[General] Excellent JN0-481 Prep Guide is Best Study Braindumps for JN0-481 exam
126
【General】 Excellent JN0-481 Prep Guide is Best Study Braindumps for JN0-481 exam
Posted at 2/18/2026 23:55:50      View:84 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that ITPassLeader JN0-481 dumps now are free: https://drive.google.com/open?id=1oPL2S40OyT2fMe-36aazxNPtHV1qOBZQ
The Data Center, Specialist (JNCIS-DC) JN0-481 Questions lead to Juniper JN0-481 certification. The JN0-481 certification is for anyone new to the industry. Whether you have just graduated from college, making a career change, already working in the sector, or searching for new ways to progress, the Juniper JN0-481 Certification is ideal for you. If you want to appear in the JN0-481 test of Juniper JN0-481 certification, you should have basic hands-on experience.
Many people now want to obtain the JN0-481 certificate. Because getting a certification can really help you prove your strength, especially in today's competitive pressure. The science and technology are very developed now. If you don't improve your soft power, you are really likely to be replaced. Our JN0-481 Exam Preparation can help you improve your uniqueness. And our JN0-481 study materials contain the most latest information not only on the content but also on the displays.
Pass Guaranteed Quiz 2026 Authoritative Juniper JN0-481: Data Center, Specialist (JNCIS-DC) Reliable Test TopicsAs a matter of fact, long-time study isn’t a necessity, but learning with high quality and high efficient is the key method to assist you to succeed. We provide several sets of JN0-481 test torrent with complicated knowledge simplified and with the study content easy to master, thus limiting your precious time but gaining more important knowledge. Our Data Center, Specialist (JNCIS-DC) guide torrent is equipped with time-keeping and simulation test functions, it’s of great use to set up a time keeper to help adjust the speed and stay alert to improve efficiency. Our expert team has designed a high efficient training process that you only need 20-30 hours to prepare the exam with our JN0-481 Certification Training. With an overall 20-30 hours’ training plan, you can also make a small to-do list to remind yourself of how much time you plan to spend in a day with JN0-481 test torrent.
Juniper Data Center, Specialist (JNCIS-DC) Sample Questions (Q53-Q58):NEW QUESTION # 53
Multilenancy for applications is achieved by creating virtual networks (VNs) within which construct?
  • A. security policy
  • B. routing table
  • C. connectivity template
  • D. routing zone
A routing zone is an L3 domain, the unit of tenancy in multi-tenant networks. You create routing zones for tenants to isolate their IP traffic from one another, thus enabling tenants to re-use IP subnets. In addition to being in its own VRF, each routing zone can be assigned its own DHCP relay server and external system connections. You can create one or more virtual networks within a routing zone, which means a tenant can stretch its L2 applications across multiple racks within its routing zone.
NEW QUESTION # 54
Within Managed Devices in the Juniper Apstra Ul, you notice that several devices have the OOS- Quarantined status. The devices cannot be added to any blueprint. Which action would solve this problem?
  • A. Install the agent, even though connectivity is established.
  • B. Upload a new pristine configuration.
  • C. Fix the hardware issues with the quarantined devices.
  • D. Acknowledge the device.
When an agent installation is successful, devices are placed into the Out of Service Quarantined (OOS-QUARANTINED) state using the Juniper Apstra UI. This state means that the device is not yet managed by Apstra and has not been assigned to any blueprint. The device configuration at this point is called Pristine Config. To make the device ready for use in a blueprint, you need to acknowledge the device, which is a manual action that confirms the device identity and ownership. Acknowledging the device changes its status to Out of Service Ready (OOS- READY).
NEW QUESTION # 55
Which two statements about ESI values are correct for the server connections to the fabric shown in the exhibit? (Choose two.)
  • A. A valid ESI value for Server A is 0x00.00.00.00.00.00.00.00.00.00.
  • B. A valid ESI value for Server A is 0x00.10.10.10.10.10.10.10.10.10.
  • C. A valid ESI value for Server B is 0x00.00.00.00.00.00.00.00.00.00.
  • D. A valid ESI value for Server B is 0x00.20.20.20.20.20.20.20.20.20.
