Quiz 2026 Ping Identity Perfect Exam PT-AM-CPE Quiz
Posted at 2/17/2026 19:21:54
View226
Replies3
The Ping Identity modern job market is becoming more and more competitive and challenging and if you are not ready for it then you cannot pursue a rewarding career. Take a smart move right now and enroll in the Certified Professional - PingAM Exam (PT-AM-CPE) certification exam and strive hard to pass the Certified Professional - PingAM Exam (PT-AM-CPE) certification exam. The Certified Professional - PingAM Exam (PT-AM-CPE) certification exam offers you a unique opportunity to learn new in-demand skills and knowledge.
Ping Identity PT-AM-CPE Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Installing and Deploying AM: This domain encompasses installing and upgrading PingAM, hardening security configurations, setting up clustered environments, and deploying PingOne Advanced Identity Platform to the cloud.
| | Topic 2 | - Federating Across Entities Using SAML2: This domain covers implementing single sign-on using SAML v2.0 and delegating authentication responsibilities between SAML2 entities.
| | Topic 3 | - Improving Access Management Security: This domain focuses on strengthening authentication security, implementing context-aware authentication experiences, and establishing continuous risk monitoring throughout user sessions.
| | Topic 4 | - Extending Services Using OAuth2-Based Protocols: This domain addresses integrating applications with OAuth 2.0 and OpenID Connect, securing OAuth2 clients with mutual TLS and proof-of-possession, transforming OAuth2 tokens, and implementing social authentication.
| | Topic 5 | - Enhancing Intelligent Access: This domain covers implementing authentication mechanisms, using PingGateway to protect websites, and establishing access control policies for resources.
Ping Identity Exam PT-AM-CPE Quiz: Certified Professional - PingAM Exam - PDFVCE Easy to PassThese Ping Identity PT-AM-CPE exam questions have a high chance of coming in the actual Certified Professional - PingAM Exam PT-AM-CPE test. You have to memorize these Ping Identity PT-AM-CPE questions and you will pass the Ping Identity PT-AM-CPE test with brilliant results. The price of Ping Identity PT-AM-CPE updated exam dumps is affordable. You can try the free demo version of any Certified Professional - PingAM Exam PT-AM-CPE exam dumps format before buying.
Ping Identity Certified Professional - PingAM Exam Sample Questions (Q10-Q15):NEW QUESTION # 10
Which organization sets, maintains, and governs the SAML2 standard?
- A. IETF
- B. ISC2
- C. OASIS
- D. WC3
PingAM 8.0.2 is strictly compliant with various identity standards to ensure interoperability between different vendors and platforms. The Security Assertion Markup Language (SAML) V2.0 is the cornerstone of modern XML-based federation.7 According to the PingAM "SAML 2.0 Introduction" and "Supported Standards" documentation, the SAML 2.0 standard is developed and maintained by OASIS (the Organization for the Advancement of Structured Information Standards).8 Specifically, the OASIS Security Services Technical Committee (SSTC) is responsible for the specifications that define the SAML core (assertions and protocols), bindings (how SAML messages are mapped onto transport protocols like HTTP), and profiles (how SAML is used to solve specific use cases like Web Browser SSO).
Knowing the governing body is important for administrators when reviewing the "Technical Metadata" and "Schema" sections of PingAM, as AM's implementation follows the OASIS SAML 2.0 standards for XML signing, encryption, and assertion structure. Other organizations listed, such as the IETF (Internet Engineering Task Force), govern protocols like OAuth2 and OpenID Connect, while the W3C (World Wide Web Consortium) handles general web standards like XML and WebAuthn. However, for SAML2, OASIS remains the authoritative governing body.
NEW QUESTION # 11
What is the purpose of the extended metadata in PingAM?
- A. It is a standard way to communicate supported SAML2 features
- B. It specifies additional information about a SAML2 entity specific to PingAM
- C. It specifies the certificates and keys for the SAML2 entity
- D. It specifies the policy to invoke during SAML2 federation
In SAML 2.0 Federation, there is a standard XML schema (defined by OASIS) that all vendors use to describe an Identity Provider (IdP) or Service Provider (SP). This is known as "Standard Metadata." However, standard metadata does not include every configuration option required to run a sophisticated Access Management server.
PingAM 8.0.2 uses Extended Metadata to store implementation-specific settings that fall outside the OASIS SAML 2.0 specification. According to the "SAML 2.0 Guide," extended metadata is stored as a separate configuration file (or JSON entry in newer versions) and includes parameters such as:
Identity Store Mapping: Which attribute in the local datastore matches the SAML NameID.
Session Information: How AM should handle the session lifecycle after a successful SAML assertion.
Attribute Mapping: Detailed instructions on how to transform local LDAP attributes into SAML attributes (and vice versa).
