[General] Three User-Friendly Formats of PracticeMaterial Palo Alto Networks XDR-Analyst U
107
【General】 Three User-Friendly Formats of PracticeMaterial Palo Alto Networks XDR-Analyst U
Posted at 2/17/2026 18:06:32      View:125 | Replies:0        Print      Only Author   [Copy Link] 1#
Based on high-quality products, our XDR-Analyst guide torrent has high quality to guarantee your test pass rate, which can achieve 98% to 100%. XDR-Analyst study tool is updated online by our experienced experts, and then sent to the user. And we provide free updates of XDR-Analyst training material for one year after your payment. The data of our XDR-Analyst Exam Torrent is forward-looking and can grasp hot topics to help users master the latest knowledge. And you can also free download the demo of XDR-Analyst exam questions to have a check.
Based on high-quality products, our XDR-Analyst guide torrent has high quality to guarantee your test pass rate, which can achieve 98% to 100%. XDR-Analyst study tool is updated online by our experienced experts, and then sent to the user. So you don’t need to pay extra attention on the updating of study materials. The data of our XDR-Analyst Exam Torrent is forward-looking and can grasp hot topics to help users master the latest knowledge. If you are not reconciled and want to re-challenge yourself again, we will give you certain discount.
Valid Palo Alto Networks XDR-Analyst Practice Materials | Exam XDR-Analyst QuizzesUp to now we classify our XDR-Analyst exam questions as three different versions. They are pdf, software and the most convenient one APP online. Though the content of these three versions is the same, but their displays are different. Each of them has their respective feature and advantage including new information that you need to know to pass the XDR-Analyst test. So you can choose the version of XDR-Analyst training quiz according to your personal preference.
Palo Alto Networks XDR Analyst Sample Questions (Q78-Q83):NEW QUESTION # 78
If you have an isolated network that is prevented from connecting to the Cortex Data Lake, which type of Broker VM setup can you use to facilitate the communication?
  • A. Broker VM Pathfinder
  • B. Broker VM Syslog Collector
  • C. Local Agent Installer and Content Caching
  • D. Local Agent Proxy
If you have an isolated network that is prevented from connecting to the Cortex Data Lake, you can use the Local Agent Proxy setup to facilitate the communication. The Local Agent Proxy is a type of Broker VM that acts as a proxy server for the Cortex XDR agents that are deployed on the isolated network. The Local Agent Proxy enables the Cortex XDR agents to communicate securely with the Cortex Data Lake and the Cortex XDR management console over the internet, without requiring direct access to the internet from the isolated network. The Local Agent Proxy also allows the Cortex XDR agents to download installation packages and content updates from the Cortex XDR management console. To use the Local Agent Proxy setup, you need to deploy a Broker VM on the isolated network and configure it as a Local Agent Proxy. You also need to deploy another Broker VM on a network that has internet access and configure it as a Remote Agent Proxy. The Remote Agent Proxy acts as a relay between the Local Agent Proxy and the Cortex Data Lake. You also need to install a strong cipher SHA256-based SSL certificate on both the Local Agent Proxy and the Remote Agent Proxy to ensure secure communication. You can read more about the Local Agent Proxy setup and how to configure it here1 and here2. Reference:
Local Agent Proxy
Configure the Local Agent Proxy Setup
NEW QUESTION # 79
Which statement regarding scripts in Cortex XDR is true?
  • A. Any script can be imported including Visual Basic (VB) scripts.
  • B. The level of risk is assigned to the script upon import.
  • C. Any version of Python script can be run.
  • D. The script is run on the machine uploading the script to ensure that it is operational.
The correct answer is B, the level of risk is assigned to the script upon import. When you import a script to the Agent Script Library in Cortex XDR, you need to specify the level of risk associated with the script. The level of risk determines the permissions and restrictions for running the script on endpoints. The levels of risk are:
Low: The script can be run on any endpoint without requiring approval from the Cortex XDR administrator. The script can also be used in remediation suggestions or automation actions.
