Latest HPE7-A02 Exam Notes - HPE7-A02 Valid Test Objectives
Posted at yesterday 21:07
P.S. Free & New HPE7-A02 dumps are available on Google Drive shared by PDFDumps: https://drive.google.com/open?id=1dGpF9mtgd_A9aDPbKXu9_ghMLHZT6f9L
One of the best features of PDFDumps exam questions is free updates for up to 1 year. The PDFDumps has hired a team of experienced and qualified HPE7-A02 exam trainers. They update the HPE7-A02 exam questions as per the latest HPE7-A02 Exam Syllabus. So rest assured that with the PDFDumps you will get the updated HPE7-A02 exam practice questions all the time. Try a free demo if you to evaluate the features of our product. Best of luck!
HP HPE7-A02 certification exam is designed to assess your expertise in network security and validate your skills in implementing secure network infrastructure solutions. Aruba Certified Network Security Professional Exam certification is specifically intended for professionals who are responsible for designing, implementing, and troubleshooting network security solutions in complex enterprise environments. The HPE7-A02 Exam focuses on testing your knowledge and skills in areas such as network security technologies, security protocols, access control, intrusion detection and prevention, and network security management.
HPE7-A02 Valid Test Objectives | New HPE7-A02 Test LabsOur online test engine and the windows software of the HPE7-A02 guide materials can evaluate your exercises of the virtual exam and practice exam intelligently. Our calculation system of the HPE7-A02 study engine is designed subtly. Our evaluation process is absolutely correct. We are strictly in accordance with the detailed grading rules of the real exam. And our pass rate of the HPE7-A02 Exam Questions are high as 98% to 100%, it is unique in the market.
HP Aruba Certified Network Security Professional Exam Sample Questions (Q29-Q34):NEW QUESTION # 29
You are establishing a cluster of HPE Aruba Networking ClearPass servers. (Assume that they are running version 6.9.).
For which type of certificate is it recommended to install a CA-signed certificate on the Subscriber before it joins the cluster?
- A. RadSec
- B. Database
- C. HTTPS
- D. RADIUS/EAP
When setting up a ClearPass cluster, it is critical to ensure secure communication between the cluster nodes and the client devices. For this purpose, certain certificates must be properly configured.
1. Why HTTPS Requires a CA-Signed Certificate?
* HTTPS communication is used for inter-cluster communication and for the web-based user interface that administrators use to manage the ClearPass cluster.
* Before joining the cluster, it is strongly recommended to install a CA-signed HTTPS certificate on the Subscriber to ensure secure communication and prevent warnings/errors due to untrusted certificates.
* Without a CA-signed certificate, the Subscriber might use a self-signed certificate, leading to security risks and lack of trust validation.
2. Analysis of Other Certificate Types
* B. Database:
* Incorrect: Database communications within ClearPass clusters are secured using internal certificates or keys. These are not user-facing and do not require a CA-signed certificate before joining the cluster.
* C. RADIUS/EAP:
* Incorrect: RADIUS/EAP certificates are important for client authentication, but they are not required on the Subscriber prior to cluster joining. These can be configured after the Subscriber is part of the cluster.
* D. RadSec:
* Incorrect: RadSec is an optional feature for secure RADIUS communication over TLS, and its certificate configuration is typically performed post-cluster setup.
Final Recommendation
To ensure secure cluster operations and seamless web-based management, a CA-signed HTTPS certificate should be installed on the Subscriber before it joins the ClearPass cluster.
References
* ClearPass Deployment Guide for Version 6.9.
* Best Practices for Certificate Management in ClearPass Clusters.
* HPE Aruba ClearPass Cluster Configuration Guide.
NEW QUESTION # 30
You have set up a mirroring session between an AOS-CX switch and a management station, running Wireshark. You want to capture just the traffic sent in the mirroring session, not the management station's other traffic.
What should you do?
- A. Edit protocol preferences and enable HPE_ERM.
- B. Apply this capture filter: udp port 5555
- C. Edit protocol preferences and enable ARUBA_ERM.
- D. Apply this capture filter: ip proto 47
To capture only the traffic sent in the mirroring session between an AOS-CX switch and a management station running Wireshark, you should apply a capture filter that isolates the specific traffic of interest. In this case, using the filter udp port 5555 will capture the traffic associated withthe mirroring session. This is because AOS-CX switches typically use UDP port 5555 for mirrored traffic, ensuring that only the relevant mirrored packets are captured and excluding other traffic generated by the management station.
