[General] Prep4sures: Your Solution to Ace the Fortinet NSE5_FSW_AD-7.6 Exam
89
【General】 Prep4sures: Your Solution to Ace the Fortinet NSE5_FSW_AD-7.6 Exam
Posted at 2/18/2026 19:01:27      View:117 | Replies:1        Print      Only Author   [Copy Link] 1#
Fortinet NSE5_FSW_AD-7.6 Exam is a very hot exam. Although it is difficult to pass the exam, the identification of entry point will make you easy to pass your exam. Prep4sures practice test dumps are your best choice and hit rate is up to 100%. And our exam dumps can help you solve any questions of NSE5_FSW_AD-7.6 exam. As long as you carefully study the questions in the dumps, all problems can be solved. Purchasing Prep4sures certification training dumps, we provide you with free updates for a year. Within a year, as long as you want to update the dumps you have, you can get the latest version. Try it and see for yourself.
Our NSE5_FSW_AD-7.6 study materials are constantly improving themselves. We keep updating them to be the latest and accurate. And we apply the latest technologies to let them applied to the electronic devices. If you have any good ideas, our NSE5_FSW_AD-7.6 Exam Questions are very happy to accept them. NSE5_FSW_AD-7.6 learning braindumps are looking forward to having more partners to join this family. We will progress together and become better ourselves.
Certification NSE5_FSW_AD-7.6 Exam - NSE5_FSW_AD-7.6 Exam DumpIf you are still study hard to prepare the Fortinet NSE5_FSW_AD-7.6 Exam, you're wrong. Of course, with studying hard, you can pass the exam. But may not be able to achieve the desired effect. Now this is the age of the Internet, there are a lot of shortcut to success. Prep4sures's Fortinet NSE5_FSW_AD-7.6 exam training materials is a good training materials. It is targeted, and guarantee that you can pass the exam. This training matrial is not only have reasonable price, and will save you a lot of time. You can use the rest of your time to do more things. So that you can achieve a multiplier effect.
Fortinet NSE 5 - FortiSwitch 7.6 Administrator Sample Questions (Q53-Q58):NEW QUESTION # 53
Refer to the exhibits.
Port1 and port2 are the only ports configured with the same native VLAN 10.
What are two reasons that can trigger port1 to shut down? (Choose two.)
  • A. port1 was shut down by loop guard protection.
  • B. An endpoint sent a BPDU on port1 that it received from another interface.
  • C. Loop guard frame sourced from port 1 was received on port 1.
  • D. STP triggered a loop and applied loop guard protection on port1.
When loop guard is enabled on port1 and port2 configured with the same native VLAN (VLAN 10), there are specific scenarios under which port1 can be shut down due to loop guard operation:
A).port1 was shut down by loop guard protection.Loop guard is a specific feature used in network environments to prevent alternative or redundant loops. When loop guard is active, it can shut down a port if it stops receiving BPDU (Bridge Protocol Data Units) on a port that is expected to receive them, assuming a loop or link failure and putting the port into an inconsistent state to prevent potential loops.
B).STP triggered a loop and applied loop guard protection on port1.If the Spanning Tree Protocol (STP) detects a loop or loss of BPDU transmissions while loop guard is enabled, it will proactively shut down the port to prevent network instability or a broadcast storm. This is an essential function of loop guard within the context of STP, providing additional protection against topology changes that could introduce loops.
Additional details about loop guard functionality and STP interaction can be found in the FortiSwitch administration guides, accessible viaFortinet Documentation.
NEW QUESTION # 54
The LLDP profile shown in the exhibit was configured to detect IP phones and automatically assign them to the appropriate VLAN. You apply this LLDP profile on a FortiSwitch port. Which configuration should you enable on the FortiSwitch profile to collect detailed information about all the connected IP phones? (Choose one answer)
  • A. Create a new LLDP profile to handle different LLDP-MED TLVs.
  • B. Enable auto-isl.
  • C. Configure a dedicated voice VLAN with DSCP 46.
  • D. Enable LLDP-MED inventory management TLVs.
According to theFortiSwitchOS 7.6 Administration Guideand theFortiSwitch 7.6 Study Guide, Link Layer Discovery Protocol-Media Endpoint Discovery (LLDP-MED) is an enhancement to standard LLDP that provides advanced discovery and configuration for endpoints li1ke IP phones. While the current configuration in the exhibit correctly handlesNetwork Policy TLVsto advertise QoS2and VLAN settings to the phones, it is missing the specific component required for data collection.34 To coll5ect detail6ed information such as themanufacturer, software version, hardware version, and serial or asset numbers, you mustEnable LLDP-MED inventory management TLVs (Option C). The documentation specifies that when the inventory-management TLV is active, the switch can retrieve these extensive device characteristics from the connected Media Endpoints. This information is then visible to the administrator through the FortiGate or FortiSwitch monitoring tools, providing a complete hardware inventory of the voice network.
Regarding the other options:Option Ais unnecessary because a single LLDP profile can support multiple TLV types simultaneously by adding them to the med-tlvs string.Option Bis already partially implemented in the exhibit's network policy but does not contribute to device detection or data collection.Option Dis used for automatic trunking between FortiSwitches and is unrelated to endpoint device information. Therefore, the addition of the inventory-management TLV is the specific requirement to fulfill the goal of collecting detailed IP phone data.
NEW QUESTION # 55
Exhibit.
LAG and MCLAG are used to increase the available network bandwidth and enable redundancy. How does spanning tree protocol see MCLAG and LAG if they are configured based on the physi-cal view shown in the exhibit? (Choose two)
  • A. Switch 1 and Switch 2 both seen as one single switch.
