[General] Test JN0-105 Dumps.zip | Juniper JN0-105 Test King: Junos, Associate (JNCIA-Juno
89
General Test JN0-105 Dumps.zip | Juniper JN0-105 Test King: Junos, Associate (JNCIA-Juno
Posted at 2/19/2026 01:57:46      View178 | Replies1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of VerifiedDumps JN0-105 dumps from Cloud Storage: https://drive.google.com/open?id=1_UUItKLlWA6nTglpH4c9A0JLGlSxkGm9
With the help of our Juniper JN0-105 practice materials, you can successfully pass the actual exam with might redoubled. Our company owns the most popular reputation in this field by providing not only the best ever Juniper JN0-105 Study Guide but also the most efficient customers' servers.
Juniper JN0-105 Exam Syllabus Topics:
  • Networking Fundamentals: The topic networking fundamentals covers identifying the concepts and functionality of different fundamental elements of networking.
  • Operational Monitoring and Maintenance: Different methods of monitoring or maintaining Junos devices are identified in this topic. Lastly, it discusses monitoring or maintenance procedures for a Junos device.
  • User Interfaces: This topic delves into identifying the concepts, operation, or functionality of the Junos user interface.
  • Junos OS Fundamentals: It covers concepts, benefits, and functionality of the core elements of the Junos OS.
JN0-105 Test King & New JN0-105 Test FeeThe selection of proper training material is a promising method to pass Juniper JN0-105 exam. No quality, no success. VerifiedDumps Juniper JN0-105 questions and answers consist of perfect exam simulations, real test questions and accurate test answers. Our VerifiedDumps Juniper JN0-105 test provides high-quality products and improves after-sales service. If you spend a lot of time catching up, the way you choose is wrong. What is more serious is that you may fail. Please trust our VerifiedDumps Juniper JN0-105 braindump. By selecting it, 100% guarantee to pass the exam.
Juniper Junos, Associate (JNCIA-Junos) Sample Questions (Q84-Q89):NEW QUESTION # 84
What is the protocol data unit (PDU) of the Data Link Layer?
  • A. bit
  • B. byte
  • C. segment
  • D. frame
In the OSI model, the Data Link Layer is responsible for node-to-node delivery of data. It frames the packets received from the Network Layer and prepares them for physical transmission. The Protocol Data Unit (PDU) for the Data Link Layer is called a "frame." Frames encapsulate the network layer packets, adding a header and a trailer that include the hardware addresses of the source and destination, among other things, facilitating the data link layer services like frame synchronization, flow control, and error checking.
NEW QUESTION # 85
You have configured some interfaces on a Junos device; however, you have not yet committed the configuration.
What happens if you issue the rollback 0 command in this scenario?
  • A. The Junos device is rebooted.
  • B. The messages.log file is deleted.
  • C. The interface changes you made are discarded.
  • D. The factory default configuration is loaded.
Issuing the rollback 0 command in Junos OS will discard any uncommitted changes and revert to the last committed configuration. This command effectively cancels any configuration changes that have been made but not yet committed, ensuring that the device returns to its previous stable state.
* "rollback 0 ...................................(rolls back the changes just made )" from Useful Juniper Commands.
txt.
* Juniper official documentation: Rolling Back a Configuration.
NEW QUESTION # 86
Which command displays all IPv6 routes in the default routing instance?
  • A. showroute table inet.l
  • B. showroute table inet.0
  • C. showroute table inet6.0
  • D. showroute table inet6.1
In Junos OS, the command to display IPv6 routes in the default routing instance isshow route table inet6.0.
The routing tableinet6.0specifically holds IPv6 routes. The commandshow route table inet.0is used for IPv4 routes, andinet6.1orinet.l(assuminginet.lis a typo forinet.1) are not standard Junos routing tables for displaying IPv6 routes in the default routing instance.
NEW QUESTION # 87
You are logged in to a Junos OS device with SSH and issued the show protocols | compare command in the configuration, but no output is shown.
Which statement is correct in this scenario?
  • A. There are no changes to the candidate configuration.
  • B. The command only works for interface configuration differences.
  • C. You must commit the configuration before any output will be shown.
  • D. Someone accidentally deleted the active configuration.
The show | compare command in Junos OS is used to display the differences between the candidate configuration and the active configuration. If no output is shown when you issue this command, it means that there are no changes between the candidate configuration and the active configuration. This indicates that the candidate configuration is identical to the active configuration, and thus no differences are displayed.
"The show | compare command displays the differences between the candidate configuration and the active configuration. If there are no changes, no output is displayed."
NEW QUESTION # 88
What are two advantages of using the Junos OS? (Choose two.)
  • A. It supports up to a maximum of two previous configurations.
  • B. It enables you to roll back to a previous configuration.
  • C. It pushes your configuration changes "live" immediately.
  • D. It is modular.
One of the key advantages of Junos OS is its ability to roll back to previous configurations. This feature allows administrators to revert to an earlier configuration state, which is invaluable for quickly recovering from configuration errors or undesired changes. Junos OS maintains an archive of previous configurations, enabling easy rollback to any saved state. Another significant advantage of Junos OS is its modular design. The operating system is structured so that different processes and services run in separate protected memory spaces, enhancing the stability and reliability of the system. If one process fails, it does not affect the others, thereby minimizing the risk of system-wide failures.
NEW QUESTION # 89
The one badge of JN0-105 certificate will increase your earnings and push you forward to achieve your career objectives. Are you ready to accept this challenge? Looking for the simple and easiest way to pass the JN0-105 certification exam? If your answer is yes then you do not need to get worried. Just visit the Juniper JN0-105 Pdf Dumps and explore the top features of JN0-105 test questions. If you feel that Junos, Associate (JNCIA-Junos) JN0-105 exam questions can be helpful in exam preparation then download Junos, Associate (JNCIA-Junos) JN0-105 updated questions and start preparation right now.
JN0-105 Test King: https://www.verifieddumps.com/JN0-105-valid-exam-braindumps.html
P.S. Free & New JN0-105 dumps are available on Google Drive shared by VerifiedDumps: https://drive.google.com/open?id=1_UUItKLlWA6nTglpH4c9A0JLGlSxkGm9
Posted at 3/9/2026 00:25:47        Only Author  2#
What a great article, Im so thankful for your sharing. The EX200 valid test dumps sheet content is of great value, and it's completely free.
