Free PDF Quiz First-grade Medical Tests PTCE - Exam Pharmacy Technician Certific
99
Posted at 2/18/2026 06:24:48      View:92 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest Prep4sures PTCE PDF Dumps and PTCE Exam Engine Free Share: https://drive.google.com/open?id=1mazLG8ap-pEh_biBVrGZYVKxksK_eYJr
Our PTCE exam questions are based on the actual situation to stimulate exam circumstance in order to provide you a high-quality and high-efficiency user experience. In addition, the PTCE exam guide function as a time-counter, and you can set fixed time to fulfill your task, so that promote your efficiency in real test. The key strong-point of our PTCE Test Guide is that we impart more important knowledge with fewer questions and answers, with those easily understandable PTCE study braindumps, you will find more interests in them and experience an easy learning process.
Although this may not sound like the hardest job in the world, being a pharmacy technician isn't easy, as the work these people do directly affects the health of others. Therefore, it is vitally important that people hired as pharmacy technicians are qualified for this job. This is why more and more pharmacies and pharmacy chains expect their employees to have a valid PTCB credential.
Who is a pharmacy technician? Sometimes known as a pharmaceutical technician, pharmacy technician is a health care provider who performs pharmacy-related functions, generally working under the direct supervision of a licensed pharmacist. Job duties include dispensing prescription drugs and other medical devices to patients and instructing on their use. They may also perform administrative duties in pharmaceutical practice, such as reviewing prescription requests with doctor's offices and insurance companies to ensure correct medications are provided and payment is received.
Quiz Medical Tests - PTCE Fantastic Exam PreviewPrep4sures offers latest braindumps pdf, braindumps sheet and braindumps questions. Real Pharmacy Technician Certification Exam PTCE Exams can help customers success in their career. Medical Tests with best Pharmacy Technician Certification Exam study material help customers pass the Pharmacy Technician Certification Exam PTCE test. And the Pharmacy Technician Certification Exam PTCE price is affordable. With 365 days updates.
PTCB Pharmacy Technician Certification BoardA PTCB Certification board exam is the professional exam validating the skills and knowledge candidates need to work as pharmacy technicians. It tests their knowledge in English, Math, Science (Chemistry) and professional aspects of their job.
Medical Tests Pharmacy Technician Certification Exam Sample Questions (Q204-Q209):NEW QUESTION # 204
Due to a drug-drug interaction, patients taking tetracycline should avoid simultaneous use of:
  • A. antitussives that contain dextromethorphan.
  • B. analgesics that contain acetaminophen.
  • C. decongestants that contain pseudoephedrine.
  • D. antacids that contain calcium.
Tetracyclines, includingdoxycycline and minocycline, are broad-spectrum antibiotics used to treat bacterial infections. They have amajor drug-drug interaction with calcium-containing antacidsand other minerals.
* Chelation Effect:Calcium binds to tetracycline, forminginsoluble complexesthat prevent the antibiotic from being absorbed in thegastrointestinal (GI) tract.
* Reduced Efficacy:Because the drug cannot be absorbed, the antibiotic's effectiveness is significantly reduced.
* Similar Interactions:Magnesium, iron, and aluminum (found in many antacids, dairy products, and multivitamins) also reduce tetracycline absorption.
* Take on an Empty Stomach(1 hour before or 2 hours after meals).
* Avoid Dairy, Antacids, and Multivitaminsfor at least2 hours before and aftertaking tetracycline.
* Drink with a Full Glass of Waterto prevent esophageal irritation.
* B. Decongestants that contain pseudoephedrine.# Incorrect. Pseudoephedrine does not interact with tetracycline.
* C. Antitussives that contain dextromethorphan.# Incorrect. Dextromethorphan does not affect tetracycline absorption.
* D. Analgesics that contain acetaminophen.# Incorrect. Acetaminophen does not bind to tetracycline or impact its absorption.
* Lexicomp Drug Interaction Database - Tetracycline and Calcium Interactions.
* FDA Drug Label for Tetracycline - Absorption and Drug Interaction Warnings.
* Mosby's Pharmacy Technician: Principles and Practice - Tetracycline Pharmacology.
* PTCB PTCE Exam Content Outline - Drug Interactions and Contraindications.
Why Should Tetracycline Not Be Taken with Calcium-Containing Antacids?Patient Counseling for Tetracycline Use:Why the Other Answer Choices Are Incorrectharmacy Technician References:
NEW QUESTION # 205
CORRECT TEXT
How many 30 mg KMNO4 (Potassium Permanganate) tablets are needed to make the following solution?
KMNO4 1:5000 600ml?
4 tablets
NEW QUESTION # 206
A prescription for acetaminophen with codeine oral solution is written for a quantity of IV oz. What volume, in mL, should be dispensed?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
"IV oz" uses Roman numerals: IV = 4, so the quantity is 4 ounces. The standard pharmacy conversion is 1 fl oz = 30 mL (approx. 29.57 mL rounded for dispensing).
Calculation:
4 oz × 30 mL/oz = 120 mL.
Therefore, the correct volume to dispense is 120 mL.
References (Pharmacy Technician documents/Study Guides):
* PTCB/ExCPT pharmaceutical calculations: Roman numerals and household-to-metric conversions (1 fl oz #
30 mL).
* USP dispensing conventions supporting rounding to practical volumes for liquid medications.
NEW QUESTION # 207
Of the following group names, which one would be used for a cough?
  • A. antitussives
  • B. anticholinerginics
  • C. antihelmintics
  • D. antihistamines
NEW QUESTION # 208
What volume, in tsp, of a 20 mEq/15 mL solution would deliver a dose of 40 mEq?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
To calculate:
* 20 mEq per 15 mL
* We need 40 mEq, so:
(40 mEq)÷(20 mEq)=2×15 mL=30 mL(40 ,         ext{mEq}) div (20 ,         ext{mEq}) = 2         imes 15,         ext{mL} =
30,         ext{mL}(40mEq)÷(20mEq)=2×15mL=30mL
Now, convert to teaspoons:
* 1 tsp = 5 mL
* 30 mL ÷ 5 = 6 tsp
This type of dosage conversion is covered in Pharmacy Technician Certification Exam Review, under Pharmaceutical Calculations.
Pharmacy Technician Certification Exam Review, Dosage Calculations Chapter Mosby's Pharmacy Technician: Principles and Practice, Conversion Charts Section
NEW QUESTION # 209
New PTCE Real Exam: https://www.prep4sures.top/PTCE-exam-dumps-torrent.html
What's more, part of that Prep4sures PTCE dumps now are free: https://drive.google.com/open?id=1mazLG8ap-pEh_biBVrGZYVKxksK_eYJr
