[General] C_CPI_2506 Exam Test - C_CPI_2506 Exams Training
100
General C_CPI_2506 Exam Test - C_CPI_2506 Exams Training
Posted at 2/18/2026 23:18:50      View147 | Replies1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PrepAwayTest C_CPI_2506 dumps for free: https://drive.google.com/open?id=1GQAXbZ7YxqVT2O2eT0zJ47Qxd9cvzN2h
Our SAP C_CPI_2506 exam prep have inspired millions of exam candidates to pursuit their dreams and motivated them to learn more high-efficiently. Our SAP C_CPI_2506 practice materials will not let your down. To lead a respectable life, our experts made a rigorously study of professional knowledge about this exam. We can assure you the proficiency of our SAP C_CPI_2506 Exam Prep.
SAP C_CPI_2506 Exam Syllabus Topics:
  • Managing APIs: This section of the exam measures the skills of Solution Architects and focuses on managing APIs within the SAP ecosystem. It covers topics such as API provisioning, lifecycle management, security policies, and monitoring, ensuring candidates can handle APIs effectively for enterprise integration needs.
  • SAP Integration Suite Overview: This section of the exam measures the skills of Integration Consultants and covers the foundational concepts of the SAP Integration Suite. It provides an understanding of the suites capabilities, its role in connecting applications, and its relevance in modern cloud-based integration scenarios.
  • SAP Event Mesh: This section of the exam measures the skills of Solution Architects and centers on using SAP Event Mesh to support event-driven integration. It highlights the importance of asynchronous communication, event publishing, and subscription models, allowing organizations to build scalable and decoupled systems.
  • Implementing Cloud Integration: This section of the exam measures the skills of Integration Consultants and examines how cloud integration flows are designed and deployed. It emphasizes creating integration scenarios, handling connectivity, and applying best practices to build efficient, secure, and reliable integration processes in SAPs cloud environment.
C_CPI_2506 Exams Training, C_CPI_2506 Test KingOur C_CPI_2506 Online test engine is convenient and easy to learn, it supports all web browsers. If you want, you can have offline practice. One of the most outstanding features of C_CPI_2506 Online test engine is it has testing history and performance review. You can have general review of what you have learnt. Besides, C_CPI_2506 Exam Braindumps offer you free demo to have a try before buying. You can get the downloading link and password within ten minutes after payment. C_CPI_2506 exam dumps contain both questions and answers, and its convenient for you to check your answers.
SAP Certified Associate - Integration Developer Sample Questions (Q48-Q53):NEW QUESTION # 48
What are some advantages of creating an OData interface through an API pro-vider? Note: There are 2 correct answers to this question.
  • A. Automatic creation of an openAPI specification
  • B. Automatic creation of a Swagger UI
  • C. Automatic creation of a WSDL specification
  • D. Automatic creation of a RAML specification
Some advantages of creating an OData interface through an API provider are automatic creation of a Swagger UI and an openAPI specification. A Swagger UI is a web-based tool that allows you to interact with the OData service and test its functionality. An openAPI specification is a standard format for describing the OData service and its metadata, which can be used by other tools and applications. Reference: Integration Software | SAP Integration Suite, Modernize Integration with SAP Integration Suite | openSAP
NEW QUESTION # 49
What kind of editor can you use to manipulate integration flows?
  • A. Graphical editor
  • B. Code editor
  • C. Command-line editor
To manipulate integration flows, you can use a graphical editor that is provided by SAP Integration Suite. The graphical editor allows you to visualize and edit your integration flows using a drag-and-drop interface. It also provides a palette of icons that represent different integration components and actions, such as senders, receivers, routers, mappers, transformers, and so on. You can use the graphical editor to design and configure complex integration scenarios in a user-friendly way. Reference: Overview of Integration Flow Editor | SAP Help Portal, Design and Deploy Your First Integration Flow | SAP Tutorials
NEW QUESTION # 50
You have set up an integration process to use a SOAP adapter. Which event allows you to run the integration flow directly after deployment?