NEW QUESTION # 31
What is a use case for running periodic subnet scans on devices from HPE Aruba Networking ClearPass Policy Manager (CPPM)?
- A. Identifying issues with authenticating and authorizing clients
- B. Using WMI to collect additional information about Windows domain clients
- C. Using DHCP fingerprints to determine a client's device category and OS
- D. Detecting devices that fail to comply with rules defined in CPPM posture policies
Running periodic subnet scans on devices from HPE Aruba Networking ClearPass Policy Manager (CPPM) can be used to gather DHCP fingerprints, which help determine a client's device category and operating system. DHCP fingerprints are unique patterns in DHCP request packets that provide valuable information about the device type and OS, assisting in device profiling and policy enforcement.
1.DHCP Fingerprinting: This technique captures specific details from DHCP packets to identify the type and operating system of a device.
2.Device Profiling: By running subnet scans, CPPM can continuously update its device database with accurate profiles, ensuring that policies are applied correctly based on the device type.
3.Network Visibility: Regular scanning helps maintain up-to-date visibility of all devices on the network, improving security and management.
Reference: ClearPass documentation on device profiling and network visibility outlines the use of DHCP fingerprints for identifying and categorizing devices, emphasizing the importance of periodic subnet scans for maintaining accurate profiles.
NEW QUESTION # 32
A company has HPE Aruba Networking gateways that implement gateway IDS/IPS. Admins sometimes check the Security Dashboard, but they want a faster way to discover if a gateway starts detecting threats in traffic.
What should they do?
- A. Set up email notifications using HPE Aruba Networking Central's global alert settings.
- B. Use Syslog to integrate the gateways with HPE Aruba Networking ClearPass Policy Manager (CPPM) event processing.
- C. Set up Webhooks that are attached to the HPE Aruba Networking Central Threat Dashboard.
- D. Integrate HPE Aruba Networking ClearPass Device Insight (CPDI) with Central and schedule hourly reports.
For a faster way to discover if a gateway starts detecting threats in traffic, admins should set up email notifications using HPE Aruba Networking Central's global alert settings. This setup ensures that the security team is promptly informed via email whenever the IDS/IPS on the gateways detects any threats, allowing for immediate investigation and response.
1.Email Notifications: By configuring email notifications, admins can receive real-time alerts directly to their inbox, reducing the time to discover and react to security incidents.
2.Global Alert Settings: HPE Aruba Networking Central's global alert settings allow for customization of alerts based on specific security events and thresholds, providing flexibility in monitoring and response.
3.Proactive Monitoring: This proactive approach ensures that the security team is always aware of potential threats without the need to constantly check the Security Dashboard manually.
NEW QUESTION # 33
You are setting up HPE Aruba Networking SSE to detect threats as remote users browse the internet.
What is part of this process?
- A. Creating a non-default file security profile
- B. Deploying a connector that can reach the remote users
- C. Integrating HPE Aruba Networking SSE with a supported third-party antivirus provider
- D. Creating an external web profile that enables SSL inspection
HPE Aruba Networking SSE is a cloud-delivered Security Service Edge platform that provides secure web gateway, ZTNA, CASB/DLP, and cloud firewall functions. Threat detection for remote web browsing relies heavily on full traffic inspection, including SSL inspection, URL filtering, and malware scanning.
In Aruba SSE deployments that protect web access from campus/branch or remote users, you:
* Integrate the on-prem gateway or AOS-10 environment with SSE using an external web profile, which defines how traffic is sent to SSE.
* Within that profile, you enable SSL inspection so that SSE can decrypt and inspect HTTPS traffic, allowing advanced threat detection, DLP, and malware scanning.
* Option A: Custom file security profiles can tune malware scanning, but using a non-default profile is not mandatory for basic threat detection.
* Option B: SSE already includes built-in anti-malware and sandboxing; it doesn't require a separate third-party antivirus integration for core features.
* Option C: Connectors in SSE are used mainly to reach private applications (ZTNA), not to "reach remote users" for general web browsing.
Therefore, an essential part of enabling threat detection for web browsing is creating an external web profile that enables SSL inspection # Option D.
NEW QUESTION # 34
We believe that the best brands of HPE7-A02 study materials are those that go beyond expectations. They don't just do the job – they go deeper and become the fabric of our lives. Therefore, our company as the famous brand, even though we have been very successful in providing HPE7-A02 practice guide we have never satisfied with the status quo, and always be willing to constantly update the contents of our HPE7-A02 Exam Torrent in order to keeps latest information about HPE7-A02 exam. With our HPE7-A02 exam questions, you can pass the HPE7-A02 exam and get the dreaming certification.
