Pass Guaranteed Quiz Reliable Amazon - AWS-Solutions-Architect-Professional Exam
Posted at 2/18/2026 16:26:51
What's more, part of that Free4Torrent AWS-Solutions-Architect-Professional dumps now are free: https://drive.google.com/open?id=16JOBhBTDQDNg2GJcJpELvhtPQ2FNAgKc
Failure in the AWS-Solutions-Architect-Professional test of the AWS Certified Solutions Architect - Professional credential leads to loss of time and money. Therefore preparing with AWS Certified Solutions Architect - Professional actual test questions matters a lot to save time and money. The prep material of Free4Torrent comes in three different formats so that users with different study styles can prepare with ease. We have made this AWS Certified Solutions Architect - Professional product after taking feedback of experts so that applicants can prepare for the Amazon AWS-Solutions-Architect-Professional Exam successfully.
Amazon AWS-Solutions-Architect-Professional (AWS Certified Solutions Architect - Professional) exam is designed to test an individual's expertise in designing and deploying scalable, highly available, and fault-tolerant systems on Amazon Web Services (AWS). AWS Certified Solutions Architect - Professional certification is ideal for professionals who already possess an AWS Certified Solutions Architect - Associate certification and are looking to take the next step in their career by demonstrating their advanced technical skills.
AWS Certified Solutions Architect - Professional certification holders are highly sought after in the industry, as they have demonstrated a mastery of advanced AWS concepts and are capable of designing complex and highly available systems. AWS Certified Solutions Architect - Professional certification can open up numerous career opportunities and can lead to higher salaries and greater job security for those who achieve it.
Exam AWS-Solutions-Architect-Professional Experience - New AWS-Solutions-Architect-Professional Test DurationThe AWS Certified Solutions Architect - Professional (AWS-Solutions-Architect-Professional) questions are in use by many customers currently, and they are preparing for their best future daily. Even the students who used it in the past to prepare for the Amazon Certification Exam have rated our practice questions as one of the best. You will receive updates till 365 days after your purchase, and there is a 24/7 support system that assists you whenever you are stuck in any problem or issues.
The AWS-Solutions-Architect-Professional Exam measures an individual's ability to design and deploy AWS cloud architectures at scale. It covers a wide range of topics, including designing and deploying highly available, fault-tolerant, and scalable systems, selecting appropriate AWS services for specific workloads, and managing costs while optimizing performance. AWS-Solutions-Architect-Professional exam also tests an individual's knowledge of security and compliance, as well as their ability to troubleshoot and optimize performance issues. By earning this certification, IT professionals can demonstrate to employers and clients that they have the skills and expertise needed to design, deploy, and manage complex AWS architectures.
Amazon AWS Certified Solutions Architect - Professional Sample Questions (Q281-Q286):NEW QUESTION # 281
A customer has a 10 GB AWS Direct Connect connection to an AWS region where they have a web application hosted on Amazon Elastic Computer Cloud (EC2). The application has dependencies on an on-premises mainframe database that uses a BASE (Basic Available, Soft state, Eventual consistency) rather than an ACID (Atomicity, Consistency, Isolation, Durability) consistency model. The application is exhibiting undesirable behavior because the database is not able to handle the volume of writes.
How can you reduce the load on your on-premises database resources in the most cost-effective way?
- A. Modify the application to write to an Amazon SQS queue and develop a worker process to flush the queue to the on-premises database.
- B. Use an Amazon Elastic Map Reduce (EMR) S3DistCp as a synchronization mechanism between the on-premises database and a Hadoop cluster on AWS.
- C. Provision an RDS read-replica database on AWS to handle the writes and synchronize the two databases using Data Pipeline.
- D. Modify the application to use DynamoDB to feed an EMR cluster which uses a map function to write to the on-premises database.
NEW QUESTION # 282
An advisory firm is creating a secure data analytics solution for its regulated financial services users Users will upload their raw data to an Amazon 53 bucket, where they have PutObject permissions only Data will be analyzed by applications running on an Amazon EMR cluster launched in a VPC The firm requires that the environment be isolated from the internet All data at rest must be encrypted using keys controlled by the firm Which combination of actions should the Solutions Architect take to meet the user's security requirements?
