[General] Reliable Plat-Arch-204 Test Voucher, Plat-Arch-204 Reliable Guide Files
【General】 Reliable Plat-Arch-204 Test Voucher, Plat-Arch-204 Reliable Guide Files
Posted at 2/18/2026 16:18:21      View:85 | Replies:1        Print      Only Author   [Copy Link] 1#
All the real Plat-Arch-204 questions are included in the Salesforce Certified Platform Integration Architect (Plat-Arch-204) PDF Dumps files. This file is compatible with smart devices. The Salesforce PDF Dumps files are portable and printable, allowing candidates to study and prepare for the Plat-Arch-204 exam from anywhere, even on smartphones, laptops, and tablets. Moreover, Braindumpsqa regularly updates its Salesforce Certified Platform Integration Architect (Plat-Arch-204) PDF questions format to keep up with the changes in the Salesforce Certified Platform Integration Architect (Plat-Arch-204) exam content, ensuring that its Salesforce Certified Platform Integration Architect (Plat-Arch-204) exam questions are up-to-date and relevant.
With the principles of customers first and service first, we will offer you the most considerate service. Free update for 365 days, and if you do have some questions about the Plat-Arch-204 exam braindumps , you can ask the live chat service stuff for help or you can contact us by email, we will answer your questions immediately, and if you have any good suggestion of the Plat-Arch-204 Exam Braindumps, we will be glad to accept. The Plat-Arch-204 exam dumps is professional and helpful, it will benefit you a lot.
Plat-Arch-204 Reliable Guide Files | Plat-Arch-204 New Dumps EbookNowadays passing the test Plat-Arch-204 certification is extremely significant for you and can bring a lot of benefits to you. Passing the test Plat-Arch-204 certification does not only prove that you are competent in some area but also can help you enter in the big company and double your wage. Buying our Plat-Arch-204 Study Materials can help you pass the test easily and successfully. We provide the study materials which are easy to be mastered, professional expert team and first-rate service to make you get an easy and efficient learning and preparation for the Plat-Arch-204 test.
Salesforce Certified Platform Integration Architect Sample Questions (Q85-Q90):NEW QUESTION # 85
The goals for implementing Salesforce include a 360-degree view, leveraging CRM for marketing, sales, and service, and reusing enterprise quoting/order management. Which three systems from the current landscape can be retired?
  • A. Email Marketing, Sales Activity, and Case Management
  • B. Order Management, Case Management, and Email Marketing
  • C. Sales Activity, Order Management, and Case Management
When implementing Salesforce to achieve a 360-degree view of the customer, the platform replaces legacy "siloed" applications that perform core CRM functions. Based on the business goals provided, Salesforce will be the master for Marketing, Sales, and Service.
The systems to be retired are those whose functionality is natively subsumed by Salesforce:
Email Marketing: Replaced by Salesforce Marketing Cloud or native marketing features.
Sales Activity: Replaced by Sales Cloud, which masters lead management, opportunity tracking, and activity logging.
Case Management: Replaced by Service Cloud, which provides the tools for customer support agents to resolve inquiries.
Order Management and Quoting are specifically noted as "Enterprise capabilities" that the business wants to reuse. This means these systems will stay in the landscape and be integrated with Salesforce, rather than being retired. Therefore, any option containing "Order Management" (A and C) is incorrect. Retiring the marketing, sales activity, and service systems allows the organization to consolidate its customer data into a single platform, fulfilling the primary goal of the Salesforce transformation.
NEW QUESTION # 86
Northern Trail Outfitters needs to make synchronous callouts to "available-to-promise" services to query product availability and reserve inventory during the customer checkout process. What should an integration architect consider when building a scalable integration solution?
  • A. The maximum query cursors open per user on the service
  • B. The number of batch jobs that can run concurrently
  • C. How many concurrent service calls are being placed
NEW QUESTION # 87
Northern Trail Outfitters needs a low-code, near real-time REST integration to an ERP when an Order is created. They have limited development resources. Which option should fulfill the use case requirements?
  • A. Implement a Workflow Rule with Outbound Messaging to send SOAP messages to the designated endpoint.
  • B. Use Lightning Flow to create a platform event, selecting the record type as the platform event name on insert of record.
  • C. Implement Change Data Capture on the Order object and leverage the replay ID in the middleware solution.
For a team with limited development resources and a low-code requirement, Lightning Flow (Flow Builder) is the primary declarative engine for modern integrations.
In this scenario, creating a Platform Event via a record-triggered flow provides a highly scalable, near real-time "Fire-and-Forget" signal to the middleware. This is considered low-code because it can be built entirely using point-and-click tools within Salesforce. Once the Order is created, the flow publishes the event to the bus. The middleware, acting as a subscriber, receives the event and orchestrates the REST call to the ERP.
Option C (Outbound Messaging) is also a low-code tool, but it natively sends messages in SOAP format. Since the ERP requires a REST endpoint, using Outbound Messaging would necessitate additional transformation logic in the middleware, making it a less efficient architectural choice than using a Flow to trigger an event or an External Service. Option B (Change Data Capture) is a powerful tool but often requires more advanced "pro-code" configuration on the subscriber/middleware side to handle Replay IDs and Bayeux protocols, which might exceed the "limited resources" constraint of the Salesforce team.
NEW QUESTION # 88
A developer is researching different implementations of the Streaming API (PushTopic, Change Data Capture, Generic Streaming, Platform Events) and asks for guidance. What should the architect consider when making the recommendation?
