[Hardware] 312-97 Real Torrent | Latest 312-97 Test Guide
100
【Hardware】 312-97 Real Torrent | Latest 312-97 Test Guide
Posted at 2/18/2026 00:41:46      View:114 | Replies:0        Print      Only Author   [Copy Link] 1#
With the arrival of a new year, most of you are eager to embark on a brand-new road for success (312-97 test prep). Now since you have made up your mind to embrace an utterly different future, you need to take immediate actions. Using 312-97 practice materials, from my perspective, our free demo is possessed with high quality which is second to none. This is no exaggeration at all. Just as what have been reflected in the statistics, the pass rate for those who have chosen our 312-97 Exam Guide is as high as 99%, which in turn serves as the proof for the high quality of our practice torrent.
ECCouncil 312-97 Exam Syllabus Topics:
  • Introduction to DevSecOps: This module covers foundational DevSecOps concepts, focusing on integrating security into the DevOps lifecycle through automated, collaborative approaches. It introduces key components, tools, and practices while discussing adoption benefits, implementation challenges, and strategies for establishing a security-first culture.
  • DevSecOps Pipeline - Plan Stage: This module covers the planning phase, emphasizing security requirement identification and threat modeling. It highlights cross-functional collaboration between development, security, and operations teams to ensure alignment with security goals.
  • DevSecOps Pipeline - Operate and Monitor Stage: This module focuses on securing operational environments and implementing continuous monitoring for security incidents. It covers logging, monitoring, incident response, and SIEM tools for maintaining security visibility and threat identification.
  • DevSecOps Pipeline - Release and Deploy Stage: This module explains maintaining security during release and deployment through secure techniques and infrastructure as code security. It covers container security tools, release management, and secure configuration practices for production transitions.
Topic 5
  • DevSecOps Pipeline - Build and Test Stage: This module explores integrating automated security testing into build and testing processes through CI pipelines. It covers SAST and DAST approaches to identify and address vulnerabilities early in development.
Topic 6
  • DevSecOps Pipeline - Code Stage: This module discusses secure coding practices and security integration within the development process and IDE. Developers learn to write secure code using static code analysis tools and industry-standard secure coding guidelines.
Latest ECCouncil 312-97 Test Guide - 312-97 Complete Exam DumpsIf you fail 312-97 exam with our 312-97 exam dumps, we will full refund the cost that you purchased our 312-97 exam dumps. However, our promise of "No help, full refund" doesn't shows our no confidence to our products; oppositely, it expresses our most sincere and responsible attitude to reassure our customers. With our professional 312-97 Exam software, you will be at ease about your 312-97 exam, and you will be satisfied with our after-sale service after you have purchased our 312-97 exam software.
ECCouncil EC-Council Certified DevSecOps Engineer (ECDE) Sample Questions (Q97-Q102):NEW QUESTION # 97
(Scott Adkins has recently joined an IT company located in New Orleans, Louisiana, as a DevSecOps engineer. He would like to build docker infrastructure using Terraform; therefore, he has created a directory named terraform-docker-container. He then changed into the directory using the command: cd terraform- docker-container. Now, Scott wants to create a file to define the infrastructure. Which of the following commands should Scott use to create a file to define the infrastructure?)
  • A. sudo main.tf.
  • B. echo main.tf.
  • C. touch main.tf.
  • D. cat main.tf.
Terraform infrastructure definitions are written in files with the .tf extension, commonly named main.tf. To create a new, empty file where infrastructure code can be added, the correct command is touch main.tf. This command creates the file without adding any content, allowing Scott to begin defining Docker infrastructure using Terraform syntax. The cat command is used to display file contents, not create files. The echo command prints text to standard output and does not create files unless output redirection is used. The command sudo main.tf is invalid and does not create files. Creating Terraform configuration files during the Release and Deploy stage supports Infrastructure as Code practices, enabling version control, repeatability, and security validation of infrastructure deployments. This approach allows DevSecOps teams to define, review, and deploy infrastructure in a consistent and auditable manner.
NEW QUESTION # 98
(Rahul Mehta is working as a DevSecOps engineer in an IT company that develops cloud-native web applications. His organization follows a strict DevSecOps practice and wants to ensure that third-party open- source dependencies used in the application do not introduce known security vulnerabilities. Rahul decided to integrate a Software Composition Analysis (SCA) tool into the CI pipeline so that every build is automatically scanned. During one of the builds, the SCA tool detects a critical vulnerability in a transitive dependency.
What should ideally happen in a mature DevSecOps pipeline when such a critical vulnerability is detected at build time?.)
  • A. The pipeline should notify the security team and continue with deploy-time checks.
  • B. The pipeline should fail the build and prevent the artifact from progressing further.
  • C. The pipeline should ignore transitive dependencies and only scan direct dependencies.
  • D. The pipeline should log the vulnerability details and continue the build to avoid delivery delays.
