Salesforce-Data-Cloud Test Result, Latest Salesforce-Data-Cloud Version
Posted at 2/18/2026 19:45:56
View136
Replies1
BTW, DOWNLOAD part of ITPassLeader Salesforce-Data-Cloud dumps from Cloud Storage: https://drive.google.com/open?id=1Wjh_cqxwOYXsBda630HNZ_atc26PAu-s
ITPassLeader has special training tools for Salesforce certification Salesforce-Data-Cloud exam, which can make you do not need to spend a lot of time and money but can get a lot of knowledge of IT technology to enhance your skills in a short time. And soon you will be able to prove your expertise knowledge and technology in IT industry. ITPassLeader's training courses for Salesforce Certification Salesforce-Data-Cloud Exam is developed by the study of ITPassLeader experts team to use their knowledge and experience.
Maybe you have desired the Salesforce-Data-Cloud certification for a long time but don't have time or good methods to study. Maybe you always thought study was too boring for you. Our Salesforce-Data-Cloud study materials will change your mind. With our products, you will soon feel the happiness of study. Thanks to our diligent experts, wonderful study tools are invented for you to pass the Salesforce-Data-Cloud Exam. You can try the demos first and find that you just can't stop studying if you use our Salesforce-Data-Cloud training guide.
Latest Salesforce-Data-Cloud Version & Exam Salesforce-Data-Cloud RegistrationReview the products offered by us by downloading Salesforce-Data-Cloud free demos and compare them with the study material offered in online course free and vendors' files. You will find our Salesforce-Data-Cloud exam dumps the better than our competitors such as exam collection and others. The excellent quality of our Salesforce-Data-Cloud exam dumps content, their relevance with the actual Salesforce-Data-Cloud Exam needs and their interactive and simple format will prove them superior and quite pertinent to your needs and requirements. If you just make sure learning of the content in the guide, there is no reason of losing the Salesforce-Data-Cloud exam.
Salesforce Data Cloud Accredited Professional Exam Sample Questions (Q18-Q23):NEW QUESTION # 18
What is the result of a segmentation criteria filtering on City | Is Equal To | 'San Jose'?
- A. Cities containing 'San Jose', 'San Jose', 'san jose', or 'san jose'
- B. Cities only containing 'San Jose' or 'san jose'
- C. Cities only containing 'San Jose' or 'san jose'
- D. Cities only containing 'San Jose' or 'San Jose'
The result of a segmentation criteria filtering on City | Is Equal To | 'San Jose' is cities only containing 'San Jose' or 'san jose'. This is because the segmentation criteria is case-sensitive and accent-sensitive, meaning that it will only match the exact value that is entered in the filter1. Therefore, cities containing 'San Jose', 'san jose', or 'San Jose' will not be included in the result, as they do not match the filter value exactly. To include cities with different variations of the name 'San Jose', you would need to use the OR operator and add multiple filter values, such as 'San Jose' OR 'San Jose' OR 'san jose' OR 'san jose'
2. References: Segmentation Criteria, Segmentation Operators
NEW QUESTION # 19
A customer has requested that their personal data be deleted. Which action should be performed to accommodate this request in Data Cloud?
- A. Manually delete customer and related records using the Profile Explorer
- B. Utilize the Data Rights Subject Request tool to request deletion of the customer's information
- C. Use Ingestion API to request deletion of the customer's information
- D. Use Consent API to request deletion of the customer's information
This action should be performed to accommodate the request to delete personal data in Data Cloud. The Consent API allows you to set a consent flag for an individual that prevents further processing of their data and deletes their records from source data streams. Reference: https://help.salesforce.com/s/ar ... _api.htm&type=5
NEW QUESTION # 20
What is the maximum limit of the number of records for Full Refresh Extract Method?
- A. No hard limit
- B. 10 million
- C. 40 million
- D. 50 million
The maximum limit of the number of records for Full Refresh Extract Method is 10 million. Full Refresh Extract Method is an option for extracting data from Marketing Cloud to Data Cloud. It extracts all records from a data extension regardless of when they were created or modified. If the number of records exceeds 10 million, an error occurs and no records are extracted. References: Extract Methods
NEW QUESTION # 21
A customer notices that their consolidation rate has recently increased. They contact the consultant to ask why.
What are two likely explanations for the increase?
Choose 2 answers
- A. Identity resolution rules have been added to the ruleset to increase the number of matchedprofiles.
- B. Identity resolution rules have been removed to reduce the number of matched profiles.
- C. Duplicates have been removed from source system data streams.
- D. New data sources have been added to Data Cloud that largely overlap with the existing profiles.
