AI-102 Reliable Test Braindumps, AI-102 Exam Sample Online
Posted at 2/18/2026 02:15:22
View110
Replies0
P.S. Free & New AI-102 dumps are available on Google Drive shared by Real4exams: https://drive.google.com/open?id=1-DcwrdOkzUQBlJZzm-HY0VmXCr3WsU2T
As is known to us, if there are many people who are plugged into the internet, it will lead to unstable state of the whole network, and you will not use your study materials in your lunch time. If you choice our AI-102 exam question as your study tool, you will not meet the problem. Because the app of our AI-102 Exam Prep supports practice offline in anytime. If you buy our products, you can also continue your study when you are in an offline state. You will not be affected by the unable state of the whole network. You can choose to use our AI-102 exam prep in anytime and anywhere.
It is incontrovertible high quality and high accuracy AI-102 practice materials that have helped more than 98 percent of exam candidates who choose our AI-102 real quiz gets the certificate successfully. So we totally understand you inmost thoughts, and the desire to win the AI-102 Exam as well as look forward to bright future that come along. During your practice process accompanied by our AI-102 study guide, you will easily get the certificate you want.
Pass-Sure AI-102 Reliable Test Braindumps Spend Your Little Time and Energy to Pass AI-102: Designing and Implementing a Microsoft Azure AI Solution examThe exam requires an enormous amount of effort and determination and dedication to get to the end goal. Real4exams is one of the most reliable platforms that offer an accurate, reliable, and straightforward Microsoft AI-102 dumps to ensure the success of students on the initial try. Real4exams offers the complete package that includes all exam dumps conforming to the syllabus for passing the Designing and Implementing a Microsoft Azure AI Solution (AI-102) exam certificate in the first try.
The AI-102 certification exam consists of multiple-choice questions and performance-based scenarios. Candidates are given a limited amount of time to complete the exam, and they must pass with a score of at least 700 out of 1000 points to earn the certification. AI-102 exam can be taken online or in a testing center, and it is recommended that candidates prepare thoroughly by taking online courses, reading technical documentation, and practicing with sample questions.
Microsoft AI-102 certification exam covers a wide range of topics related to AI, including natural language processing, machine learning, computer vision, and conversational AI. AI-102 exam also tests the candidate's ability to integrate AI solutions with other Azure services such as Azure Cognitive Services, Azure Machine Learning, and Azure Bot Service. AI-102 Exam is intended for solution architects, developers, and data scientists who are responsible for designing and implementing AI solutions using Azure services.
Microsoft AI-102 exam consists of multiple-choice questions that are designed to test the candidate's knowledge in various areas. These areas include designing and implementing AI solutions, creating natural language processing solutions, integrating AI services with other applications, and deploying AI models. AI-102 exam is intended for individuals who have a strong understanding of Azure services, machine learning concepts, and AI principles. AI-102 exam is ideal for professionals who want to advance their career in the field of Artificial Intelligence and demonstrate their proficiency in designing and implementing Azure AI solutions.
Microsoft Designing and Implementing a Microsoft Azure AI Solution Sample Questions (Q356-Q361):NEW QUESTION # 356
You have an Azure subscription that contains an Azure Al Video Indexer account.
You need to add a custom brand and logo to the indexer and configure an exclusion for the custom brand.
How should you complete the REST API call? To answer, select the appropriate options in the answer area.
Comprehensive Detailed ExplanationThe scenario:
* You are working with Azure AI Video Indexer.
* You need to add a custom brand/logo and also configure an exclusion so that this brand is not indexed.
In Video Indexer's REST API for brands, the configuration JSON includes:
* "enabled": true/false # Determines whether the brand should be indexed.
* Setting "enabled": false means the brand is excluded.
The other properties in the dropdown (state, tags, useBuiltin) are not correct in this context for configuring exclusions.
Therefore, to exclude a custom brand:
"enabled": false
The answer:
* Attribute: "enabled"
* Value: false
* Video Indexer - Brands customization
* Azure Video Indexer API - Brands
Microsoft References
NEW QUESTION # 357
You have the following C# method for creating Azure Cognitive Services resources programmatically.
You need to call the method to create a free Azure resource in the West US Azure region. The resource will be used to generate captions of images automatically.
Which code should you use?
- A. create_resource(client, "res1", "ComputerVision", "F0", "westus")
- B. create_resource(client, "res1", "ComputerVision", "S0", "westus")
- C. create_resource(client, "res1", "CustomVision.Prediction", "S0", "westus")
- D. create_resource(client, "res1", "CustomVision.Prediction", "F0", "westus")
The question is about creating an Azure Cognitive Services resource programmatically with C#.
* Free resource # This requires the F0 (Free) pricing tier.
* West US region # Location should be "westus".
* Generate captions of images automatically # This requires the Computer Vision service.
* A. create_resource(client, "res1", "ComputerVision", "F0", "westus")
* Uses "ComputerVision" kind # Correct, because Computer Vision provides the image captioning feature.
* Tier is "F0" # Correct, free tier.
* Location "westus" # Correct.
* This is the correct answer.
* B. create_resource(client, "res1", "CustomVision.Prediction", "F0", "westus")
* Custom Vision is for building and deploying custom image classifiers.