  • B. Switch 3 and switch 4 are seen as one MCLAG switch client
  • C. Switch 1. Switch 2, and Switch 3 are seen as one MCLAG peer group
  • D. Switch 3 and Switch 4 uplinks are treated as single interfaces.
According to theFortiSwitchOS 7.6 Administration Guideand theFortiSwitch 7.6 Study Guide, Multichassis Link Aggregation (MCLAG) and standard Link Aggregation Groups (LAG) are designed to provide link-level and node-level redundancy while presenting a simplified logical view to the Spanning Tree Protocol (STP).
In the provided topology:
* Logical Switch View (Option D):Switch 1 and Switch 2 are configured asMCLAG peersconnected via an Inter-Chassis Link (ICL). From the perspective of downstream devices and STP, these two physical switches act as a single logical entity. This prevents STP from seeing a loop between the two switches and the downstream Switch 3, as the redundant physical paths are bundled into a single logical MCLAG trunk.
* Logical Interface View (Option B):The exhibit shows Switch 4 connected to Switch 3 via two physical links bundled into aLAG, and Switch 3 connected to the MCLAG peers via split links. In both cases, STP treats the aggregated physical links as asingle logical interface. Because the multiple physical paths are managed by the Link Aggregation Control Protocol (LACP) as one trunk, STP does not block individual ports to prevent loops; instead, it sees one high-bandwidth path.
Regarding the incorrect options:Option Ais false because Switch 3 is an MCLAGclient, not a peer in the group.Option Cis incorrect because Switch 3 and Switch 4 are separate physical and logical nodes; they are not seen as a single client entity by the core.
NEW QUESTION # 56
Which packet capture method allows FortiSwitch to capture traffic on trunks and management interfaces?
  • A. TCP dump
  • B. Sniffer profile
  • C. sFlow
  • D. SPAN
FortiSwitch supports packet capture through various methods, but the Sniffer profile is specifically capable of capturing traffic on both trunks and management interfaces.Here's why:
* Sniffer Profile (B):
* Versatile Capture:The sniffer profile in FortiSwitch is designed to capture traffic across different types of interfaces, including trunks (where multiple VLANs are present) and management interfaces (used for controlling and monitoring the switch).
* Configuration Flexibility:You can configure sniffer profiles to target specific traffic, offering flexibility in monitoring and troubleshooting network issues on both data and management planes.
* Other Options:
* SPAN (A)is used mainly for mirroring traffic to another port for analysis but is typically limited in its ability to capture management interface traffic.
* sFlow (C)andTCP dump (D)are useful tools but do not specifically align with the capability to universally capture traffic across trunks and management interfaces in the context described.
References:For further details on configuring and utilizing sniffer profiles on FortiSwitch, refer to the FortiSwitch management documentation:Fortinet Product Documentation
NEW QUESTION # 57
Exhibit.
port1 and port2 are the only ports configured with the same native VLAN 10.
  • B. STP triggered a loop and applied loop guard protection on port1.
  • C. An endpoint sent a BPDU on port1 that it received from another interface.
  • D. Loop guard frame sourced from port1 was received on port1.
NEW QUESTION # 58
Some people prefer books, some check videos, and some hire online tutors, to clear the NSE5_FSW_AD-7.6 exam. It all depends on you what you like the most. If you learn better by books, go for it but if you are busy, and don't have much time to consult a list of books for studying, it’s better to get the most probable Fortinet NSE 5 - FortiSwitch 7.6 Administrator (NSE5_FSW_AD-7.6) exam questions. We are sure that you will learn well and can crack Fortinet NSE5_FSW_AD-7.6 exam easily.
Certification NSE5_FSW_AD-7.6 Exam: https://www.prep4sures.top/NSE5_FSW_AD-7.6-exam-dumps-torrent.html
Fortinet Certification NSE5_FSW_AD-7.6 Exam Infor It is more convenient for you to look and read while protect our eye, NSE5_FSW_AD-7.6 study guide is highly targeted, If you do not pass the Fortinet Fortinet Network Security Expert NSE5_FSW_AD-7.6 exam (TS: Fortinet NSE 5 - FortiSwitch 7.6 Administrator) on your first attempt using ourPrep4sures testing engine, we will give you a FULL REFUND of your purchasing fee, Self Test Software and Online Enging of NSE5_FSW_AD-7.6 study guide have simulation functions which is not only easy for you to master our questions and answers better but also make you familiar with exam mood so that you will be confident.
circle_g.jpg Navigate to the folder on your Mac where Certification NSE5_FSW_AD-7.6 Exam Infor you want to copy the document and click Open, As I started giving interviews and met so many candidates, one thing I noticed quite a lot was that they NSE5_FSW_AD-7.6 all were having professional certificates, which made them easily the best candidates for the jobs.
Get Useful Certification NSE5_FSW_AD-7.6 Exam Infor and Pass Exam in First AttemptIt is more convenient for you to look and read while protect our eye, NSE5_FSW_AD-7.6 Study Guide is highly targeted, If you do not pass the Fortinet Fortinet Network Security Expert NSE5_FSW_AD-7.6 exam (TS: Fortinet NSE 5 - FortiSwitch 7.6 Administrator) on your first attempt using ourPrep4sures testing engine, we will give you a FULL REFUND of your purchasing fee.
Therefore, except that you can have a balance in studying for the NSE5_FSW_AD-7.6 exam test and doing you own business; you can also improve learning efficiency.
Posted at 2/19/2026 05:59:09        Only Author  2#
Through this article, my work thinking has significantly improved. The AZ-305 latest exam tutorial material is amazing, and it's free for you to use.