Medium: The script can be run on any endpoint, but requires approval from the Cortex XDR administrator. The script can also be used in remediation suggestions or automation actions.
High: The script can only be run on isolated endpoints, and requires approval from the Cortex XDR administrator. The script cannot be used in remediation suggestions or automation actions.
The other options are incorrect for the following reasons:
A is incorrect because not any version of Python script can be run in Cortex XDR. The scripts must be written in Python 2.7, and must follow the guidelines and limitations described in the Cortex XDR documentation. For example, the scripts must not exceed 64 KB in size, must not use external libraries or modules, and must not contain malicious or harmful code.
C is incorrect because not any script can be imported to Cortex XDR, including Visual Basic (VB) scripts. The scripts must be written in Python 2.7, and must follow the guidelines and limitations described in the Cortex XDR documentation. VB scripts are not supported by Cortex XDR, and will not run on the endpoints.
D is incorrect because the script is not run on the machine uploading the script to ensure that it is operational. The script is only validated for syntax errors and size limitations when it is imported to the Agent Script Library. The script is not executed or tested on the machine uploading the script, and the script may still fail or cause errors when it is run on the endpoints.
Import a Script
Run Scripts on an Endpoint
NEW QUESTION # 80
As a Malware Analyst working with Cortex XDR you notice an alert suggesting that there was a prevented attempt to download Cobalt Strike on one of your servers. Days later, you learn about a massive ongoing supply chain attack. Using Cortex XDR you recognize that your server was compromised by the attack and that Cortex XDR prevented it. What steps can you take to ensure that the same protection is extended to all your servers?
  • A. Create IOCs of the malicious files you have found to prevent their execution.
  • B. Enable Behavioral Threat Protection (BTP) with cytool to prevent the attack from spreading.
  • C. Enable DLL Protection on all servers but there might be some false positives.
  • D. Create Behavioral Threat Protection (BTP) rules to recognize and prevent the activity.
To ensure that the same protection is extended to all your servers, you need to create Behavioral Threat Protection (BTP) rules to recognize and prevent the activity. BTP is a feature of Cortex XDR that allows you to create custom rules that detect and block malicious or suspicious behaviors on your endpoints, such as file execution, process injection, network connection, or registry modification. BTP rules can use various operators, functions, and variables to define the criteria and the actions for the rules. By creating BTP rules that match the behaviors of the supply chain attack, you can prevent the attack from compromising your servers12.
Let's briefly discuss the other options to provide a comprehensive explanation:
B . Enable DLL Protection on all servers but there might be some false positives: This is not the correct answer. Enabling DLL Protection on all servers will not ensure that the same protection is extended to all your servers. DLL Protection is a feature of Cortex XDR that allows you to block the execution of unsigned or untrusted DLL files on your endpoints. DLL Protection can help to prevent some types of attacks that use malicious DLL files, but it may not be effective against the supply chain attack that used a Trojanized DLL file that was digitally signed by a trusted vendor. DLL Protection may also cause some false positives, as it may block some legitimate DLL files that are unsigned or untrusted3.
C . Create IOCs of the malicious files you have found to prevent their execution: This is not the correct answer. Creating IOCs of the malicious files you have found will not ensure that the same protection is extended to all your servers. IOCs are indicators of compromise that you can create to detect and respond to known threats on your endpoints, such as file hashes, registry keys, IP addresses, domain names, or full paths. IOCs can help to identify and block the malicious files that you have already discovered, but they may not be effective against the supply chain attack that used different variants of the malicious files with different hashes or names. IOCs may also become outdated, as the attackers may change or update their files to evade detection4.
D . Enable Behavioral Threat Protection (BTP) with cytool to prevent the attack from spreading: This is not the correct answer. Enabling BTP with cytool will not ensure that the same protection is extended to all your servers. BTP is a feature of Cortex XDR that allows you to create custom rules that detect and block malicious or suspicious behaviors on your endpoints, such as file execution, process injection, network connection, or registry modification. BTP rules can help to prevent the attack from spreading, but they need to be created and configured in the Cortex XDR app, not with cytool. Cytool is a command-line tool that allows you to perform various operations on the Cortex XDR agent, such as installing, uninstalling, upgrading, or troubleshooting. Cytool does not have an option to enable or configure BTP rules.