* The Prediction resource is specifically for running inference, not general captioning.
* Wrong service for the requirement.
* C. create_resource(client, "res1", "ComputerVision", "S0", "westus")
* "ComputerVision" is correct.
* But "S0" is a paid tier, not the required free tier.
* Does not meet the requirement.
* D. create_resource(client, "res1", "CustomVision.Prediction", "S0", "westus")
* Wrong service (captioning is not handled by Custom Vision).
* Wrong tier (paid instead of free).
* Incorrect.
The answer: A. create_resource(client, "res1", "ComputerVision", "F0", "westus")
* Azure AI Computer Vision documentation
* Create a Cognitive Services resource in Azure
* Computer Vision capabilities - Image analysis and captioning
NEW QUESTION # 358
Select the answer that correctly completes the sentence.
NEW QUESTION # 359
Drag and Drop Question
You have an Azure subscription that contains an Azure OpenAI resource named AI1.
You plan to build an app named App1 that will write press releases by using AI1.
You need to deploy an Azure OpenAI model for App1. The solution must minimize development effort.
Which three actions should you perform in sequence in Azure OpenAI Studio? To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.
NEW QUESTION # 360
NEW QUESTION # 361
The next step to do is to take Microsoft AI-102. These AI-102 practice questions can help you measure your skill to see if it has already met the standard set by Microsoft AI-102. To optimize the effectiveness, We have made the AI-102 Practice Test using the same format as the Designing and Implementing a Microsoft Azure AI Solution exam. All Microsoft Exam Dumps questions appearing on the mock test are the ones we carefully predicted to appear on your upcoming exam.
AI-102 Exam Sample Online: https://www.real4exams.com/AI-102_braindumps.html
- Designing and Implementing a Microsoft Azure AI Solution Exam Demo - AI-102 Torrent Vce - Designing and Implementing a Microsoft Azure AI Solution Pass Guide 🈵 [url]www.practicevce.com is best website to obtain ➥ AI-102 🡄 for free download ⭕Exam AI-102 Discount[/url]
- 100% Pass Quiz AI-102 - Latest Designing and Implementing a Microsoft Azure AI Solution Reliable Test Braindumps 🌰 Search on ✔ [url]www.pdfvce.com ️✔️ for ☀ AI-102 ️☀️ to obtain exam materials for free download 😨New AI-102 Test Testking[/url]
- Test AI-102 Discount Voucher 👇 Latest AI-102 Guide Files 👤 Valid Dumps AI-102 Ppt 🥏 Search for AI-102 and download it for free immediately on [url]www.pass4test.com 🦗AI-102 Clear Exam[/url]
- AI-102 First-grade Reliable Test Braindumps - 100% Pass Quiz Microsoft AI-102 ↔ Copy URL [url]www.pdfvce.com open and search for ➽ AI-102 🢪 to download for free 🧫Test AI-102 Discount Voucher[/url]
- Designing and Implementing a Microsoft Azure AI Solution Exam Demo - AI-102 Torrent Vce - Designing and Implementing a Microsoft Azure AI Solution Pass Guide 💆 Download { AI-102 } for free by simply searching on [ [url]www.examcollectionpass.com ] 😇Instant AI-102 Discount[/url]
- 2026 Excellent AI-102 Reliable Test Braindumps | Designing and Implementing a Microsoft Azure AI Solution 100% Free Exam Sample Online 👈 Search for ⮆ AI-102 ⮄ and download it for free immediately on ⮆ [url]www.pdfvce.com ⮄ ☯AI-102 Test Cram[/url]
- Latest AI-102 Guide Files 〰 Valid AI-102 Study Guide ℹ Test AI-102 Discount Voucher 🕉 Easily obtain free download of { AI-102 } by searching on [url]www.prepawayexam.com 🦓Reliable AI-102 Exam Voucher[/url]
- AI-102 C 100% Free Reliable Test Braindumps | Trustable Designing and Implementing a Microsoft Azure AI Solution Exam Sample Online 🚍 Open ▶ [url]www.pdfvce.com ◀ enter { AI-102 } and obtain a free download 🐓AI-102 Pdf Braindumps[/url]
- Valid Dumps AI-102 Ppt 🎢 New AI-102 Test Testking 🍖 Valid AI-102 Study Guide 🕰 The page for free download of [ AI-102 ] on [url]www.troytecdumps.com will open immediately 👜Latest AI-102 Exam Online[/url]
- Designing and Implementing a Microsoft Azure AI Solution Exam Demo - AI-102 Torrent Vce - Designing and Implementing a Microsoft Azure AI Solution Pass Guide 🧫 Download AI-102 for free by simply entering ✔ [url]www.pdfvce.com ️✔️ website 🏈Valid AI-102 Study Guide[/url]
- AI-102 Test Cram 🚞 Test AI-102 Discount Voucher 🤣 AI-102 Technical Training ☑ Search for ✔ AI-102 ️✔️ and easily obtain a free download on ⇛ [url]www.prep4away.com ⇚ 🤠
ass4sure AI-102 Dumps Pdf[/url] - myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free 2026 Microsoft AI-102 dumps are available on Google Drive shared by Real4exams: https://drive.google.com/open?id=1-DcwrdOkzUQBlJZzm-HY0VmXCr3WsU2T
