[General] F5CAB4 Lead2pass Review - F5CAB4 Reliable Test Practice
91
General F5CAB4 Lead2pass Review - F5CAB4 Reliable Test Practice
Posted at 2/18/2026 19:54:12      View99 | Replies0        Print      Only Author   [Copy Link] 1#
We offer you free update for one year after you purchase F5CAB4 study guide from us, namely, in the following year, you can get the update version for free. And our system will automatically send the latest version to your email address. Moreover, F5CAB4 exam dumps of us are compiled by experienced experts of the field, and they are quite familiar with dynamics of the exam center, therefore the quality and accuracy of the F5CAB4 Study Guide can be guaranteed. You just need to choose us, and we will help you pass the exam successfully.
F5 F5CAB4 Exam Syllabus Topics:
  • Explain config sync: This section focuses on configuration synchronization procedures, identifying sync errors, determining sync necessity, checking sync status, and comparing configuration timestamps.
  • Identify and report current device status: This domain covers monitoring BIG-IP operational status through LCD panels, dashboards, Network Map, GUI
  • TMSH commands, and checking high availability states.
  • Identify management connectivity configurations: This section focuses on understanding management access configurations, including management IP addresses, port lockdown settings, remote connectivity verification, and troubleshooting access issues.
  • Explain authentication methods: This section focuses on user management including creating
  • modifying users, configuring remote authentication providers, and implementing group-based access control.
Topic 5
  • Given a scenario, determine device upgrade eligibility: This domain covers determining appropriate timing for software and platform upgrades and strategies to minimize downtime during upgrades.
Topic 6
  • Identify configured system services: This domain covers verifying proper configuration of essential services including DNS, NTP, SNMP, and syslog.
Topic 7
  • List which log files could be used to find events and
  • or hardware issues: This section teaches identification of key log files (
  • var
  • log
  • ltm, secure, audit), understanding event severity levels, and interpreting log messages.
Topic 8
  • Given a scenario, interpret Service status: This section teaches interpreting service states, analyzing netstat output, and determining whether services are listening on specific ports.
Topic 9
  • Apply procedural concepts required to create, manage, and restore a UCS archive: This domain covers UCS backup and restore procedures, understanding backup use cases, proper storage practices, and UCS file contents including private keys.
From F5CAB4 Lead2pass Review to BIG-IP Administration Control Plane Administration, Eastest Way to PassOur F5CAB4 practice engine is admired by all our customers for our experts' familiarity and dedication with the industry all these years. By their help, you can qualify yourself with high-quality F5CAB4 exam materials. Our experts pass onto the exam candidate their know-how of coping with the exam by our F5CAB4 Training Questions. And i can say that our F5CAB4 study guide is the unique on the market for its high-effective.
F5 BIG-IP Administration Control Plane Administration Sample Questions (Q40-Q45):NEW QUESTION # 40
As an organization grows, more people have to log into the BIG-IP. Instead of adding more local users, the BIG-IP Administrator is asked to configure remote authentication against a central authentication server.
Which two types of remote server can be used here? (Choose two answers)
  • A. SAML
  • B. LDAP
  • C. OAUTH
  • D. RADIUS
Comprehensive and Detailed Explanation From BIG-IP Administration Control Plane Administration documents:
BIG-IP supports remote authentication by integrating with centralized authentication services through its AAA framework. The supported and commonly used remote authentication servers include:
LDAP (A)
Used to authenticate users against directory services such as Active Directory or other LDAP-compliant directories.
RADIUS (C)
Commonly used for centralized authentication, authorization, and accounting, especially in network and security environments.
OAUTH (B) is an authorization framework, not supported as a direct administrative authentication backend for BIG-IP management access.
SAML (D) is primarily used for single sign-on (SSO) in application authentication scenarios, not for BIG-IP administrative login authentication.
Thus, the correct remote authentication server types are LDAP and RADIUS.
NEW QUESTION # 41
Which TMSH command initiates a manual configuration synchronization to the specified device group?