  • A. End Message
  • B. End Event
  • C. Start Message
  • D. Start Event
A Start Message event allows you to run the integration flow directly after deployment. A Start Message event is triggered when a message arrives at the integration flow through an inbound channel, such as a SOAP adapter. You can use a Start Message event to initiate an integration process based on a message input. Reference: Modernize Integration with SAP Integration Suite | openSAP
NEW QUESTION # 51
You configured a content modifier as follows: Action: Create | Name: ProductID | Source Type: XPath Source Value: //ProductID | Data Type: java.lang.string. After testing the content modifier, you receive an error message that contains the following fragment: "Java.lang.ClassNotFoundException: java.lang.string..." What caused the error message?
  • A. Incorrect name
  • B. Incorrect data type
  • C. Incorrect source type
  • D. Incorrect source value
In SAP Cloud Integration, when defining Content Modifier properties, the Java data type names are case- sensitive.
Correct type # java.lang.String
In the configuration, java.lang.string was used (lowercase "s"), which causes a ClassNotFoundException, since Java cannot find the class.
Other options are correct in form:
Source Type = XPath # Valid.
Source Value = //ProductID # Valid XPath.
Name = ProductID # Valid.
Thus, the error occurred because of incorrect data type specification.
NEW QUESTION # 52
Which combination of SAP BTP role collections allows a user to manage queues and topic subscriptions in SAP Event Mesh, and monitor its usage and resources?
  • A. EventMeshAdmin and EventMeshDevelop
  • B. SecurityAdmin and SecurityDevelop
  • C. ApplicationAdmin and ApplicationDevelop
  • D. IntegrationAdmin and IntegrationDevelop
In SAP BTP, SAP Event Mesh provides messaging capabilities (queues, topics, and subscriptions) that require specific role collections to enable developers and administrators to perform tasks. SAP delivers two dedicated role collections for Event Mesh:
EventMeshDeveloper:
Manages queues and topic subscriptions
Monitors Event Mesh and its queues
Performs testing of queues and message flows
EventMeshAdmin:
Includes all developer capabilities
Provides additional administration rights for lifecycle management of Event Mesh instances and configurations When a user is assigned these role collections, they gain the ability to:
Create and manage queues and topic subscriptions.
Monitor usage and resources such as queue depth, consumers, connections, and spool size within Event Mesh.
Other provided options are incorrect:
ApplicationAdmin/ApplicationDevelop # These are not SAP Event Mesh role collections, they do not provide queue or topic subscription access.
SecurityAdmin/SecurityDevelop # These roles are tied to security configurations and do not allow Event Mesh operations.
IntegrationAdmin/IntegrationDevelop # These roles belong to SAP Integration Suite (Cloud Integration) capability, not Event Mesh.
Therefore, the correct and verified answer according to SAP Integration Developer documentation is:
B). EventMeshAdmin and EventMeshDevelop
NEW QUESTION # 53
The C_CPI_2506 test materials are mainly through three learning modes, Pdf, Online and software respectively. Among them, the software model is designed for computer users, can let users through the use of Windows interface to open the C_CPI_2506 test prep of learning. It is convenient for the user to read. The C_CPI_2506 test materials have a biggest advantage that is different from some online learning platform which has using terminal number limitation, the C_CPI_2506 Quiz torrent can meet the client to log in to learn more, at the same time, the user can be conducted on multiple computers online learning, greatly reducing the time, and people can use the machine online of C_CPI_2506 test prep more conveniently at the same time. As far as concerned, the online mode for mobile phone clients has the same function.
C_CPI_2506 Exams Training: https://www.prepawaytest.com/SAP/C_CPI_2506-practice-exam-dumps.html
Posted at 2/24/2026 16:00:33        Only Author  2#
This is brilliantlike clicked without hesitation. Free GICSP valid cram materials shared to help you improve your IT skills. Best of luck!
