for reporting as finished1.
NEW QUESTION # 51
A manufacturing company is implementing Dynamics 365 Supply Cham Management.
Bill of materials (BOMs) must be calculated using standard cost principles.
Miscellaneous charges must be included in the unit cost price. The explosion mode must arways be enforced as single level.
You need to configure the system to meet the requirements.
Which configuration should you enable for each requirement? To answer, drag the appropriate configurations to the correct requirements. Each configuration may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
NEW QUESTION # 52
Our company has realized that a really good product is not only reflected on the high quality but also the consideration service, including the pre-sale service and after-sale service. So we not only provide all people with the MB-335 test training materials with high quality, but also we are willing to offer the fine pre-sale and after-sale service system for the customers, these guarantee the customers can get that should have. If you decide to buy the MB-335 learn prep from our company, we are glad to arrange our experts to answer your all questions about the study materials. We believe that you will make the better choice for yourself by our consideration service.
Minimum MB-335 Pass Score: https://www.topexamcollection.com/MB-335-vce-collection.html
BTW, DOWNLOAD part of TopExamCollection MB-335 dumps from Cloud Storage: https://drive.google.com/open?id=1riGv8gGHftOc19x4W1uYYKG2rx185g1r
