Simulated CCAAK Test - Trustable Confluent CCAAK Practice Tests: Confluent Certi
Posted at 2/19/2026 03:16:27
P.S. Free & New CCAAK dumps are available on Google Drive shared by DumpTorrent: https://drive.google.com/open?id=1DXG_H8dx9Mb9qAy2n7BRe7P51Yu1kw8m
We are going to promise that we will have a lasting and sustainable cooperation with customers who want to buy the CCAAK study materials from our company. We can make sure that our experts and professors will try their best to update the study materials in order to help our customers to gain the newest and most important information about the CCAAK Exam. If you decide to buy our study materials, you will never miss any important information. In addition, we can promise the updating system is free for you.
Confluent CCAAK Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Apache Kafka® Cluster Configuration: This section of the exam measures skills of a Kafka Administrator and includes configuring broker properties, tuning for performance, managing topic-level settings, and applying best practices for production-grade environments.
| | Topic 2 | - Kafka Connect: This section of the exam measures skills of a Site Reliability Engineer and addresses the use and management of Kafka Connect for data integration. It includes setting up connectors, managing configurations, and ensuring efficient movement of data between Kafka and external systems.
| | Topic 3 | - Apache Kafka® Security: This section of the exam measures skills of a Site Reliability Engineer and focuses on securing Kafka environments. It includes authentication mechanisms such as TLS and SASL, authorization using ACLs, and encrypting data at rest and in transit to ensure secure communication and access control.
| | Topic 4 | - Observability: This section of the exam measures skills of a Site Reliability Engineer and focuses on monitoring Kafka clusters. It assesses knowledge of metrics, logging, and alerting tools, including how to use them to maintain cluster health and performance visibility.
| | Topic 5 | - Deployment Architecture: This section of the exam measures skills of a Kafka Administrator and covers different Kafka deployment topologies. It evaluates understanding of high availability, disaster recovery, multi-data center replication, and the roles of Zookeeper or KRaft in the cluster architecture.
| | Topic 6 | - Troubleshooting: This section of the exam measures skills of a Kafka Administrator and includes diagnosing common issues in Kafka clusters. It covers problem areas such as performance bottlenecks, message delivery failures, replication issues, and consumer lag, along with techniques to resolve them effectively.
100% Pass 2026 Confluent CCAAK: Confluent Certified Administrator for Apache Kafka Unparalleled Simulated TestWith our CCAAK practice test software, you can simply assess yourself by going through the CCAAK practice tests. We highly recommend going through the CCAAK answers multiple times so you can assess your preparation for the CCAAK exam. Make sure that you are preparing yourself for the CCAAK test with our practice test software as it will help you get a clear idea of the real CCAAK exam scenario. By passing the exams multiple times on practice test software, you will be able to pass the real CCAAK test in the first attempt.
Confluent Certified Administrator for Apache Kafka Sample Questions (Q53-Q58):NEW QUESTION # 53
Per customer business requirements, a system's high availability is more important than message reliability.
Which of the following should be set?
- A. Unclean leader election should be enabled.
- B. The linger.ms should be set to '0'.
- C. Message retention.ms should be set to -1.
- D. The number of brokers in the cluster should be always odd (3, 5. 7 and so on).
Enabling unclean leader election allows Kafka to elect a non-in-sync replica as leader if all in-sync replicas are unavailable. This sacrifices message reliability (possible data loss) in favor of high availability, aligning with the requirement.
NEW QUESTION # 54
Kafka Connect is running on a two node cluster in distributed mode. The connector is a source connector that pulls data from Postgres tables (users/payment/orders), writes to topics with two partitions, and with replication factor two. The development team notices that the data is lagging behind.
What should be done to reduce the data lag*?
The Connector definition is listed below:
"name": "confluent-postgresql-source",
"connector class": "PostgresSource",
"topic.prefix": "postgresql_",
& nbsp;& nbsp;& nbsp;...
"db.name": "postgres",
"table.whitelist": "users.payment.orders",
"timestamp.column.name": "created_at",
"output.data format": "JSON",
"db.timezone": "UTC",
"tasks.max": "1"
- A. Increase the number of Connect Nodes.
- B. Increase the number of Connect Tasks (tasks max value).
- C. Increase the number of partitions.
- D. Increase the replication factor and increase the number of Connect Tasks.
The connector is currently configured with "tasks.max": "1", which means only one task is handling all tables (users, payment, orders). This can create a bottleneck and lead to lag. Increasing tasks.max allows Kafka Connect to parallelize work across multiple tasks, which can pull data from different tables concurrently and reduce lag.
NEW QUESTION # 55
How can authentication for both internal component traffic and external client traffic be accomplished?
- A. Configure multiple security protocols on the same listener.
- B. Configure LoadBalancer.
- C. Configure multiple listeners on the broker.
- D. Configure multiple brokers.
Kafka supports multiple listeners, each with its own port, hostname, and security protocol. This allows you to:
* Use one listener for internal communication (e.g., brokers, ZooKeeper, Connect, etc.) with one type of authentication (e.g., PLAINTEXT or SASL).
