[General] Reliable CCM Test Labs Pass Certify| Latest Exam Dumps CCM Free: Certified Case
110
【General】 Reliable CCM Test Labs Pass Certify| Latest Exam Dumps CCM Free: Certified Case
Posted at 2/18/2026 16:48:06      View:111 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New CCM dumps are available on Google Drive shared by iPassleader: https://drive.google.com/open?id=1MdIkELziCtxaykou-q50rPdu4FJ_HG8V
iPassleader designed this prep material to help you pass the exam on the first try. It may sound complicated, but once you go through regular study and intensive practice, passing the final exam would be a piece of cake. The cost of Certified Case Manager Certification Exam (CCM) (CCM) certification itself is expensive, ranging from $100 to $1000, so you can't risk wasting that amount. iPassleader ensures that this does not happen by providing you with reliable and updated preparation material.
Three versions for CCM training materials are available, and you can choose the most suitable one according to your own needs. CCM PDF version is printable, and you can print them into hard one and take them with you, you can also study anywhere and anyplace. CCM Soft test engine can install in more than 200 computers, and it has two modes for practice. CCM Soft test engine can also simulate the real exam environment, so that your confidence for the exam will be strengthened. CCM Online test engine is convenient and easy to learn. You can have a review of what you have learned through this version.
Pass Guaranteed Quiz 2026 Perfect CCM: Reliable Certified Case Manager Certification Exam (CCM) Test LabsThere is a way to clear your CCM certification exam without finding the best source of help. As an applicant for the Certified Case Manager Certification Exam (CCM) (CCM) exam, you need actual Medical Professional CCM exam questions to know how you can score well and attempt it successfully. You can visit iPassleader to get the best quality CCM Practice Test material for the CCM exam.
Medical Professional Certified Case Manager Certification Exam (CCM) Sample Questions (Q68-Q73):NEW QUESTION # 68
Applying FIDIC Silver Book (edition 1999), which one of the following elements shallnotform part of the time Programme/revised programme?
  • A. The intended order of the works.
  • B. Review periods under Sub-Clause 5.2.
  • C. The remedial work (if any) instructed under Sub-Clause 7.6.
  • D. The sequence and timing of inspections and tests.
According to the FIDIC Silver Book, 1999 Edition (The Conditions of Contract for EPC/Turnkey Projects), the Contractor is required under Sub-Clause 8.3 ("Programme") to submit a time programme that illustrates the sequence and timing of the works, including milestones and key events. The intended order of the works (Option A), sequence and timing of inspections and tests (Option B), and review periods (Option D) related to contract management processes such as approval of design or submissions (Sub-Clause 5.2) are integral to effective scheduling and coordination.
However,remedial work instructed under Sub-Clause 7.6, which concerns remedying defects or damage, is generally not part of the initial or revised programme. Instead, remedial works are typically handled as separate tasks or incorporated into specific defect liability or rectification schedules after the main programme has been executed. Such remedial works arise from defects liability obligations and do not belong to the original or revised time programme used to plan the main construction phases.
This distinction is important because the programme reflects planned works execution, whereas remedial work is reactive and may be scheduled separately under defects liability clauses or final project close-out arrangements.
FIDIC Silver Book 1999 Edition, Clause 8.3 - Programme
FIDIC Silver Book 1999 Edition, Clause 7.6 - Remedial Work
FIDIC Contract Manager Study Guide, Module on Time and Delay Management
NEW QUESTION # 69
FIDIC Red, Yellow, and Silver Books (both editions) contain a provision for the Engineer or Employer to instruct the Contractor to employ a subcontractor, thereby also permitting the Contractor to refuse to employ such proposed subcontractor on the basis of a reasonable objection by a notice. Is this statement true or false?
  • A. True
  • B. False
All main FIDIC contract editions contain provisions that allow the Employer or Engineer to propose or instruct the Contractor to employ certain subcontractors (e.g., nominated subcontractors). The Contractor retains the right to refuse such subcontractors only for reasonable cause, which must be communicated formally.
This mechanism protects the Employer's interests in subcontractor selection while safeguarding the Contractor's right to reject subcontractors that may not be competent or suitable.
Therefore, the statement is true.
FIDIC Red, Yellow, and Silver Books 1999 and 2017 Editions, Sub-Clause 4.4 - Subcontractors FIDIC Contract Manager Study Guide, Module on Contract Administration Procedures
NEW QUESTION # 70
Before applying the procurement process of any FIDIC Book, the Employer should always check if there are local procurement rules that also apply. Which one of these responses is correct?
  • A. No, because the FIDIC procurement process is universal.
