Free PDF Quiz Efficient PAP-001 - Cheap Certified Professional - PingAccess Dump
94
Posted at 2/17/2026 19:08:37      View104 | Replies0        Print      Only Author   [Copy Link] 1#
What's more, part of that VCETorrent PAP-001 dumps now are free: https://drive.google.com/open?id=1blvgi2puMOw_eUI-0KCGj14_foQK2prh
VCETorrent offers Ping Identity PAP-001 exam dumps that every candidate can rely on to get success on the first take. The registration fee for the Ping Identity PAP-001 real certification test is considerably expensive. That is why a VCETorrent has launched a budget-friendly PAP-001 updated study material compared to other brands in the market.
Ping Identity PAP-001 Exam Syllabus Topics:
  • General Maintenance and File System: This section of the exam measures the skills of System Engineers and addresses maintenance tasks such as license management, backups, configuration imports or exports, auditing, and product upgrades. It also includes the purpose of log files and an overview of the PingAccess file system structure with important configuration files.
  • General Configuration: This section of the exam measures skills of Security Administrators and introduces the different object types within PingAccess such as applications, virtual hosts, and web sessions. It explains managing application resource properties, creating web sessions, configuring identity mappings, and navigating the administrative console effectively.
  • Security: This section of the exam measures skills of Security Administrators and highlights how to manage certificates and certificate groups. It covers the association of certificates with virtual hosts or listeners and the use of administrator roles for authentication management.
  • Product Overview: This section of the exam measures skills of Security Administrators and focuses on understanding PingAccess features, functionality, and its primary use cases. It also covers how PingAccess integrates with other Ping products to support secure access management solutions.
Prepare with updated Ping Identity PAP-001 dumps - Get up to one year of free updatesYou can also trust VCETorrent PAP-001 exam practice questions and start preparation with complete peace of mind and satisfaction. The PAP-001 Exam Questions are designed and verified by experienced and renowned Ping Identity exam trainers. They work collectively and strive hard to ensure the top quality of PAP-001 Exam Practice questions all the time.
Ping Identity Certified Professional - PingAccess Sample Questions (Q35-Q40):NEW QUESTION # 35
An administrator is integrating a new PingAccess Proxied Application. The application will use an SSL certificate issued by a publicly trusted Certificate Authority. PingAccess is terminating SSL and is responsible for loading the SSL certificate for that application. What initial action must the administrator take in PingAccess in this situation?
  • A. Import the SSL public key with the full certificate chain into the Key Pairs.
  • B. Import the PKCS#12 file with the full certificate chain into the Certificates.
  • C. Import the SSL public key with the full certificate chain into the Certificates.
  • D. Import the PKCS#12 file with the full certificate chain into the Key Pairs.
For PingAccess to terminate SSL for a proxied application, it requires access to theprivate key and certificate chain. These are stored asKey Pairs.
Exact Extract:
"For SSL termination, you must import the server certificate and its private key as a PKCS#12 file intoKey Pairs."
* Option Ais incorrect - a public key alone cannot terminate SSL.
* Option Bis incorrect - PKCS#12 files must go intoKey Pairs, not Certificates.
* Option Cis incorrect - public keys alone are insufficient; PingAccess must have the private key.
* Option Dis correct - the PKCS#12 file with full chain and private key is imported intoKey Pairs.
ReferenceingAccess Administration Guide -Managing Certificates and Key Pairs
NEW QUESTION # 36
A company uses an internally based legacy PKI solution that does not adhere to theCertification Path Validationsection of RFC-5280. Which configuration option needs to be enabled when creating Trusted Certificate Groups in PingAccess?
  • A. Validate disordered certificate chains
  • B. Skip Certificate Date Check
  • C. Use Java Trust Store
  • D. Deny when unable to determine revocation status
Legacy PKIs often provide certificate chains that areout of orderor non-compliant with RFC-5280 path validation. PingAccess provides an option in Trusted Certificate Groups calledValidate disordered certificate chainsto allow chaining even if the order is not RFC-5280 compliant.
Exact Extract:
"EnableValidate disordered certificate chainswhen the certificate chain is not in RFC-5280 compliant order but should still be accepted."
* Option Ais incorrect; using the Java trust store is unrelated to PKI ordering.
