[General] C-ARCIG-2508 Dumps Questions & New C-ARCIG-2508 Test Online
104
General C-ARCIG-2508 Dumps Questions & New C-ARCIG-2508 Test Online
Posted at 2/18/2026 04:20:48      View116 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New C-ARCIG-2508 dumps are available on Google Drive shared by Lead1Pass: https://drive.google.com/open?id=18815DNT-DFFoWXpdoWU30wmd9zqpDEgS
Our C-ARCIG-2508 study materials do our best to find all the valuable reference books, then, the product we hired experts will carefully analyzing and summarizing the related materials, such as: C-ARCIG-2508 C-ARCIG-2508 exam, eventually form a complete set of the review system. Experts before starting the compilation of " the C-ARCIG-2508 study materials ", has put all the contents of the knowledge point build a clear framework in mind, though it needs a long wait, but product experts and not give up, but always adhere to the effort, in the end, they finished all the compilation. So, you're lucky enough to meet our C-ARCIG-2508 Study Materials l, and it's all the work of the experts.
SAP C-ARCIG-2508 Exam Syllabus Topics:
  • SAP Business Network Integration Configuration: This section of the exam measures the skills of Implementation Consultants and focuses on configuring integration with the SAP Business Network. It validates understanding of connectivity steps to enable business-to-business collaboration.
  • SAP Ariba Strategic Sourcing Integration Configuration: This section of the exam measures the skills of Solution Architects and focuses on the configuration required for strategic sourcing processes within SAP Ariba. It ensures candidates understand integration steps that connect sourcing data with SAP systems.
  • Supplier Lifecycle Performance: This section of the exam measures the skills of Implementation Consultants and includes the setup and management of supplier lifecycle performance processes. It validates understanding of integration elements supporting supplier evaluation and collaboration.
  • Managing Clean Core: This section of the exam measures the skills of Implementation Consultants and focuses on applying clean core principles within SAP environments. It highlights practices that maintain standard processes, minimize customizations, and ensure long-term system stability.
Topic 5
  • SAP Ariba Procurement Integration Configuration: This section of the exam measures the skills of Implementation Consultants and focuses on procurement-related integration tasks. It highlights knowledge of system setup that enables seamless procurement processes between SAP Ariba and SAP S
  • 4HANA.
Topic 6
  • CI to Managed Gateway: This section of the exam measures the skills of Implementation Consultants and deals with the integration setup between SAP Ariba and Managed Gateway. It emphasizes understanding connection points and smooth data flow for business processes.
Topic 7
  • Managed Gateway Configuration: This section of the exam measures skills of Implementation Consultants and emphasizes practical knowledge of configuring Managed Gateway. It includes mapping, routing, and handling different business process requirements.
Topic 8
  • Managed Gateway Tools: This section of the exam measures skills of Solution Architects and addresses the tools provided within Managed Gateway. It covers their role in monitoring, managing, and troubleshooting integration scenarios.
New C-ARCIG-2508 Test Online - Exam C-ARCIG-2508 ScoreNowadays the competition in the society is fiercer and if you don't have a specialty you can't occupy an advantageous position in the competition and may be weeded out. Passing the test C-ARCIG-2508 certification can help you be competent in some area and gain the competition advantages in the labor market. If you buy our C-ARCIG-2508 Study Materials you will pass the C-ARCIG-2508 test smoothly. Our product boosts many advantages and it is your best choice to prepare for the test. Our C-ARCIG-2508 learning prep is compiled by our first-rate expert team and linked closely with the real exam.
SAP Certified Associate - Implementation Consultant - Managed gateway for spend management and SAP Business Network Sample Questions (Q26-Q31):NEW QUESTION # 26
You are a consultant on an SAP S/4HANA Cloud greenfield project. As part of their clean core journey, the customer must analyze the current IT landscape to eliminate redundant systems and establish an efficient architectural design. Which of the following can you use to do the analysis?
  • A. SAP Best Practices
  • B. Lean ix
  • C. SAP Solution Manager
  • D. SAP Cloud ALM
From the "Managing Clean Core for SAP S/4HANA Cloud" learning journey on learning.sap.com, the recommended tool (among the options listed) for analyzing the current IT landscape-especially in a greenfield, clean-core journey-is:
*C. SAP Best Practices
These provide pre-configured, standard processes and a baseline understanding of SAP S/4HANA Cloud functionality, helping you assess what existing processes/systems you may retain, optimize, or eliminate. SAP Learning+1 Neither SAP Solution Manager, SAP Cloud ALM, nor Lean-IX is cited in the clean-core greenfield context on learning.sap.com for this analysis.
Therefore, the correct answer from that source is:
(It appears that only one of the given options is supported in the SAP learning content for this scenario.)
NEW QUESTION # 27
You are migrating from Ariba CI to the Managed Gateway for Spend & Network solution. If you choose to manually create the service names for Proxy/Web service transactions, which of the following documents should you consider?
  • A. Invoice in SAP Business Network Integration
  • B. Invoice in SAP Ariba Procurement Integration
  • C. Purchasing info record in SAP Ariba Sourcing Integration
  • D. Receipt in SAP Business Network Integration
  • E. Receipt in SAP Ariba Procurement Integration
Answer: A,B,E
NEW QUESTION # 28
What is the purpose of implementing an implicit enhancement for a purchase order transaction in SAP Business Network integration via Managed Gateway for Spend&Network?
  • A. To enable service map key functionality
  • B. To send accounting information in the purchase order
  • C. To handle the Purchase Order Change & Cancel scenario
  • D. To filter out account assignment details based on the company code
Solution:
From the "Implementing a Customer Exit for Purchase Order" lesson on learning.sap.com, the purpose of using an implicit enhancement (via INCLUDEs in the Customer Exit) for a purchase order transaction in the SAP Business Network integration via Managed Gateway for Spend & Network is:
*D. To send accounting information in the purchase order
The lesson explains that one of the standard INCLUDEs (ARBCIG_ORDER_REQUEST_011) is used to include accounting information - such as account assignments: cost center, GL account, WBS elements, internal orders, assets - in the Purchase Order XML (OrderRequest) sent from SAP ERP/S/4HANA to the SAP Business Network. SAP Learning The other options (filtering by company code, service map key functionality, change & cancel scenarios) are not described in that context.
NEW QUESTION # 29
Which Ariba values are associated with QuoteRequestMatchingType in the CIG lookup table? Note: There are 3correctanswers to this question.
  • A. Public
  • B. invitationOnly
  • C. approvedVendorOnly
  • D. winningOnly
  • E. Private
Answer: A,B,C
NEW QUESTION # 30
What value proposition does the SAP Integration Suite, managed gateway for spend management and SAP Business Network offer? Note: There are 3 correct answers to this question.
  • A. Ability to integrate with any middleware
  • B. Integration with non-SAP ERP applications
  • C. Shorter deployment cycle
  • D. Simple steps to integrate
  • E. Self-Service wizard to manage the integration process
Answer: C,D,E
NEW QUESTION # 31
Nowadays passing the C-ARCIG-2508 test certification is extremely significant for you and can bring a lot of benefits to you. Passing the C-ARCIG-2508 test certification does not only prove that you are competent in some area but also can help you enter in the big company and double your wage. And our C-ARCIG-2508 Exam Questions are in good quality. As long as you study with our C-ARCIG-2508 learning guide, you will find that the content is easily to understand and the displays are enjoyable.
New C-ARCIG-2508 Test Online: https://www.lead1pass.com/SAP/C-ARCIG-2508-practice-exam-dumps.html
