[General] Latest Cisco 350-801 Exam Notes | Dumps 350-801 Discount
94
【General】 Latest Cisco 350-801 Exam Notes | Dumps 350-801 Discount
Posted at 2/18/2026 03:42:29      View:101 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Braindumpsqa 350-801 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1fWbEpYwes4DcNoSWc1vs5P8fLj_UfOpR
Choose Braindumpsqa 350-801 new dumps questions, you will never regret for your decision. Our high-quality 350-801 exam cram can ensure you 100% pass. You see, we have quality control system, each questions of 350-801 exam dumps are checked and confirmed strictly according to the quality control system. Besides, the updated frequency for 350-801 Exam Questions is so regular and in accordance with the real exam changes. You can enjoy one year free update after purchase.
As the saying goes, practice makes perfect. We are now engaged in the pursuit of Craftsman spirit in all walks of life. Professional and mature talents are needed in each field, similarly, only high-quality and high-precision 350-801 practice materials can enable learners to be confident to take the qualification examination so that they can get the certificate successfully, and our 350-801 learning materials are such high-quality learning materials, it can meet the user to learn the most popular test site knowledge. Because our experts have extracted the frequent annual test centers are summarized to provide users with reference. Only excellent learning materials such as our 350-801 practice materials can meet the needs of the majority of candidates, and now you should make the most decision is to choose our products.
Features of Cisco 350-801 Dumps PDF FormatPlease believe that our company is very professional in the research field of the 350-801 training questions, which can be illustrated by the high passing rate of the examination. Despite being excellent in other areas, we have always believed that quality and efficiency should be the first of our 350-801 real exam. For study materials, the passing rate is the best test for quality and efficiency. There may be some other study materials with higher profile and lower price than our products, but we can assure you that the passing rate of our 350-801 Learning Materials is much higher than theirs. And this is the most important. According to previous data, 98 % to 99 % of the people who use our 350-801 training questions passed the exam successfully. If you are willing to give us a trust, we will give you a success.
Cisco 350-801 exam covers a wide range of topics, including implementing and troubleshooting Cisco Unified Communications Manager (CUCM), Cisco Unity Connection, Cisco Unified Contact Center Express (UCCX), and Cisco Unified IM and Presence (IM&P). 350-801 Exam also covers topics related to implementing and troubleshooting voice gateways, SIP trunks, and video endpoints.
Cisco Implementing and Operating Cisco Collaboration Core Technologies Sample Questions (Q133-Q138):NEW QUESTION # 133
A customer wants a video conference with five Cisco TelePresence IX5000 Series systems. Which media resource is necessary in the design to fully utilize the immersive functions?
  • A. Cisco Meeting Server
  • B. software conference bridge on Cisco Unified Communications Manager
  • C. Cisco PVDM4-128
  • D. Cisco Webex Meetings Server
NEW QUESTION # 134
Refer to the exhibit. An administrator is attempting to register a SIP phone to a Cisco UCM but the registration is failing. The IP address of the SIP Phone is 10.117.34 222 and the IP 1 address of the Cisco UCM is 10.0.101.10. Pings from the SIP phone to the Cisco UCM are successful.
What is the cause of this issue and how should it be resolved?
  • A. An network device is blocking TCP port 5060 from the SIP phone to the Cisco UCM. This device must be reconfigured to allow traffic from the IP phone.
  • B. The certificates on the SIP phone are not trusted by the Cisco UCM. The SIP phone must generate new certificates.
  • C. DNS lookup for the Cisco UCM FQDN is failing. The SIP phone must be reconfigured with the proper DNS server.
  • D. An NTP mismatch is preventing connection of the TCP session between the SIP phone and the Cisco UCM. The SIP phone and Cisco UCM must be set with identical NTP sources.
NEW QUESTION # 135
Refer to the exhibit. Given this "debug isdn q921" output, what is the problem with the PRI?
  • A. Nothing, the PRI is sending keepalives.
  • B. Layer 1 is down on the controller.
  • C. Layer 2 is down on the controller.
  • D. PRI does not have an IP address configured on the interface.
Section: Cisco IOS XE Gateway and Media Resources
NEW QUESTION # 136
An engineer must modify the existing QoS policy-map statement to implement LLQ for voice traffic. Which change must the engineer make in the configuration?
  • A. bandwidth 170 to percent 170
  • B. bandwidth 170 to LLQ 170
  • C. bandwidth 170 to reserve 170
  • D. bandwidth 170 to priority 170
NEW QUESTION # 137
Which configuration on Cisco UCM is required for SIP MWl to work?
  • A. The line partition must be inside the rerouting CSS assigned to the Cisco Unity Connection SIP trunk.
  • B. The line partition must be inside the inbound CSS assigned to the CUC SIP trunk.
  • C. Assign an MWl extension on the mailbox.
  • D. Set the"Enable message waiting indicator" on the port group.
The line partition must be inside the inbound CSS assigned to the CUC SIP trunk. This ensures that the SIP MWI messages are sent to the correct destination.
The other options are incorrect because:
Assigning an MWI extension on the mailbox is not required for SIP MWI to work.
The line partition does not need to be inside the rerouting CSS assigned to the Cisco Unity Connection SIP trunk.
Setting the "Enable message waiting indicator" on the port group is not required for SIP MWI to work.
NEW QUESTION # 138
The valid updated, and real Cisco 350-801 PDF questions and both practice test software are ready to download. Just take the best decision of your professional career and get registered in the Cisco 350-801 Certification Exam and start this journey with Braindumpsqa 350-801 exam PDF dumps and practice test software.
Dumps 350-801 Discount: https://www.braindumpsqa.com/350-801_braindumps.html
BTW, DOWNLOAD part of Braindumpsqa 350-801 dumps from Cloud Storage: https://drive.google.com/open?id=1fWbEpYwes4DcNoSWc1vs5P8fLj_UfOpR
