[General] Latest updated 1z0-076 Latest Exam Guide¨CThe Best Valid Study Materials for your
77
¡¾General¡¿ Latest updated 1z0-076 Latest Exam Guide¨CThe Best Valid Study Materials for your
Posted at 2/18/2026 12:33:56      View£º130 | Replies£º0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ExamBoosts 1z0-076 dumps for free: https://drive.google.com/open?id=1KdRMaJO75XMsyAqIKN-FZiMZrJyFhOGU
If you take a little snack, you will find that young people are now different. They made higher demands on themselves. This is a change in one's own mentality and it is also a requirement of the times! Whether you want it or not, you must start working hard! And our 1z0-076 exam materials may slightly reduce your stress. With our 1z0-076 study braidumps for 20 to 30 hours, we can proudly claim that you can pass the exam easily just as a piece of cake. And as long as you try our 1z0-076 practice questions, you will love it!
You must believe that you have extraordinary ability to work and have an international certificate to prove your inner strength. You will definitely be the best one among your colleagues. The help you provide with our 1z0-076 Learning Materials is definitely what you really need. And if you study with our 1z0-076 exam braindumps, you will know your dream clearly. Join 1z0-076 study guide and you will be the best person!
Free PDF Accurate Oracle - 1z0-076 Latest Exam GuideOur 1z0-076 guide torrent is compiled by experts and approved by the experienced professionals. They are revised and updated according to the change of the syllabus and the latest development situation in the theory and practice. The language is easy to be understood to make any learners have no learning obstacles and our 1z0-076 study questions are suitable for any learners. The software boosts varied self-learning and self-assessment functions to check the results of the learning. The software can help the learners find the weak links and deal with them. Our 1z0-076 Exam Torrent boosts timing function and the function to stimulate the exam. Our product sets the timer to stimulate the exam to adjust the speed and keep alert. Our 1z0-076 study questions have simplified the complicated notions and add the instances, the stimulation and the diagrams to explain any hard-to-explain contents.
Oracle Database 19c: Data Guard Administration Sample Questions (Q96-Q101):NEW QUESTION # 96
Which three are prerequisites for enabling Fast-Start Failover?
  • A. The Data Guard environment must be managed by the Data Guard Broker.
  • B. Flashback Database must be enabled on both the primary database and the Fast-Start Failover target standby database.
  • C. The maximum protection mode can be used, but with two or more standby databases.
  • D. The configuration must be operating in either Maximum Performance or Maximum Protection mode.
  • E. You can specify only one standby database as the fast-start failover target.
  • F. Flashback Database must be enabled only on the Fast-Start Failover target standby database.
Answer: A,B,E
To enable Fast-Start Failover in a Data Guard environment, the following conditions must be in place:
The Data Guard environment must be managed by the Data Guard Broker (A): The Broker simplifies management tasks and is required to enable fast-start failover, which is an automatic failover mechanism provided by Data Guard.
You can specify only one standby database as the fast-start failover target (C): Fast-start failover is designed to fail over to a single, predetermined standby database, known as the target standby.
Flashback Database must be enabled on both the primary database and the Fast-Start Failover target standby database (F): Flashback Database provides a quick way to revert a database to a point in time before a logical or physical corruption or error occurred. It must be enabled on both the primary and target standby databases to allow for the possibility of reinstating the old primary as a standby after a failover.
Oracle Data Guard Concepts and Administration Guide
Oracle Database High Availability Overview
NEW QUESTION # 97
Which THREE statements are true........ open in real time query mode, which becomes a new.
  • A. User sessions and Current Buffers are maintained by default.
  • B. User sessions can be retained.
  • C. Sessions that are using database links
  • D. All current buffers can be retained.
  • E. Sessions that have long running queries can be retained.
  • F. All sessions are disconnected and all
Answer: B,D,F
When a physical standby database is opened in real-time query mode, which may be referred to as real-time apply when using Active Data Guard, certain operations can disrupt ongoing sessions. However, with features like Application Continuity and the proper configuration of initialization parameters such as STANDBY_DB_PRESERVE_STATES, user sessions and current buffers may be preserved during role transitions such as a switchover or failover. Specifically, the STANDBY_DB_PRESERVE_STATES parameter can be set to preserve none, all, or only user sessions during such transitions. This ensures that in-flight transactions are not lost and that users do not experience disruptions during the role transitions of a physical standby database.
References
* Oracle Data Guard Concepts and Administration
* Oracle Database Licensing Information User Manual
* Oracle Data Guard Broker User Manual
NEW QUESTION # 98
Examine the Data Guard configuration: DGMGRL> show configuration;
Configuration - Animals
Protection Mode: MaxPerformance
Databases:
dogs- Primary database
sheep - Physical standby database
cats- Snapshot standby database
Fast-Start Failover: DISABLED
Configuration Status: SUCCESS
You receive an error while attempting to raise the protection mode to Maximum Protection:
DGMGRL> edit configuration set protection mode as maxprotection;
Error: ORA-16627: operation disallowed since no standby databases would remain to support protection mode Failed.
What can you conclude based on this error?
  • A. The redo transport mode is set to async for the standby database Sheep.
  • B. The redo transport mode is set to async for both standby databases.
  • C. Cats is a snapshot standby database.