The consolidation rate is a metric that measures the amount by which source profiles are combined to produce unified profiles in Data Cloud, calculated as 1 - (number of unified profiles / number of source profiles). A higher consolidation rate means that more source profiles are matched and merged into fewer unified profiles, while a lower consolidation rate means that fewer source profiles are matched and more unified profiles are created. There are two likely explanations for why the consolidation rate has recently increased for a customer:
New data sources have been added to Data Cloud that largely overlap with the existing profiles. This means that the new data sources contain many profiles that are similar or identical to the profiles from the existing data sources. For example, if a customer adds a new CRM system that has the same customer records as their old CRM system, the new data source will overlap with the existing one. When Data Cloud ingests the new data source, it will use the identity resolution ruleset to match and merge the overlapping profiles into unified profiles, resulting in a higher consolidation rate.
Identity resolution rules have been added to the ruleset to increase the number of matched profiles. This means that the customer has modified their identity resolution ruleset to include more match rules or more match criteria that can identify more profiles as belonging to the same individual. For example, if a customer adds a match rule that matches profiles based on email address and phone number, instead of just email address, the ruleset will be able to match more profiles that have the same email address and phone number, resulting in a higher consolidation rate.
Identity Resolution Calculated Insight: Consolidation Rates for Unified Profiles, Configure Identity Resolution Rulesets
NEW QUESTION # 22
If a data source does not have a field that can be designated as a primary key, what should the consultant do?
- A. Remove duplicates from the data source and then select a primary key.
- B. Select a field as a primary key and then add a key qualifier.
- C. Use the default primary key recommended by Data Cloud.
- D. Create a composite key by combining two or more source fields through a formula field.
Understanding Primary Keys in Salesforce Data Cloud:
A primary key is a unique identifier for records in a data source. It ensures that each record can be uniquely identified and accessed.
Reference: Salesforce Primary Key Documentation
Challenges with Missing Primary Keys:
Some data sources may lack a natural primary key, making it difficult to uniquely identify records.
Reference: Salesforce Data Integration Guide
Solution: Creating a Composite Key:
Composite Key Definition: A composite key is created by combining two or more fields to generate a unique identifier.
Formula Fields: Using a formula field, different fields can be concatenated to create a unique composite key.
Example: If "Email" and "Phone Number" together uniquely identify a record, a formula field can concatenate these values to form a composite key.
Reference: Salesforce Composite Key Creation Guide
Steps to Create a Composite Key:
Identify fields that, when combined, can uniquely identify each record.
Create a formula field that concatenates these fields.
Use this composite key as the primary key for the data source in Data Cloud.
Reference: Salesforce Formula Field Documentation
NEW QUESTION # 23
You can take the online Salesforce Salesforce-Data-Cloud practice exam multiple times. At the end of each attempt, you will get your progress report. By analyzing this report you can eliminate and overcome your mistakes. Salesforce Salesforce-Data-Cloud real dumps increase your chances of passing the Salesforce-Data-Cloud certification exam. A huge number of professionals got successful by using ITPassLeader Salesforce-Data-Cloud practice test material. In case you don't pass the Salesforce Data Cloud Accredited Professional Exam, Salesforce-Data-Cloud test after using Salesforce Salesforce-Data-Cloud pdf questions and practice tests, you can claim your refund. You can download a free demo of any Salesforce-Data-Cloud exam dumps format and check the features before buying. Start Salesforce Salesforce-Data-Cloud test preparation today and obtain the highest marks in the actual Salesforce-Data-Cloud exam.
Latest Salesforce-Data-Cloud Version: https://www.itpassleader.com/Salesforce/Salesforce-Data-Cloud-dumps-pass-exam.html
Salesforce Salesforce-Data-Cloud Test Result Q12: Is it possible to download some of the sample test files before any actual purchase of the product, Pass with ease, You can get your money back if you failed the exam with Latest Salesforce-Data-Cloud Version certification dumps, Salesforce Salesforce-Data-Cloud Test Result Unless you are completely desperate, our study guide can deal with your troubles, Salesforce Salesforce-Data-Cloud Test Result Our test dumps will actually help you pass exams with passing marks surely.
What's more important is that we have spare space, so you can take notes under each question in the process of learning Salesforce-Data-Cloud Study Tool, It's to get a moderate volume of people who will be interested in your message.
Pass Salesforce-Data-Cloud Exam Confidently with ITPassLeader Real DumpsQ12: Is it possible to download some of the sample test files before any Salesforce-Data-Cloud actual purchase of the product, Pass with ease, You can get your money back if you failed the exam with Accredited Professional certification dumps.
