Excellent 1z0-1047-25 New Dumps Free - Win Your Oracle Certificate with Top Scor
104
Posted at 2/18/2026 06:31:49      View:92 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Oracle 1z0-1047-25 dumps are available on Google Drive shared by ValidTorrent: https://drive.google.com/open?id=1coGAfht1QHRK6NoWJXpqvZ5929WeRvQ9
Are you still hesitating about which kind of 1z0-1047-25 exam torrent should you choose to prepare for the exam in order to get the related certification at ease? Our 1z0-1047-25 Exam Torrent can help you get the related certification at ease and 1z0-1047-25 Practice Materials are compiled by our company for more than ten years. I am glad to introduce our study materials to you. Our company has already become a famous brand all over the world in this field since we have engaged in compiling the 1z0-1047-25 practice materials for more than ten years and have got a fruitful outcome. You are welcome to download it for free in this website before making your final decision.
Passing 1z0-1047-25 certification can help you realize your dreams. If you buy our product, we will provide you with the best 1z0-1047-25 study materials and it can help you obtain 1z0-1047-25 certification. Our 1z0-1047-25 exam braindump is of high quality and our service is perfect. With our proved data from our loyal customers that the pass rate of our 1z0-1047-25 Practice Engine is as high as 99% to 100%. Your success is insured with our excellent 1z0-1047-25 training questions.
1z0-1047-25 Study Materials Review & 1z0-1047-25 Test FreeValidTorrent is professional platform to establish for compiling 1z0-1047-25 exam materials for candidates, and we aim to help you to pass the examination as well as getting the related certification in a more efficient and easier way. Owing to the superior quality and reasonable price of our 1z0-1047-25 Exam Materials, our 1z0-1047-25 exam torrents are not only superior in price than other makers in the international field, but also are distinctly superior in many respects.
Oracle Absence Management Cloud 2025 Implementation Professional Sample Questions (Q86-Q91):NEW QUESTION # 86
You want to modify workers' payments when a certification requirement has passed its due date. Which three rules should you select when you create the absence certification?
  • A. Recalculate
  • B. Revise
  • C. Adjust
  • D. Retract
  • E. Override
  • F. Stop Payments
Answer: A,D,E
NEW QUESTION # 87
You created an Incremental accrual absence plan with a Monthly Accrual processing period, a flat accrual rate of 2.5 hours, and a vesting period of 1 month.
How much accrual will be available to an employee after two months of the employee's enrollment into the accrual plan?
  • A. 2.5
  • B. 0
  • C. 1
  • D. 7.S
  • E. 2
Answer: E
NEW QUESTION # 88
The HR Director of a global organization, whose workforce is enrolled in numerous Absence Plans according to country, wants all related absences to be set up against a single Absence Type, for example, all sickness in a single "Sickness" Absence Type.
What would be your response?
  • A. Everyone should be moved to the same Absence Plan for it to be possible.
  • B. It is not possible because Absence Types have to be split by legislation, the same way Absence Plans are, due to the varying rules for each country.
  • C. Absence Types have to be split according to the number of Absence Plans, and each Absence Plan has to have its own Absence Type configuration.
NEW QUESTION # 89
A customer requires their administrator to enter paternity leave for their employees. Paternity leave can only be entered if an employee hasn't taken an absence called special absence in the previous 30 days of the paternity leave start date.
The customer requires also that this paternity leave absence is only available for the employees who have one year of seniority in the company. Employees should notify of the absence at least 30 days in advance of the start date of the absence; otherwise, the absence is not considered timely.
Which configuration should you use to implement these requirements?
  • A. 1. Create an absence type using a childbirth or placement pattern.
    2. Enable administrative updates.
    3. Create a validation formula with the logic to evaluate if the "special absence" was taken 30 days before this absence and add it to the absence type.
    4. Create an eligibility profile with the criteria of employees with 1 or more seniority in the company and add it to the absence type.
    5. Configure the late notification evaluation rule according to the requirement of at least 30 days in advance of the start date.
  • B. 1. Create an absence type using a childbirth or placement pattern.
    3. Create an eligibility profile with the criteria of employees with 1 or more seniority in the company and add it to the absence type.
    4. Create an absence certification of type Documentation that prevents absence entry if linked absence of type Special absence exists in the previous 30 days.
  • C. 1. Create an absence type using a childbirth or placement pattern.
  • D. 1. Create an absence type using a childbirth or placement pattern.
    5. Select the qualified entitlements check box and set the evaluation rule to check for 30 days from the start date.
NEW QUESTION # 90
Your Absence Manager is unsure why after running the "Absence and Payroll Info for Reconciliation" extract, there are zeros in the "Absence Plan Unit Difference" column.
How do you explain this?
  • A. The zeros represent successful reconciliation.
  • B. The extract failed
  • C. The relevant absence data was not present.
  • D. The data was partially reconciled.
NEW QUESTION # 91
Today is the right time to learn new and in demands skills. You can do this easily, just get registered in certification exam and start preparation with Oracle Absence Management Cloud 2025 Implementation Professional 1z0-1047-25 exam dumps. The Oracle Absence Management Cloud 2025 Implementation Professional 1z0-1047-25 pdf questions and practice test are ready for download. Just pay the affordable 1z0-1047-25 authentic dumps charges and click on the download button. Get the 1z0-1047-25 latest dumps and start preparing today.
1z0-1047-25 Study Materials Review: https://www.validtorrent.com/1z0-1047-25-valid-exam-torrent.html
Oracle 1z0-1047-25 New Dumps Free We will offer the update service for one year, Oracle 1z0-1047-25 New Dumps Free All customers have the right to choose the most suitable version according to their need, Customers' needs are our first consideration, we certainly know how difficult to prepare the 1z0-1047-25 Study Materials Review - Oracle Absence Management Cloud 2025 Implementation Professional and how time-costing to achieve the all potential examination site, In this way, choosing our 1z0-1047-25 test prep is able to bring you more benefits than that of all other exam files.
A byproduct is the intention that all VMs are able to communicate with each 1z0-1047-25 other quickly and efficiently, is a Cloud Solution Manager at Onx.com, specializing in the architecture and delivery of cloud-based services.
100% Free 1z0-1047-25 – 100% Free New Dumps Free | High Hit-Rate Oracle Absence Management Cloud 2025 Implementation Professional Study Materials ReviewWe will offer the update service for one year, All customers 1z0-1047-25 Test Free have the right to choose the most suitable version according to their need, Customers' needsare our first consideration, we certainly know how difficult Test 1z0-1047-25 Vce Free to prepare the Oracle Absence Management Cloud 2025 Implementation Professional and how time-costing to achieve the all potential examination site.
In this way, choosing our 1z0-1047-25 Test Prep is able to bring you more benefits than that of all other exam files, 1z0-1047-25 sure exam dumps empower the candidates to master their desired technologies for their own 1z0-1047-25 exam test.
What's more, part of that ValidTorrent 1z0-1047-25 dumps now are free: https://drive.google.com/open?id=1coGAfht1QHRK6NoWJXpqvZ5929WeRvQ9
