[General] ServiceNow CSA Exam Forum - CSA Online Test
104
General ServiceNow CSA Exam Forum - CSA Online Test
Posted at 2/19/2026 02:13:26      View98 | Replies0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest DumpsMaterials CSA PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1CofA-qLNYAhoBaoDd1dsd0jhr413DKE0
DumpsMaterials is one of the leading platforms that has been helping ServiceNow Exam Questions candidates for many years. Over this long time, period the ServiceNow Certified System Administrator (CSA) exam dumps helped countless ServiceNow Certified System Administrator (CSA) exam questions candidates and they easily cracked their dream ServiceNow CSA Certification Exam. You can also trust ServiceNow Certified System Administrator (CSA) exam dumps and start ServiceNow Certified System Administrator (CSA) exam preparation today.
We consider the actual situation of the test-takers and provide them with high-quality CSA learning materials at a reasonable price. Choose the CSA test guide absolutely excellent quality and reasonable price, because the more times the user buys the CSA test guide, the more discounts he gets. In order to make the user's whole experience smoother, we also provide a thoughtful package of services. Once users have any problems related to the CSA learning questions, our staff will help solve them as soon as possible.
Quiz ServiceNow - Reliable CSA - ServiceNow Certified System Administrator Exam ForumThe DumpsMaterials supports ServiceNow CSA exam candidates by listening to their worries, resolving their problems, and offering them actual exam questions. The exam candidate has several concerns before choosing any platform. They want a platform that satisfies them and promises to help them prepare for the CSA test successfully on the first time.
ServiceNow Certified System Administrator Sample Questions (Q330-Q335):NEW QUESTION # 330
What are the 6 methods available for user authentication?
  • A. Digest Token: An encrypted digest of the user name and password in the user record.
  • B. SAML 2.0: The user name and password configured in a SAML identity provider account, which has a matching user account in the database.
  • C. Local Database: The user name and password in their user record in the instance database.
  • D. OAuth 2.0: The user name and password of OAuth identity provider, which has a matching user account in the database.
  • E. LDAP: The user name and password are accessed via LDAP in the corporate directory, which has a matching user account in the database.
  • F. Multifactor: The user name and password in the database and passcode sent to the user's mobile device that has Google Authenticator installed
Answer: A,B,C,D,E,F
Thesix methods available for user authenticationin ServiceNow are:
Local Database- The user authenticates using a username and password stored in theinstance database.
Multifactor Authentication (MFA)- The user provides their username, password, and apasscode(e.g., from Google Authenticator).
LDAP (Lightweight Directory Access Protocol)- The user authenticates using credentials stored in a corporateLDAP directory.
SAML 2.0 (Security Assertion Markup Language)- The user is authenticated via an externalSAML Identity Provider (IdP).
OAuth 2.0- The user authenticates via anOAuth identity provider(such as Google, Microsoft, or Facebook).
Digest Token Authentication- The user authenticates using anencrypted tokenrather than directly submitting a password.
Thus, the correct answer is:
A, B, C, D, E, F
ServiceNow supports multiple authentication methods to provideflexibility, security, and integration capabilitieswith external identity providers.
Local Database Authentication:
ServiceNow storesusernames and passwordsin the internal database.
Users authenticate directly with the instance.
This method is commonly used when no external authentication provider is configured.
Multifactor Authentication (MFA):
Enhances security by requiringtwo authentication factors:
Username and password(stored in the database).
Passcodefrom a registered device (such as Google Authenticator, Microsoft Authenticator).
MFA helpsprevent unauthorized accesseven if credentials are compromised.
LDAP Authentication:
Allows users toauthenticate against an external LDAP directory(such as Microsoft Active Directory).
The user must have amatching record in the ServiceNow user table ([sys_user]).
ServiceNowdoes not store passwordswhen using LDAP; it only validates credentials against the directory.
SAML 2.0 Authentication:
Users authenticate via aSAML Identity Provider (IdP)such asOkta, Microsoft Azure AD, or Ping Identity.
ServiceNow acts as aService Provider (SP)and does not store passwords.
ProvidesSingle Sign-On (SSO)capabilities.
OAuth 2.0 Authentication:
Allows authentication viaOAuth providers(Google, Facebook, Microsoft, etc.).
Users do not need to store passwords in ServiceNow; instead, authentication is delegated to theOAuth identity provider.
Digest Token Authentication:
Uses anencrypted token(instead of a plaintext password) to authenticate users.
Often used forAPI-based authenticationor scenarios where passwords should not be transmitted over the network.
Each method aligns with ServiceNow's authentication mechanisms as per official documentation.
ServiceNow supports a hybrid authentication approach, allowing multiple methods to coexist.
