JN0-336 Trusted Exam Resource - Real JN0-336 Exam Dumps
Posted at 2/17/2026 11:18:43
View91
Replies0
P.S. Free 2026 Juniper JN0-336 dumps are available on Google Drive shared by BraindumpsVCE: https://drive.google.com/open?id=10u6yE4hd8xD6O7p_Kcub08eDDSXFHrrC
With JN0-336 study tool, you no longer need to look at a drowsy textbook. You do not need to study day and night. With JN0-336 learning dumps, you only need to spend 20-30 hours on studying, and then you can easily pass the exam. At the same time, the language in JN0-336 test question is very simple and easy to understand. Even if you are a newcomer who has just entered the industry, you can learn all the knowledge points without any obstacles. We believe that JN0-336 Study Tool will make you fall in love with learning. Come and buy it now.
We offer you free demo to you to have a try before buying JN0-336 study guide, therefore you can have a better understanding of what you are going to buy. Free demo can be find in our website, if you are quite satisfied with the free demo, just add the JN0-336 study guide to shopping cart, after you buy it, our system will send the downloading link and password to you within ten minutes, and you can start your learning right now. Moreover, we offer you free update for one year after you buy the JN0-336 Exam Dumps, therefore you can get the latest version timely.
New Release Juniper JN0-336 Dumps [2026]Online test version is the best choice for IT person who want to feel the atmosphere of Juniper real exam. And you can practice latest JN0-336 exam questions on any electronic equipment without any limit. Besides, there is no need to install any security software because our JN0-336 Vce File is safe, you just need to click the file and enter into your password.
Juniper Security, Specialist (JNCIS-SEC) Sample Questions (Q73-Q78):NEW QUESTION # 73
How does the SSL proxy detect if encryption is being used?
- A. It looks at the destination port number.
- B. It uses application identity services.
- C. It verifies the length of the packet
- D. It queries the client device.
The SSL proxy can detect if encryption is being used by looking at the destination port number of the packet. If the port number is 443, then the proxy can assume that the packet is being sent over an encrypted connection. If the port number is different, then the proxy can assume that the packet is not encrypted. For more information, please refer to the Juniper Networks JNCIS-SEC Study Guide.
NEW QUESTION # 74
Click the Exhibit button.
You are asked to create a security policy that will automatically add infected hosts to the infected hosts feed and block further communication through the SRX Series device.
What needs to be added to this configuration to complete this task?
- A. Add logging to the permit portion of the security policy.
- B. Add an action to the permit portion of the security policy.
- C. Add a security intelligence policy to the permit portion of the security policy.
- D. Add a match rule to the security policy with an appropriate threat level.
To create a security policy that will automatically add infected hosts to the infected hosts feed and block further communication through the SRX Series device, you need to add a security intelligence policy to the permit portion of the security policy. A security intelligence policy is a policy that allows you to block or monitor traffic from malicious sources based on threat intelligence feeds from Juniper ATP Cloud or other providers. One of the feeds that you can use is the Infected-Hosts feed, which contains IP addresses of hosts that are infected with malware and communicate with command-and-control servers.
You can create a profile and a rule for the Infected-Hosts feed and specify the threat level and the action to take for the infected hosts. Then, you can link the security intelligence policy with the firewall policy and apply it to the traffic that you want to protect. Reference: = Security Intelligence Overview, Configuring Security Intelligence Policy, Configure the Security Intelligence Policy on the SRX Series Device
NEW QUESTION # 75
You need to deploy an SRX Series device in your virtual environment. In this scenario, what are two benefits of using a CSRX? (Choose two.)
- A. The cSRX supports Layer 2 and Layer 3 deployments.
- B. The cSRX has low memory requirements.
- C. The cSRX supports firewall, NAT, IPS, and UTM services.
- D. The cSRX default configuration contains three default zones: trust, untrust, and management.
