[General] SAP-C02 PDF Download | Online SAP-C02 Tests
94
General SAP-C02 PDF Download | Online SAP-C02 Tests
Posted at 2/17/2026 18:47:48      View123 | Replies0        Print      Only Author   [Copy Link] 1#
What's more, part of that Test4Cram SAP-C02 dumps now are free: https://drive.google.com/open?id=1pf6CwBiwOtUsyjO3p1gGJTnCdexgcnCM
Our SAP-C02 cram materials will help you gain the success in your career. You can be respected and enjoy the great fame among the industry. When applying for the jobs your resumes will be browsed for many times and paid high attention to. The odds to succeed in the job interview will increase. So you could see the detailed information of our SAP-C02 Exam Questions before you decide to buy them.
The SAP-C02 exam consists of multiple-choice and multiple-response questions and lasts for 180 minutes. Candidates must achieve a passing score of 750 out of 1000 to earn their certification. SAP-C02 exam can be taken at a testing center or online through a proctored exam. Earning the SAP-C02 Certification demonstrates a high level of expertise in AWS architecture and design and can open up new career opportunities in the rapidly growing field of cloud computing.
Excel in Your SAP-C02 Exam with Test4Cram: The Quick Solution for SuccessUp to now we classify our SAP-C02 exam questions as three different versions. They are pdf, software and the most convenient one APP online. Though the content of these three versions is the same, but their displays are different. Each of them has their respective feature and advantage including new information that you need to know to pass the SAP-C02 test. So you can choose the version of SAP-C02 training quiz according to your personal preference.
The SAP-C02 exam covers a broad range of topics related to AWS architecture, including designing and deploying complex applications, designing and deploying enterprise-scale operations, and designing and deploying hybrid IT architectures. SAP-C02 Exam also covers topics related to security, cost optimization, and performance optimization, among others. SAP-C02 exam consists of multiple-choice and multiple-response questions, and candidates have 180 minutes to complete it.
Amazon AWS Certified Solutions Architect - Professional (SAP-C02) Sample Questions (Q202-Q207):NEW QUESTION # 202
A solutions architect must implement a multi-Region architecture for an Amazon RDS for PostgreSQL database that supports a web application. The database launches from an AWS CloudFormation template that includes AWS services and features that are present in both the primary and secondary Regions.
The database is configured for automated backups, and it has an RTO of 15 minutes and an RPO of 2 hours. The web application is configured to use an Amazon Route 53 record to route traffic to the database.
Which combination of steps will result in a highly available architecture that meets all the requirements? (Choose two.)
  • A. Create an AWS Lambda function to copy the latest automated backup to the secondary Region every 2 hours.
  • B. In the primary Region, create a health check on the database that will invoke an AWS Lambda function when a failure is detected. Program the Lambda function to recreate the database from the latest database snapshot in the secondary Region and update the Route 53 host records for the database.
  • C. Create a hot standby database in the secondary Region. Use an AWS Lambda function to restore the secondary database to the latest RDS automatic backup in the event that the primary database fails.
  • D. Create a failover routing policy in Route 53 for the database DNS record. Set the primary and secondary endpoints to the endpoints in each Region.
  • E. Create a cross-Region read replica of the database in the secondary Region. Configure an AWS Lambda function in the secondary Region to promote the read replica during a failover event.
Answer: D,E
NEW QUESTION # 203
A company is storing data on premises on a Windows file server. The company produces 5 GB of new data daily.
The company migrated part of its Windows-based workload to AWS and needs the data to be available on a file system in the cloud. The company already has established an AWS Direct Connect connection between the on-premises network and AWS.
Which data migration strategy should the company use?
  • A. Use AWS DataSync to schedule a daily task to replicate data between the on-premises Windows file server and Amazon FSx.
  • B. Use the file gateway option in AWS Storage Gateway to replace the existing Windows file server, and point the existing file share to the new file gateway.
  • C. Use AWS DataSync to schedule a daily task lo replicate data between the on-premises Windows file server and Amazon Elastic File System (Amazon EFS),
  • D. Use AWS Data Pipeline to schedule a daily task to replicate data between the on-premises Windows file server and Amazon Elastic File System (Amazon EFS).
https://aws.amazon.com/storagegateway/file/
https://docs.aws.amazon.com/fsx/ ... o-fsx-datasync.html
https://docs.aws.amazon.com/syst ... s-os-windows-server
NEW QUESTION # 204
A company is hosting an image-processing service on AWS in a VPC. The VPC extends across two Availability Zones. Each Availability Zone contains one public subnet and one private subnet.
The service runs on Amazon EC2 instances in the private subnets. An Application Load Balancer in the public subnets is in front of the service. The service needs to communicate with the internet and does so through two NAT gateways. The service uses Amazon S3 for image storage.
The EC2 instances retrieve approximately of data from an S3 bucket each day.
The company has promoted the service as highly secure. A solutions architect must reduce cloud expenditures as much as possible without compromising the service's security posture or increasing the time spent on ongoing operations.
