New 1Z0-182 Braindumps Free | 1Z0-182 Practice Exams Free
95
Posted at 2/17/2026 07:49:46      View113 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest TestKingFree 1Z0-182 PDF Dumps and 1Z0-182 Exam Engine Free Share: https://drive.google.com/open?id=1onb892WVLyvulIKZRWBdszUmVIUBLvkH
Our 1Z0-182 exam review contains the latest test questions and accurate answers along with the professional explanations. A little attention to prepare 1Z0-182 practice test will improve your skills to clear exam with high passing score. For most busy IT workers, 1Z0-182 Dumps PDF is the best alternative to your time and money to secure the way of success in the IT filed.
About your blurry memorization of the knowledge, our 1Z0-182 learning materials can help them turn to very clear ones. We have been abiding the intention of providing the most convenient services for you all the time on 1Z0-182 study guide, which is also the objection of us. We also have high staff turnover with high morale after-sales staff offer help 24/7. So our customer loyalty derives from advantages of our 1Z0-182 Preparation quiz.
Oracle 1Z0-182 Practice Exams Free | Certificate 1Z0-182 ExamOur 1Z0-182 preparation exam have assembled a team of professional experts incorporating domestic and overseas experts and scholars to research and design related exam bank, committing great efforts to work for our candidates. Most of the experts have been studying in the professional field for many years and have accumulated much experience in our 1Z0-182 Practice Questions. So we can say that our 1Z0-182 exam questions are the first-class in the market. With our 1Z0-182 learning guide, you will get your certification by your first attempt.
Oracle Database 23ai Administration Associate Sample Questions (Q85-Q90):NEW QUESTION # 85
You unplugged a PDB to plug it into another CDB with the following command: SQL> ALTER PLUGGABLE DATABASE pdb1 UNPLUG INTO '/tmp/pdb1.pdb'; Which statement is true prior to plugging the PDB into the other CDB?
  • A. The PDB archive file must be copied to the target CDB.
  • B. The PDB manifest and all the datafiles must be copied to the target CDB.
  • C. The PDB manifest, the data files, and the PDB archive file must be copied to the target CDB.
  • D. PDB archive file and only the user-defined tablespaces must be copied to the target CDB.
D .True. The .pdb file (archive) contains the manifest and data files; all must be copied to the target CDB for plugging.
A-C .False. The archive alone isn't enough; all components are needed.
NEW QUESTION # 86
Which two account management capabilities can be configured using Oracle profiles?
  • A. The ability to prevent a password from ever being reused.
  • B. The maximum amount of CPU time allowed for a user's sessions before their account is locked.
  • C. The number of days for which an account may be logged in to one or more sessions before it is locked.
  • D. The maximum number of sessions permitted for a user before the password must be changed.
  • E. The number of days for which an account may be inactive before it is locked.
Answer: A,E
A .False. Session limits don't tie to password changes.
B .False. CPU limits don't lock accounts.
C .False. No direct "logged-in days" parameter.
D .True. PASSWORD_REUSE_MAX=UNLIMITED prevents reuse.
E .True. PASSWORD_LOCK_TIME sets inactivity lockout.
NEW QUESTION # 87
Which of the following statements is true about external tables?
  • A. They describe how data is stored in the external source.
  • B. They describe data stored in the database.
  • C. They are read/write tables.
  • D. They describe how the external table layer presents data to the server.
A .False. External tables are read-only.
B .True. Defines how external data (e.g., CSV) is mapped to SQL.
C .False. Data is external, not in the DB.
D .False. Storage is external; Oracle doesn't define it.
NEW QUESTION # 88
Which two actions can you perform using DBCA for an existing database?
  • A. Create an additional listener.
  • B. Change the server mode from dedicated to shared, and vice versa.
  • C. Create a template that can be used to clone the database.
  • D. Change the character set.
  • E. Create nonstandard block size tablespaces.
A .False. DBCA can't change character sets post-creation.
B .False. Listeners are managed via NetCA or lsnrctl.
C .True. DBCA can switch server modes for existing DBs.
D .False. Tablespaces are created via SQL, not DBCA for existing DBs.
E .True. DBCA can generate clone templates from existing DBs.
NEW QUESTION # 89
In the SPFILE of a single instance database, LOCAL_LISTENER is set to LISTENER_1. The TNSNAMES.ORA file in $ORACLE_HOME/network/admin in the database home contains: LISTENER_1 = (ADDRESS = (PROTOCOL = TCP)(HOST = host1.abc.com)(PORT = 1521)). Which statement is true?
  • A. Dynamic service registration cannot be used for this database instance.
  • B. LISTENER_1 must also be defined in the LISTENER.ORA file to enable dynamic service registration.
  • C. There are two listeners named LISTENER and LISTENER_1 running simultaneously using port 1521 on the same host as the database in LISTENERS.