* Use a separate listener for external clients (e.g., producers and consumers) with a different protocol (e.g., SSL or SASL_SSL).
NEW QUESTION # 56
What are important factors in sizing a ksqlDB cluster? (Choose three.)
- A. Data Encryption
- B. Number of Partitions
- C. Number of Queries
- D. Data Schema
- E. Topic Data Retention
Answer: B,C,D
The complexity of the schema (number of fields, data types, etc.) affects processing and memory usage.
Each ksqlDB persistent query consumes resources (CPU, memory), so more queries require more capacity.
More partitions increase parallelism, but also resource usage, especially in scaling and state management.
NEW QUESTION # 57
What are benefits to gracefully shutting down brokers? (Choose two.)
- A. It will sync all its logs to disk to avoid needing to do any log recovery when it restarts.
- B. It will migrate any partitions the server is the leader for to other replicas prior to shutting down.
- C. It will balance the partitions across brokers before restarting.
- D. It will automatically re-elect leaders on restart.
A graceful shutdown ensures that logs are flushed to disk, minimizing recovery time during restart.
Kafka performs controlled leader migration during a graceful shutdown to avoid disruption and ensure availability.
NEW QUESTION # 58
If you still desperately cram knowledge and spend a lot of precious time and energy to prepare for passing Confluent certification CCAAK exam, and at the same time do not know how to choose a more effective shortcut to pass Confluent Certification CCAAK Exam. Now DumpTorrent provide you a effective method to pass Confluent certification CCAAK exam. It will play a multiplier effect to help you pass the exam.
CCAAK Practice Tests: https://www.dumptorrent.com/CCAAK-braindumps-torrent.html
- CCAAK Exam Pass Guide 🚍 CCAAK Valid Test Duration ⛴ New CCAAK Exam Test 🧿 Search for ➠ CCAAK 🠰 on [ [url]www.verifieddumps.com ] immediately to obtain a free download 🦪Dump CCAAK Check[/url]
- Simulated CCAAK Test | High-quality CCAAK Practice Tests: Confluent Certified Administrator for Apache Kafka 🥀 Download { CCAAK } for free by simply searching on ➽ [url]www.pdfvce.com 🢪 🙈Exam CCAAK Cram Questions[/url]
- New CCAAK Exam Bootcamp 👲 Exam CCAAK Cram Questions 🦟 Exam CCAAK Quizzes 🛕 Search for ⇛ CCAAK ⇚ and download exam materials for free through ⇛ [url]www.troytecdumps.com ⇚ 😶Free CCAAK Download Pdf[/url]
- 2026 Simulated CCAAK Test - First-grade Confluent CCAAK Practice Tests 100% Pass 🐢 Immediately open 【 [url]www.pdfvce.com 】 and search for ☀ CCAAK ️☀️ to obtain a free download ✌Regualer CCAAK Update[/url]
- CCAAK valid vce collection - CCAAK latest training dumps 🦙 Enter ☀ [url]www.examcollectionpass.com ️☀️ and search for ☀ CCAAK ️☀️ to download for free 🪀Reliable CCAAK Exam Review[/url]
- Simulated CCAAK Test | High-quality CCAAK Practice Tests: Confluent Certified Administrator for Apache Kafka 🛒 Search on ⏩ [url]www.pdfvce.com ⏪ for ➠ CCAAK 🠰 to obtain exam materials for free download 🩲Exam CCAAK Passing Score[/url]
- Simulated CCAAK Test | High-quality CCAAK Practice Tests: Confluent Certified Administrator for Apache Kafka 🖕 Search for 【 CCAAK 】 and download it for free immediately on { [url]www.examcollectionpass.com } 🧡Regualer CCAAK Update[/url]
- CCAAK dumps torrent: Confluent Certified Administrator for Apache Kafka - CCAAK valid test 🏳 Open website 「 [url]www.pdfvce.com 」 and search for ➥ CCAAK 🡄 for free download 🐼Exam CCAAK Cram Questions[/url]
- Simulated CCAAK Test | High-quality CCAAK Practice Tests: Confluent Certified Administrator for Apache Kafka ⏰ Search for ➽ CCAAK 🢪 and download it for free immediately on ▶ [url]www.torrentvce.com ◀ 🕣CCAAK Torrent[/url]
- Exam CCAAK Quizzes 🐚 New CCAAK Exam Bootcamp 🛷 Dump CCAAK Check 🔪 Download ➡ CCAAK ️⬅️ for free by simply searching on ➥ [url]www.pdfvce.com 🡄 🕛New CCAAK Test Cram[/url]
- The Best Accurate Simulated CCAAK Test to Obtain Confluent Certification 📴 The page for free download of ➠ CCAAK 🠰 on ▷ [url]www.exam4labs.com ◁ will open immediately 🧒CCAAK Exam Preparation[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.valentinacolonna.it, www.stes.tyc.edu.tw, course.mbonisi.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, shop.blawantraining.pro, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
What's more, part of that DumpTorrent CCAAK dumps now are free: https://drive.google.com/open?id=1DXG_H8dx9Mb9qAy2n7BRe7P51Yu1kw8m