(Select TWO )
- A. Launch the Amazon EMR cluster in a private subnet configured to use an AWS CloudHSM appliance for at-rest encryption Configure a gateway VPC endpoint for Amazon S3 and an interface VPC endpoint for CloudHSM
- B. Configure the S3 endpoint policies to permit access to the necessary data buckets only
- C. Launch the Amazon EMR cluster in a private subnet configured to use an AWS KMS CMK for at-rest encryption Configure a gateway VPC endpomint for Amazon S3 and a NAT gateway to access AWS KMS
- D. Configure the S3 bucket polices lo permit access using an aws sourceVpce condition lo match the S3 endpoint ID
- E. Launch the Amazon EMR cluster m a private subnet configured to use an AWS KMS CMK for at-rest encryption Configure a gateway VPC endpoint (or Amazon S3 and an interlace VPC endpoint for AWS KMS
Answer: A,E
NEW QUESTION # 283
A company hosts a blog post application on AWS using Amazon API Gateway, Amazon DynamoDB, and AWS Lambda. The application currently does not use API keys to authorize requests. The API model is as follows:
GET/posts/[postid] to get post details
GET/users[userid] to get user details
GET/comments/[commentid] to get comments details
The company has noticed users are actively discussing topics in the comments section, and the company wants to increase user engagement by marking the comments appears in real time.
Which design should be used to reduce comment latency and improve user experience?
- A. Modify the blog application code to request GET comment[commented] every 10 seconds.
- B. Use AWS AppSync and leverage WebSockets to deliver comments.
- C. Use edge-optimized API with Amazon CloudFront to cache API responses.
- D. Change the concurrency limit of the Lambda functions to lower the API response time.
https://docs.aws.amazon.com/apps ... aphql-overview.html AWS AppSync is a fully managed GraphQL service that allows applications to securely access, manipulate, and receive data as well as real-time updates from multiple data sources1. AWS AppSync supports GraphQL subscriptions to perform real-time operations and can push data to clients that choose to listen to specific events from the backend1. AWS AppSync uses WebSockets to establish and maintain a secure connection between the clients and the API endpoint2. Therefore, using AWS AppSync and leveraging WebSockets is a suitable design to reduce comment latency and improve user experience.
NEW QUESTION # 284
A company has a legacy application running on servers on premises. To increase the application's reliability, the company wants to gain actionable insights using application logs. A Solutions Architect has been given following requirements for the solution:
* Aggregate logs using AWS.
* Automate log analysis for errors.
* Notify the Operations team when errors go beyond a specified threshold.
What solution meets the requirements?
- A. Install Logstash on servers, send logs to Amazon S3 and use Amazon Athena to identify errors, use sendmail to notify the Operations team of errors.
- B. Install the Amazon CloudWatch agent on servers, send logs to Amazon CloudWatch Logs and use metric filters to identify errors, create a CloudWatch alarm to notify the Operations team of errors.
- C. Install Amazon Kinesis Agent on servers, send logs to Amazon Kinesis Data Streams and use Amazon Kinesis Data Analytics to identify errors, create an Amazon CloudWatch alarm to notify the Operations team of errors
- D. Install an AWS X-Ray agent on servers, send logs to AWS Lambda and analyze them to identify errors, use Amazon CloudWatch Events to notify the Operations team of errors.
NEW QUESTION # 285
An organization is planning to setup a management network on the AWS VPC. The organization is trying
to secure the webserver on a single VPC instance such that it allows the internet traffic as well as the
back-end management traffic. The organization wants to make so that the back end management network
interface can receive the SSH traffic only from a selected IP range, while the internet facing webserver will
have an IP address which can receive traffic from all the internet IPs.
How can the organization achieve this by running web server on a single instance?
- A. The organization should create two network interfaces with separate subnets so one instance can have
two subnets and the respective security groups for controlled access. - B. It is not possible to have two IP addresses for a single instance.
- C. The organization should create two network interfaces with the same subnet and security group to
assign separate IPs to each network interface. - D. The organization should launch an instance with two separate subnets using the same network
interface which allows to have a separate CIDR as well as security groups.
A Virtual Private Cloud (VPC) is a virtual network dedicated to the user's AWS account. It enables the
user to launch AWS resources into a virtual network that the user has defined. An Elastic Network
Interface (ENI) is a virtual network interface that the user can attach to an instance in a VPC.
The user can create a management network using two separate network interfaces. For the present
scenario it is required that the secondary network interface on the instance handles the public facing
traffic and the primary network interface handles the back-end management traffic and it is connected to a
separate subnet in the VPC that has more restrictive access controls. The public facing interface, which
may or may not be behind a load balancer, has an associated security group to allow access to the server
from the internet while the private facing interface has an associated security group allowing SSH access
only from an allowed range of IP addresses either within the VPC or from the internet, a private subnet
within the VPC or a virtual private gateway.