Two benefits of using a cSRX in your virtual environment are:
The cSRX supports firewall, NAT, IPS, and UTM services: The cSRX is a containerized version of the SRX Series firewall that runs as a Docker container on Linux hosts. It provides the same features and functionality as the SRX Series physical firewalls, such as firewall, NAT, IPS, and UTM services. The cSRX can protect your virtual workloads and applications from various threats and attacks.
The cSRX has low memory requirements: The cSRX is designed to be lightweight and efficient, with low memory and CPU requirements. The cSRX can run on as little as 1 GB of RAM and 1 vCPU, making it suitable for resource-constrained environments. Reference: = cSRX Overview, cSRX Container Firewall Datasheet
NEW QUESTION # 76
Which two statements are true about application identification? (Choose two.)
- A. Application signatures are the same as IDP signatures.
- B. Application identification can identity nested applications that are within Layer 7.
- C. Application identification cannot identify nested applications that are within Layer 7.
- D. Application signatures are not the same as IDP signatures.
Application identification is a feature that enables SRX Series devices to identify and classify network traffic based on application signatures or custom rules. Application identification can enhance security, visibility, and control over network applications.
Two statements that are true about application identification are:
Application identification can identify nested applications that are within Layer 7: Nested applications are applications that run within another application protocol, such as HTTP or SSL. For example, Facebook or YouTube are nested applications within HTTP. Application identification can identify nested applications by inspecting the application payload and matching it against predefined or custom signatures.
Application signatures are not the same as IDP signatures: Application signatures are patterns of bytes or strings that uniquely identify an application protocol or a nested application. IDP signatures are patterns of bytes or strings that indicate an attack or an exploit against a vulnerability. Application signatures are used for application identification and classification, while IDP signatures are used for intrusion detection and prevention.
Reference: = [Application Identification Overview], [Application Identification Concepts], [Understanding Signature Rules and Protocol Anomaly Rules]
NEW QUESTION # 77
Which two statements are correct about security policy changes when using the policy rematch feature? (Choose two.)
- A. When a policy change includes changing the policy's action from permit to deny, all existing sessions are dropped.
- B. When a policy change includes changing the policy's source or destination address match condition, all existing sessions are reevaluated.
- C. When a policy change includes changing the policy's action from permit to deny, all existing sessions are maintained
- D. When a policy change includes changing the policy's source or destination address match condition, all existing sessions are dropped.
policy rematch is a feature that enables the device to reevaluate an active session when its associated security policy is modified. The session remains open if it still matches the policy that allowed the session initially. The session is closed if its associated policy is renamed, deactivated, or deleted1.
NEW QUESTION # 78
Our experts are constantly looking for creative way to immortalize our JN0-336 actual exam in this line. Their masterpieces are instrumental to offer help and improve your performance in the real exam. Being dedicated to these practice materials painstakingly and pooling useful points into our JN0-336 Exam Materials with perfect arrangement and scientific compilation of messages, our JN0-336 practice materials can propel the exam candidates to practice with efficiency.
Real JN0-336 Exam Dumps: https://www.braindumpsvce.com/JN0-336_exam-dumps-torrent.html
If you fail the Real JN0-336 Exam Dumps - Security, Specialist (JNCIS-SEC) exam, we are sure that we will full refund to you after you send us your unqualified score, The online version is only service you can enjoy from our BraindumpsVCE Real JN0-336 Exam Dumps, Juniper JN0-336 Trusted Exam Resource As we all know, looking at things on a computer for a long time can make your eyes wear out and even lead to the decline of vision, The software test engine of Juniper JN0-336 is very practical.
As these developers gain experience in the technology, they can JN0-336 Vce Exam then move on to become the design leads and mentors for other developers, as new projects with the technology are started.
Part of the The Pearson Service Technology Series from Thomas Erl Real JN0-336 Exam Dumps series, If you fail the Security, Specialist (JNCIS-SEC) exam, we are sure that we will full refund to you after you send us your unqualified score.
