Plat-Arch-203 New Braindumps Questions, Test Plat-Arch-203 Assessment
Posted at 2/19/2026 02:42:56
Might it be said that you are enthused about drifting through the Salesforce Plat-Arch-203 certification on the chief endeavor? Then, you are at the ideal locale for Salesforce Plat-Arch-203 exam Readiness. Salesforce Plat-Arch-203 Dumps gives you the most recent review material that has been figured out for you to pass the Plat-Arch-203 exam on the key endeavor.
Our Plat-Arch-203 test training will provide you with a well-rounded service so that you will not lag behind and finish your daily task step by step. At the same time, our Plat-Arch-203 study torrent will also save your time and energy in well-targeted learning as we are going to make everything done in order that you can stay focused in learning our Plat-Arch-203 Study Materials without worries behind. We are so honored and pleased to be able to read our detailed introduction and we will try our best to enable you a better understanding of our Plat-Arch-203 test training better.
Test Plat-Arch-203 Assessment & Valid Plat-Arch-203 Exam DurationLatest Plat-Arch-203 test questions are verified and tested several times by our colleagues to ensure the high pass rate of our Salesforce Plat-Arch-203 study guide. We are popular not only because our outstanding Salesforce Plat-Arch-203 practice dumps, but also for our well-praised after-sales service. After purchasing our Salesforce Plat-Arch-203 practice materials, the free updates will be sent to your mailbox for one year long if our experts make any of our Salesforce Plat-Arch-203 guide materials.
Salesforce Certified Platform Identity and Access Management Architect Sample Questions (Q52-Q57):NEW QUESTION # 52
Universal containers (UC) built a customer Community for customers to buy products, review orders, and manage their accounts. UC has provided three different options for customers to log in to the customer Community: salesforce, Google, and Facebook. Which two role combinations are represented by the systems in the scenario? Choose 2 answers
- A. Salesforce is the service provider and Google is the identity provider
- B. Facebook is the service provider and salesforce is the identity provider
- C. Salesforce is the service provider and Facebook is the identity provider
- D. Google is the service provider and Facebook is the identity provider
NEW QUESTION # 53
Containers (UC) uses a legacy Employee portal for their employees to collaborate. Employees access the portal from their company's internal website via SSO. It is set up to work with SiteMinder and Active Directory. The Employee portal has features to support posing ideas. UC decides to use Salesforce Ideas for voting and better tracking purposes. To avoid provisioning users on Salesforce, UC decides to integrate Employee portal ideas with Salesforce idea through the API. What is the role of Salesforce in the context of SSO, based on this scenario?
- A. Identity Provider, because the API calls are authenticated by Salesforce.
- B. Service Provider, because Salesforce is the application for managing ideas.
- C. An independent system, because Salesforce is not part of the SSO setup.
- D. Connected App, because Salesforce is connected with Employee portal via API.
NEW QUESTION # 54
Universal containers (UC) would like to enable self - registration for their salesforce partner community users. UC wants to capture some custom data elements from the partner user, and based on these data elements, wants to assign the appropriate profile and account values. Which two actions should the architect recommend to UC? Choose 2 answers
- A. Configure registration for communities to use a custom apex controller.
- B. Modify the selfregistration trigger to assign profile and account.
- C. Configure registration for communities to use a custom visualforce page.
- D. Modify the communitiesselfregcontroller to assign the profile and account.
NEW QUESTION # 55
Northern Trail Outfitters (NTO) has an off-boarding process where a terminated employee is first disabled in the Lightweight Directory Act Protocol (LDAP) directory, then requests are sent to the various application support teams to finish user deactivations. A terminated employee recently was able to login to NTO's Salesforce instance 24 hours after termination, even though the user was disabled in the corporate LDAP directory.
What should an identity architect recommend to prevent this from happening in the future?
- A. Setup an identity provider (IdP) to authenticate users using LDAP, set up single sign-on to Salesforce and disable Login Form authentication.
- B. use a login flow to make a callout to the LDAP directory before authenticating the user to Salesforce.
- C. Configure an authentication provider to delegate authentication to the LDAP directory.
- D. Create a Just-in-Time provisioning registration handler to ensure users are deactivated in Salesforce as they are disabled in LDAP.
NEW QUESTION # 56
Northern Trail Outfitters (NTO) wants to improve its engagement with existing customers to boost customer loyalty. To get a better understanding of its customers, NTO establishes a single customer view including their buying behaviors, channel preferences and purchasing history. All of this information exists but is spread across different systems and formats.
NTO has decided to use Salesforce as the platform to build a 360 degree view. The company already uses Microsoft Active Directory (AD) to manage its users and company assets.
What should an Identity Architect do to provision, deprovision and authenticate users?
- A. Salesforce Identity is not needed since NTO uses Microsoft AD.
- B. Salesforce Identity can be included but NTO will be required to build a custom integration with Microsoft AD.
- C. A Salesforce Identity can be included but NTO will require Identity Connect.
- D. Salesforce Identity is included in the Salesforce licenses so it does not need to be considered separately.
NEW QUESTION # 57
Our Plat-Arch-203 test prep attaches great importance to a skilled, trained and motivated workforce as well as the company’s overall performance. Adhere to new and highly qualified Plat-Arch-203 quiz guide to meet the needs of customer, we are also committed to providing the first -class after-sale service. There will be our customer service agents available 24/7 for your supports; any request for further assistance or information about Plat-Arch-203 Exam Torrent will receive our immediate attention. And you can contact us online or send us email on the Plat-Arch-203 training questions.
