MS-102 Dumps Collection - Real MS-102 Questions
Posted at 2/19/2026 02:05:53
P.S. Free & New MS-102 dumps are available on Google Drive shared by TestsDumps: https://drive.google.com/open?id=1wPBkqzwzedFnSEte6WxQq2CJyaNcsop-
Our Microsoft 365 Administrator exam question has been widely praised by all of our customers in many countries and our company has become the leader in this field. Our product boost varied functions and they include the self-learning and the self-assessment functions, the timing function and the function to stimulate the exam to make you learn efficiently and easily. There are many advantages of our MS-102 Study Tool. If any questions or doubts exist, the client can contact our online customer service or send mails to contact us and we will solve them as quickly as we can. We always want to let the clients be satisfied and provide the best MS-102 test torrent and won’t waste their money and energy.
Microsoft MS-102 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Deploy and manage a Microsoft 365 tenant: Management of roles in Microsoft 365 and management of users and groups are discussion points of this topic. It also focuses on implementing and managing a Microsoft 365 tenant.
| | Topic 2 | - Manage compliance by using Microsoft Purview: Implementation of Microsoft Purview information protection and data lifecycle management is discussed in this topic. Moreover, questions about implementing Microsoft Purview data loss prevention (DLP) also appear.
| | Topic 3 | - Implement and manage Microsoft Entra identity and access: In this topic, questions about Microsoft Entra tenant appear. Moreover, it delves into implementation and management of authentication and secure access.
| | Topic 4 | - Manage security and threats by using Microsoft Defender XDR: This topic discusses how to use Microsoft Defender portal to manage security reports and alerts. It also focuses on usage of Microsoft Defender for Office 365 to implement and manage email and collaboration protection. Lastly, it discusses the usage of Microsoft Defender for Endpoint for the implementation and management of endpoint protection.
3 Formats of Microsoft MS-102 Dumps that Suit your Study StyleThe Microsoft MS-102 certification exam is one of the top-rated and valuable credentials in the Microsoft world. This Microsoft MS-102 exam questions is designed to validate the candidate's skills and knowledge. With Microsoft 365 Administrator exam dumps everyone can upgrade their expertise and knowledge level. By doing this the successful MS-102 Exam candidates can gain several personal and professional benefits in their career and achieve their professional career objectives in a short time period.
Microsoft 365 Administrator Sample Questions (Q163-Q168):NEW QUESTION # 163
You have a Microsoft 365 E5 tenant that contains a user named User1.
You plan to implement insider risk management.
You need to ensure that User1 can perform the following tasks:
Review alerts.
Manage cases.
Create notice templates.
Review user emails by using Content explorer.
The solution must use the principle of least privilege.
To which role group should you add User1?
- A. Insider Risk Management Admin
- B. Insider Risk Management Investigators
- C. Insider Risk Management
- D. Insider Risk Management Analysts
https://docs.microsoft.com/en-us ... view=o365-worldwide
NEW QUESTION # 164
You have a Microsoft 365 E5 subscription that contains a Microsoft SharePoint site named Sitel. Site! contains the files shown in the following table.
You have a data loss prevention (DLP) policy named DLP1 that has the advanced DLP rules shown in the following table.
You apply DLP1 to Site1.
Which policy tip is displayed for each file? To answer, select the appropriate options in the answer area.
NEW QUESTION # 165
You have a Microsoft 365 E5 tenant that contains 500 Windows 10 devices and a Windows 10 compliance policy.
You deploy a third-party antivirus solution to the devices.
You need to ensure that the devices are marked as compliant.
Which three settings should you modify in the compliance policy? To answer, select the appropriate settings in the answer area.
https://docs.microsoft.com/en-us ... licy-create-windows
NEW QUESTION # 166
HOTSPOT
You have a Microsoft 365 subscription that contains the users shown in the following table.
You need to configure a dynamic user group that will include the guest users in any department that contains the word Support.
How should you complete the membership rule? To answer, select the appropriate options in the answer area.
Box 1: -eq "Guest"
Dynamic membership rules for groups in Azure Active Directory
Supported expression operators
The following table lists all the supported operators and their syntax for a single expression. Operators can be used with or without the hyphen (-) prefix. The Contains operator does partial string matches but not item in a collection matches.
* Equals
-eq
* Contains
-contains
* Etc.
Box 2: -contains "Support"
Incorrect:
* -in
If you want to compare the value of a user attribute against multiple values, you can use the -in or -notIn operators.
https://learn.microsoft.com/en-u ... -dynamic-membership
NEW QUESTION # 167
HOTSPOT
You create the Microsoft 365 tenant.
