[General] New Launch Salesforce PDII Exam Questions Are Out: Download And Prepare [2026]
142
【General】 New Launch Salesforce PDII Exam Questions Are Out: Download And Prepare [2026]
Posted at 2/17/2026 17:11:16      View:88 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Prep4sureExam PDII PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1FvP025i9GN9a_NtTxhEhpp-k9H4uIPlY
Salesforce PDII can ensure your success. So here comes Salesforce, who provides you with the Salesforce PDII exam dumps to get your dream Salesforce PDII certification with no hassle. Salesforce PDII Certification will add up to your excellence in your field and leave no space for any doubts in the mind of the hiring team.
You must believe that you have extraordinary ability to work and have an international certificate to prove your inner strength. You will definitely be the best one among your colleagues. The help you provide with our PDII Learning Materials is definitely what you really need. And if you study with our PDII exam braindumps, you will know your dream clearly. Join PDII study guide and you will be the best person!
Salesforce PDII Dumps PDF To Gain Brilliant ResultThere is no doubt that among our three different versions of PDII guide torrent, the most prevalent one is PDF version, and this is particularly suitable and welcomed by youngsters. There are some features of this version: first of all, PDF version of our PDII prep guide can be printed into paper, though which you are able to do some note-writing and highlight the important exam points. Besides our PDII Exam Torrent support free demo download, as we mentioned before, it is an ideal way for you to be fully aware of our PDII prep guide and then purchasing them if suitable and satisfactory.
Salesforce Platform Developer II Sample Questions (Q46-Q51):NEW QUESTION # 46
An integration user makes a successful login() call via the SOAP API.
What can be used in the SOAP header to provide server authorization for subsequent API requests?
  • A. OAuth access token
  • B. Security token
  • C. Session ID
  • D. Named Credentials
NEW QUESTION # 47
A developer has written an After Update trigger on Account. A workflow rule and field update cause the trigger to repeatedly update the Account records.
How should the developer handle the recursive trigger?
  • A. Deactivate the trigger and move the logic into a Process or Flow
  • B. Use a global variable to prevent the trigger from executing more than once
  • C. Use a static variable to prevent the trigger from executing more than once
  • D. Deactivate the workflow rule to prevent the field update from executing
NEW QUESTION # 48
A developer created and tested a Visualforce page in their developer sandbox, but now receives reports that user encounter view state errors when using it in production.
What should the developer ensure to correct these errors?
  • A. Ensure queries do net exceed governor limits,
  • B. Ensure profiles have access to the Visualforce page.
  • C. Ensure properties are marked as private,
  • D. Ensure variables are marked as transient.
The developer should ensure variables are marked as transient to correct the view state errors. The transient keyword is used to mark a variable as transient, which means that the variable is not part of the view state, and it is not persisted or transferred between the server and the client. The developer should use the transient keyword for variables that are used for temporary storage or calculations, and that do not need to be retained across postbacks. This way, the developer can reduce the size of the view state, and avoid exceeding the view state limit. Ensuring queries do not exceed governor limits will not help, as it will only avoid hitting the SOQL query limit, but it will not reduce the size of the view state. Ensuring properties are marked as private will not help, as it will only limit the access to the properties, but it will not reduce the size of the view state. Ensuring profiles have access to the Visualforce page will not help, as it will only grant the permissions to view the page, but it will not reduce the size of the view state. Reference: [transient Keyword], [Visualforce View State], [Visualforce Developer Guide]
NEW QUESTION # 49
What is the transaction limit on the number of "sendEmail" method calls?
  • A. 0
  • B. 1
  • C. 2
  • D. There is no limit
  • E. 3
Explanation/Reference:
The reserveEmailCapacity methods let you declare how many emails you want to send prior to actually sending, allowing you to handle limit errors prematurely
NEW QUESTION # 50
A developer wrote an Apex class to make several callouts to an external system.
If the URLs used in these callouts will change often, which feature should the developer use to minimize changes needed to the Apex class?
  • A. Connected Apps
  • B. Remote Site Settings
  • C. Session Id
The correct feature to use is C, Named Credentials. Named Credentials are a secure way of storing the endpoint and authentication details for callouts to external services. When URLs change frequently, using Named Credentials allows you to manage the endpoint URL in one place without changing the Apex code.
Named Credentials
NEW QUESTION # 51
As we all know, respect and power is gained through knowledge or skill. The society will never welcome lazy people. Do not satisfy what you have owned. Challenge some fresh and meaningful things, and when you complete PDII Exam, you will find you have reached a broader place where you have never reach. Your life will become more meaningful because of your new change, and our PDII question torrents will be your first step.
Exam PDII Course: https://www.prep4sureexam.com/PDII-dumps-torrent.html
I wonder if you noticed that there are three versions of our PDII test questions—PDF, software on pc, and app online, which can bring you the greatest convenience, Salesforce Latest PDII Exam Book We would not sell rather than sell old versions, Salesforce Latest PDII Exam Book You can take full use of your spare time with and have a good preparation, However, if you do not pass the Platform Developer II exam even after properly using the Platform Developer II PDII pdf questions and practice tests Prep4sureExam also gives a money-back guarantee.
Share images through email, iCloud, Shutterfly, Flickr, PDII OneDrive, Google Drive, or Dropbox, The Art of Computer Programming: Introduction to Algorithms, I wonder if you noticed that there are three versions of our PDII Test Questions—PDF, software on pc, and app online, which can bring you the greatest convenience.
PDII Practice Torrent: Platform Developer II - PDII Pass-King Materials & PDII Exam PracticeWe would not sell rather than sell old versions, You PDII Pass Guarantee can take full use of your spare time with and have a good preparation, However, if you do not pass the Platform Developer II exam even after properly using the Platform Developer II PDII pdf questions and practice tests Prep4sureExam also gives a money-back guarantee.
It is a package of Salesforce Certification PDII braindumps that is prepared by the proficient Salesforce Developers experts.
What's more, part of that Prep4sureExam PDII dumps now are free: https://drive.google.com/open?id=1FvP025i9GN9a_NtTxhEhpp-k9H4uIPlY