(Choose one answer)
  • A. tmsh run cm config-sync to-group <device_group>
  • B. tmsh modify sys failover auto-sync enable
  • C. tmsh run sys device-group update-config
  • D. tmsh load sys config to-group <device_group>
In a BIG-IP Device Service Cluster (DSC), manual configuration synchronization is performed using the ConfigSync framework. The supported and documented command to manually push the local configuration to a specific device group is:
This command:
* Initiates a one-time manual ConfigSync
* Pushes the local device's configuration to all members of the specified device group
* Is commonly used when auto-sync is disabled or when the administrator wants explicit control over synchronization timing Why the other options are incorrect:
* A is not a valid TMSH command for ConfigSync.
* B enables auto-sync but does not perform an immediate synchronization.
* D is not a valid or supported TMSH command for device group configuration synchronization.
Therefore, the correct command to manually synchronize configuration to a device group is C.
NEW QUESTION # 42
A BIG-IP Administrator needs to restore a UCS file to an F5 device using the Configuration Utility.
Which section of the Configuration Utility should the BIG-IP Administrator access to perform this task? (Choose one answer)
  • A. Local Traffic > Policies
  • B. System > Configuration
  • C. Local Traffic > Virtual Servers
  • D. System > Archives
In the BIG-IP Configuration Utility, all system backup and restore operations-including UCS (User Configuration Set) file restoration-are performed from the Archives section.
The correct navigation path is:
System > Archives
From this location, the administrator can:
Upload UCS files
Restore UCS backups
Manage system archive files used for backup and recovery
A . System > Configuration is used for general system settings, not backup restoration.
C . Local Traffic > Virtual Servers is used for application traffic objects.
D . Local Traffic > Policies manages traffic policies, not system backups.
Therefore, the correct section to restore a UCS file using the Configuration Utility is System > Archives.
NEW QUESTION # 43
A user needs to generate a QKView to upload to iHealth to determine any issues with upgrading TMOS. Where can the user generate the QKView in the Configuration Utility?
  • A. System > Support
  • B. System > Software Management
  • C. System > Archives
  • D. System > Configuration
Comprehensive and Detailed Explanation From BIG-IP Administration Control Plane Administration documents: Generating a QKView is a standard procedure for identifying device health and upgrade readiness42. Within the Configuration Utility, this Control Plane diagnostic tool is located under System > Support43. This utility collects configuration and state data into a single file used by the iHealth 'Upgrade Advisor' to report on known bugs or compatibility issues prior to a version change.
NEW QUESTION # 44
A BIG-IP Administrator defines a device Self IP. The Self IP is NOT reachable from the network. What should the administrator verify first?
  • A. The correct VLAN has been selected.
  • B. The correct Trunk has been selected.
  • C. The correct Interface has been selected.
  • D. Verify if auto last hop is disabled.
Connectivity management requires a proper logical-to-physical mapping within the BIG-IP Control Plane.
* VLAN Association: In TMOS, a Self IP address is not assigned directly to a physical interface. Instead, it is assigned to a VLAN (Virtual Local Area Network) object.
* Procedural Troubleshooting: If a Self IP is unreachable, the primary failure point is often that the IP was associated with the wrong VLAN, or the VLAN itself is not correctly associated with the intended physical interface or trunk.
* Layer 2 Mapping: The Control Plane requires the VLAN to be "up" and "untagged" or "tagged" on a valid interface for traffic to flow. If the administrator selects the incorrect VLAN, the Self IP will exist in the configuration but will be logically isolated from the physical network wire.
NEW QUESTION # 45
The price of Our F5CAB4 practice guide is affordable, and you can always find that from time to time, we will give some promotion for our worthy customers. Meanwhile, we provide the wonderful service before and after the sale to let you have a good understanding of our F5CAB4 Study Materials. Our service are working at 24/7 online to give you the best and the most professional guidance on our F5CAB4 learning braindumps.
F5CAB4 Reliable Test Practice: https://www.briandumpsprep.com/F5CAB4-prep-exam-braindumps.html
