[General] Real AP-219 Braindumps | Exam AP-219 Format
107
General Real AP-219 Braindumps | Exam AP-219 Format
Posted at 2/17/2026 20:54:01      View150 | Replies1        Print      Only Author   [Copy Link] 1#
With passing rate more than 98 percent from exam candidates who chose our Salesforce AP-219 Study Guide, we have full confidence that your AP-219 actual test will be a piece of cake by them. Our Salesforce Order Management Administrator Accredited Professional exam questions provide with the software which has a variety of self-study and self-assessment functions to detect learning results.
Salesforce AP-219 Exam Syllabus Topics:
  • Advanced Topics: Troubleshooting configuration issues, diagnosing system integration problems, and resolving deployment obstacles.
  • User Experience and Customization: Customizing Lightning UI for different user roles using declarative tools like Lightning Page Editor and Report Builder.
  • Data Model: Core objects (Order, Order Summary, Fulfillment Orders, Return Orders), B2C Commerce integrations, and tracing data flow including custom attributes.
  • Deployment and Debugging: Deployment options, lifecycle management, building processes with pre-configured data, and understanding supporting objects and system runtime.
Topic 5
  • Process Automation and Integrations: Configuring end-to-end Order Management processes and external system integrations using declarative tools and clicks-based configuration.
Explore the Benefits and Salesforce AP-219 Exam Preparation StrategiesBoring life will wear down your passion for life. It is time for you to make changes. Our AP-219study materials are specially prepared for you. In addition, learning is becoming popular among all age groups. After you purchase our AP-219 study materials, you can make the best use of your spare time to update your knowledge. When your life is filled with enriching yourself, you will feel satisfied with your good change. Our AP-219 Study Materials are designed to stimulate your interest in learning so that you learn in happiness.
Salesforce Order Management Administrator Accredited Professional Sample Questions (Q17-Q22):NEW QUESTION # 17
An administrator is attempting to deploy aChange Set from a development org to a test org but the test org is not available in the list of target organizations. What are two reasons that could cause this issue?
  • A. The components in the Change set could not be found within the test org
  • B. The development org and test org are not associated with the same production org.
  • C. The development org has not been approved to upload Change Sets from within the test org
  • D. ChangeSets can only be deployed from a sandbox org to a production org, not another sandbox org.
Two reasons that could cause the issue of not being able to deploy a Change Set from a development org to a test org are:
The development org has not been approved to upload Change Sets from within the test org. To deploy ChangeSets between two sandbox orgs, the administrator needs to establish a deployment connection between them. A deployment connection allows one org to send outbound Change Sets and another org to receive inbound Change Sets. The administrator can create a deployment connection request from the development org and approve it from the test org.
The development org and test org are not associated with the same production org. To deploy Change Sets between two sandbox orgs, they must be linked to the same production org. A production org is an org that contains live data and business processes. A sandbox org is a copy of a production org that is used for development, testing, or training purposes. Sandbox orgs inherit the deployment connections of their source production orgs. Reference: Deploy Using Change Sets, Deploy a Change Set
NEW QUESTION # 18
When are Fulfillment Orders created by default?
  • A. The Status field on the Order Summary entity changes and a platform event which is caught by a flow
  • B. During import with a status of Managed
  • C. During import with a status of Activated
NEW QUESTION # 19
What type of relationship exists between FulfilmentOrder and Location?
  • A. One-to-many Lookup (Location) FulfilledFromLocation
  • B. Many-to-One Lookup (Location) FulfilledfromLocationId
  • C. Junction (Many to Many)
  • D. One-to-one Lookup (Location) FulfilledFromLocationId
NEW QUESTION # 20
Which two practices ate needed for a custom attribute to map into Order Management assumingthe attribute has been created on the necessary objects?
  • A. The types must be an exact match (i.e. String to String)
  • B. The types must match within reason
  • C. The names must be an exact match
  • D. The names must only contain letters and underscores
Two practices that are needed for a custom attribute to map into Order Management assuming the attribute has been created on the necessary objects are:
The types must match within reason. The data type of the custom attribute in Order Managementmust match or be compatible with the data type of the corresponding attribute in the external system, such as B2C Commerce or B2B Commerce. For example, if the attribute is a string in B2C Commerce, it must also be a string in Order Management.
The namesmust be an exact match. The name of the custom attribute in Order Management must be exactly the same as the name of the corresponding attribute in the external system, including capitalization and punctuation. For example, if the attribute is named "kitItem" in B2C Commerce, it must also be named "kitItem" in Order Management.
Verified Reference: https://documentation.b2c.commer ... stomAttributes.html
NEW QUESTION # 21
Which object is used to createan invoice?
  • A. Order Summary
  • B. Order
  • C. Shipment
  • D. Fulfillment Order
The Order Summary object is used to create an invoice. An invoice is a document that requests payment from a customer for an order. An invoice can include one or more fulfillment orders and one or more credit memos. A fulfillment order is a record that represents a part of an order that is fulfilled by a specific location. A credit memo is a record that represents a partial or full refund for an order or a fulfillment order. To create an invoice, an administrator can use the Create Invoice Apex action in a flow. The Create Invoice Apex action requires the Order Summary ID as an input parameter and creates an Invoice record associated with the Order Summary record. Reference: Order Management Objects, [Create Invoice Apex Action]
NEW QUESTION # 22
When we are in some kind of learning web site, often feel dazzling, because web page design is not reasonable, put too much information all rush, it will appear desultorily. Believe it or not, we face the more intense society, and we should prompt our competitiveness and get a AP-219 certification to make our dreams come true. Although it is not an easy thing to achieve it, once you choose our AP-219 prepare torrent, we will send the new updates for one year long, which is new enough to deal with the exam for you and guide you through difficulties in your exam preparation.
Exam AP-219 Format: https://www.actualtestsit.com/Salesforce/AP-219-exam-prep-dumps.html
Posted at 3/7/2026 01:43:07        Only Author  2#
Im truly amazed by your article, thank you for your generosity! Enhance your IT expertisefree NSE7_SSE_AD-25 latest dumps book available now! Best wishes for success!