  • B. Yes, based on the law system, internal governance or type of Employer additional procurement rules can apply.
  • C. Yes, but this is only applicable for public entities like governments. If the Employer is a private organisation (like a company), they are free to procure how they want.
  • D. No, because Employers never have specific procurement rules.
Local procurement laws, regulations, and internal governance rules often apply in addition to or alongside FIDIC contract provisions. Employers, whether public or private, must comply with applicable national or sector-specific rules, which may affect procurement procedures, documentation, and contract award processes.
Option C is correct because procurement requirements depend on local legal systems, the nature of the Employer, and applicable governance.
Option A is incorrect as FIDIC contracts provide contractual frameworks but do not override local legal obligations.
Option B is incorrect because many Employers have procurement policies.
Option D is incorrect since private entities may also be subject to procurement laws or internal policies.
FIDIC Contract Manager Study Guide, Module on Contract Formation and Procurement Strategies World Bank Procurement Guidelines and National Procurement Laws
NEW QUESTION # 71
The procurement process of a project executed based on any FIDIC Contract model is exactly the same in terms of definitions, time and steps, which makes it universal and more easy to use worldwide. Is this statement true or false?
  • A. True
  • B. False
This statement is false. While FIDIC Contracts provide standardized contractual frameworks, procurement processes vary widely depending on local laws, employer requirements, contract editions, and project specifics. Definitions, timelines, and procurement steps may differ between models and jurisdictions, making the procurement process not universally identical.
The FIDIC contracts are adaptable tools, not rigid procurement procedures, so users must tailor procurement to local and project needs.
FIDIC Contract Manager Study Guide, Module on Contract Formation and Procurement Strategies Various National Procurement Regulations and Practices
NEW QUESTION # 72
For the FIDIC Red Book (both editions), the Contractor is required to submit a progress report monthly.
When does the Contractor's reporting requirement end?
  • A. Until all outstanding works as stated in the Taking-Over Certificate are completed.
  • B. After issuance of the Performance Certificate.
  • C. After issuance of the Taking-Over Certificate.
  • D. At the Date of Completion of the Works (irrespective of whether there is minor outstanding work to be performed).
The Contractor's obligation to submit progress reports continues until all outstanding work identified in the Taking-Over Certificate has been completed. The Taking-Over Certificate signals substantial completion but may allow for outstanding minor works. Reporting is essential to monitor progress on these outstanding works.
The Performance Certificate relates to final contract completion but reporting usually ends earlier only after all works are completed.
Therefore, Option D is correct.
FIDIC Red Book 1999 & 2017 Editions, Sub-Clause 4.21 - Progress Reports FIDIC Contract Manager Study Guide, Module on Communication and Reporting
NEW QUESTION # 73
Using these Medical Professional CCM practice test software you will identify your mistakes, gain confidence and learn time-management skills. It will help you to prepare better for the final CCM exam. iPassleader Medical Professional CCM Valid Dumps - Free Demo Download & Refund Guarantee Medical Professional CCM exam dumps are the best option if you really want to pass the Certified Case Manager Certification Exam (CCM) exam on your first attempt.
Exam Dumps CCM Free: https://www.ipassleader.com/Medical-Professional/CCM-practice-exam-dumps.html
In fact, the time that spends on learning the Medical Professional CCM latest vce pdf is restrictive and inadequate, Medical Professional Reliable CCM Test Labs Besides, we offer considerate aftersales services 24/7 and our staff treasures all your constructive opinions to be better of our services in all respects, We work 24/7 to keep our CCM valid training pdf and quickly to respond your questions and requirements.
Do not postpone seeking help from our extraordinary Medical Professional CCM dumps to get the crucial Medical Professional CCM certification exams, It does not have a parameter that contains a count of the number of parameters.
Accurate CCM Practice Engine gives you high-effective Exam Quiz - iPassleaderIn fact, the time that spends on learning the Medical Professional CCM latest vce pdf is restrictive and inadequate, Besides, we offer considerate aftersales services 24/7 and our staff CCM treasures all your constructive opinions to be better of our services in all respects.
We work 24/7 to keep our CCM valid training pdf and quickly to respond your questions and requirements, They can engage their attention in the Medical Professional CCM exam visual effects and pictures that present a lot of.
iPassleader is a trusted and reliable platform that has been helping Certified Case Manager Certification Exam (CCM) (CCM) exam candidates for many years.
P.S. Free 2026 Medical Professional CCM dumps are available on Google Drive shared by iPassleader: https://drive.google.com/open?id=1MdIkELziCtxaykou-q50rPdu4FJ_HG8V
