[General] Microsoft SC-300 Valid Test Materials - SC-300 Real Testing Environment
93
【General】 Microsoft SC-300 Valid Test Materials - SC-300 Real Testing Environment
Posted at 2/18/2026 18:20:27      View:88 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest PassTorrent SC-300 PDF Dumps and SC-300 Exam Engine Free Share: https://drive.google.com/open?id=1ZHnCOnrLoRBzAtRxsNJrAgPpwLJDSyem
We have authoritative production team made up by thousands of experts helping you get hang of our SC-300 study question and enjoy the high quality study experience. We will update the content of SC-300 test guide from time to time according to recent changes of examination outline and current policies. Besides, our SC-300 Exam Questions can help you optimize your learning method by simplifying obscure concepts so that you can master better. One more to mention, with our SC-300 test guide, there is no doubt that you can cut down your preparing time in 20-30 hours of practice before you take the exam.
Skills measured
  • Implement an authentication and access management solution (25-30%)
  • Plan and implement an identity governance strategy (25-30%)
  • Implement access management for apps (10-15%)
  • Implement an identity management solution (25-30%)
Innovatively SC-300 Practice Engine Boost the Most Admirable Exam Questions - PassTorrentIn this website, you can find three different versions of our SC-300 guide torrent which are prepared in order to cater to the different tastes of different people from different countries in the world since we are selling our SC-300 test torrent in the international market. Most notably, the simulation test is available in our software version. With the simulation test, all of our customers will have an access to get accustomed to the SC-300 Exam atmosphere and pass easily in the real SC-300 exam.
The SC-300 certification exam is a part of Microsoft's role-based certification program, which aims to provide a clear path for professionals to develop skills and advance their careers. By earning the SC-300 certification, you demonstrate your ability to design, implement, and manage identity and access solutions using Microsoft technologies. Microsoft Identity and Access Administrator certification exam is a valuable asset for professionals who want to work in a variety of industries, including healthcare, finance, government, and more.
The SC-300 Exam covers a wide range of topics, including configuring and managing identity and access, implementing identity management solutions, managing access and authentication, and configuring security for applications. SC-300 exam is designed to test the candidate's practical skills and knowledge of working with Microsoft technologies, such as Azure AD, Active Directory, and Microsoft 365. SC-300 exam consists of around 40-60 multiple-choice questions, and the duration of the exam is 150 minutes.
Microsoft Identity and Access Administrator Sample Questions (Q101-Q106):NEW QUESTION # 101
Your network contains an on-premises Active Directory domain that sync to an Azure Active Directory (Azure AD) tenant. The tenant contains the shown in the following table.
All the users work remotely.
Azure AD Connect is configured in Azure as shown in the following exhibit.
Connectivity from the on-premises domain to the internet is lost.
Which user can sign in to Azure AD?
  • A. User1 only
  • B. User1, User2, and User3
  • C. User1 and User 3 only
  • D. User1, and User2 only
NEW QUESTION # 102
You have an Azure Active Directory (Azure AD) tenant that has multi-factor authentication (MFA) enabled.
The account lockout settings are configured as shown in the following exhibit.
NEW QUESTION # 103
You have an Azure subscription that contains the resources shown in the following table.
You need to grant permissions to the resources by using attribute-based access control (ABAC).
To which resource can you grant permissions?
  • A. VM1
  • B. Vault1
  • C. App1
  • D. storage 1
NEW QUESTION # 104
You need to configure the detection of multi-staged attacks to meet the monitoring requirements.
What should you do?
  • A. Customize the Azure Sentinel rule logic.
  • B. Add Azure Sentinel data connectors.
  • C. Create a workbook.
  • D. Add an Azure Sentinel playbook.
Topic 1, Litware, Inc
Overview
Litware, Inc. is a pharmaceutical company that has a subsidiary named fabrikam, inc Litware has offices in Boston and Seattle, but has employees located across the United States. Employees connect remotely to either office by using a VPN connection.
Identity Environment
The network contains an Active Directory forest named litware.com that is linked to an Azure Active Directory (Azure AD) tenant named litware.com. Azure AD Connect uses pass-through authentication and has password hash synchronization disabled.
Litware.com contains a user named User1 who oversees all application development. Litware implements Azure AD Application Proxy.
Fabrikam has an Azure AD tenant named fabrikam.com. The users at Fabrikam access the resources in litware.
com by using gu est accounts in the litware.com tenant.
Cloud Environment
All the users at Litware have Microsoft 365 Enterprise E5 licenses. All the built-in anomaly detection polices in Microsoft Cloud App Security are enabled.
Litware has an Azure subscription associated to the litware.com Azure AD tenant. The subscription contains an Azure Sentinel instance that uses the Azure Active Directory connector and the Office 365 connector.
Azure Sentinel currently collects the Azure AD sign-ins logs and audit logs.
On-premises Environment
The on-premises network contains the severs shown in the following table.
Both Litware offices connect directly to the internet. Both offices connect to virtual networks in the Azure subscription by using a site-to-site VPN connection. All on-premises domain controllers are prevented from accessing the internet.
Delegation Requirements
Litware identifies the following delegation requirements:
* Delegate the management of privileged roles by using Azure AD Privileged Identity Management (PIM).
* Prevent nonprivileged users from registering applications in the litware.com Azure AD tenant-
* Use custom catalogs and custom programs for Identity Governance.
* Ensure that User1 can create enterprise applications in Azure AD. Use the principle of least privilege.
Licensing Requirements
Litware recently added a custom user attribute named LWLicenses to the litware.com Active Directory forest.
Litware wants to manage the assignment of Azure AD licenses by modifying the value of the LWLicenses attribute. Users who have the appropriate value for LWLicenses must be added automatically to Microsoft
365 group that he appropriate license assigned.
Management Requirement
Litware wants to create a group named LWGroup1 will contain all the Azure AD user accounts for Litware but exclude all the Azure AD guest accounts.
Authentication Requirements
Litware identifies the following authentication requirements:
* Implement multi-factor authentication (MFA) for all Litware users.
* Exempt users from using MFA to authenticate to Azure AD from the Boston office of Litware.
* Implement a banned password list for the litware.com forest.
* Enforce MFA when accessing on-premises applications.
* Automatically detect and remediate externally leaked credentials
Access Requirements
Litware wants to create a group named LWGroup1 that will contain all the Azure AD user accounts for Litware but exclude all the Azure AD guest accounts.
Monitoring Requirements
Litware wants to use the Fusion rule in Azure Sentinel to detect multi-staged that include a combination of suspicious Azure AD sign-ins followed by anomalous Microsoft Office 365 activity.
NEW QUESTION # 105
You have an Azure Active Directory (Azure AD) tenant that contains a user named User1 and the groups shown in the following table.
In the tenant, you create the groups shown in the following table.
Which members can you add to GroupA and GroupB? To answer, select the appropriate options in the answer area.
https://bitsizedbytes.wordpress. ... 365-groups-nesting/
NEW QUESTION # 106
SC-300 Real Testing Environment: https://www.passtorrent.com/SC-300-latest-torrent.html
DOWNLOAD the newest PassTorrent SC-300 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1ZHnCOnrLoRBzAtRxsNJrAgPpwLJDSyem