  • D. The redo transport mode is set to asyn: for the standby database Cats.
Comprehensive Detailed Explanation:
In an Oracle Data Guard environment, the Maximum Protection mode requires that all redo data be transmitted synchronously to at least one standby database, ensuring no data loss even in the event of a primary database failure. However, a snapshot standby database, by its nature, allows read-write access and is temporarily disconnected from the redo stream, which makes it unable to participate in the synchronous redo transport required by Maximum Protection mode. The presence of a snapshot standby database in the Data Guard configuration thus prevents the activation of Maximum Protection mode, as it cannot guarantee zero data loss without a standby database capable of receiving redo data synchronously.
Oracle Data Guard documentation clearly outlines the requirements and restrictions of different protection modes, including the necessity for standby databases to participate in synchronous redo transport to enable Maximum Protection mode. The inability of snapshot standby databases to fulfill this requirement is a key consideration when planning Data Guard configurations and protection levels.
The error indicates that switching the protection mode to Maximum Protection is not possible due to the presence of a snapshot standby database in the Data Guard configuration, which cannot participate in synchronous redo transport required by the Maximum Protection mode. Therefore, the correct answer is:
NEW QUESTION # 99
Examine the fast-start failover configuration:
  • A. You must disable fast-start failover first to change the fast-start failover target to East sales.
  • B. The observer is running.
  • C. A failover may occur if the observer has lost connectivity to the primary database, even if the Fast-Start Failover target standby database has a good connection to the primary database
  • D. If South_Sales develops a problem and cannot be the target of a failover, the broker automatically changes the fast-start failover target to one of the other candidate targets.
  • E. The observer will initiate a failover when the primary database is unable to produce local archived redo log files.
Answer: B,C,E
NEW QUESTION # 100
Which THREE statements are TRUE about Global Sequences when connected to a physical standby database with Real-Time Query enabled?
  • A. They must have the NOORDEK and CACHE options set.
  • B. Their usage will always have a performance impact on the primary database.
  • C. If the CACHE option is set then the size of the cache must be at least 100.
  • D. Their creation requires that a LOG archive_dest_n parameter be defined in the standby that points back to the primary.
  • E. Their usage may have a performance impact on the physical standby database if the CACHE size is too small.
Answer: A,B,E
Global Sequences are Oracle sequences that generate unique values across multiple instances in an Oracle RAC or a Data Guard configuration. Regarding their behavior and performance when connected to a physical standby database with Real-Time Query enabled:
* A: The usage of Global Sequences can indeed have a performance impact on the primary database due to the need to generate unique values that are consistent across both primary and standby databases.
* D: The performance impact on the physical standby database may occur if the CACHE size is too small. This is because the standby database will frequently have to access the primary database to replenish the cache, which can increase the load and potentially lead to performance degradation.
* E: Global Sequences should have the NOORDER and CACHE options set. The NOORDER option ensures that sequence numbers are provided without guaranteeing sequence order, thus improving scalability and performance. The CACHE option is used to specify how many sequence values will be held in memory for faster access.
Option B is incorrect as the LOG_ARCHIVE_DEST_n parameter's definition for standbys pointing back to the primary does not directly pertain to the creation of sequences.
Option C is incorrect because there is no requirement that the size of the cache for a sequence must be at least
100. The CACHE size can be set to a different number based on specific use cases or performance considerations.
References: Oracle's documentation on sequences and their behavior in a Data Guard environment provides insights into the performance considerations and best practices for using sequences, particularly in a Real-Time Query context.
NEW QUESTION # 101
Nowadays the competition in the job market is fiercer than any time in the past. If you want to find a good job£¬you must own good competences and skillful major knowledge. So owning the 1z0-076 certification is necessary for you because we will provide the best study materials to you. Our 1z0-076 Exam Torrent is of high quality and efficient, and it can help you pass the test successfully.
1z0-076 Valid Study Materials: https://www.examboosts.com/Oracle/1z0-076-practice-exam-dumps.html
Our 1z0-076 exam torrent is finalized after being approved by industry experts and 1z0-076 Practice Materials are tested by professionals with a high pass rate as 99%, Oracle 1z0-076 Latest Exam Guide The product is easy to use and very simple to understand ensuring it is student-oriented, Oracle 1z0-076 Latest Exam Guide So once people make allusions to effective exam materials, we naturally come into their mind, They find our 1z0-076 test torrent and prepare for exams, then they pass exam with a good passing score.
Without the magnet, your BlackBerry doesn't know when it is in its holster, Quick Style Sheet Primer, Our 1z0-076 Exam Torrent is finalized after being approved by industry experts and 1z0-076 Practice Materials are tested by professionals with a high pass rate as 99%.
Pass Guaranteed 1z0-076 - Reliable Oracle Database 19c: Data Guard Administration Latest Exam GuideThe product is easy to use and very simple to understand ensuring 1z0-076 it is student-oriented, So once people make allusions to effective exam materials, we naturally come into their mind.
They find our 1z0-076 test torrent and prepare for exams, then they pass exam with a good passing score, You need efficiency and exam skills as well.
P.S. Free 2026 Oracle 1z0-076 dumps are available on Google Drive shared by ExamBoosts: https://drive.google.com/open?id=1KdRMaJO75XMsyAqIKN-FZiMZrJyFhOGU
