[General] New SPI Test Questions - Exam SPI Fees
106
【General】 New SPI Test Questions - Exam SPI Fees
Posted at 2/17/2026 21:14:00      View:119 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Exam-Killer SPI dumps for free: https://drive.google.com/open?id=1qzKGXs2qR6uizfOHblMb6860pahZXdjn
Our SPI guide torrent has gone through strict analysis and summary according to the past exam papers and the popular trend in the industry and are revised and updated according to the change of the syllabus and the latest development conditions in the theory and the practice. The SPI exam questions have simplified the sophisticated notions. The software boosts varied self-learning and self-assessment functions to check the learning results. The software of our SPI Test Torrent provides the statistics report function and help the students find the weak links and deal with them.
ARDMS SPI Exam Syllabus Topics:
  • Provide Clinical Safety and Quality Assurance: This section of the exam measures skills of Clinical Ultrasound Supervisors and focuses on maintaining safety and quality standards in ultrasound practice. It includes infection control protocols, transducer and machine integrity checks, and quality assurance testing using tissue-mimicking phantoms. The section also requires familiarity with statistical parameters like sensitivity and specificity to evaluate diagnostic performance and ensure consistent, reliable imaging outcomes.
  • Apply Doppler Concepts: This section of the exam measures skills of Vascular Sonographers and evaluates understanding and application of Doppler ultrasound principles. It includes knowledge of Doppler angle, flow dynamics, and color and spectral Doppler imaging. The section also covers eliminating aliasing, interpreting waveforms, applying continuous and pulsed wave Doppler, and optimizing Doppler gain and scale to accurately measure blood flow and velocity within vessels.
  • Optimize Sonographic Images: This section of the exam measures skills of Diagnostic Medical Sonographers and assesses their ability to enhance image quality using advanced optimization techniques. It includes understanding axial, lateral, elevational, and temporal resolution, as well as manipulating gain, depth, magnification, and dynamic range. Examinees are expected to apply harmonic imaging, spatial compounding, and gray-scale techniques to produce clear, accurate diagnostic images.
  • Perform Ultrasound Examinations: This section of the exam measures skills of Sonographers and covers how to conduct ultrasound procedures while ensuring patient safety and diagnostic accuracy. It includes understanding of imaging protocols, ergonomics, patient care, and the interaction between sound and tissue. Candidates are expected to demonstrate abilities to manage patient encounters, apply 3D
  • 4D and contrast imaging concepts, identify and correct artifacts, and follow confidentiality and privacy standards throughout the scanning process.
Topic 5
  • Manage Ultrasound Transducers: This section of the exam measures skills of Ultrasound Technicians and focuses on the management and proper use of different types of transducers. It evaluates knowledge of transducer components, frequency selection, and application of various 2D, 3D, 4D, and nonimaging transducer concepts. Candidates must show they can choose the appropriate transducer for specific examinations and make necessary frequency adjustments to ensure image quality.
Free PDF ARDMS - SPI - Sonography Principles and Instrumentation –High-quality New Test QuestionsThe third format is desktop SPI practice exam software that can be accessed easily after installing it on your Windows PC or Laptop. These formats are there so that the students can use them as per their unique needs and prepare successfully for SPI the on first try. The SPI mock tests are specially built for you to evaluate what you have studied. These Sonography Principles and Instrumentation (SPI) practice exams (desktop and web-based) are customizable, which means that you can change the time and questions according to your needs. Our SPI practice tests teach you time management so you can pass the Sonography Principles and Instrumentation (SPI) certification exam.
ARDMS Sonography Principles and Instrumentation Sample Questions (Q188-Q193):NEW QUESTION # 188
Which change should be made to lower the mechanical index (MI)?
  • A. Activating tissue harmonics
  • B. Increasing gain
  • C. Decreasing output power
  • D. Lowering transducer frequency
Mechanical Index (MI) is proportional to the peak negative pressure and inversely proportional to the square root of frequency. Lowering output power directly decreases the peak pressure, thus reducing MI.
