[Hardware] Associate-Cloud-Engineer New Dumps Book, Associate-Cloud-Engineer Questions Answ
105
【Hardware】 Associate-Cloud-Engineer New Dumps Book, Associate-Cloud-Engineer Questions Answ
Posted at 2/18/2026 22:50:08      View:124 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Braindumpsqa Associate-Cloud-Engineer PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1t_q47OI_VD9tBUQszwvFh7Hi-gqCUvd9
Braindumpsqa has launched the Associate-Cloud-Engineer exam dumps with the collaboration of world-renowned professionals. Braindumpsqa Google Associate-Cloud-Engineer exam study material has three formats: Associate-Cloud-Engineer PDF Questions, desktop Google Associate-Cloud-Engineer practice test software, and a Associate-Cloud-Engineer web-based practice exam. You can easily download these formats of Google Associate Cloud Engineer Exam (Associate-Cloud-Engineer) actual dumps and use them to prepare for the Google Associate-Cloud-Engineer certification test.
Below is the cost of Associate Cloud Engineer ExamThe price of Associate Cloud Engineer exam is $125 USD (plus tax where appropriate)
Exam TopicsThe content of the Google Associate Cloud Engineer test includes five extensive topics, each covering a wide range of subtopics and skills that the applicants must develop mastery in. The detailed exam blueprint can be viewed on the official webpage. The highlights of the domains that constitute the certification exam syllabus are outlined below:
Topic 1. Setting Up the Cloud Solution Environment
Within this subject area, the candidates are required to demonstrate their proficiency in setting up Cloud accounts & projects. They should also be capable of managing billing configuration. Besides that, the examinees will be evaluated based on their capacity to install and configure the command-line interface (CLI), particularly Cloud SDK (for instance, setting the default project).
Associate-Cloud-Engineer Questions Answers, Test Certification Associate-Cloud-Engineer CostAfter clients pay successfully for our Associate-Cloud-Engineer guide torrent, they will receive our mails sent by our system in 5-10 minutes. Then they can dick the mail and log in to use our software to learn immediately. For that time is extremely important for the learners, everybody hope that they can get the efficient learning. So clients can use our Associate-Cloud-Engineer Test Torrent immediately is the great merit of our Associate-Cloud-Engineer exam questions. When you begin to use, you can enjoy the various functions and benefits of our Associate-Cloud-Engineer practice guide such as it can simulate the exam and boosts the timing function.
Google Associate-Cloud-Engineer certification is an excellent way for IT professionals to validate their cloud computing skills and demonstrate their competence in the GCP environment. Earning this certification can be highly beneficial as it can help individuals boost their careers and succeed in the cloud computing industry. If you want to pursue a career in cloud computing or improve your existing cloud skills, the Google Associate-Cloud-Engineer Certification is definitely worth considering.
Google Associate Cloud Engineer Exam Sample Questions (Q147-Q152):NEW QUESTION # 147
You created a Google Cloud Platform project with an App Engine application inside the project. You initially configured the application to be served from the us-central region. Now you want the application to be served from the asia-northeast1 region. What should you do?
  • A. Create a new GCP project and create an App Engine application inside this new project. Specify asia-northeast1 as the region to serve your application.
  • B. Change the region property setting in the existing App Engine application from us-central to asia-northeast1.
  • C. Change the default region property setting in the existing GCP project to asia-northeast1.
  • D. Create a second App Engine application in the existing GCP project and specify asia-northeast1 as the region to serve your application.
https://cloud.google.com/appengi ... t=Each%20Cloud%20pr Two App engine can't be running on the same project: you can check this easy diagram for more info:https://cloud.google.com/appengi ... nts_of_an_applicati And you can't change location after setting it for your app Engine.https://cloud.google.com/appengine/docs/standard/locations App Engine is regional and you cannot change an apps region after you set it. Therefore, the only way to have an app run in another region is by creating a new project and targeting the app engine to run in the required region (asia-northeast1 in our case).
Ref: https://cloud.google.com/appengine/docs/locations
NEW QUESTION # 148
You have a Linux VM that must connect to Cloud SQL. You created a service account with the appropriate access rights. You want to make sure that the VM uses this service account instead of the default Compute Engine service account. What should you do?
  • A. Download a JSON Private Key for the service account. On the Custom Metadata of the VM, add that JSON as the value for the key compute-engine-service-account.
  • B. When creating the VM via the web console, specify the service account under the 'Identity and API Access' section.
  • C. Download a JSON Private Key for the service account. On the Project Metadata, add that JSON as the value for the key compute-engine-service-account.
  • D. Download a JSON Private Key for the service account. After creating the VM, ssh into the VM and save the JSON under ~/.gcloud/compute-engine-service-account.json.
NEW QUESTION # 149
Your web application has been running successfully on Cloud Run for Anthos. You want to evaluate an updated version of the application with a specific percentage of your production users (canary deployment).
What should you do?
  • A. Create a new revision with the new version of the application.
    Add HTTP Load Balancer in front of both revisions.
  • B. Create a new service with the new version of the application.
    Split traffic between this version and the version that is currently running.
  • C. Create a new revision with the new version of the application.
  • D. Create a new service with the new version of the application.
    Add HTTP Load Balancer in front of both services.
You need to specify CloudRun for Anthos
https://cloud.google.com/kuberun ... s-traffic-migration Anyway principles for CloudRun and CloundRun for Anthos are the same. Traffic can be split between multiple revisions.
NEW QUESTION # 150
As a cloud engineer, you have been asked to upgrade the free trial of your account and rename it to a production-inventory system. You are getting permission denied error while making the changes. Which of the following permissions will solve the problem?
  • A. Billing.account.update
  • B. Billing.accounts.upgrade
  • C. Billing.accounts.update
  • D. Billing.account.upgrade
The required permission is billing.accounts.update on Billing Account resource.
NEW QUESTION # 151
You need to select and configure compute resources for a set of batch processing jobs. These jobs take around
2 hours to complete and are run nightly. You want to minimize service costs. What should you do?
  • A. Select Compute Engine. Use preemptible VM instances of the appropriate standard machine type.
  • B. Select Google Kubernetes Engine. Use a single-node cluster with a small instance type.
  • C. Select Compute Engine. Use VM instance types that support micro bursting.
  • D. Select Google Kubernetes Engine. Use a three-node cluster with micro instance types.
If your apps are fault-tolerant and can withstand possible instance preemptions, then preemptible instances can reduce your Compute Engine costs significantly. For example, batch processing jobs can run on preemptible instances. If some of those instances stop during processing, the job slows but does not completely stop.
Preemptible instances complete your batch processing tasks without placing additional workload on your existing instances and without requiring you to pay full price for additional normal instances.
https://cloud.google.com/compute/docs/instances/preemptible
NEW QUESTION # 152
Associate-Cloud-Engineer Questions Answers: https://www.braindumpsqa.com/Associate-Cloud-Engineer_braindumps.html