Test Plat-Arch-203 Assessment: https://www.pass4test.com/Plat-Arch-203.html
Salesforce Plat-Arch-203 New Braindumps Questions To develop a new study system needs to spend a lot of manpower and financial resources, first of all, essential, of course, is the most intuitive skill learning materials, to some extent this greatly affected the overall quality of the learning materials, If you have been struggling hard to pass out the Salesforce Plat-Arch-203 exam and haven't got satisfactory results yet, you just have to try our Plat-Arch-203 training material once for getting 100% success in Salesforce certification exam, And the update version for Plat-Arch-203 exam torrent will send to your email automatically.
For access from mobile phones and devices, they offer apps for Plat-Arch-203 Valid Exam Objectives the most popular platforms, When you're hired to shoot something, somebody wants your expertise as a photographer.
To develop a new study system needs to spend Plat-Arch-203 a lot of manpower and financial resources, first of all, essential, of course, isthe most intuitive skill learning materials, Test Plat-Arch-203 Assessment to some extent this greatly affected the overall quality of the learning materials.
Efficient Salesforce - Plat-Arch-203 - Salesforce Certified Platform Identity and Access Management Architect New Braindumps QuestionsIf you have been struggling hard to pass out the Salesforce Plat-Arch-203 Exam and haven't got satisfactory results yet, you just have to try our Plat-Arch-203 training material once for getting 100% success in Salesforce certification exam.
And the update version for Plat-Arch-203 exam torrent will send to your email automatically, One of the reasons to get customers' support and trust is that we have the best high-quality Salesforce Plat-Arch-203 prep material.
Almost all questions of the real exam will be predicated accurately in our Plat-Arch-203 practice questions, which can add you passing rate of the exam.
- 100% Pass 2026 Salesforce Efficient Plat-Arch-203 New Braindumps Questions 🖤 Open ➽ [url]www.vce4dumps.com 🢪 enter [ Plat-Arch-203 ] and obtain a free download 🈺Exam Plat-Arch-203 Review[/url]
- Exam Plat-Arch-203 Review 🛷 Latest Plat-Arch-203 Questions 🚤 Plat-Arch-203 Updated Testkings 💾 Search for ➡ Plat-Arch-203 ️⬅️ and download it for free on ✔ [url]www.pdfvce.com ️✔️ website 🌱
lat-Arch-203 Valid Exam Online[/url] - Plat-Arch-203 Testking Exam Questions 🙏 Plat-Arch-203 Authorized Test Dumps 🦆 Plat-Arch-203 Reliable Practice Materials 🎎 Search for [ Plat-Arch-203 ] on ➤ [url]www.prepawaypdf.com ⮘ immediately to obtain a free download 🪕
lat-Arch-203 Testking Exam Questions[/url] - Plat-Arch-203 Training Solutions 🐨 Plat-Arch-203 Current Exam Content 🌯 Pdf Plat-Arch-203 Pass Leader 🎨 Download ➤ Plat-Arch-203 ⮘ for free by simply searching on ✔ [url]www.pdfvce.com ️✔️ 🐎Exam Plat-Arch-203 Review[/url]
- Reliable 100% Free Plat-Arch-203 – 100% Free New Braindumps Questions | Test Plat-Arch-203 Assessment 😎 Search on ☀ [url]www.examcollectionpass.com ️☀️ for ⏩ Plat-Arch-203 ⏪ to obtain exam materials for free download 🥿
lat-Arch-203 Testking Exam Questions[/url] - Latest Plat-Arch-203 Exam Question 🛴 Plat-Arch-203 Instant Download 🧥 Plat-Arch-203 Training Solutions 🌘 The page for free download of ➤ Plat-Arch-203 ⮘ on ( [url]www.pdfvce.com ) will open immediately 🍮Latest Plat-Arch-203 Questions[/url]
- Plat-Arch-203 Study Guide Pdf 🏆 Plat-Arch-203 Reliable Practice Materials 📂 Test Plat-Arch-203 Answers 🏏 Easily obtain free download of [ Plat-Arch-203 ] by searching on ▷ [url]www.prep4away.com ◁ ⛅Associate Plat-Arch-203 Level Exam[/url]
- Trustable Plat-Arch-203 New Braindumps Questions - Find Shortcut to Pass Plat-Arch-203 Exam 🔘 Download ⮆ Plat-Arch-203 ⮄ for free by simply entering ⏩ [url]www.pdfvce.com ⏪ website 🎁Exam Plat-Arch-203 Review[/url]
- Plat-Arch-203 Test Torrent and Plat-Arch-203 Preparation Materials: Salesforce Certified Platform Identity and Access Management Architect - Plat-Arch-203 Practice Test ⏰ Go to website 【 [url]www.exam4labs.com 】 open and search for ⮆ Plat-Arch-203 ⮄ to download for free 🧄
df Plat-Arch-203 Pass Leader[/url] - Reliable Plat-Arch-203 Learning guide Materials are the best for you - Pdfvce 🐣 Simply search for ☀ Plat-Arch-203 ️☀️ for free download on ⏩ [url]www.pdfvce.com ⏪ 🗺Latest Plat-Arch-203 Questions[/url]
- Test Plat-Arch-203 Answers 💒 Plat-Arch-203 Authorized Test Dumps 🛹 Exam Plat-Arch-203 Review 🧩 Go to website 《 [url]www.vce4dumps.com 》 open and search for 《 Plat-Arch-203 》 to download for free 🌺Exam Plat-Arch-203 Review[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
