[Hardware] 100% Pass 2026 Oracle 1Z0-947: Pass-Sure Exam Oracle GoldenGate 19c Implementati
137
【Hardware】 100% Pass 2026 Oracle 1Z0-947: Pass-Sure Exam Oracle GoldenGate 19c Implementati
Posted at 2/18/2026 05:32:28      View:87 | Replies:0        Print      Only Author   [Copy Link] 1#
To attempt the Oracle 1Z0-947 exam optimally and ace it on the first attempt, proper exam planning is crucial. Since the Oracle 1Z0-947 exam demands a lot of time and effort, we designed the Oracle GoldenGate 19c Implementation Professional (1Z0-947) exam dumps in such a way that you won't have to go through sleepless study nights or disturb your schedule. Before starting the Oracle 1Z0-947 Preparation, plan the amount of time you will allot to each topic, determine the topics that demand more effort and prioritize the components that possess more weightage in the Oracle 1Z0-947 exam.
Good product can was welcomed by many users, because they are the most effective learning tool, to help users in the shortest possible time to master enough knowledge points, so as to pass the qualification test, and our 1Z0-947 learning dumps have always been synonymous with excellence. Our 1Z0-947 practice guide can help users achieve their goals easily, regardless of whether you want to pass various qualifying examination, our products can provide you with the learning materials you want. Of course, our 1Z0-947 Real Questions can give users not only valuable experience about the exam, but also the latest information about the exam. Our 1Z0-947 practical material is a learning tool that produces a higher yield than the other. If you make up your mind, choose us!
Features of Oracle 1Z0-947 Desktop and Web-based Practice Exams2Pass4sure has many Oracle GoldenGate 19c Implementation Professional (1Z0-947) practice questions that reflect the pattern of the real Oracle 1Z0-947 exam. 2Pass4sure allows you to create a Oracle GoldenGate 19c Implementation Professional (1Z0-947) exam dumps according to your preparation. It is easy to create the Oracle GoldenGate 19c Implementation Professional (1Z0-947) practice questions by following just a few simple steps. Our 1Z0-947 exam dumps are customizable based on the time and type of questions.
Oracle GoldenGate 19c Implementation Professional Sample Questions (Q34-Q39):NEW QUESTION # 34
A Distribution Path sends the transaction of data from Extract to Replicat. How can you create a Distribution Path?
  • A. In GGSCI with GoldenGate commands
  • B. From Cloud Shell with REST APIs
  • C. At OS prompt with run preceding the GoldenGate commands
  • D. From the Service Manager home page
In Oracle GoldenGate Microservices Architecture, the Service Manager UI is the recommended and primary interface to create a Distribution Path using the Distribution Server. This method is officially documented and intended for simplified management.
NEW QUESTION # 35
Which parameter is used to identify the remote target system in Oracle GoldenGate?
  • A. Map
  • B. TargetTrail
  • C. RmtHost
  • D. HostName
NEW QUESTION # 36
Oracle GoldenGate can be deployed quickly and easily. You need to prepare the environment, configure and start change capture to GoldenGate trail files, perform Initial Load to synchronize databases, and configure and start change delivery. You can perform the tasks for Initial Load before or after starting change capture. When do you not need to do an Initial Load at all?
  • A. You don't need to address Initial Load as it is just optional.
  • B. You already have the tables and data on the target needed for replicating data changes.
  • C. You created the target database with Initial Load enabled.
  • D. You need only to replicate to the new table on the target database with changes from the source table starting at a specific time.
An Initial Load is used to synchronize source and target databases before real-time replication begins.
NEW QUESTION # 37
A process group in GoldenGate is a collection of things associated with a specific GoldenGate Extract or Replicat process. Which of these is not an item in a GoldenGate process group?
  • A. A checkpoint table for the Extract
  • B. The Extract processes
  • C. A checkpoint file
  • D. A parameter file
? Checkpoint tables are used only for Integrated Replicat, not Extract. Extract uses checkpoint files, not tables. So, "A checkpoint table for the Extract" is not part of an Extract process group.
NEW QUESTION # 38
Why might you use multiple data pumps for one source trail?
  • A. Send to multiple targets and improve parallelism
  • B. Encrypt extract data
  • C. Minimize CPU usage
  • D. Reduce redo generation
To support multiple target systems, table separation, and parallel processing.
NEW QUESTION # 39
Our Oracle GoldenGate 19c Implementation Professional (1Z0-947) PDF file is portable which means customers can carry this real questions document to any place. You just need smartphones, or laptops, to access this Oracle GoldenGate 19c Implementation Professional (1Z0-947) PDF format. These Oracle GoldenGate 19c Implementation Professional (1Z0-947) questions PDFs are also printable. So candidates who prefer to study in the old way which is paper study can print Oracle GoldenGate 19c Implementation Professional (1Z0-947) questions PDF as well.
1Z0-947 Exam Questions Answers: https://www.2pass4sure.com/Oracle-GoldenGate/1Z0-947-actual-exam-braindumps.html
Oracle Exam 1Z0-947 Bootcamp It proves highly profitable to the candidates to go through these questions and answers as they overcome all of their fears, The key of our success is that we offer the comprehensive service and the up-to-date 1Z0-947 Exam Questions Answers dumps pdf to our customers, Oracle Exam 1Z0-947 Bootcamp You can get assistant by them as long as you made your inquire, They work together and put all their efforts and ensure the top standard of 2Pass4sure Oracle 1Z0-947 exam dumps all the time.
Stallkamp offers a complete blueprint for deploying 1Z0-947 Exam Questions Answers strategic collaboration with suppliers, customers, and employees, You canknow after downloading our free PDF demo of the 1Z0-947 Learning Materials: Oracle GoldenGate 19c Implementation Professional to have a quick look of the content.
Latest 1Z0-947 Practice Exam Guide Materials: Oracle GoldenGate 19c Implementation Professional - 2Pass4sureIt proves highly profitable to the candidates 1Z0-947 to go through these questions and answers as they overcome all of their fears,The key of our success is that we offer the 1Z0-947 Exam Questions Answers comprehensive service and the up-to-date Oracle GoldenGate dumps pdf to our customers.
Oracle GoldenGate 19c Implementation Professional 1Z0-947 dumps are updated regularly and contain an excellent course of action material.
