1z0-1054-25 Test Fee, 1z0-1054-25 Online Bootcamps
Posted at 2/18/2026 07:20:58
BTW, DOWNLOAD part of Pass4sures 1z0-1054-25 dumps from Cloud Storage: https://drive.google.com/open?id=1RKhV9xWxK3JqGos6VKn0-QFuCsXAE_am
As is known to us, the quality is an essential standard for a lot of people consuming movements, and the high quality of the 1z0-1054-25 guide questions is always reflected in the efficiency. We are glad to tell you that the 1z0-1054-25 actual dumps from our company have a high quality and efficiency. If you decide to choose 1z0-1054-25 Actual Dumps as you first study tool, it will be very possible for you to pass the exam successfully, and then you will get the related certification in a short time.
Oracle 1z0-1054-25 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Implementing Enterprise and Financial Reporting Structures: This section of the exam measures skills of Oracle ERP Implementation Consultants and covers the core components used in setting up enterprise structures and reporting configurations. It assesses knowledge in defining legal entities, jurisdictions, and geographies, as well as the design and configuration of Chart of Accounts. Candidates must also demonstrate how to set up and secure chart structures and manage reporting calendars and currencies.
| | Topic 2 | - Configuring Financial Reports: This portion of the exam measures the abilities of Financial Reporting Analysts and includes creating and managing a range of reports using tools like the Financial Reporting Center, Web Studio, OTBI, Smart View, and Dashboards. Candidates must know how to define account groups, set up infolets, and build custom analytics tailored to user needs.
| | Topic 3 | - Implementing Ledgers: This part evaluates the competencies of Financial Systems Analysts and focuses on defining and configuring ledgers within Oracle Financials. Candidates are expected to manage ledger-level security and understand how to utilize General Ledger Balances Cubes for better financial visibility and reporting accuracy.
| | Topic 4 | - Performing Period Close: Designed for Oracle Financial Application Managers, this section evaluates expertise in executing and managing the period close lifecycle. Topics include reconciliations, revaluation, translation, and consolidation. Candidates are required to configure the Period Close Monitor and associated setups like revaluation, allocations, and chart mappings for financial consolidation.
| | Topic 5 | - Using AI
- ML
- Mobile and Other Automation Features: This final section assesses Finance Transformation Architects and focuses on the business value derived from incorporating AI, machine learning, and mobile capabilities in Oracle Financials. Candidates are expected to understand automation use cases and the practical benefits these modern features offer in streamlining financial operations.
| | Topic 6 | - Processing Intercompany: This domain assesses the skills of Finance Integration Specialists in configuring and managing intercompany transactions. Candidates must understand balancing rules, clearing configurations, and transaction processing, as well as how to maintain intercompany reconciliations in multi-entity structures.
New 1z0-1054-25 Test Fee | Reliable 1z0-1054-25 Online Bootcamps: Oracle Financials Cloud: General Ledger 2025 Implementation Professional 100% PassPass4sures is a trusted platform that has been helping Oracle Financials Cloud: General Ledger 2025 Implementation Professional 1z0-1054-25 candidates for many years. Over this long time period, countless candidates have passed their Oracle Financials Cloud: General Ledger 2025 Implementation Professional 1z0-1054-25 Exam and they all got help from Oracle Financials Cloud: General Ledger 2025 Implementation Professional practice questions and easily pass the final exam.
Oracle Financials Cloud: General Ledger 2025 Implementation Professional Sample Questions (Q115-Q120):NEW QUESTION # 115
You are required to changetoday's daily ratesfor convertingGBP to USD. What are three ways in which you can update existing daily rates?
- A. Update rates manually using the Currency Rates Manager, which can be accessed from the Functional Setup Manager or the General Ledger's Period Close work area.
- B. Use the spreadsheet loader from the Currency Rates Manager.
- C. Edit existing transactions and update the rates manually.
- D. Update rates manually using the Currency Rates Manager, which can be accessed only from the Functional Setup Manager.
- E. Import daily rates through the Daily Rates open interface table.
Answer: A,B,E
NEW QUESTION # 116
On a primary ledger in Use system options close section, the following field has been selected:
'Prevent General Ledger Period Close When Open Subledger Periods Exist'.
What three exceptions will prevent closing of the accounting period?