  • A. Change Data Capture can be published from Apex.
  • B. Change Data Capture does not have record access support.
  • C. PushTopic Events can define a custom payload.
When recommending a streaming solution, the architect must evaluate how each event type handles Record-Level Security (Sharing). Change Data Capture (CDC) is unique because it ignores sharing settings for record change events. This means all records of an enabled object generate change events, regardless of whether a particular user has access to those records in the Salesforce UI.
While CDC disregards record-level sharing, it does respect Field-Level Security (FLS). Delivered events only include the fields that the subscribing user is permitted to access. This is a critical consideration for integrations: if a system requires a "Master" view of all record changes across the enterprise (such as a data warehouse sync), CDC is the appropriate tool because it ensures no data is missed due to user-specific sharing constraints.
In contrast, PushTopic Events (Option A) provide a fixed payload based on a SOQL query and do not allow a "custom" payload in the same sense as Platform Events. Platform Events (Option C) are published from Apex or external APIs, but CDC is a platform-native feature that broadcasts automatically when a database record is modified, rather than being "published from Apex" by a developer.
NEW QUESTION # 89
Northern Trail Outfitters uses Salesforce to track leads and opportunities, and to capture order details. However, Salesforce isn't the system that holds or processes orders. After the order details are captured in Salesforce, an order must be created in the Remote system, which manages the order's lifecycle. The integration architect for the project is recommending a remote system that will subscribe to the platform event defined in Salesforce. Which integration pattern should be used for this business use case?
  • A. Fire and Forget
  • B. Remote Call-In
  • C. Request and Reply
In this scenario, Salesforce acts as the trigger for a business process that completes in an external system. The architect's recommendation for the remote system to subscribe to a platform event is the classic implementation of the Remote Process Invocation-Fire and Forget pattern.1 In a Fire and Forget pattern, Salesforce initiates a process by publishing a message (the event) to the event bus and then immediately continues its own2 processing without waiting for a functional response from the target system. The "Fire" part occurs when the order details are captured and the event is published; the "Forget" part refers to Salesforce handing off the responsibility of order creation to the remote system. This pattern is ideal for improving user experience and system performance, as it avoids blocking the user interface while waiting for potentially slow back-office systems to respond.
Option A (Request and Reply) is incorrect because that would require Salesforce to make a synchronous call and wait for the remote system to confirm the order was created before allowing the user to proceed. Option C (Remote Call-In) is the inverse of what is described; it would involve the remote system actively reaching into Salesforce to "pull" the data, whereas here Salesforce is "pushing" the notification via an event stream. By using Platform Events to facilitate this hand-off, Northern Trail Outfitters ensures a decoupled, scalable architecture where the remote system can process orders at its own pace while Salesforce remains responsive to sales users.
NEW QUESTION # 90
I know that all your considerations are in order to finally pass the Plat-Arch-204 exam. Our Plat-Arch-204 study materials have helped many people pass the exam and is about to help you. The 99% pass rate of our Plat-Arch-204 training prep is enough to make you feel at ease. Of course, we do everything we could do to ensure that you could think through it and that you also needed to pay a bit of your effort. And with our Plat-Arch-204 Exam Questions, you will pass the exam for sure.
Plat-Arch-204 Reliable Guide Files: https://www.braindumpsqa.com/Plat-Arch-204_braindumps.html
That is to say, our product boosts many advantages and to gain a better understanding of our Plat-Arch-204 question torrent, So must believe that you will embrace a promising future under the help of our Plat-Arch-204 test cram: Salesforce Certified Platform Integration Architect, Salesforce Reliable Plat-Arch-204 Test Voucher You need a professional guider to point out the key knowledge, Salesforce Reliable Plat-Arch-204 Test Voucher Your exam practice materials are exactly as you say.
Optimizing Usage Data Collection Log Settings, No doubtly there is a variety of Salesforce Plat-Arch-204 study materials on the internet for this exam, and we know the more choices equal to more entanglement, so we really want to recommend the best exam products to you and let you make a wise selection (Plat-Arch-204 Exam Preparation).
Magnificent Plat-Arch-204 Preparation Exam: Salesforce Certified Platform Integration Architect forms high-quality Training Engine - BraindumpsqaThat is to say, our product boosts many advantages and to gain a better understanding of our Plat-Arch-204 question torrent, So must believe that you will embrace a promising future under the help of our Plat-Arch-204 test cram: Salesforce Certified Platform Integration Architect.
You need a professional guider to point out Plat-Arch-204 the key knowledge, Your exam practice materials are exactly as you say, For quick and complete Salesforce Certified Platform Integration Architect (Plat-Arch-204) exam preparation you can trust Braindumpsqa Salesforce Plat-Arch-204 Exam Questions.
Posted at 2/19/2026 16:18:18        Only Author  2#
在我們的网站中,你可以獲得關于 Ping Identity PAP-001 考古題的培訓工具。我們的IT精英團隊會及時為你提供準確以及詳細的關于 Ping Identity PAP-001 考古題的培訓材料。通過使用我們提供的學習材料以及考試練習題和答案,能確保你第一次參加 Ping Identity PAP-001 考古題認證考試時挑戰成功,而且不用花費大量時間和精力來準備考試。如果在考試過程中變題了,考生可以享受全額退費或一年內更新考題的服務,保障了考生的權利。