In a mature DevSecOps pipeline, security controls are enforced asgates, not merely as informational checks.
When an SCA tool detects acritical vulnerabilityin a dependency-whether direct or transitive-the correct response at the Build and Test stage is tofail the build. This prevents vulnerable artifacts from moving forward into later stages such as deployment or production, where remediation would be more expensive and risky. Allowing the build to continue, even with notifications, contradicts the shift-left security principle.
Ignoring transitive dependencies is also dangerous, as many real-world vulnerabilities originate from indirect libraries. Failing the build forces developers to remediate the issue immediately by upgrading, replacing, or mitigating the vulnerable dependency. This approach reduces attack surface, enforces accountability, and ensures that only secure artifacts are released. Therefore, stopping the pipeline upon detection of critical vulnerabilities reflects a strong DevSecOps maturity model and effective security governance.
NEW QUESTION # 99
(Gabriel Bateman has been working as a DevSecOps engineer in an IT company that develops virtual classroom software for online teaching. He would like to clone the BDD security framework on his local machine using the following URL,https://github.com/continuumsecurity/bdd-security.git. Which of the following command should Gabriel use to clone the BBD security framework?)
To clone a repository from GitHub, the correct command is git clone followed by the accurate repository URL. The organization name continuumsecurity and repository name bdd-security must be spelled correctly for the command to succeed. Options using github clone are invalid because github is not a standard Git command-line utility. Options with misspelled organization names will result in errors. Cloning security testing frameworks during the Code stage enables DevSecOps engineers to evaluate, customize, and integrate security automation tools into development workflows, supporting secure application development and testing practices.
NEW QUESTION # 100
(DWART is an IT company that develops cyber security software and web applications. The organization ensures that all users should be identified and authorized, enforces proper auditing, secures data at rest, ensures that the attacker cannot bypass the security layers, implements multiple layers of defense, maintains proper data integrity, and performs proper input validation for the application. Based on the above-mentioned information, which of the following secure coding principles is achieved by DWART?.)
  • A. Secure by default.
  • B. Secure by implementation.
  • C. Secure by communication.
  • D. Secure by design.
The practices described-user identification and authorization, auditing, defense-in-depth, data protection, integrity enforcement, and input validation-are core elements that are planned and architected into the system from the beginning. These controls reflectSecure by Design, which focuses on embedding security principles at the design and architecture stage rather than adding them later. Secure by implementation emphasizes coding correctness, secure by default focuses on default configurations, and secure by communication focuses on trusted communication channels. DWART's approach shows a holistic security mindset that anticipates attacker behavior and integrates layered defenses and controls into the system blueprint. This aligns directly with Secure by Design, which aims to reduce systemic risk by ensuring the application's foundational structure enforces security consistently across all components and use cases.
NEW QUESTION # 101
(Christopher Brown has been working as a DevSecOps engineer in an IT company that develops software and web applications for an ecommerce company. To automatically detect common security issues and coding error in the C++ code, she performed code scanning using CodeQL in GitHub. Which of the following entries will Christopher find for CodeQL analysis of C++ code?)
  • A. CodeQL/Analyze (cp) (push-request).
  • B. CodeQL/Analyze (cpp) (push-request).
  • C. CodeQL/Analyze (cp) (pull-request).
  • D. CodeQL/Analyze (cpp) (pull-request).
When GitHub Code Scanning is enabled using CodeQL, each supported programming language is identified by a specific language key. For C++ code, CodeQL uses the identifiercpp, not "cp." CodeQL workflows are commonly configured to run during pull request events so that security issues and coding errors can be detected and reviewed before code is merged into the main branch. As a result, the CodeQL analysis entry displayed in GitHub Actions and the Security tab for C++ pull request analysis appears asCodeQL/Analyze (cpp) (pull-request). Options A and B are incorrect because "cp" is not a valid CodeQL language identifier.
Option C uses the correct language identifier but references an incorrect event format. Identifying the correct CodeQL analysis entry helps DevSecOps engineers confirm that scans are executing correctly for the intended language during the Code stage and that security feedback is available early in the development lifecycle.
NEW QUESTION # 102
PassLeader offers you a free demo version of the ECCouncil 312-97 dumps. This way candidates can easily check the validity and reliability of the 312-97 exam products without having to spend time. This relieves any sort of anxiety in the candidate's mind before the purchase of EC-Council Certified DevSecOps Engineer (ECDE) certification exam preparation material. This 312-97 Exam study material is offered to you at a very low price. We also offer up to 1 year of free updates on ECCouncil 312-97 dumps after the date of purchase. Going through our EC-Council Certified DevSecOps Engineer (ECDE) exam prep material there remains no chance of failure in the ECCouncil 312-97 exam.
Latest 312-97 Test Guide: https://www.passleader.top/ECCouncil/312-97-exam-braindumps.html