- A. Pending Transaction in General Ledger Interface
- B. No pending transaction in the General Ledger Interface table
- C. Intercompany Transactions are completed
- D. Pending Intercompany Transactions
Answer: A,C,D
NEW QUESTION # 117
You are using the Create Budgets in a Spreadsheet option to load your budget balances into the General Ledger balances cube. Your FYXX Budget is not appearing in the Budget Name list of values.
What are two reasons for this?
- A. Transfer Budget Balances to Budget Cubes has not been run.
- B. Publish Chart of Accounts Dimension Members and Hierarchies to the Balances Cube has not been run.
- C. A value for the budget scenario is not created.
- D. Budgeting is not enabled in the Ledger options.
- E. The Create Scenario Dimension Members program has not been run.
Answer: C,E
To use the Create Budgets in a Spreadsheet option, you need to have a budget scenario value and a scenario dimension member for your budget. A budget scenario value is a user-defined value that identifies a budget, such as FYXX Budget. A scenario dimension member is a member of the scenario dimension in the General Ledger balances cube that corresponds to a budget scenario value, such as FYXX_Budget. You can create budget scenario values and scenario dimension members using the Manage Budget Scenario Values task or the Create Scenario Dimension Members program. If you do not create these values and members, your budget will not appear in the Budget Name list of values in the spreadsheet. Therefore, the two reasons for your issue are:
* A value for the budget scenario is not created: You need to create a budget scenario value for your budget using the Manage Budget Scenario Values task. This task enables you to define and maintain budget scenario values and their attributes, such as description, start date, end date, and status. You can also specify whether the budget scenario value is enabled for budgeting and reporting. You need to enable the budget scenario value for budgeting to use it in the spreadsheet.
* The Create Scenario Dimension Members program has not been run: You need to run the Create Scenario Dimension Members program to create scenario dimension members for your budget scenario values. This program automatically creates scenario dimension members for all budget scenario values that are enabled for budgeting and do not have existing scenario dimension members. You can run this program manually or schedule it to run periodically. You need to run this program after you create or update budget scenario values to ensure that they are reflected in the scenario dimension.
NEW QUESTION # 118
Your customer has a number of Chart of Account Mapping Rules for their Primary and Secondary ledgers.
You decide to use the FBDI template to load the rules.
Which two statements are true when using this method of entry? (Choose two.)
- A. It supports external integration using REST services.
- B. You can download the template only from the Manage Chart of Accounts Mappings page.
- C. You can create, update, and delete account rules for a chart of accounts mapping.
- D. You can create, update, and delete segment rules for a chart of accounts mapping.
According to Oracle documentation3, when using FBDI template to load Chart of Account Mapping Rules for their Primary and Secondary ledgers, you can create, update, and delete account rules for a chart of accounts mapping, and you can create, update, and delete segment rules for a chart of accounts mapping. FBDI enables you to import chart of accounts mapping rules from a spreadsheet template into General Ledger. You can use FBDI to manage both account rules and segment rules for a chart of accounts mapping. Therefore, options C and D are correct. Option A is incorrect because you can download the template from other pages besides the Manage Chart of Accounts Mappings page. Option B is incorrect because FBDI does not support external integration using REST services.
NEW QUESTION # 119
When creating your financial statements, you want a chart such as a bar graph to be included in the report output. Which two reporting tools allow you to achieve this?
- A. Financial Reporting Studio
- B. Financial Statement Generator
- C. Account Inspector
- D. Smart View
Smart View and Financial Reporting Studio are two reporting tools that allow you to create and include charts such as bar graphs in your financial statements. Smart View is a multidimensional pivot analysis tool that enables you to interactively analyze your balances and define reports using a familiar spreadsheet environment. You can also insert charts and graphs to visualize your data. Financial Reporting Studio is a tool that lets you design and format financial reports using data from the Oracle General Ledger balances cube.
You can also add charts and graphs to enhance your reports and display data trends. References:
* Overview of Financial Reporting Center, Oracle Cloud Applications Financials 23B, https://docs.oracle.
com/en/cloud/saas/financials/23b/faiah/overview-of-financial-reporting-center.html
* Using Smart View with Oracle Financials Cloud, Oracle Cloud Applications Financials 23B,
https://docs.oracle.com/en/cloud ... -oracle-financials- cloud.html
* Creating Financial Reports, Oracle Cloud Applications Financials 23B, https://docs.oracle.com/en/cloud
/saas/financials/23b/farug/creating-financial-reports.html
NEW QUESTION # 120
We promise you that if you fail to pass the exam in your first attempt after using 1z0-1054-25 training materials of us, we will give you full refund. And we are also pass guarantee and money back guarantee. In addition, 1z0-1054-25 exam dumps are edited by skilled experts, and they are quite familiar with the exam center, therefore, if you choose us, you can know the latest information for the exam timely. We provide you with free update for 365 days for 1z0-1054-25 Exam Training materials and the update version will be sent to your email address automatically.
