Palo Alto Networks SecOps-Generalist PDF Question & SecOps-Generalist Reliab
137
Posted at 2/18/2026 21:50:06      View:69 | Replies:0        Print      Only Author   [Copy Link] 1#
Being a social elite and making achievements in your own field may be the dream of all people. However, only a very few people seize the initiative in their life. Perhaps our research data will give you some help. As long as you spend less time on the game and spend more time on learning, the SecOps-Generalist study materials can reduce your pressure so that users can feel relaxed and confident during the preparation and certification process. It is believed that many users have heard of the SecOps-Generalist Study Materials from their respective friends or news stories. So why don't you take this step and try? You will not regret your wise choice.
The passing rate of our SecOps-Generalist test torrent is high but if you fail in the exam we will refund you in full immediately. Some people may worry that the refund procedure is complicate but we guarantee to the client that the refund procedure is very simple. If only you provide the screenshot or the scanning copy of SecOps-Generalist Exam failure marks list we will refund you immediately and the process is really simple. It is very worthy for you to buy our SecOps-Generalist guide questions and we can help you pass the exam successfully.
Quiz 2026 Palo Alto Networks SecOps-Generalist: Palo Alto Networks Security Operations Generalist – Efficient PDF QuestionWe learned that a majority of the candidates for the exam are office workers or students who are occupied with a lot of things, and do not have plenty of time to prepare for the SecOps-Generalist exam. Taking this into consideration, we have tried to improve the quality of our SecOps-Generalist training materials for all our worth. Now, I am proud to tell you that our SecOps-Generalist Exam Questions are definitely the best choice for those who have been yearning for success but without enough time to put into it. Just buy them and you will pass the exam by your first attempt!
Palo Alto Networks Security Operations Generalist Sample Questions (Q63-Q68):NEW QUESTION # 63
Device-ID, as a feature on Palo Alto Networks NGFWs and integrated with IoT Security, provides visibility into the types of devices communicating on the network. Which of the following network attributes or protocols can Device-ID leverage to help identify and profile connected devices (including IoT devices)? (Select all that apply)
  • A. Reading the Serial Number of the device remotely via SNMP.
  • B. User-Agent strings in HTTP/HTTPS traffic
  • C. Specific protocols and communication patterns observed in the traffic (e.g., Modbus, BACnet, specific IoT protocols)
  • D. DHCP option fields (e.g., Option 60 - Vendor Class Identifier)
  • E. OS fingerprinting based on TCP/IP stack characteristics
Answer: B,C,D,E
Device-ID (and the underlying technology leveraged by IoT Security) uses various passive methods to fingerprint and identify devices based on their network behavior and communication characteristics. - Option A (Correct): DHCP options, particularly the Vendor Class Identifier, often contain information about the device manufacturer or model. - Option B (Correct): User-Agent strings in web traffic can reveal details about the browser, OS, and sometimes the device type (e.g., mobile vs. desktop). - Option C (Correct): Different operating systems and network stacks have unique ways of handling TCP/IP (e.g., initial window size, TTL values, flag combinations). Device-ID can fingerprint devices based on these characteristics. - Option D (Correct): Many IoT devices use specific industry protocols or exhibit unique communication patterns. Identifying these protocols (like Modbus for industrial control) and patterns helps classify the device. - Option E (Incorrect): Device-ID is primarily a passive identification technology based on traffic analysis, not active management protocols like SNMP that require authentication and configuration on the endpoint.
NEW QUESTION # 64
When onboarding IoT devices for visibility and security using Palo Alto Networks platforms with the IoT Security subscription, which of the following is the primary method the NGFW or Prisma Access uses to gain visibility into the IoT traffic and identify the devices communicating on the network?
  • A. Analyzing network traffic flows passing through the firewall to identify device types based on communication patterns, protocols, and metadata.
  • B. Installing an agent on each IoT device to report its characteristics and communication patterns.
  • C. Performing active scans of network subnets to discover and profile IoT devices.
  • D. Integrating with endpoint detection and response (EDR) agents deployed on IoT devices.
  • E. Relying on SNMP traps from network switches to identify device connections.
Palo Alto Networks IoT Security focuses on passive analysis of network traffic to identify and profile IoT devices without requiring agents on the devices themselves, which is often impossible or impractical for IoT. - Option A: Most IoT devices do not support installing third-party agents. - Option B (Correct): The NGFW or Prisma Access acts as a sensor, inspecting traffic flows (packet headers, protocols, behavioral patterns, connection destinations) as they pass through. This passive analysis is fed to the IoT Security cloud service, which uses machine learning and a vast database of known IoT devices and their behaviors to profile and categorize the devices. - Option C: Active scanning is generally avoided for IoT devices as it can disrupt their operation or be unreliable. - Option D: EDR agents are not typically deployable on IoT devices. - Option E: SNMP traps from switches can provide information about device connectivity but not the deep traffic analysis needed for device profiling and behavioral anomaly detection provided by the IoT Security subscription.
NEW QUESTION # 65
A security operations center (SOC) analyst is responsible for monitoring security events for users connected to Prisma Access. They need to access a centralized repository of logs generated by the Prisma Access service edges to investigate incidents, analyze traffic patterns, and generate reports. Which Palo Alto Networks cloud-based service provides this centralized logging functionality for Prisma Access?
  • A. Prisma SD-WAN Cloud Management Console
  • B. Legacy Syslog server
  • C. Prisma Cloud
  • D. Cortex Data Lake (formerly Strata Logging Service)
  • E. Panorama M-Series appliance
Cortex Data Lake (CDL), previously known as the Strata Logging Service, is the dedicated cloud-based log collection and storage service for Palo Alto Networks next-generation firewalls (PA-Series, VM-Series, CN-Series) and cloud-delivered security services like Prisma Access and Prisma SD-WAN. It provides a centralized repository for logs from distributed devices/services, enabling comprehensive monitoring and analysis. Option A is for managing SD-WAN. Option B is for cloud security posture management. Option D is an on-premises hardware appliance for management, not the primary cloud logging service. Option E is a generic logging solution, not the integrated Palo Alto Networks cloud service.
