[General] Related Salesforce Data-Con-101 Certifications & Latest Data-Con-101 Test Re
【General】 Related Salesforce Data-Con-101 Certifications & Latest Data-Con-101 Test Re
Posted at 2/18/2026 22:11:19      View:85 | Replies:1        Print      Only Author   [Copy Link] 1#
In order to save a lot of unnecessary trouble to users, we have completed our Salesforce Certified Data Cloud Consultant study questions research and development of online learning platform, users do not need to download and install, only need your digital devices have a browser, can be done online operation of the Data-Con-101 test guide. This kind of learning method is very convenient for the user, especially in the time of our fast pace to get Salesforce certification. In addition, our test data is completely free of user's computer memory, will only consume a small amount of running memory when the user is using our product. At the same time, as long as the user ensures that the network is stable when using our Data-Con-101 Training Materials, all the operations of the learning material of can be applied perfectly.
TestKingFree releases 100% pass-rate Salesforce Data-Con-101 study guide files which guarantee candidates 100% pass exam in the first attempt. It is time for you to choose a valid Salesforce Data-Con-101 study guide, this will be your best method for clearing exam and obtain a certification. Good Data-Con-101 Study Guide will be a shortcut for you to well-directed prepare and practice efficiently, you will avoid do much useless efforts and do something interesting.
Data-Con-101 valid study questions & Data-Con-101 exam preparation & Data-Con-101 pdf vce trainingTestKingFree is the website that has been known to learn IT technology. TestKingFree gets high praise from our customers in real test questions and answers. It is the real website that can help you to pass Salesforce Data-Con-101 certificate. Why is TestKingFree very popular? Because TestKingFree has a group of IT elite which is committed to provide you with the best test questions and test answers. Therefore, TestKingFree will provide you with more and better certification training materials to satisfy your need.
Salesforce Data-Con-101 Exam Syllabus Topics:
  • Act on Data: This domain focuses on leveraging Data Cloud data for downstream actions through activations and data actions. It covers working with attributes, managing timing dependencies, troubleshooting activation issues like errors and rejected counts, and understanding requirements for triggering automated processes.
  • Data Ingestion and Modeling: This domain addresses bringing data into Data Cloud and structuring it properly through transformation, ingestion from various sources, and data mapping. It emphasizes best practices for modeling data to support identity resolution and validating ingested data using available tools.
  • Data Cloud Overview: This domain covers the foundational understanding of Data Cloud including its core purpose, terminology, business value, and technical architecture. It also addresses typical use cases and the essential principles of ethical data handling when working with customer data.
  • Segmentation and Insights: This domain centers on creating audience segments and deriving analytical insights from Data Cloud. It includes configuring and maintaining segments, analyzing membership scenarios, and distinguishing between calculated insights and real-time streaming insights.
Salesforce Certified Data Cloud Consultant Sample Questions (Q15-Q20):NEW QUESTION # 15
A new user of Data Cloud only needs to be able to review individual rows of ingested data and validate that it has been modeled successfully to its linked data model object. The user will also need to make changes if required.
What is the minimum permission set needed to accommodate this use case?
  • A. Data Cloud for Marketing Specialist
  • B. Data Cloud User
  • C. Data Cloud Admin
  • D. Data Cloud for Marketing Data Aware Specialist
The Data Cloud User permission set is the minimum permission set needed to accommodate this use case.
The Data Cloud User permission set grants access to the Data Explorer feature, which allows the user to review individual rows of ingested data and validate that it has been modeled successfully to its linked data model object. The user can also make changes to the data model object fields, such as adding or removing fields, changing field types, or creating formula fields. The Data Cloud User permission set does not grant access to other Data Cloud features or tasks, such as creating data streams, creating segments, creating activations, or managing users. The other permission sets are either too restrictive or too permissive for this use case. The Data Cloud for Marketing Specialist permission set only grants access to the segmentation and activation features, but not to the Data Explorer feature. The Data Cloud Admin permission set grants access to all Data Cloud features and tasks, including the Data Explorer feature, but it is more than what the user needs. The Data Cloud for Marketing Data Aware Specialist permission set grants access to the Data Explorer feature, but also to the segmentation and activation features, which are not required for this use case. References: Data Cloud Standard Permission Sets, Data Explorer, Set Up Data Cloud Unit
NEW QUESTION # 16
Which two dependencies need to be removed prior to disconnecting a data source?
Choose 2 answers
  • A. Segment
  • B. Activation
  • C. Activation target
  • D. Data stream
Dependencies in Data Cloud:
Before disconnecting a data source, all dependencies must be removed to prevent data integrity issues.
Reference: Salesforce Data Source Management Documentation
Identifying Dependencies:
Segment: Segments using data from the source must be deleted or reassigned.
Data Stream: The data stream must be disconnected, as it directly relies on the data source.
Reference: Salesforce Segment and Data Stream Management Guide
Steps to Remove Dependencies:
Remove Segments:
Navigate to the Segmentation interface in Salesforce Data Cloud.