To answer this question, we need to understand the concept of ESI values in EVPN LAGs. An ESI is a 10-byte value that identifies an Ethernet segment, which is a set of links that connect a multihomed device (such as a server) to one or more PE devices (such as leaf switches) in an EVPN network. The same ESI value must be configured on all the PE devices that connect to the same Ethernet segment. This allows the PE devices to form an EVPN LAG, which supports active-active or active-standby multihoming for the device. The ESI value can be manually configured (type 0) or automatically derived from LACP (type 1) or other methods. In the exhibit, Server A is connected to two leaf switches (QFX 5210) using a LAG with LACP enabled. Server B is connected to three leaf switches (QFX 5120) using a LAG with LACP enabled.
NEW QUESTION # 56
Which protocol is used to advertise EVPN routes?
  • A. BGP
  • B. IS-IS
  • C. RIP
  • D. OSPF
BGP is the protocol used to advertise EVPN routes. EVPN routes are a new type of BGP network layer reachability information (NLRI) that carry MAC address and IP prefix information for Ethernet VPNs. EVPN routes are exchanged between PEs using BGP multiprotocol extensions (MP-BGP) over MPLS, VXLAN, SR, or SRv6 tunnels. EVPN routes enable PEs to learn the reachability of MAC addresses and IP prefixes of different sites within the same EVPN instance.
EVPN routes also support various features such as fast convergence, redundancy, aliasing, and inter-subnet routing.
NEW QUESTION # 57
Which two statements are correct regarding a pristine configuration in Juniper Apstra? (Choose two.)
  • A. It is the device's currently active configuration.
  • B. It is the device's previously active configuration.
  • C. It Is the configuration file on a device before acknowledgment in Apstra.
  • D. It is the configuration file placed on the device when decommissioning the device.
A pristine configuration in Juniper Apstra is the configuration file that is used to onboard a device into the Apstra software application. A pristine configuration contains the minimum settings that are required for the device to communicate with the Apstra server, such as the hostname, management IP address, username, password, and SSH key. A pristine configuration has the following characteristics:
It is the configuration file placed on the device when decommissioning the device. This is because when a device is decommissioned from the Apstra software application, it is reverted back to its pristine configuration, which removes all the network configuration and services that were applied by the Apstra software application. This allows the device to be reused or repurposed for another network.
It is the configuration file on a device before acknowledgment in Apstra. This is because when a device is onboarded into the Apstra software application, it is initially in the discovery state, which means that the device is discovered by the Apstra server, but not yet acknowledged by the user.
In the discovery state, the device has the pristine configuration, which can be viewed and edited by the user. Once the user acknowledges the device, the device moves to the deployed state, which means that the device is ready to receive the network configuration and services from the Apstra software application.
NEW QUESTION # 58
According to different kinds of questionnaires based on study condition among different age groups, our JN0-481 test prep is totally designed for these study groups to improve their capability and efficiency when preparing for Data Center, Specialist (JNCIS-DC) JN0-481 Exams, thus inspiring them obtain the targeted Juniper JN0-481 certificate successfully.
Reliable JN0-481 Study Guide: https://www.itpassleader.com/Juniper/JN0-481-dumps-pass-exam.html
Juniper JN0-481 Reliable Test Topics Files with extension can be opened with Suite, These formats are JN0-481 desktop practice test software, Data Center, Specialist (JNCIS-DC) JN0-481 web-based practice exam, and Juniper JN0-481 PDF dumps file, Our company has been engaged in compiling the JN0-481 latest dumps: Data Center, Specialist (JNCIS-DC) for workers more than 10 years, and our products has become the rage at the market, Nowadays, a mass of materials about the Juniper Reliable JN0-481 Study Guide exam flooded into the market and made the exam candidates get confused to make their choice, and you may be one of them.
Tactic One: Shoot On Overcast Days, By Matt Liebowitz, Reliable JN0-481 Study Guide Alexander Fontana, Files with extension can be opened with Suite, These formatsare JN0-481 desktop practice test software, Data Center, Specialist (JNCIS-DC) JN0-481 web-based practice exam, and Juniper JN0-481 PDF dumps file.
Free PDF Quiz 2026 JN0-481: Perfect Data Center, Specialist (JNCIS-DC) Reliable Test TopicsOur company has been engaged in compiling the JN0-481 latest dumps: Data Center, Specialist (JNCIS-DC) for workers more than 10 years, and our products has become the rage at the market.
Nowadays, a mass of materials about the Juniper exam flooded JN0-481 into the market and made the exam candidates get confused to make their choice, and you may be one of them.
Therefore, how to pass the exam to gain a JN0-481 certificate efficiently has become a heated issue.
DOWNLOAD the newest ITPassLeader JN0-481 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1oPL2S40OyT2fMe-36aazxNPtHV1qOBZQ