Authentication Trees: Which specific tree should be triggered when a request arrives at the IdP.
Option D is the correct description. Option C is incorrect because extended metadata is not a standard way to communicate features; in fact, other SAML products (like ADFS or Okta) cannot read or process PingAM's extended metadata. Option A is incorrect because basic certificates/keys are usually part of the standard metadata (KeyDescriptor), and Option B is incorrect because SAML federation usually triggers authentication journeys or attribute mapping rather than a standard authorization "policy."
NEW QUESTION # 12
In PingAM, which OpenID Connect endpoint can be used to validate an unencrypted ID token?
- A. /oauth2/introspect
- B. /oauth2/userinfo
- C. /oauth2/tokeninfo
- D. /oauth2/idtokeninfo
While OpenID Connect (OIDC) is built on top of OAuth2, it introduces specific endpoints for handling ID Tokens (the identity layer). In PingAM 8.0.2, when a client receives an ID Token, it is recommended to validate it locally using the provider's public keys. However, PingAM also provides a convenience endpoint for validation.
According to the "OpenID Connect 1.0 Endpoints" documentation:
/oauth2/idtokeninfo (Option A): This is the dedicated endpoint designed to receive an ID Token as a parameter.8 It validates the token's signature, checks the expiration and audience, and returns the claims contained within the token in a JSON format. This is specifically used for unencrypted ID tokens.
/oauth2/userinfo (Option B): This endpoint returns claims about the authenticated user but requires a valid Access Token in the authorization header, not an ID Token.9
/oauth2/introspect (Option C): This is a standard OAuth2 endpoint (RFC 7662) used to check the metadata and "activeness" of Access Tokens or Refresh Tokens, not the internal identity claims of an OIDC ID Token.10
/oauth2/tokeninfo (Option D): This is a legacy/non-standard endpoint that was used in older versions for Access Token validation and is not the primary OIDC validation endpoint in version 8.0.2.11 Therefore, for the specific task of validating an ID Token and retrieving its claims, /oauth2/idtokeninfo is the correct and authoritative endpoint in the PingAM 8.0.2 OIDC implementation.
NEW QUESTION # 13
Which area of PingAM does affinity mode relate to?
- A. Authentication
- B. Self-service
- C. Authorization
- D. Load balancing
In PingAM 8.0.2, the term Affinity Mode (or session affinity) is strictly related to Load Balancing (Option B). It describes a configuration where a load balancer ensures that all requests belonging to a specific user session are consistently routed to the same PingAM server instance in a cluster.
According to the "Load Balancing" and "Deployment Planning" documentation:
Affinity is critical for performance in stateful deployments. While PingAM can operate in a "stateless" manner by retrieving sessions from the Core Token Service (CTS) on every request, this creates unnecessary overhead. Affinity Mode allows the AM server to satisfy requests using its local "In-memory" session cache.
There are two primary levels of affinity discussed in PingAM documentation:
Client-to-AM Affinity: Usually handled by the load balancer using a cookie (like the AMLB cookie) to keep the user on the same AM node.
AM-to-DS Affinity: Used when AM connects to the CTS (PingDS). This ensures that an AM server always talks to the same directory server node to avoid "replication lag" where a session might be written to one DS node but not yet visible on another.
Without affinity, the system remains functional due to the CTS, but performance decreases as every request requires a cross-network database lookup. Therefore, affinity is a core concept of the Load Balancing and high-availability architecture.
NEW QUESTION # 14
Which set of Directory Server stores can be enabled for affinity in a PingAM cluster configuration?
- A. Core Token Service Store, Identity Store, Policy Data Store, Application Data Store
- B. Identity Store, Configuration Store, Policy Data Store, Application Data Store
- C. Core Token Service Store, Identity Stores, Configuration Store, Application Data Store
- D. Core Token Service Store, Identity Stores, Configuration Store, Policy Data Store
In a high-availability PingAM 8.0.2 cluster, Affinity Load Balancing is a mechanism used to ensure that requests related to a specific session or configuration are routed to the same Directory Server (DS) instance to avoid issues with replication lag. This is particularly important for stores where data changes frequently or where consistent reads are required immediately after a write.
According to the PingAM documentation on "Load Balancing" and "External Data Stores," affinity can be configured for the following primary stores:
Core Token Service (CTS) Store: This is the most critical area for affinity. Since the CTS handles stateful data like session tokens and OAuth2 tokens that are updated constantly, ensuring that an AM server consistently communicates with a specific DS node (using the HOST ORT|SERVERID|SITEID syntax) prevents "token not found" errors that might occur if a request reached a DS node before the token was replicated.
Configuration Store: This store holds the central configuration for the AM deployment. In multi-server environments, affinity ensures that configuration changes are read consistently across the cluster.