ServiceNow Docs - Authentication Methodshttps://docs.servicenow.com
ServiceNow Security Best Practices - Authentication & Access Controls
ServiceNow Developer Portal - SSO & OAuth Authentication
Why These Are the Correct Methods?References from Certified System Administrator (CSA) Documentation:
NEW QUESTION # 331
What needs to be specified, when creating a Business Rule? (Choose four.)
  • A. Timing
  • B. Who can run
  • C. Script to run
  • D. UI action
  • E. Table
  • F. Update set
  • G. Application scope
  • H. Condition to evaluate
  • I. Fields to update
Answer: C,D,E,G
https://docs.servicenow.com/bund ... stration/task/t_Edi
NEW QUESTION # 332
From a form, what would you click to add additional fields to the form? (Choose two.)
  • A. Right-click on header > Configure > UX Dashboard ❌ (Incorrect)
  • B. Right click on header > Add > Field
  • C. Context Menu > Form > Layout
  • D. Context Menu > Configure > Form Design
  • E. Context Menu > Configure > Form Layout
  • F. Context Menu > Form > Designer
Answer: D,E
UX Dashboards are used for analytics and reporting, not form configuration.
Official Reference from Certified System Administrator (CSA) Documentation:
Form Layout in ServiceNow:
https://docs.servicenow.com/en-U ... gureFormLayout.html Form Designer Overview:
https://docs.servicenow.com/en-U ... c_FormDesigner.html Explanation:
In ServiceNow, you can add additional fields to a form using either:
Form Layout (for quick field additions)
Form Designer (for a drag-and-drop UI approach)
Correct Methods:
Context Menu > Configure > Form Layout (B) ✅
This allows administrators to add or remove fields in a simple list-based interface.
Used when only minor modifications are needed.
Context Menu > Configure > Form Design (C) ✅
Opens the Form Designer, a drag-and-drop UI editor for configuring forms.
Allows users to rearrange fields, sections, and tabs easily.
Explanation of Incorrect Options:
A . Context Menu > Form > Layout ❌ (Incorrect)
The correct path is Configure > Form Layout, not "Form > Layout."
D . Right-click on header > Add > Field ❌ (Incorrect)
Right-clicking the form header does not provide an option to add fields directly.
E . Context Menu > Form > Designer ❌ (Incorrect)
The correct option is Configure > Form Design, not "Form > Designer."
NEW QUESTION # 333
Which of the following is true about deleting fields from a table?
  • A. Inherited fields can be deleted
  • B. Table records are deleted when a field is deleted
  • C. User-defined non-inherited fields can be deleted
  • D. Any field on a table can be deleted
NEW QUESTION # 334
The wait time for end users is based on the round-trip between the client and the server. What activities are included in the round-trips?
  • A. Save + Update
  • B. Request + Response
  • C. Submit + Query
  • D. Insert + Verify
  • E. Write + Read
Reference: https://docs.servicenow.com/bund ... ript/client-scripts
/concept/client-script-best-practices.html
NEW QUESTION # 335
If you want to make progress and mark your name in your circumstances, you should never boggle at difficulties. As far as we know, many customers are depressed by the exam ahead of them, afraid of they may fail it unexpectedly. Our CSA exam tool has three versions for you to choose, PDF, App, and software. If you have any question or hesitate, you can download our free Demo. The Demo will show you part of the content of our CSA Study Materials real exam materials. So you do not have to worry about the quality of our exam questions. Our CSA exam tool have been trusted and purchased by thousands of candidates. What are you waiting for?
CSA Online Test: https://www.dumpsmaterials.com/CSA-real-torrent.html
ServiceNow CSA Exam Forum A: All purchases are downloaded from the internet or by e-mail, They keep close attention to any tiny changes of CSA Dumps VCE: ServiceNow Certified System Administrator, ServiceNow CSA Exam Forum Except your assiduous preparation, it is the professional materials that you used made it, ServiceNow CSA Exam Forum We know that once we sell fake products to customers, we will be knocked out by the market.
An interesting variation of the Channel Adapter is the Metadata CSA Adapter, sometimes called Design-Time Adapter, So, how can you tell if your image is using the old or new process version?
A: All purchases are downloaded from the internet or by e-mail, They keep close attention to any tiny changes of CSA Dumps Vce: ServiceNow Certified System Administrator, Except your assiduous preparation, it is the professional materials that you used made it.
CSA Real Questions C Best Material for Smooth ServiceNow Exam PreparationWe know that once we sell fake products to customers, we will be knocked out by the market, Tt is very easy for you to download the PDF version of our CSA study materials, and it has two ways to use.
What's more, part of that DumpsMaterials CSA dumps now are free: https://drive.google.com/open?id=1CofA-qLNYAhoBaoDd1dsd0jhr413DKE0