Free PDF Quiz 2026 Juniper JN0-336: Security, Specialist (JNCIS-SEC) C Professional Trusted Exam ResourceThe online version is only service you can enjoy from our BraindumpsVCE, JN0-336 As we all know, looking at things on a computer for a long time can make your eyes wear out and even lead to the decline of vision.
The software test engine of Juniper JN0-336 is very practical, If you are using our products for the preparation of Security, Specialist (JNCIS-SEC) exam, then we offer 90 days free updates on all of our products.
- Dumps JN0-336 Cost 🕞 Dumps JN0-336 Cost 🐭 Braindump JN0-336 Pdf 👍 Search for JN0-336 and download it for free immediately on ➠ [url]www.prepawayexam.com 🠰 🕦Instant JN0-336 Discount[/url]
- Hot JN0-336 Trusted Exam Resource Pass Certify | Professional Real JN0-336 Exam Dumps: Security, Specialist (JNCIS-SEC) 🏯 The page for free download of JN0-336 on [ [url]www.pdfvce.com ] will open immediately 🔰Certification JN0-336 Dump[/url]
- JN0-336 Braindumps ☕ JN0-336 PDF VCE 🏅 Braindump JN0-336 Pdf 🦱 Download [ JN0-336 ] for free by simply searching on [url]www.validtorrent.com ☣JN0-336 Sample Questions[/url]
- Braindump JN0-336 Pdf 📞 Dump JN0-336 Check 🥾 JN0-336 Braindumps 🚘 Download ➽ JN0-336 🢪 for free by simply entering ▷ [url]www.pdfvce.com ◁ website ⤴JN0-336 Pass4sure Dumps Pdf[/url]
- JN0-336 PDF VCE 🙅 JN0-336 Pass4sure Dumps Pdf 🚦 Valid JN0-336 Exam Test 🥨 Immediately open ☀ [url]www.examcollectionpass.com ️☀️ and search for [ JN0-336 ] to obtain a free download 🚓Valid Exam JN0-336 Braindumps[/url]
- Hot JN0-336 Trusted Exam Resource Pass Certify | Professional Real JN0-336 Exam Dumps: Security, Specialist (JNCIS-SEC) 🎢 Open website [url]www.pdfvce.com and search for ➡ JN0-336 ️⬅️ for free download 🎩Instant JN0-336 Discount[/url]
- Exam JN0-336 Sample 🔸 JN0-336 Certification Materials ⤴ Latest Study JN0-336 Questions 🍲 Easily obtain JN0-336 for free download through [url]www.prepawaypdf.com 🐺Dump JN0-336 Check[/url]
- Pass Guaranteed JN0-336 - Security, Specialist (JNCIS-SEC) Latest Trusted Exam Resource ⚓ Download ➠ JN0-336 🠰 for free by simply searching on [url]www.pdfvce.com ✉JN0-336 Braindumps[/url]
- 100% Pass Juniper - JN0-336 CValid Trusted Exam Resource 🍝 Search for JN0-336 and download it for free on ▛ [url]www.prep4away.com ▟ website 📷Instant JN0-336 Discount[/url]
- Exam JN0-336 Sample 🎇 JN0-336 Braindumps 🦋 Instant JN0-336 Discount 👳 Search for JN0-336 and easily obtain a free download on [url]www.pdfvce.com 👌JN0-336 Pass4sure Dumps Pdf[/url]
- 100% Pass Juniper - JN0-336 CValid Trusted Exam Resource 🛌 Copy URL [url]www.testkingpass.com open and search for ➽ JN0-336 🢪 to download for free 🦺Examcollection JN0-336 Questions Answers[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.lms.khinfinite.in, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, ilmacademyedu.com, tinnitusheal.com, Disposable vapes
BONUS!!! Download part of BraindumpsVCE JN0-336 dumps for free: https://drive.google.com/open?id=10u6yE4hd8xD6O7p_Kcub08eDDSXFHrrC