Which solution will meet these requirements?
  • A. Attach an Amazon Elastic File System (Amazon EFS) volume to the EC2 instances. Host the image on the EFS volume.
  • B. Set up an S3 gateway VPC endpoint in the VPC. Attach an endpoint policy to the endpoint to allow the required actions on the S3 bucket.
  • C. Replace the NAT gateways with NAT instances. In the VPC route table, create a route from the private subnets to the NAT instances.
  • D. Move the EC2 instances to the public subnets. Remove the NAT gateways.
Create Amazon S3 gateway endpoint in the VPC and add a VPC endpoint policy. This VPC endpoint policy will have a statement that allows S3 access only via access points owned by the organization.
NEW QUESTION # 205
A video processing company has an application that downloads images from an Amazon S3 bucket, processes the images, stores a transformed image in a second S3 bucket, and updates metadata about the image in an Amazon DynamoDB table. The application is written in Node.js and runs by using an AWS Lambda function.
The Lambda function is invoked when a new image is uploaded to Amazon S3.
The application ran without incident for a while. However, the size of the images has grown significantly. The Lambda function is now failing frequently with timeout errors. The function timeout is set to its maximum value. A solutions architect needs to refactor the application's architecture to prevent invocation failures. The company does not want to manage the underlying infrastructure.
Which combination of steps should the solutions architect take to meet these requirements? (Choose two.)
  • A. Create a new Amazon Elastic Container Service (Amazon ECS) task definition with a compatibility type of Amazon EC2. Configure the task definition to use the new image in Amazon Elastic Container Registry (Amazon ECR). Adjust the Lambda function to invoke an ECS task by using the ECS task definition when a new file arrives in Amazon S3.
  • B. Modify the application deployment by building a Docker image that contains the application code.
    Publish the image to Amazon Elastic Container Registry (Amazon ECR).
  • C. Create an AWS Step Functions state machine with a Parallel state to invoke the Lambda function.
    Increase the provisioned concurrency of the Lambda function.
  • D. Modify the application to store images on Amazon Elastic File System (Amazon EFS) and to store metadata on an Amazon RDS DB instance. Adjust the Lambda function to mount the EFS file share.
  • E. Create a new Amazon Elastic Container Service (Amazon ECS) task definition with a compatibility type of AWS Fargate. Configure the task definition to use the new image in Amazon Elastic Container Registry (Amazon ECR). Adjust the Lambda function to invoke an ECS task by using the ECS task definition when a new file arrives in Amazon S3.
Answer: B,E
A: Modify the application deployment by building a Docker image that contains the application code. Publish the image to Amazon Elastic Container Registry (Amazon ECR). - This step is necessary to package the application code in a container and make it available for running on ECS. B. Create a new Amazon Elastic Container Service (Amazon ECS) task definition with a compatibility type of AWS Fargate. Configure the task definition to use the new image in Amazon Elastic Container Registry (Amazon ECR). Adjust the Lambda function to invoke an ECS task by using the ECS task definition when a new file arrives in Amazon S3.
NEW QUESTION # 206
A solutions architect is designing a solution to connect a company's on-premises network with all the company's current and future VPCs on AWS. The company is running VPCs in five different AWS Regions and has at least 15 VPCs in each Region.
The company's AWS usage is constantly increasing and will continue to grow. Additionally, all the VPCs throughout all five Regions must be able to communicate with each other.
The solution must maximize scalability and ease of management.
Which solution meets these requirements?
  • A. Set up a transit gateway in each Region. Establish a redundant AWS Site-to-Site VPN connection between the on-premises firewalls and the transit gateway in the Region that is closest to the on- premises network. Peer all the transit gateways with each other. Connect all the VPCs to the transit gateway in their Region.
  • B. Set up a transit gateway in each Region. Establish a redundant AWS Site-to-Site VPN connection between the on-premises firewalls and each transit gateway. Route traffic between the different Regions through the company's on-premises firewalls. Connect all the VPCs to the transit gateway in their Region.
  • C. Create an AWS CloudFormation template for a redundant AWS Site-to-Site VPN tunnel to the on- premises network. Deploy the CloudFormation template for each VPC. Set up VPC peering between all the VPCs for VPC-to-VPC communication.
  • D. Create an AWS CloudFormation template for a redundant AWS Site-to-Site VPN tunnel to the on- premises network. Deploy the CloudFormation template for each VPC. Route traffic between the different Regions through the company's on-premises firewalls.
https://aws.amazon.com/blogs/net ... ransit-gateway-now- supports-intra-region-peering/
https://aws.amazon.com/about-aws ... way-supports-inter- region-peering/?nc1=h_ls
NEW QUESTION # 207
Online SAP-C02 Tests: https://www.test4cram.com/SAP-C02_real-exam-dumps.html
BONUS!!! Download part of Test4Cram SAP-C02 dumps for free: https://drive.google.com/open?id=1pf6CwBiwOtUsyjO3p1gGJTnCdexgcnCM