HPE7-A02 Valid Test Objectives: https://www.pdfdumps.com/HPE7-A02-valid-exam.html
- Customized HPE7-A02 Lab Simulation ↗ HPE7-A02 PDF Guide 🔃 Reliable HPE7-A02 Test Price 🎰 Search for ➡ HPE7-A02 ️⬅️ and download it for free immediately on ➠ [url]www.prepawayete.com 🠰 🕚HPE7-A02 Free Dump Download[/url]
- Latest Latest HPE7-A02 Exam Notes by Pdfvce 🍪 Download ➤ HPE7-A02 ⮘ for free by simply searching on ➽ [url]www.pdfvce.com 🢪 🎎HPE7-A02 Valid Test Simulator[/url]
- HPE7-A02 Valid Exam Preparation 😅 HPE7-A02 Free Dump Download 🍯 HPE7-A02 Latest Training ☘ Open website ➤ [url]www.dumpsquestion.com ⮘ and search for ➽ HPE7-A02 🢪 for free download 🎲HPE7-A02 Test Questions Vce[/url]
- Web-Based Practice Exams to Evaluate HPE7-A02 Aruba Certified Network Security Professional Exam Exam Preparation 🥪 Search for ➽ HPE7-A02 🢪 and download it for free immediately on ⏩ [url]www.pdfvce.com ⏪ 🍒
ractice HPE7-A02 Test Engine[/url] - HPE7-A02 Exam Simulation: Aruba Certified Network Security Professional Exam - HPE7-A02 Study Guide Materials 🌆 The page for free download of ➽ HPE7-A02 🢪 on [ [url]www.prep4sures.top ] will open immediately 😀
ractice HPE7-A02 Test Engine[/url] - HP Latest HPE7-A02 Exam Notes: Aruba Certified Network Security Professional Exam - Pdfvce 100% Pass Rate Offer 🥬 Search for ⮆ HPE7-A02 ⮄ on ☀ [url]www.pdfvce.com ️☀️ immediately to obtain a free download 💈HPE7-A02 Valid Test Fee[/url]
- HPE7-A02 Latest Training ♥ Hot HPE7-A02 Questions 💾 HPE7-A02 Latest Dumps Files 🥦 Copy URL ⮆ [url]www.pdfdumps.com ⮄ open and search for ▶ HPE7-A02 ◀ to download for free 🏩HPE7-A02 Latest Exam Simulator[/url]
- [url=http://amerimartest.ml/?s=HPE7-A02%20Exam%20Simulation:%20Aruba%20Certified%20Network%20Security%20Professional%20Exam%20-%20HPE7-A02%20Study%20Guide%20Materials%20%f0%9f%8d%a6%20The%20page%20for%20free%20download%20of%20[%20HPE7-A02%20]%20on%20%e2%9e%a4%20www.pdfvce.com%20%e2%ae%98%20will%20open%20immediately%20%f0%9f%a4%95HPE7-A02%20Test%20Topics%20Pdf]HPE7-A02 Exam Simulation: Aruba Certified Network Security Professional Exam - HPE7-A02 Study Guide Materials 🍦 The page for free download of [ HPE7-A02 ] on ➤ www.pdfvce.com ⮘ will open immediately 🤕HPE7-A02 Test Topics Pdf[/url]
- HPE7-A02 Exam Simulation: Aruba Certified Network Security Professional Exam - HPE7-A02 Study Guide Materials 🔐 Open 「 [url]www.troytecdumps.com 」 and search for 【 HPE7-A02 】 to download exam materials for free 🤽Reliable HPE7-A02 Test Price[/url]
- 100% Pass HP First-grade HPE7-A02 Latest Aruba Certified Network Security Professional Exam Exam Notes 🚞 Search for ➥ HPE7-A02 🡄 and download it for free on ⇛ [url]www.pdfvce.com ⇚ website 🏨HPE7-A02 Free Dump Download[/url]
- How to Get the HP HPE7-A02 Certification within the Target Period? 🍌 Search for [ HPE7-A02 ] on 「 [url]www.pdfdumps.com 」 immediately to obtain a free download 📙HPE7-A02 Reliable Braindumps Free[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, vanessapotter.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
BONUS!!! Download part of PDFDumps HPE7-A02 dumps for free: https://drive.google.com/open?id=1dGpF9mtgd_A9aDPbKXu9_ghMLHZT6f9L
