[General] High Pass Rate PDII-JPN Study Materials Tool Helps You Get the PDII-JPN Certific
104
【General】 High Pass Rate PDII-JPN Study Materials Tool Helps You Get the PDII-JPN Certific
Posted at 2/18/2026 06:39:12      View:129 | Replies:0        Print      Only Author   [Copy Link] 1#
There are many businesses in the market who boast about the high quality of their test materials. However, we can pat on the chest confidently to say that the passing rate of students who use our PDII-JPN test torrent is between 98% and 99%. If you unfortunately fail to pass the PDII-JPN exam, upload your exam certificate and screenshots of the failed scores, and we will immediately give a full refund. Using our PDII-JPN Test Questions will not bring you any loss. In addition, the refund process is very simple and will not bring you any trouble. If you have any questions, you can always contact us online or email us. We will reply as soon as possible.
Prep4cram also offers Salesforce PDII-JPN desktop practice exam software which is accessible without any internet connection after the verification of the required license. This software is very beneficial for all those applicants who want to prepare in a scenario which is similar to the  real examination.
PDII-JPN Pdf Braindumps & Reliable PDII-JPN Test CramAs the famous saying goes, time is life. Time is so important to everyone because we have to use our limited time to do many things. Especially for candidates to take the PDII-JPN exam, time is very precious. They must grasp every minute and every second to prepare for it. From the point of view of all the candidates, our PDII-JPN Study Materials give full consideration to this problem. We can send you a link within 5 to 10 minutes after your payment.
Salesforce  Sample Questions (Q34-Q39):NEW QUESTION # 34
開発者は、コンポーネントがレコードページ上でデスクトップサイズのフォームファクタに対してのみ表示されるように、Lightning Web コンポーネントの設定ファイルにコードを追加する必要があります。
この要件を満たすために、開発者はコンポーネントのレコード ページ ターゲット設定に何を追加する必要がありますか?
  • A.
  • B.
  • C.
  • D.
When you want a Lightning web component to only render for a specific form factor, you can use the <targets
> tag within the component's .xml configuration file. To specify that the component should only appear on a desktop, you use the <targetConfig> tag with the targets="lightning__RecordPage" attribute and nest a < supportedFormFactors> tag inside it. Within this tag, you include a <supportedFormFactor> tag with the attribute type="Large".
Option B is the correct markup to ensure that the component only appears for the desktop form factor on a record page.
Lightning Web Components Developer Guide - Configure Components for Lightning Experience and the Salesforce Mobile App
NEW QUESTION # 35
Visualforce ページには業界選択リストが含まれており、業界項目に一致する値を持つ取引先の表が表示されます。
ユーザーが業界選択リストの値を変更すると、アカウントの表が自動的に更新され、選択した業界に関連付けられたアカウントが表示されます。これを実装する最適な方法は何ですか?
  • A. <apax:selectList> 内に <apex:actionFunction> を追加します。
  • B. <apex:selectOptions> 内に <apex:actionsupport> を追加します。
  • C. <apex:selectList> 内に <apex:actionsupport> を追加します。
  • D. <apex:selectOptions> 内に <apex:actionFunction> を追加します。
The <apex:actionSupport> component is designed to be used with another component to provide AJAX support. When the value of the industry select list changes, the <apex:actionSupport> can trigger an AJAX request to the server, causing the page to rerender the table of Accounts with the matching industry. This process occurs without a full page refresh, providing a smoother user experience.
Visualforce Developer Guide
NEW QUESTION # 36
2 Visualforce 検索ページで使用される RemoteAction を定義する以下の Apex クラスについて考えてみましょう。
リモート アクションが正しいアカウントを返したことを示すコード スニペットはどれですか?
  • A.
  • B.
  • C.
  • D.
The correct code snippet to assert that the remote action returned the correct Account is option C. This is because the getAccount method is a global static method within the MyRemoter class and can be directly called without needing to instantiate an object of the class.
References: Apex Developer Guide - Exposing Apex Methods to JavaScript
NEW QUESTION # 37
Universal Containers は、夜間の Apex バッチジョブの実行時に未処理の例外が発生した場合に、外部システムに通知したいと考えています。
この要件を満たす適切なパブリッシュ/サブスクライブ ロジックは何ですか?
  • A. addError{) で起動されるカスタム プラットフォーム イベントを外部システムにサブスクライブさせます。
  • B. 外部システムに標準をサブスクライブさせます
    Eventbus.publish(1.
  • C. 外部システムに、起動される標準プラットフォーム イベントをサブスクライブさせます。
  • D. 外部システムにカスタムをサブスクライブさせます。
    EventBus.publish(1,
NEW QUESTION # 38
ビジネス ルールでは、新しいアカウントを作成するときに常に連絡先を作成する必要があります。連絡先の作成に失敗した場合にアカウントが作成されないようにするためのカスタム画面を開発するときに使用できるものは何ですか?
  • A. allOrNone を False に設定して Database.Insert メソッドを使用します。
  • B. setSavePoint() と rollback() を try/catch ブロックで使用します。
  • C. 連絡先の挿入に失敗した場合は、Database.Delete メソッドを使用します。
  • D. 連絡先の検証ルールを無効にし、トリガーで既定値を設定します。
NEW QUESTION # 39
The sources and content of our PDII-JPN practice dumps are all based on the real PDII-JPN exam. And they are the masterpieces of processional expertise these area with reasonable prices. Besides, they are high efficient for passing rate is between 98 to 100 percent, so they can help you save time and cut down additional time to focus on the PDII-JPN Actual Exam review only. We understand your drive of the certificate, so you have a focus already and that is a good start.
PDII-JPN Pdf Braindumps: https://www.prep4cram.com/PDII-JPN_exam-questions.html
That is why our PDII-JPN training prep is the best seller on the market, Perhaps you will need our PDII-JPN learning materials, Salesforce Reliable PDII-JPN Real Test During one's formative process, we all experienced some unforgettable exams in which we gain desirable outcomes, Salesforce Reliable PDII-JPN Real Test Also most of them came from the largest companies such as Microsoft, Cisco, SAP, Oracle and they are familiar with those certifications examinations, What's more, you can do marks on the PDII-JPN exam study reviews, which will be conductive to your memory.
Most hotspots don't provide tech support, so Reliable PDII-JPN Real Test make it easy on yourself, In the initiation phase of training, trainees learn howto assess the project, define the high-level PDII-JPN scope of the project, analize the stakeholders, identify the risks and constraints.
Reliable PDII-JPN Real Test | Professional PDII-JPN Pdf Braindumps:  100% PassThat is why our PDII-JPN training prep is the best seller on the market, Perhaps you will need our PDII-JPN learning materials, During one's formative process, Reliable PDII-JPN Real Test we all experienced some unforgettable exams in which we gain desirable outcomes.
Also most of them came from the largest companies PDII-JPN Braindump Free such as Microsoft, Cisco, SAP, Oracle and they are familiar with those certifications examinations, What's more, you can do marks on the PDII-JPN exam study reviews, which will be conductive to your memory.