You implement Azure AD Connect as shown in the following exhibit.
Box 1: only on-premises
In the exhibit, seamless single sign-on (SSO) is disabled. Therefore, as SSO is disabled in the cloud, the Sales department users can access only on-premises applications by using SSO.
In the exhibit, directory synchronization is enabled and active. This means that the on-premises Active Directory user accounts are synchronized to Azure Active Directory user accounts. If the on-premises Active Directory becomes unavailable, the users can access resources in the cloud by authenticating to Azure Active Directory. They will not be able to access resources on-premises if the on-premises Active Directory becomes unavailable as they will not be able to authenticate to the on-premises Active Directory.
Box 2: in the cloud only
NEW QUESTION # 168
The client can try out and download our MS-102 training materials freely before their purchase so as to have an understanding of our product and then decide whether to buy them or not. The website pages of our product provide the details of our MS-102 learning questions. You can see the demos which are part of the all titles selected from the test bank and the forms of the questions and answers and know the form of our software on the website pages of our study materials.
Real MS-102 Questions: https://www.testsdumps.com/MS-102_real-exam-dumps.html
- Valid MS-102 Test Dumps 🛐 MS-102 Detailed Study Dumps 📚 MS-102 Latest Test Vce 👬 Enter [ [url]www.troytecdumps.com ] and search for ▷ MS-102 ◁ to download for free 🥳Reliable MS-102 Test Sample[/url]
- Pass Guaranteed Quiz Microsoft - Valid MS-102 Dumps Collection ⏬ Open website ▷ [url]www.pdfvce.com ◁ and search for “ MS-102 ” for free download 🍀MS-102 Pdf Files[/url]
- Detail MS-102 Explanation 🔌 MS-102 Latest Test Vce 🍬 MS-102 Test Questions Pdf 🍃 Open website { [url]www.prepawayete.com } and search for ⮆ MS-102 ⮄ for free download 😻MS-102 VCE Dumps[/url]
- Get Pdfvce Free one year Update On Real Microsoft MS-102 Exam Questions 🔼 Easily obtain free download of ☀ MS-102 ️☀️ by searching on ➥ [url]www.pdfvce.com 🡄 🕌MS-102 Latest Exam Tips[/url]
- MS-102 Latest Exam Tips 🛶 Test MS-102 Prep 🐁 Reliable MS-102 Test Sample 🏟 Search on { [url]www.validtorrent.com } for [ MS-102 ] to obtain exam materials for free download 🎍MS-102 Test Simulator Online[/url]
- Avail Efficient MS-102 Dumps Collection to Pass MS-102 on the First Attempt ⏭ Open ⇛ [url]www.pdfvce.com ⇚ and search for ➠ MS-102 🠰 to download exam materials for free ⚔MS-102 Reliable Study Questions[/url]
- Some Top Features of [url]www.examdiscuss.com Microsoft MS-102 Exam Practice Questions 👋 Search for ⇛ MS-102 ⇚ on ▛ www.examdiscuss.com ▟ immediately to obtain a free download 😕MS-102 Detailed Study Dumps[/url]
- MS-102 Detailed Study Dumps 🧂 MS-102 VCE Dumps 🏓 MS-102 Exam Pass4sure 🧞 Easily obtain free download of ✔ MS-102 ️✔️ by searching on ➽ [url]www.pdfvce.com 🢪 🚾MS-102 Pdf Files[/url]
- 2026 MS-102 Dumps Collection - Realistic Real Microsoft 365 Administrator Questions Free PDF 🐞 Open ➠ [url]www.examcollectionpass.com 🠰 and search for ( MS-102 ) to download exam materials for free 🔗MS-102 Exam Pass4sure[/url]
- MS-102 valid exam format - MS-102 free practice pdf - MS-102 latest study material 💽 Search for ➤ MS-102 ⮘ and download it for free on ( [url]www.pdfvce.com ) website 🧮MS-102 Latest Exam Tips[/url]
- Reliable MS-102 Test Answers 💚 MS-102 Latest Test Vce 🔆 MS-102 Practice Test 📒 Download ➠ MS-102 🠰 for free by simply searching on ▛ [url]www.troytecdumps.com ▟ 🧏Test MS-102 Prep[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, avion-aerospace.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, dionkrivenko.hathorpro.com, Disposable vapes
What's more, part of that TestsDumps MS-102 dumps now are free: https://drive.google.com/open?id=1wPBkqzwzedFnSEte6WxQq2CJyaNcsop-