Unless you are completely desperate, our study guide Salesforce-Data-Cloud Test Result can deal with your troubles, Our test dumps will actually help you pass exams with passing marks surely.
- Valid Salesforce-Data-Cloud Exam Simulator 💓 Salesforce-Data-Cloud Test Free 💛 Salesforce-Data-Cloud Valuable Feedback 🌱 Open website ➤ [url]www.prepawaypdf.com ⮘ and search for ▶ Salesforce-Data-Cloud ◀ for free download 😳New APP Salesforce-Data-Cloud Simulations[/url]
- Test Salesforce-Data-Cloud Collection 🐉 Valid Salesforce-Data-Cloud Exam Simulator 🏪 Salesforce-Data-Cloud Latest Braindumps Pdf ⚔ Search for Salesforce-Data-Cloud on ➤ [url]www.pdfvce.com ⮘ immediately to obtain a free download 🤴Salesforce-Data-Cloud Simulations Pdf[/url]
- Test Salesforce-Data-Cloud Collection 🥾 Salesforce-Data-Cloud Latest Study Notes 👰 Valid Salesforce-Data-Cloud Exam Simulator 🕜 Easily obtain free download of ▛ Salesforce-Data-Cloud ▟ by searching on ⇛ [url]www.testkingpass.com ⇚ 🧴Valid Dumps Salesforce-Data-Cloud Questions[/url]
- Salesforce-Data-Cloud Reliable Exam Cost 😆 New APP Salesforce-Data-Cloud Simulations 🕔 Exam Cram Salesforce-Data-Cloud Pdf 🧅 Open ➡ [url]www.pdfvce.com ️⬅️ enter ▷ Salesforce-Data-Cloud ◁ and obtain a free download 🦱Salesforce-Data-Cloud Simulations Pdf[/url]
- Salesforce-Data-Cloud Test Engine Version 🕝 Salesforce-Data-Cloud Simulations Pdf 🛒 Salesforce-Data-Cloud Study Guide 🆖 Open website [ [url]www.prepawayexam.com ] and search for ▛ Salesforce-Data-Cloud ▟ for free download ❎Salesforce-Data-Cloud Test Free[/url]
- Salesforce-Data-Cloud Valuable Feedback 🅾 Salesforce-Data-Cloud Free Exam Dumps 📹 Salesforce-Data-Cloud Test Engine Version 💝 Easily obtain free download of ➠ Salesforce-Data-Cloud 🠰 by searching on ⇛ [url]www.pdfvce.com ⇚ 🧔Salesforce-Data-Cloud Latest Study Notes[/url]
- Pass Guaranteed 2026 Salesforce - Salesforce-Data-Cloud Test Result 😊 Search for ⇛ Salesforce-Data-Cloud ⇚ and download it for free immediately on ☀ [url]www.vceengine.com ️☀️ 🦳New APP Salesforce-Data-Cloud Simulations[/url]
- Test Salesforce-Data-Cloud Dumps Pdf 🔀 New APP Salesforce-Data-Cloud Simulations 👠 Salesforce-Data-Cloud Latest Study Notes 🍴 Easily obtain Salesforce-Data-Cloud for free download through ⏩ [url]www.pdfvce.com ⏪ 🛵Salesforce-Data-Cloud Simulations Pdf[/url]
- Pass the First Time For The Salesforce Salesforce-Data-Cloud Exam 🦙 Easily obtain ➽ Salesforce-Data-Cloud 🢪 for free download through ▶ [url]www.prepawayete.com ◀ 🔵Valid Dumps Salesforce-Data-Cloud Questions[/url]
- Reliable Salesforce-Data-Cloud Study Guide 🥭 Salesforce-Data-Cloud Braindumps Downloads L Salesforce-Data-Cloud Latest Braindumps Pdf 🎹 Download ⮆ Salesforce-Data-Cloud ⮄ for free by simply entering [url]www.pdfvce.com website 📺Salesforce-Data-Cloud Valuable Feedback[/url]
- Salesforce-Data-Cloud Test Free ☯ Salesforce-Data-Cloud Latest Study Notes 🤣 New APP Salesforce-Data-Cloud Simulations ⏏ The page for free download of ✔ Salesforce-Data-Cloud ️✔️ on [url]www.prep4sures.top will open immediately 🚢Salesforce-Data-Cloud Test Practice[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, conceptplusacademy.com, Disposable vapes
DOWNLOAD the newest ITPassLeader Salesforce-Data-Cloud PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1Wjh_cqxwOYXsBda630HNZ_atc26PAu-s
