[Hardware] CPMAIY㏊ & CPMAIӢZ
81
Hardware CPMAIY㏊ & CPMAIӢZ
Posted at 2/17/2026 11:22:15      View122 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS PassTest CPMAIפһoϤǥ`ɣhttps://drive.google.com/open?id=19MtEG4oHwH3_px9MR_mIFNkbwRcQ2w-H
PassTestϡЄ|θߤCPMAIѧɤ^ޤσ줿ѧɤϤޤ 100_g˺ϸ񤷤ƜΤYäˤϡCPMAIȥ`˥pdfmФѧե󥹤ˤʤޤoϤǥ`ɤǤoϥǥ⤫顢|ЄԤCPMAIgHΥƥȤʽ_JǤޤˡCPMAIԇYYϤ΁ϡ٤ƤˤˤȤäƺĤ핤ʁǤ CPMAIȥ`˥󥰤|ُ뤷Ƥ
ڥꥹȤϡCPMAIΌgHԇYݤո¤뤫ɤ_Jޤ¤Щ`󤬤Ϥϡ``¤Υ꥽`äǤ褦ˡ餬rgڤ˥``ŤޤΤ褦ˤơCPMAIYϤϡ``Υ˩`򿼑]줿dz˸٤ʸ¥`Ȥ֤ĤȤǤޤ CPMAIѧYʹä``ϡ¤꥽`ȽӴΥ`פǤҪޤ CPMAI}¥ޥ`ܤȡä顢rgڤ˥Щ`¤ǤҪʥå`ҊӤȤϤޤ
CPMAIӢZ桢CPMAIPMICPMAIJԇYܤCPMAIJ^YȡäǤPassTestϤʤγɹ^뤳ȤǤޤԇYΜʂ򤹤ȤԇYvB֪Rѧ֤ΤϱҪǤʤФʤΤϡԷ֤ꤷʵĤʥĩ`xk뤳ȤǤPassTestCPMAI}Ϥʤ˺ϤƤ㏊ǤθƷ|Ά}ŤʤۤɤνYҊ뤳ȤǤޤԷ֤ԇY˺ϸǤʤ䤬СϤ䤯PassTestΥ֥Ȥ򥯥åƤäȶयiǤ
PMI Cognitive Project Management in AI (PMI-CPMAI) J CPMAI ԇY} (Q53-Q58):| # 53
Your company is insisting on running an automation project and applying AI best practices and methodologies to the project. You understand that automating things is just the act of using machines to repeat tasks, and does not require AI to achieve results. You think it is overkill but the project moves forward as planned.
What would likely have helped avoid this conflict?
  • A. Senior management should become involved in the project.
  • B. Applying a hybrid approach of automation and AI best practices would have achieved better results.
  • C. Nothing - running automation projects like autonomous projects is the correct thing to do.
  • D. Everyone on the team should understand the differences between automation and autonomous systems.
⣺D
| # 54
Use cognitive technologies/AI when you can't code the rules or you can't scale easily with people or automation. As a good rule of thumb when deciding if AI is right for the project you should:
  • A. See if simple rules work. If yes, then pick the right AI solution to solve the problem.
  • B. Decide if it's a statistics pattern. If it's statistical then go with the AI project.
  • C. Decide if it's probabilistic or deterministic patterns. If it's deterministic then go with the AI project.
  • D. Decide if it's probabilistic or deterministic patterns. If it's probabilistic then go with the AI project.
⣺C
| # 55
You are leading a project to develop a new predictive maintenance solution. Together with your project team you determine your data needs, see if you have access to the data, and then begin working on the project.
Which phase best describes the work you are performing?
  • A. Phase IV
  • B. Phase V
  • C. Phase VI
  • D. Phase II
  • E. Phase I
  • F. Phase III
⣺D
| # 56
As the project manager, you are leading a brainstorming session with key stakeholders around a new Hyperpersonalization project. What's a key feature for this project that should happen to ensure success?
  • A. Develop a unique profile of each individual, and have that profile learn and adapt over time for a wide variety of purposes
  • B. Develop a unique profile of each individual, and manually update that profile over time for a wide variety of purposes
  • C. Develop a unique profile of each type of individual, and have that profile stay the same over the lifetime of that user
  • D. Develop a unique profile of each individual, and having that profile both learn and adapt over time as well as be programmed for a wide variety of purposes
⣺A
| # 57
During CPMAI Phase II, it's important to not only understand the sources of your data but also what data is required for training as well as identifying the features that are required.
When looking to gather data, what approach is best when determining how much data you need?
  • A. The "Goldilocks" approach
  • B. The "more is better" approach
  • C. The "less is better" approach
  • D. There is no correct approach
⣺A
| # 58
CPMAIѧ̲Ĥϡ٤ƤˡѧʤϤΤ˷dzޤ٤ƤʵĤФȡץ`󤬺gˤʤޤ CPMAIԇYΜʂM䤹rg̿sϡCPMAIԇY˺ϸ񤷤ƶ̕rgJYȡäϤϡCPMAIѧ̲mxkȤʤޤʤΉ CPMAIԇY|20〜30rgѧǡŤ֤äCPMAIԇY˺ϸ񤹤뤳ȤǤޤ
CPMAIӢZ: https://www.passtest.jp/PMI/CPMAI-shiken.html
ҡȫĤCPMAI}CPMAI}ITIǡ֥ɤˤʤäƤޤPMI CPMAIY㏊ ͤΆϤ碌Ѹ٤˷ŤǤ褦ҤTϣrgnjꤷƤޤPMI CPMAIY㏊ ФʤΤϤʤɤʷʹȤȤǤPMI CPMAIY㏊ 񤹤ϼš˾ͤȡˤ~ˤʤޤPMI CPMAIY㏊ 줬⤦FβǷһȤʤޤCPMAI Cognitive Project Management in AI (PMI-CPMAI)ȥ`˥YϤϤηҰǃuƷǤ
˥`ФⱣФˤʤ뤷SM򿼤Ɨ뤳Ȥˤʤޤ ʤۤ ˽ϴCPMAIϤ碌ΤǑޤˤ⤫餺˩`ՓĤΤ줫ͬˡۤȤɤˤϡܤՓζǤhõζǤ⡢줬ʤΥ٥_ȤϿƤޤ
PMICPMAIJԇY¤ʆ}ҡȫĤCPMAI}CPMAI}ITIǡ֥ɤˤʤäƤޤͤΆϤ碌Ѹ٤˷ŤǤ褦ҤTϣrgnjꤷƤޤФʤΤϤʤɤʷʹȤȤǤ
񤹤ϼš˾ͤȡˤ~ˤʤޤ
ˡPassTest CPMAIפһFڟoϤṩƤޤhttps://drive.google.com/open?id=19MtEG4oHwH3_px9MR_mIFNkbwRcQ2w-H