Identity Stores: These hold the user profiles. While often read-heavy, affinity is used here to improve caching efficiency and ensure that profile updates (like password changes or attribute updates) are reflected immediately in subsequent authentication steps within the same cluster.
Policy Data Store: This stores authorization policies. Similar to configuration, affinity ensures consistent policy evaluation.
Option D is the correct answer because it includes the Core Token Service, Identity Stores, Configuration Store, and Policy Data Store. The "Application Data Store" (mentioned in other options) is often logically grouped with or replaced by the Policy Data Store in many 8.0.2 configurations, but the four stores listed in Option D are the specific ones explicitly called out in the "External Data Stores" secondary configuration documentation for supporting affinity settings.
NEW QUESTION # 15
PDFVCE Ping Identity PT-AM-CPE exam training materials have the best price value. Compared to many others training materials, PDFVCE's Ping Identity PT-AM-CPE exam training materials are the best. If you need IT exam training materials, if you do not choose PDFVCE's Ping Identity PT-AM-CPE Exam Training materials, you will regret forever. Select PDFVCE's Ping Identity PT-AM-CPE exam training materials, you will benefit from it last a lifetime.
Valid PT-AM-CPE Exam Camp: https://www.pdfvce.com/Ping-Identity/PT-AM-CPE-exam-pdf-dumps.html
- Latest Exam PT-AM-CPE Quiz C Marvelous Valid Exam Camp Provider for PT-AM-CPE 🛅 Open [ [url]www.verifieddumps.com ] and search for PT-AM-CPE to download exam materials for free 🚮
T-AM-CPE Training Courses[/url] - Exam PT-AM-CPE QuizHigh Pass RateDownlaod Instantly 🏊 Search for ➥ PT-AM-CPE 🡄 and obtain a free download on { [url]www.pdfvce.com } 🪑Latest PT-AM-CPE Real Test[/url]
- Reliable PT-AM-CPE Exam Book 😀 PT-AM-CPE Pass Guide 💧 PT-AM-CPE Demo Test 🧷 Search for [ PT-AM-CPE ] and download it for free immediately on [ [url]www.exam4labs.com ] 🔃
T-AM-CPE Valid Test Notes[/url] - Latest Exam PT-AM-CPE Quiz C Marvelous Valid Exam Camp Provider for PT-AM-CPE 🕑 Copy URL ⇛ [url]www.pdfvce.com ⇚ open and search for ➡ PT-AM-CPE ️⬅️ to download for free 😢
T-AM-CPE Valid Exam Bootcamp[/url] - Pass Guaranteed PT-AM-CPE - Trustable Exam Certified Professional - PingAM Exam Quiz 🚇 Search for ▶ PT-AM-CPE ◀ and download exam materials for free through ➽ [url]www.pdfdumps.com 🢪 🦊
T-AM-CPE Demo Test[/url] - PT-AM-CPE Reliable Test Vce 😦 New PT-AM-CPE Real Test 📲 Reliable PT-AM-CPE Braindumps Ppt 🛰 Download ⮆ PT-AM-CPE ⮄ for free by simply searching on ⏩ [url]www.pdfvce.com ⏪ 🍡Test PT-AM-CPE Dumps.zip[/url]
- Latest PT-AM-CPE Test Report 🧖 Test PT-AM-CPE Dumps.zip 🤧 Test PT-AM-CPE Dumps.zip 🦰 Immediately open [url]www.torrentvce.com and search for ✔ PT-AM-CPE ️✔️ to obtain a free download 🎌Study PT-AM-CPE Demo[/url]
- Pdfvce Offers Actual and Updated Ping Identity PT-AM-CPE Practice Questions 👲 Immediately open ➽ [url]www.pdfvce.com 🢪 and search for ➤ PT-AM-CPE ⮘ to obtain a free download 🔽
T-AM-CPE Valid Exam Bootcamp[/url] - PT-AM-CPE Exam Resources - PT-AM-CPE Actual Questions - PT-AM-CPE Exam Guide 🆗 Open website ⇛ [url]www.pass4test.com ⇚ and search for ▷ PT-AM-CPE ◁ for free download ♥
T-AM-CPE Study Materials[/url] - First-grade Exam PT-AM-CPE Quiz - 100% Pass PT-AM-CPE Exam 🥛 Search on [url]www.pdfvce.com for PT-AM-CPE to obtain exam materials for free download ℹ
T-AM-CPE Certification[/url] - Exam PT-AM-CPE QuizHigh Pass RateDownlaod Instantly 📙 Enter ➽ [url]www.validtorrent.com 🢪 and search for PT-AM-CPE to download for free 🐰
T-AM-CPE Demo Test[/url] - myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, Disposable vapes