Reference: http://docs.aws.amazon.com/AWSEC2/latest/UserGuide/using-eni.html
NEW QUESTION # 286
Exam AWS-Solutions-Architect-Professional Experience: https://www.free4torrent.com/AWS-Solutions-Architect-Professional-braindumps-torrent.html
- New AWS-Solutions-Architect-Professional Test Braindumps ⛪ AWS-Solutions-Architect-Professional Reliable Test Questions 👜 Latest AWS-Solutions-Architect-Professional Test Vce 🐱 Download ✔ AWS-Solutions-Architect-Professional ️✔️ for free by simply entering ➽ [url]www.troytecdumps.com 🢪 website 💇AWS-Solutions-Architect-Professional Latest Test Prep[/url]
- AWS-Solutions-Architect-Professional PDF VCE 🐪 AWS-Solutions-Architect-Professional Reliable Test Questions 📌 Latest AWS-Solutions-Architect-Professional Test Vce 🎀 Go to website ➽ [url]www.pdfvce.com 🢪 open and search for 《 AWS-Solutions-Architect-Professional 》 to download for free 👷AWS-Solutions-Architect-Professional Reliable Test Dumps[/url]
- Amazon AWS-Solutions-Architect-Professional Dumps - Pass Exam With Ease [2026] 🆎 Easily obtain free download of ➠ AWS-Solutions-Architect-Professional 🠰 by searching on ▛ [url]www.prepawayete.com ▟ 🐝AWS-Solutions-Architect-Professional Top Questions[/url]
- AWS-Solutions-Architect-Professional Exam Dumps Free - How to Download for Exam AWS-Solutions-Architect-Professional Experience Free of Charge 🌑 Search for ➤ AWS-Solutions-Architect-Professional ⮘ and easily obtain a free download on ➠ [url]www.pdfvce.com 🠰 🥵Latest AWS-Solutions-Architect-Professional Test Vce[/url]
- AWS-Solutions-Architect-Professional Get Certified Get Ahead AWS-Solutions-Architect-Professional 🌸 Open ➡ [url]www.testkingpass.com ️⬅️ enter 「 AWS-Solutions-Architect-Professional 」 and obtain a free download 🥰AWS-Solutions-Architect-Professional Test Sample Questions[/url]
- Amazon AWS-Solutions-Architect-Professional Exam Dumps - Obtain Brilliant Result [2026] 📧 Open ➤ [url]www.pdfvce.com ⮘ enter [ AWS-Solutions-Architect-Professional ] and obtain a free download 🍻Valid AWS-Solutions-Architect-Professional Braindumps[/url]
- AWS-Solutions-Architect-Professional Exam Preparation - AWS-Solutions-Architect-Professional Exam Questions - AWS-Solutions-Architect-Professional Online Test 🔙 Copy URL ➤ [url]www.practicevce.com ⮘ open and search for ➤ AWS-Solutions-Architect-Professional ⮘ to download for free 📗Reliable AWS-Solutions-Architect-Professional Braindumps Free[/url]
- Valid AWS-Solutions-Architect-Professional Guide Files 👗 AWS-Solutions-Architect-Professional Top Questions 🍱 Valid AWS-Solutions-Architect-Professional Guide Files 🔶 Easily obtain free download of ▶ AWS-Solutions-Architect-Professional ◀ by searching on 「 [url]www.pdfvce.com 」 🏺Trustworthy AWS-Solutions-Architect-Professional Pdf[/url]
- AWS-Solutions-Architect-Professional Exam Dumps Free - How to Download for Exam AWS-Solutions-Architect-Professional Experience Free of Charge 🔎 Easily obtain free download of ▶ AWS-Solutions-Architect-Professional ◀ by searching on ⮆ [url]www.troytecdumps.com ⮄ 🎇AWS-Solutions-Architect-Professional Top Questions[/url]
- 2026 Amazon Pass-Sure AWS-Solutions-Architect-Professional Exam Dumps Free 🥊 Search for ➡ AWS-Solutions-Architect-Professional ️⬅️ and obtain a free download on ⮆ [url]www.pdfvce.com ⮄ 📗Trustworthy AWS-Solutions-Architect-Professional Pdf[/url]
- New AWS-Solutions-Architect-Professional Test Braindumps 📿 AWS-Solutions-Architect-Professional Test Sample Questions ⚗ AWS-Solutions-Architect-Professional Top Questions 🦟 Download ➽ AWS-Solutions-Architect-Professional 🢪 for free by simply searching on { [url]www.testkingpass.com } 🌏AWS-Solutions-Architect-Professional PDF VCE[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, eishkul.com, www.stes.tyc.edu.tw, tawhaazinnurain.com, Disposable vapes
DOWNLOAD the newest Free4Torrent AWS-Solutions-Architect-Professional PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=16JOBhBTDQDNg2GJcJpELvhtPQ2FNAgKc