  • D. The LREG process registers services dynamically with the LISTENER_1 listener.
  • E. The definition for LISTENER_1 requires a CONNECT_DATA section to enable dynamic service registration.
Dynamic service registration allows a database to automatically register its services with a listener without manual configuration in LISTENER.ORA. Let's analyze each option:
A . The definition for LISTENER_1 requires a CONNECT_DATA section to enable dynamic service registration.
False. The CONNECT_DATA section is part of a client-side TNSNAMES.ORA entry for connecting to a service, not for listener registration. Dynamic registration is handled by the database's LREG (Listener Registration) process, which uses the LOCAL_LISTENER parameter to locate the listener's address (e.g., host1.abc.com:1521). No CONNECT_DATA is needed in the listener address definition itself. This option confuses client connection syntax with listener configuration.
Mechanics:The listener address in TNSNAMES.ORA (LISTENER_1) is sufficient for LREG to find and register with it, as long as the listener is running at that address.
B . LISTENER_1 must also be defined in the LISTENER.ORA file to enable dynamic service registration.
False. Dynamic registration doesn't require the listener to be explicitly defined in LISTENER.ORA. The LOCAL_LISTENER parameter pointing to LISTENER_1 (resolved via TNSNAMES.ORA) tells LREG where to register services. If the listener is running on host1.abc.com:1521, LREG will find it without a LISTENER.ORA entry. However, LISTENER.ORA is needed tostartthe listener process, but that's separate from dynamic registration.
Practical Note:If LISTENER.ORA isn't configured, a default listener might run on port 1521, but the question implies LISTENER_1 is operational.
C . The LREG process registers services dynamically with the LISTENER_1 listener.
True. In Oracle 23ai, the LREG background process (replacing PMON's registration role in earlier versions) dynamically registers database services with listeners specified by LOCAL_LISTENER. Here, LOCAL_LISTENER=LISTENER_1 resolves to host1.abc.com:1521 via TNSNAMES.ORA. LREG periodically sends service information (e.g., service names, instance details) to the listener, enabling clients to connect without static configuration.
MechanicsREG uses the TNS alias (LISTENER_1) to locate the listener's IP and port, registers services like orcl or orclpdb, and updates the listener's service table. This happens automatically every 60 seconds or on significant events (e.g., instance startup).
D . Dynamic service registration cannot be used for this database instance.
False. The setup (LOCAL_LISTENER set and a valid TNSNAMES.ORA entry) explicitly supports dynamic registration. No blockers (e.g., REGISTRATION_EXCLUDED_LISTENERS) are mentioned, so LREG can function normally.
E . There are two listeners named LISTENER and LISTENER_1 running simultaneously using port 1521 on the same host as the database in LISTENERS.
False. The question mentions only LISTENER_1 in the SPFILE and TNSNAMES.ORA. There's no evidence of a second listener (LISTENER) or a LISTENERS configuration (possibly a typo). Two listeners can't share the same port (1521) on the same host due to port conflicts unless explicitly configured with different IPs, which isn't indicated here.
NEW QUESTION # 90
TestKingFree provide you with the most authoritative and the fullest Oracle 1Z0-182 Exam Dumps, thus the hit rate is very high. All questions that may appear in the exam are included in our exam dumps. With the changes of exam outline, we also update our exam dumps at any time. TestKingFree pdf real questions and answers can prevent you from wasting lots of time and efforts on preparing for the exam and can help you sail through you exam with ease and high efficiency. But even you fail the exam, we assure we will give you FULL REFUND. Opportunities always for those who are well prepared and we wish you not to miss the good opportunities.
1Z0-182 Practice Exams Free: https://www.testkingfree.com/Oracle/1Z0-182-practice-exam-dumps.html
To get the Oracle Database 23ai Administration Associate 1Z0-182 practice test, find a reliable source that provides the 1Z0-182 exam dumps to their clients, Our 1Z0-182 study materials are worthy of your trust, It is easy to pass with our 1Z0-182 practice questions as our pass rate of 1Z0-182 exam material is more than 98%, They all have a good command of exam skills to cope with the 1Z0-182 preparation materials efficiently in case you have limited time to prepare for it, because all questions within them are professionally co-related with the 1Z0-182exam.
Another name for list comprehension might be list compaction, Another option 1Z0-182 is to use the same transition for all slides related to a specific topic, but then switch transitions each time you move onto another topic.
Actual 1Z0-182 Oracle Database 23ai Administration Associate Questions 2026To get the Oracle Database 23ai Administration Associate 1Z0-182 Practice Test, find a reliable source that provides the 1Z0-182 exam dumps to their clients, Our 1Z0-182 study materials are worthy of your trust.
Just give it to us and you will succeed easily.
BONUS!!! Download part of TestKingFree 1Z0-182 dumps for free: https://drive.google.com/open?id=1onb892WVLyvulIKZRWBdszUmVIUBLvkH