* Option Bis correct - this setting allows PingAccess to process disordered certificate chains.
* Option Cis incorrect; date checks are unrelated to RFC-5280 path ordering.
* Option Dis incorrect; revocation status handling does not address legacy PKI ordering issues.
ReferenceingAccess Administration Guide -Trusted Certificate Groups
NEW QUESTION # 37
For a Web Application, theid_tokenmust be transmitted through a back channel with the OIDC standards- based approach. Which action should the administrator perform in the Web Session to meet this requirement?
  • A. Set the request preservation to None
  • B. Set the login type to code
  • C. Set the login type to POST
  • D. Set the request preservation to POST
To transmit theid_tokenvia a back channel according to OIDC best practices, the application must use the Authorization Code Flow(login type =code). This ensures tokens are retrieved securely via the back channel instead of being exposed in the browser.
Exact Extract:
"For back-channel transmission of ID tokens, configure the OIDC login type as Authorization Code."
* Option Ais correct - setting login type to code ensures back-channel delivery.
* Option Bis incorrect - request preservation concerns request method persistence, not OIDC flow.
* Option Cis incorrect - POST is not a valid login type; only Code, Implicit, or Hybrid.
* Option Dis incorrect - request preservation has no bearing on token delivery.
ReferenceingAccess Administration Guide -Configuring OIDC Web Sessions
NEW QUESTION # 38
What is the purpose of theengine.ssl.protocolsin therun.propertiesfile?
  • A. To configure the supported HTTPS port
  • B. To configure SSL protocols used for clustering
  • C. To configure the supported TLS versions
  • D. To configure the supported ciphers
The propertyengine.ssl.protocolsinrun.propertiesspecifies the TLS protocol versions that PingAccess engines will support for incoming HTTPS traffic.
Exact Extract:
"Theengine.ssl.protocolsproperty configures which TLS versions are enabled for HTTPS listeners."
* Option A (ciphers)is incorrect - cipher suites are defined separately, not in this property.
* Option B (HTTPS port)is incorrect - the port is defined in the engine listener, not here.
* Option C (TLS versions)is correct - this property controls TLS version support (e.g., TLSv1.2, TLSv1.3).
* Option D (clustering)is incorrect - clustering does not depend on this property.
ReferenceingAccess Administration Guide -run.properties settings
NEW QUESTION # 39
Anycompany has several applications that need to load images and fonts fromwww.anycompany.com. Users are currently getting CORS errors. How should the Cross-Origin Request rule be set to allow secure access?
  • A. Allowed Origins to*.anycompany.comand disable the Allow Credentials option
  • B. Allowed Origins towww.anycompany.comand enable the Allow Credentials option
  • C. Allowed Origins value for each of the listed domains
  • D. Allowed Origins to*and enable the Allow Credentials option
To prevent CORS errors, administrators must configure aCross-Origin Request (CORS) Processing Rule.
The secure practice is to allow thespecific trusted domain(www.anycompany.com) and, when cookies or credentials are required, to enableAllow Credentials.
Exact Extract:
"For secure CORS, specify exact origins rather than wildcards. Enable 'Allow Credentials' when client-side resources must include cookies or authentication data."
* Option Ais incomplete - multiple values are possible, but in this case onlywww.anycompany.comis required.
* Option Bis less secure - using a wildcard (*.anycompany.com) broadens exposure unnecessarily.
* Option Cis insecure -*with credentials is disallowed by CORS specifications.
* Option Dis correct - restricts access to the trusted domain and allows credentialed requests.
ReferenceingAccess Administration Guide -Cross-Origin Request Rule
NEW QUESTION # 40
In the Desktop PAP-001 practice exam software version of Ping Identity PAP-001 practice test is updated and real. The software is useable on Windows-based computers and laptops. There is a demo of the PAP-001 Practice Exam which is totally free. Certified Professional - PingAccess (PAP-001) practice test is very customizable and you can adjust its time and number of questions.
Answers PAP-001 Free: https://www.vcetorrent.com/PAP-001-valid-vce-torrent.html
P.S. Free & New PAP-001 dumps are available on Google Drive shared by VCETorrent: https://drive.google.com/open?id=1blvgi2puMOw_eUI-0KCGj14_foQK2prh