In conclusion, to ensure that the same protection is extended to all your servers, you need to create BTP rules to recognize and prevent the activity. By using BTP rules, you can create custom and flexible prevention rules that match the behaviors of the supply chain attack.
Create a BTP Rule
DLL Protection
Create an IOC Rule
[Cytool]
NEW QUESTION # 81
Which search methods is supported by File Search and Destroy?
  • A. File Search and Repair
  • B. File Seek and Repair
  • C. File Search and Destroy
  • D. File Seek and Destroy
File Search and Destroy is a feature of Cortex XDR that allows you to search for and remove malicious files from endpoints. You can use this feature to find files by their hash, full path, or partial path using regex parameters. You can then select the files from the search results and destroy them by hash or by path. When you destroy a file by hash, all the file instances on the endpoint are removed. File Search and Destroy is useful for quickly responding to threats and preventing further damage. Reference:
Search and Destroy Malicious Files
Cortex XDR Pro Administrator Guide
NEW QUESTION # 82
Phishing belongs to which of the following MITRE ATT&CK tactics?
  • A. Persistence, Command and Control
  • B. Reconnaissance, Persistence
  • C. Reconnaissance, Initial Access
  • D. Initial Access, Persistence
Phishing is a technique that belongs to two MITRE ATT&CK tactics: Reconnaissance and Initial Access. Reconnaissance is the process of gathering information about a target before launching an attack. Phishing for information is a sub-technique of Reconnaissance that involves sending phishing messages to elicit sensitive information that can be used during targeting. Initial Access is the process of gaining a foothold in a network or system. Phishing is a sub-technique of Initial Access that involves sending phishing messages to execute malicious code on victim systems. Phishing can be used for both Reconnaissance and Initial Access depending on the objective and content of the phishing message. Reference:
Phishing, Technique T1566 - Enterprise | MITRE ATT&CK 1
Phishing for Information, Technique T1598 - Enterprise | MITRE ATT&CK 2 Phishing for information, Part 2: Tactics and techniques 3 PHISHING AND THE MITREATT&CK FRAMEWORK - EnterpriseTalk 4 Initial Access, Tactic TA0001 - Enterprise | MITRE ATT&CK 5
NEW QUESTION # 83
Our XDR-Analyst exam questions have three versions: the PDF, Software and APP online. Also, there will have no extra restrictions to your learning because different versions have different merits. All in all, you will not be forced to buy all versions of our XDR-Analyst Study Materials. You have the final right to select. Please consider our XDR-Analyst learning quiz carefully and you will get a beautiful future with its help.
Valid XDR-Analyst Practice Materials: https://www.practicematerial.com/XDR-Analyst-exam-materials.html
Palo Alto Networks Valid XDR-Analyst Test Voucher Some candidates reflect our dumps torrent is even totally same with their real test, Enroll in our XDR-Analyst APP to access over 1,600 XDR-Analyst questions and answers, Palo Alto Networks Valid XDR-Analyst Test Voucher With the international standard certification means a wider range of choices for you, It's especially for people who want and need to pass the XDR-Analyst exam in a short time with short-term study on it.
Our XDR-Analyst practice materials made them enlightened and motivated to pass the exam within one week, which is true that someone did it always, The research valley of death" is defined as the time in the life of a technology between early stage prototyping XDR-Analyst in the research lab and readiness for the kind of capital injection offered at later stages by venture capitalists.
Free PDF 2026 Palo Alto Networks XDR-Analyst: Latest Valid Palo Alto Networks XDR Analyst Test VoucherSome candidates reflect our dumps torrent is even totally same with their real test, Enroll in our XDR-Analyst APP to access over 1,600 XDR-Analyst questions and answers.
Our company offers free demo of XDR-Analyst exam dumps for you to have a try.
