[General] MB-820問題例 & MB-820難易度受験料
98
【General】 MB-820問題例 & MB-820難易度受験料
Posted at 2/17/2026 14:14:49      View:195 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. GoShikenがGoogle Driveで共有している無料かつ新しいMB-820ダンプ:https://drive.google.com/open?id=1ox_EagoWz01ozwy-nj2nXebOtHLX_FeX
MicrosoftのMB-820認定試験に合格するためにたくさん方法があって、非常に少ないの時間とお金を使いのは最高で、GoShikenが対応性の訓練が提供いたします。
Microsoft MB-820 認定試験の出題範囲:
トピック出題範囲
トピック 1
  • Integrate Business Central with other applications: Accessing Representational State Transfer (REST) services is discussed in this topic.  It also explains implementation of APIs.
トピック 2
  • Describe Business Central: Describing the components and capabilities of Business Central, and describing the core solution and extensions approach for Business Central are focal points of this topic. It also explains the difference between Business Central Online and Business Central on-premises features.
トピック 3
  • Develop by using AL objects: Building and extending tables and reports is discussed in this topic. It also explains Designing and creating an XMLport. Lastly, it discusses how to work with entitlement and permission set objects.
トピック 4
  • Develop by using AL: How to Customize the UI experience and Use AL for business central extension is discussed here. It also delves into explaining the essential development standards.
トピック 5
  • Install, develop, and deploy for Business Central: It delves into the installation and configuration of a Business Central development environment. Moreover, it discusses creating, debugging, and deploying an extension in Business Central.
Microsoft MB-820難易度受験料 & MB-820試験弊社のMB-820問題集は三種類の版を提供いたします。PDF版、ソフト版とオンライン版があります。PDF版のMB-820日本語問題集は印刷されることができ、ソフト版のMB-820日本語問題集はいくつかのパソコンでも使われることもでき、オンライン版の問題集はパソコンでもスマホでも直接に使われることができます。お客様は自分の愛用する版が選べます。
Microsoft Dynamics 365 Business Central Developer 認定 MB-820 試験問題 (Q113-Q118):質問 # 113
You need to develop the report Subcontract Documents Excel List that is required by the control department.
You have the following code:
正解:
質問 # 114
A company owns and operates hotels, restaurants, and stores.
When the staff orders materials from the purchasing department, the requests are not directed to the correct approvers.
The staff requires a new field named Approver from which they can select the appropriate approver. The field must include the following options:
* Hotel manager
* Restaurant manager
* Store manager
* Purchasing manager
You need to create the Approver field in the Item table by using an AL extension.
正解:
1 - Create an enum object named Approver and include all options.
2 - Create a table extension object for an Item table with an Approver field of enum type named Approver in the fields section.
3 - Create a page extension object that extends the Item Card object. Add the field to the fields section.
質問 # 115
* Hotel manager
* Store manager
正解:
3 - Item Card object. Add the field to the fields section.
質問 # 116
You need to parse the API JSON response and retrieve each order no. in the response body.
How should you complete the code segment? To answer select the appropriate options in the answer area.
正解:
質問 # 117
You are creating a new Business Central report.
You plan to use triggers and functions to dynamically create a dataset and control the report behavior.
You must provide the following implementation.
* Run when the report is loaded.
* Run when the data item is iterated for the last time.
* Skip the rest of the report.
You need to select the triggers and functions for the report.
Which triggers and functions should you use? To answer, select the appropriate options in the answer area.
正解:
質問 # 118
MicrosoftのMB-820試験の合格書は君の仕事の上で更に一歩の昇進と生活条件の向上を助けられて、大きな財産に相当します。MicrosoftのMB-820認定試験はIT専門知識のレベルの考察として、とっても重要な地位になりつつます。GoShikenは最も正確なMicrosoftのMB-820試験資料を追求しています。
MB-820難易度受験料: https://www.goshiken.com/Microsoft/MB-820-mondaishu.html
BONUS!!! GoShiken MB-820ダンプの一部を無料でダウンロード:https://drive.google.com/open?id=1ox_EagoWz01ozwy-nj2nXebOtHLX_FeX
Posted at 4/19/2026 16:40:07        Only Author  2#
The article is easy to understand, and I have benefited a lot from it. Free NSE7_SOC_AR-7.6 reliable dumps sheet materials available for all—good luck!