1z0-1054-25 Online Bootcamps: https://www.pass4sures.top/Oracle-Financials-Cloud/1z0-1054-25-testking-braindumps.html
- Practice 1z0-1054-25 Exam 🛸 Exam 1z0-1054-25 Cost 👣 New 1z0-1054-25 Test Topics 🚂 Search on ▛ [url]www.troytecdumps.com ▟ for ⏩ 1z0-1054-25 ⏪ to obtain exam materials for free download 🐲Exam 1z0-1054-25 Overviews[/url]
- New 1z0-1054-25 Dumps Sheet 🥙 Exam 1z0-1054-25 Cost 💜 1z0-1054-25 Exam Preparation 🏌 Go to website ➤ [url]www.pdfvce.com ⮘ open and search for ▛ 1z0-1054-25 ▟ to download for free 🪁Exam 1z0-1054-25 Cost[/url]
- New 1z0-1054-25 Test Topics 🌽 1z0-1054-25 Reliable Cram Materials 🚆 1z0-1054-25 Valid Test Tutorial 🤖 ▷ [url]www.prepawaypdf.com ◁ is best website to obtain ⇛ 1z0-1054-25 ⇚ for free download 🚬
ractice 1z0-1054-25 Exam[/url] - 1z0-1054-25 Latest Dumps Free 🗾 Valid 1z0-1054-25 Test Vce 🌀 1z0-1054-25 Valid Test Practice 🎷 Simply search for ✔ 1z0-1054-25 ️✔️ for free download on ⮆ [url]www.pdfvce.com ⮄ 🧨Latest 1z0-1054-25 Test Format[/url]
- New 1z0-1054-25 Exam Papers 👧 Visual 1z0-1054-25 Cert Test 🐒 New 1z0-1054-25 Test Topics 👐 Open website ☀ [url]www.practicevce.com ️☀️ and search for 「 1z0-1054-25 」 for free download 🥼1z0-1054-25 Latest Dumps Free[/url]
- Get Efficient 1z0-1054-25 Test Fee and Pass Exam in First Attempt 💏 Enter ( [url]www.pdfvce.com ) and search for ✔ 1z0-1054-25 ️✔️ to download for free 🐆New 1z0-1054-25 Exam Papers[/url]
- Ace Oracle 1z0-1054-25 Exam Instantly with This Tried-and-Tested Method 💇 Open ⮆ [url]www.pass4test.com ⮄ enter ⏩ 1z0-1054-25 ⏪ and obtain a free download 🔩1z0-1054-25 Upgrade Dumps[/url]
- 100% Pass Quiz 2026 Oracle Newest 1z0-1054-25 Test Fee 🎂 Easily obtain ➤ 1z0-1054-25 ⮘ for free download through ➽ [url]www.pdfvce.com 🢪 🧅
ractice 1z0-1054-25 Exam[/url] - 1z0-1054-25 Exam Test Fee - High Pass-Rate 1z0-1054-25 Online Bootcamps Pass Success 🚄 Easily obtain free download of 【 1z0-1054-25 】 by searching on ▛ [url]www.verifieddumps.com ▟ 🍤New 1z0-1054-25 Test Topics[/url]
- 1z0-1054-25 Exam Preparation 🏮 New 1z0-1054-25 Test Topics 🌉 1z0-1054-25 Valid Test Tutorial 🍑 Search for ➡ 1z0-1054-25 ️⬅️ and download it for free immediately on “ [url]www.pdfvce.com ” ⚫New 1z0-1054-25 Dumps Sheet[/url]
- 1z0-1054-25 Exam Test Fee - High Pass-Rate 1z0-1054-25 Online Bootcamps Pass Success 😋 Go to website ➽ [url]www.examdiscuss.com 🢪 open and search for [ 1z0-1054-25 ] to download for free 💏New 1z0-1054-25 Test Topics[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BONUS!!! Download part of Pass4sures 1z0-1054-25 dumps for free: https://drive.google.com/open?id=1RKhV9xWxK3JqGos6VKn0-QFuCsXAE_am