Identify and delete segments relying on the data source.
Disconnect Data Stream:
Go to the Data Stream settings.
Locate and disconnect the data stream associated with the source.
Reference: Salesforce Segment Deletion and Data Stream Disconnection Tutorial Practical Application:
Example: When preparing to disconnect a legacy CRM system, ensure all segments and data streams using its data are properly removed or migrated.
Reference: Salesforce Data Source Disconnection Best Practices
NEW QUESTION # 17
A consultant is setting up a data stream with transactional data,
Which field type should the consultant choose to ensure that leading
zeros in the purchase order number are preserved?
  • A. Number
  • B. Decimal
  • C. Text
  • D. Serial
The field type Text should be chosen to ensure that leading zeros in the purchase order number are preserved.
This is because text fields store alphanumeric characters as strings, and do not remove any leading or trailing characters. On the other hand, number, decimal, and serial fields store numeric values as numbers, and automatically remove any leading zeros when displaying or exporting the data123. Therefore, text fields are more suitable for storing data that needs to retain its original format, such as purchase order numbers, zip codes, phone numbers, etc. References:
Zeros at the start of a field appear to be omitted in Data Exports
Keep First '0' When Importing a CSV File
Import and export address fields that begin with a zero or contain a plus symbol
NEW QUESTION # 18
A consultant notices that the unified individual profile is not storing the latest email address.
Which action should the consultant take to troubleshoot this issue?
  • A. Confirm that the reconciliation rules are correctly used.
  • B. Check if the mapping of DLO objects is correct to Contact Point Email.
  • C. Remove any old email addresses from Salesforce CRM.
  • D. Verify and update the email address in the source systems if needed.
Understanding Unified Individual Profile:
The unified individual profile combines data from multiple sources to create a comprehensive view of each customer.
Reference: Salesforce Unified Profile Documentation
Issue with Latest Email Address:
If the latest email address is not being stored, the reconciliation rules, which determine how data from different sources is combined and updated, may be incorrectly configured.
Reference: Salesforce Data Reconciliation Overview
Reconciliation Rules:
These rules define which data source has priority and how conflicts are resolved when combining data.
Ensuring that these rules are correctly configured is essential for maintaining accurate and up-to-date profiles.
Reference: Salesforce Reconciliation Rules Guide
Steps to Troubleshoot:
Navigate to the reconciliation rules settings in Salesforce Data Cloud.
Review the current rules to ensure the correct handling of email addresses.
Verify that the rules prioritize the most recent data and handle duplicates appropriately.
Reference: Salesforce Reconciliation Rules Configuration Documentation
NEW QUESTION # 19
Which two requirements must be met for a calculated insight to appear in the segmentation canvas?
Choose 2 answers
  • A. The primary key of the segmented table must be a dimension in the calculated insight.
  • B. The calculated insight must contain a dimension including the Individual or Unified Individual Id.
  • C. The metrics of the calculated insights must only contain numeric values.
  • D. The primary key of the segmented table must be a metric in the calculated insight.
A calculated insight is a custom metric or measure that is derived from one or more data model objects or data lake objects in Data Cloud. A calculated insight can be used in segmentation to filter or group the data based on the calculated value. However, not all calculated insights can appear in the segmentation canvas. There are two requirements that must be met for a calculated insight to appear in the segmentation canvas:
The calculated insight must contain a dimension including the Individual or Unified Individual Id. A dimension is a field that can be used to categorize or group the data, such as name, gender, or location. The Individual or Unified Individual Id is a unique identifier for each individual profile in Data Cloud. The calculated insight must include this dimension to link the calculated value to the individual profile and to enable segmentation based on the individual profile attributes.
The primary key of the segmented table must be a dimension in the calculated insight. The primary key is a field that uniquely identifies each record in a table. The segmented table is the table that contains the data that is being segmented, such as the Customer or the Order table. The calculated insight must include the primary key of the segmented table as a dimension to ensure that the calculated value is associated with the correct record in the segmented table and to avoid duplication or inconsistency in the segmentation results.
Create a Calculated Insight, Use Insights in Data Cloud, Segmentation
NEW QUESTION # 20
As for Salesforce Data-Con-101 exam, it is the most difficult to pass. But, as long as you believe in TestKingFree, everything is ok. TestKingFree Salesforce Data-Con-101 exam simulations contain the most accurate questions and answers. If you don't believe our Salesforce Data-Con-101 certification training, you can go to our TestKingFree. You can find pdf real questions and answers and download it. And the purchase rate is unbelievably high every day. By choosing it, pass rate is 100%. Hurry up! Don't hesitate to add our Salesforce Data-Con-101 Dumps Torrent to your shopping cart.
Latest Data-Con-101 Test Report: https://www.testkingfree.com/Salesforce/Data-Con-101-practice-exam-dumps.html
Posted at 2/20/2026 09:38:01        Only Author  2#
Your article has truly stayed with me, thank you for sharing. Free Reliable MD-102 exam blueprint resources—unlock promotions and salary increases today!
