[General] Scripting-and-Programming-Foundations Passing Score - Practice Scripting-and-Pro
88
【General】 Scripting-and-Programming-Foundations Passing Score - Practice Scripting-and-Pro
Posted at 2/19/2026 00:46:16      View:154 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 WGU Scripting-and-Programming-Foundations dumps are available on Google Drive shared by ITCertMagic: https://drive.google.com/open?id=1zPXnESI4HMmMvrd9DIbXtGzK_1g2G5ff
At ITCertMagic, we strive hard to offer a comprehensive WGU Scripting and Programming Foundations Exam (Scripting-and-Programming-Foundations) exam questions preparation material bundle pack. The product available at ITCertMagic includes WGU Scripting-and-Programming-Foundations Real Dumps pdf and mock tests (desktop and web-based). Practice exams give an experience of taking the WGU Scripting and Programming Foundations Exam (Scripting-and-Programming-Foundations) actual exam.
WGU Scripting-and-Programming-Foundations Exam Syllabus Topics:
  • Identifying Scripts for Computer Program Requirements: This section of the exam measures the skills of Junior Software Developers and covers the ability to match a task with the correct script or programming approach. It highlights how different scripts can satisfy specific requirements and how to recognize the right structure for a given programming problem.
  • Scripting and Programming Foundations: This section of the exam measures the skills of Junior Software Developers and covers the essential building blocks of programming. It focuses on variables, data types, flow control, and basic design concepts. Learners understand how programming logic works and how different languages handle similar tasks. The section also introduces the difference between interpreted and compiled languages in a simple and practical way.
  • Using Fundamental Programming Elements: This section of the exam measures skills of Entry Level Programmers and covers the use of basic programming components required in everyday tasks. It includes working with variables, loops, conditions, and simple logic to perform common operations. The focus is on applying these elements correctly to complete small programming assignments in a clear and organized way.
  • Explaining Logic and Outcomes of Simple Algorithms: This section of the exam measures the skills of Entry Level Programmers and covers the ability to read simple algorithms and understand how they work. It focuses on predicting outputs, understanding step by step logic, and identifying how basic instructions create a final result. The goal is to help learners understand algorithm reasoning without requiring advanced coding knowledge.
Practice Scripting-and-Programming-Foundations Exam, Valid Scripting-and-Programming-Foundations Exam GuideYou may worry that you still fail Scripting-and-Programming-Foundations exam although you have made full preparation for the exam; or you may afraid that the exam software you purchased is not right for you. Our Scripting-and-Programming-Foundations exam software developed by our ITCertMagic will clear your worries. Our Scripting-and-Programming-Foundations exam software will provide two level of insurance for you: the first is the reassuring high pass rate; the second is full refund of your cost you purchased our exam software. Don't worry, if you fail Scripting-and-Programming-Foundations Exam with our software, we will refund the money you purchased our dumps. What you do is to prepare for the exam confidently, and our ITCertMagic will be in charge of other issues.
WGU Scripting and Programming Foundations Exam Sample Questions (Q105-Q110):NEW QUESTION # 105
Which problem is solved by Dijkstra's shortest path algorithm?
  • A. Given an increasing array of numbers, is the number 19 in the array?
  • B. Given the coordinates of five positions, what is the most fuel-efficient flight path?
  • C. Given an alphabetized list of race entrants and a person's name, is the person entered in the race?
  • D. Given two newspaper articles, what is the greatest sequence of words shared by both articles?
Dijkstra's shortest path algorithm finds the shortest path between nodes in a weighted graph, often used for navigation or network routing. According to foundational programming principles (e.g., Certiport Scripting and Programming Foundations Study Guide, Section on Algorithms), it is designed for problems involving optimal paths in graphs with non-negative edge weights.
* Option A: "Given an increasing array of numbers, is the number 19 in the array?" This is incorrect. This is a search problem, typically solved by binary search for a sorted array, not Dijkstra's algorithm, which deals with graphs.
* Option B: "Given an alphabetized list of race entrants and a person's name, is the person entered in the race?" This is incorrect. This is another search problem, solvable by binary search or linear search, not related to graph paths.
* Option C: "Given two newspaper articles, what is the greatest sequence of words shared by both articles?" This is incorrect. This is a longest common subsequence (LCS) problem, solved by dynamic programming, not Dijkstra's algorithm.
* Option D: "Given the coordinates of five positions, what is the most fuel-efficient flight path?" This is correct. This describes a shortest path problem in a graph where nodes are positions (coordinates) and edges are distances or fuel costs. Dijkstra's algorithm can find the most efficient path (e.g., minimizing fuel) between these points, assuming non-negative weights.
Certiport Scripting and Programming Foundations Study Guide (Section on Algorithms).
Cormen, T.H., et al., Introduction to Algorithms, 3rd Edition (Dijkstra's Algorithm, Chapter 24).
GeeksforGeeks: "Dijkstra's Shortest Path Algorithm" (https://www.geeksforgeeks.org/dijkstras-shortest-path- algorithm-greedy-algo-7/).
NEW QUESTION # 106
Which output results from the given algorithm?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
The algorithm depicted in the image is a simple loop that iterates 5 times. Each iteration multiplies the current value of i by 2 and adds it to the variable sum. The loop starts with i equal to 1 and sum equal to 0. Here's the breakdown:
* First iteration: i = 1, sum = 0 + (1 * 2) = 2
* Second iteration: i = 2, sum = 2 + (2 * 2) = 6
* Third iteration: i = 3, sum = 6 + (3 * 2) = 12
* Fourth iteration: i = 4, sum = 12 + (4 * 2) = 20
* Fifth iteration: i = 5, sum = 20 + (5 * 2) = 30
However, the algorithm includes a condition that checks if sum is greater than 10. If this condition is true, the algorithm outputs the value of i and stops. This condition is met during the third iteration, where sum becomes
12. Therefore, the algorithm outputs the value of i at that point, which is 3.
NEW QUESTION # 107
Which operator is helpful in determining if an integer is a multiple of another integer?
  • A. %
  • B. +
  • C. /
  • D. ||
To determine if one integer is a multiple of another, the modulo operator (%) is used. According to foundational programming principles, the modulo operator returns the remainder of division, and if the remainder is zero, the first integer is a multiple of the second.
* Option A: "/." This is incorrect. The division operator (/) returns the quotient of division, which may include a decimal (e.g., 7 / 2 = 3.5). It does not directly indicate if one number is a multiple of another.
* Option B: "||." This is incorrect. The logical OR operator (||) is used for boolean operations (e.g., in conditional statements) and is unrelated to checking multiples.
* Option C: "+." This is incorrect. The addition operator (+) adds two numbers and is not used to check if one is a multiple of another.
* Option D: "%." This is correct. The modulo operator (%) returns the remainder after division. If a % b
== 0, then a is a multiple of b (e.g., 10 % 5 == 0, so 10 is a multiple of 5).
Certiport Scripting and Programming Foundations Study Guide (Section on Operators).
C Programming Language Standard (ISO/IEC 9899:2011, Section on Arithmetic Operators).
W3Schools: "Python Operators" (https://www.w3schools.com/python/python_operators.asp).
NEW QUESTION # 108
Which two operators can be used for checking divisibility of a number?
Choose 2 answers.
Posted at 2/23/2026 18:03:31        Only Author  2#
After reading this article, I’ve gained a new perspective on how to look at the problem. Latest exam camp NSE5_FNC_AD_7.6 sheet offers rich material, available for free to support your learning goals.
