[General] TDA-C01 Test Simulator & TDA-C01 Reliable Test Duration
88
General TDA-C01 Test Simulator & TDA-C01 Reliable Test Duration
Posted at 2/19/2026 00:41:39      View104 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New TDA-C01 dumps are available on Google Drive shared by Pass4sureCert: https://drive.google.com/open?id=1_gq7CQd_xnP5LiI_QeNQ-EoM_-6x0U_u
We take responses from thousands of experts globally while updating the TDA-C01 content of preparation material. Their feedback and reviews of successful applicants enable us to make our Tableau TDA-C01 dumps material comprehensive for exam preparation purposes. This way we bring dependable and latest exam product which is enough to pass the Tableau TDA-C01 certification test on the very first take.
We hope that you have understood the major features of our three formats. Now let's discuss the benefits you can get upon buying our Tableau Certified Data Analyst (TDA-C01) exam material today. The first benefit you can get is the affordable price. Our Tableau Certified Data Analyst (TDA-C01) practice material is not expensive and every applicant can purchase it without running tight on his budget. Additionally, you can get a limited-time discount offer on real TDA-C01 exam questions as well.
Free PDF Quiz Tableau - TDA-C01 - Tableau Certified Data Analyst CThe Best Test SimulatorThe Tableau TDA-C01 exam dumps features are a free demo download facility, real, updated, and error-free Tableau TDA-C01 test questions, 1 year free updated Tableau Certified Data Analyst (TDA-C01) exam questions and availability of Tableau TDA-C01 real questions in three different formats. Tableau PDF Questions format, web-based practice test, and desktop-based TDA-C01 Practice Test formats. All these three Tableau TDA-C01 exam dumps formats features surely will help you in preparation and boost your confidence to pass the challenging Tableau Certified Data Analyst (TDA-C01) exam with good scores.
Tableau TDA-C01 Certification Exam covers a wide range of topics related to data analytics, including data visualization, business intelligence, data analysis, and data reporting. Participants in this certification program will learn how to use different Tableau tools and features to create effective visualizations and dashboards. They will also develop skills in interpreting data and identifying trends and patterns that can be used to make data-driven decisions. In addition, participants will learn how to create effective data reports and communicate data insights to stakeholders.
Tableau Certified Data Analyst Sample Questions (Q49-Q54):NEW QUESTION # 49
You have the following chart that shows profits and discounts over time.
You need to combine the lines to appear as shown in the following chart.
What should you do?
  • A. Drag Discount to the Columns shelf
  • B. Convert Discount to Discrete
  • C. Drag Discount to Color on the Marks card
  • D. Set Discount to Dual Axis
To combine the lines to appear as shown in the second chart, you should set Discount to Dual Axis. Dual Axis is a feature that allows you to show two measures on two separate axes on one chart. You can create a dual axis by right-clicking on a measure on any shelf and selecting Dual Axis from the menu. This will create two axes on one chart and synchronize their scales.
In this case, you want to show Profit and Discount on two separate axes on one chart. You can right-click on Discount on any shelf and select Dual Axis from the menu. This will create a dual axis chart that shows Profit and Discount as two lines with different colors.
The other options are not correct for this scenario. Dragging Discount to Color on the Marks card will change the color of Profit based on Discount, but it will not show two lines. Converting Discount to Discrete will change Discount from a green pill to a blue pill, but it will not affect how it appears on the chart. Dragging Discount to Columns shelf will create two separate charts for Profit and Discount, but it will not combine them. Reference: https://help.tableau.com/current ... ultiplemeasures.htm https://help.tableau.com/current ... asures_dualaxes.htm
NEW QUESTION # 50
You create the following worksheet
The Pick Measure parameter contains the following list of values
Users can select a value from Pick Measure to change the visualization to show either the Sales measure or the Profit measure.
Which formula is used in the Selected Measure calculated field lo switch between measures?
  • A. Case [Pick Measure]
    WHEN 1 then ([Sales])
    WHEN 2 then ([Profit]) END
  • B. Case AVG([Pick Measure])
    WHEN [Sales] then 1
    WHEN [Profit] then 2
    END
  • C. Case [Pick Measure:
    WHEN [Sales] then 1
    WHEN [Profit] then 2 END
  • D. Case STFMEPick Measure])
    WHEN "Sales" then ([Sales])
    WHEN "Profit" then ([Profit]) e::i
https://help.tableau.com/current ... parameters_swap.htm
NEW QUESTION # 51
You want to connect a Tableau workbook to a dataset in a Microsoft Excel spreadsheet.
What should you do from Tableau Desktop?
  • A. From the Data menu select New Data Source
  • B. From the Data menu select Replace Data Source
  • C. From the File menu select Import Workbook
  • D. From the File menu select New
To connect a Tableau workbook to a dataset in a Microsoft Excel spreadsheet, you need to select New Data Source from the Data menu. This will open the Connect pane, where you can choose Microsoft Excel as your data source and browse for your spreadsheet file. You can then drag and drop your sheets or tables to join or union them in the data source page. References: https://help.tableau.com/current/pro/desktop/en-us
/connect_basic.htm https://help.tableau.com/current ... s/connect_excel.htm When connecting to a dataset in Tableau Desktop, you would go to the 'Data' menu and select 'New Data Source'. This allows you to connect to various types of data sources, including Microsoft Excel spreadsheets, where you can then select the specific file you wish to connect to.
NEW QUESTION # 52
You have the following dataset.
You need to create the following worksheet.
The table must show either profit or sales based on the selection from the Parameter 1 menu.
Which three actions should you perform in orders
(Place the three correct options in order Use the arrows to move Options lo Answer Area Use Answer Area arrows to reorder the options)
1 - Create a parameter that has list string values of profit and sales. Select Show Parameter
2 - Create a calculated field that uses the following formula:....
3 - Drag the calculated field to Detail on the Marks card and add tRegion to the Columns sheif.
NEW QUESTION # 53
You have the following visualization.
The Last() calculation is set to compute using Table (across)
Which value will appear in the crosstab for the Consumer segment of the year 2018 if you change compute to use Oder Dale?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
The value that will appear in the crosstab for the Consumer segment of the year 2018 if you change compute to use Order Date is 0. The Last() calculation is a table calculation that returns the number of rows from the current row to the last row in the partition. The partition is determined by how you compute the calculation. In this case, you change compute to use Order Date, which means that the calculation will be performed for each value of Order Date.
The crosstab shows that there are two values of Order Date for the Consumer segment of the year 2018: Q1 and Q4. The Last() calculation will return 0 for Q4, because it is the last row in the partition. It will return 1 for Q1, because it is one row away from the last row in the partition.
The other options are not correct for this scenario. The Last() calculation will not return 2, 3, or 4 for any value of Order Date, because there are only two values in each partition.
NEW QUESTION # 54
Pass4sureCert has made these formats so the students don't face issues while preparing for Tableau Certified Data Analyst (TDA-C01) certification exam dumps and get success in a single try. The web-based format is normally accessed through browsers. This format doesn't require any extra plugins so users can also use this format to pass Tableau TDA-C01 test with pretty good marks.
TDA-C01 Reliable Test Duration: https://www.pass4surecert.com/Tableau/TDA-C01-practice-exam-dumps.html