NEW QUESTION # 66
An organization is using Panorama to manage its PA-Series firewalls and has integrated Prisma Access logging with Panorama's Log Collector. The security team wants to generate a report that shows all traffic sessions that were denied by any security policy rule across all managed firewalls and Prisma Access nodes, grouped by the denying policy rule name and showing the source user and destination application. Which of the following steps or considerations are necessary to build this comprehensive report in Panorama? (Select all that apply)
  • A. Include columns for 'Rule Name', 'Source User', and 'Application' in the custom report definition.
  • B. Create a custom report in Panorama's Monitor > Reports tab, filtering for Log Type 'Traffic' and Action 'deny'.
  • C. Ensure that all relevant Security Policy rules on managed firewalls and Prisma Access are configured with logging enabled.
  • D. Generate the report using System logs, as they contain policy violation details.
  • E. Ensure that traffic logs from all managed firewalls and Prisma Access nodes are successfully being forwarded to the Panorama Log Collector.
Answer: A,B,C,E
Generating comprehensive reports across multiple devices/services requires data availability and correct reporting configuration. - Option A (Correct): Policy rule logs must be enabled on the individual firewalls/Prisma Access nodes. If a deny rule doesn't have logging enabled, sessions hitting it won't be recorded in the traffic logs. - Option B (Correct): Logs must be successfully collected in Panorama (or CDL if Panorama is forwarding to it). If logs are not forwarded correctly, the central repository won't have the data. - Option C (Correct): You use the 'Traffic' log type because it contains details about allowed/denied sessions, and you filter for the 'deny' action. - Option D (Correct): To see the requested information (rule name, user, application), you must include these fields as columns in the report output. The firewall logs capture this information (assuming User-ID and App-ID were operational). - Option E (Incorrect): System logs are for firewall operational events, not details of denied traffic sessions.
NEW QUESTION # 67
In addition to identifying device types and vulnerabilities, the Palo Alto Networks IoT Security subscription also performs behavioral analytics on IoT traffic. If the platform detects a 'High' severity behavioral anomaly from a device (e.g., unexpected communication with an external IP, unusual data transfer size), how is this intelligence typically integrated with the NGFW for policy enforcement or alerting?
  • A. The IoT Security cloud service automatically changes the firewall's security policy to block the anomalous communication.
  • B. The NGFW sends the full packet capture of the anomalous traffic to WildFire for detailed analysis.
  • C. The anomaly triggers a 'Threat' log entry with a specific threat ID and severity on the NGFW/Panorama/CDL.
  • D. An alert is generated in the IoT Security dashboard, but no immediate action is taken on the NGFW.
  • E. The anomalous device is automatically moved into a 'High-Risk IoT' dynamic device group, which can be used as a matching criterion in Security Policy rules with a 'deny' action.
Answer: C,E
Behavioral anomalies detected by IoT Security are integrated for alerting and policy enforcement. - Option A (Correct): Behavioral anomalies are typically logged as specific event types, often categorized as threats or system events with a relevant severity, visible in the NGFW/Panorama/CDL logs for investigation. - Option B (Incorrect): The cloud service doesn't automatically modify the firewall's security policy. Policy changes are managed by the administrator. - Option C (Correct): Detecting a high-severity anomaly can cause the device to be automatically classified into a dynamic device group representing high-risk devices. Administrators can then leverage this group in Security Policies to isolate or restrict traffic from such devices automatically upon reclassification. - Option D: An alert is generated, but automated actions via policy integration (as described in A and C) are possible and intended. - Option E: While WildFire analyzes files and potentially stream content, behavioral analysis is distinct and doesn't necessarily involve sending full packet captures to WildFire for every anomaly.
NEW QUESTION # 68
Our Palo Alto Networks SecOps-Generalist can help you clear exams at first shot. We promise that we provide you with best quality Palo Alto Networks SecOps-Generalist original questions and competitive prices. We provide one year studying assist service and one year free updates downloading of Palo Alto Networks Security Operations Generalist exam questions.
SecOps-Generalist Reliable Exam Guide: https://www.braindumpquiz.com/SecOps-Generalist-exam-material.html
BraindumpQuiz SecOps-Generalist Reliable Exam Guide presents its practice platform in the form of desktop practice exam software, So please feel frustrate or depressed, trust us, trust our SecOps-Generalist VCE torrent, you will no need to spend too much time & money on your test but you can go through exam also, To encounter BraindumpQuiz SecOps-Generalist Reliable Exam Guide, you will encounter the best training materials, the study guides of BraindumpQuiz SecOps-Generalist Reliable Exam Guide are there to help you get through the exam without any hassle.
SharePoint supports numerous authentication methods, and you need to SecOps-Generalist PDF Question understand when it is appropriate to use each type of authentication, Now, there are so many customers have passed the exam smoothly.
Efficient SecOps-Generalist PDF Question | SecOps-Generalist 100% Free Reliable Exam GuideBraindumpQuiz presents its practice platform in SecOps-Generalist the form of desktop practice exam software, So please feel frustrate or depressed, trust us, trust our SecOps-Generalist VCE torrent, you will no need to spend too much time & money on your test but you can go through exam also.
To encounter BraindumpQuiz, you will encounter the best training SecOps-Generalist PDF Question materials, the study guides of BraindumpQuiz are there to help you get through the exam without any hassle.
I know many people are concerned about the content of Palo Alto Networks Security Operations Generalist actual test.