Principles and Instrumentation state:
"Mechanical index decreases with lower output power, reducing the risk of mechanical bioeffects such as cavitation." Lowering frequency (A) increases MI.
Tissue harmonics (B) improves image quality but does not reduce MI directly.
Increasing gain (D) affects displayed brightness, not acoustic power.
Therefore, the correct answer is C: Decreasing output power.
NEW QUESTION # 189
What is the effect of an increased aperture in a linear array transducer?
  • A. Decreased temporal resolution
  • B. Shorter near-field length
  • C. Deeper focus
  • D. Improved axial resolution
The aperture of a transducer is the active area that emits and receives the ultrasound waves. In a linear array transducer, increasing the aperture (using more elements for transmission and reception) results in a deeper focus because the beam is more tightly focused over a longer distance. This improves lateral resolution at greater depths, as the ultrasound beam maintains a narrower width for a longer distance. It allows for better imaging of deeper structures without sacrificing resolution.
American Registry for Diagnostic Medical Sonography (ARDMS). Sonography Principles and Instrumentation (SPI) Examination Review Guide.
NEW QUESTION # 190
What is an advantage of power Doppler over color Doppler?
  • A. Diminished flash artifact
  • B. Less angle dependent
  • C. Accurate velocity information
  • D. Increased frame rate
Power Doppler, unlike color Doppler, is less angle dependent because it detects the strength of the Doppler signal rather than the velocity of the blood flow. This means it is more sensitive to detecting low-velocity flow and flow in smaller vessels, regardless of the angle between the ultrasound beam and the flow direction. Color Doppler provides information on flow direction and velocity but is highly dependent on the angle of insonation, making it less reliable when the angle is suboptimal.
ARDMS Sonography Principles and Instrumentation guidelines
Zwiebel, W. J., & Pellerito, J. S. (2017). Introduction to Vascular Ultrasonography. Elsevier.
NEW QUESTION # 191
Which technique averages individual frames together to improve the image?
  • A. Coded excitation
  • B. Harmonic imaging
  • C. Compression
  • D. Persistence
Persistence is a technique used in ultrasound imaging that averages individual frames together to improve the overall image quality. This process helps to reduce noise and improve the signal-to-noise ratio, leading to clearer and more stable images. By averaging multiple frames, transient artifacts are minimized, and the continuity of structures is better visualized. Persistence is particularly useful in imaging static or slow-moving structures. Reference:
"Ultrasound Physics and Technology: How, Why and When" by M. Evans, C. Archer, and K. Weston
NEW QUESTION # 192
Which feature is a characteristic of write magnification?
  • A. Post-processing
  • B. Larger pixel size
  • C. Decreased spatial resolution
  • D. New data acquisition
Write magnification acquires new data over the smaller field of view with a higher number of scan lines, improving spatial resolution.
"Write magnification rescans the selected region with new data acquisition, increasing the number of pixels and improving resolution."
* Post-processing (A) applies to read magnification.
* Larger pixel size (C) would decrease resolution.
* Write magnification improves, not decreases (D), spatial resolution.
Therefore, the correct answer is B: New data acquisition.
NEW QUESTION # 193
Test your knowledge of the SPI exam dumps with Exam-Killer Sonography Principles and Instrumentation (SPI) practice questions. The software is designed to help with Sonography Principles and Instrumentation (SPI) exam dumps preparation. Sonography Principles and Instrumentation (SPI) practice test software can be used on devices that range from mobile devices to desktop computers. We provide the Sonography Principles and Instrumentation (SPI) exam questions in a variety of formats, including a web-based practice test, desktop practice exam software, and downloadable PDF files.
Exam SPI Fees: https://www.exam-killer.com/SPI-valid-questions.html
P.S. Free 2026 ARDMS SPI dumps are available on Google Drive shared by Exam-Killer: https://drive.google.com/open?id=1qzKGXs2qR6uizfOHblMb6860pahZXdjn
