[General] NP-Con-101 Fresh Dumps & NP-Con-101 Practice Questions
138
【General】 NP-Con-101 Fresh Dumps & NP-Con-101 Practice Questions
Posted at 2/19/2026 03:20:51      View:81 | Replies:0        Print      Only Author   [Copy Link] 1#
The NP-Con-101 software supports the MS operating system and can simulate the real test environment. In addition, the NP-Con-101 software has a variety of self-learning and self-assessment functions to test learning outcome, which will help you increase confidence to pass exam. The contents of the three versions are the same. Each of them neither limits the number of devices used or the number of users at the same time. You can choose according to your needs. NP-Con-101 Study Materials provide 365 days of free updates, you do not have to worry about what you missed.
Belive it or not, our efficient and authoritative NP-Con-101 exam materials are always here waiting for you to provide you with the best help of NP-Con-101 exam preparation. Maybe you just need a NP-Con-101 exam certification to realize your dream of promotion. We know that impulse spending will make you regret, so we suggest that you first download our free demo to check before purchasing. You can easily download our free demo of NP-Con-101 Exam; come on and try it.
100% Pass Salesforce - Accurate NP-Con-101 Fresh DumpsIn today's society, everyone wants to find a good job and gain a higher social status. As we all know, the internationally recognized NP-Con-101 certification means that you have a good grasp of knowledge of certain areas and it can demonstrate your ability. This is a fair principle. But obtaining this NP-Con-101 certificate is not an easy task, especially for those who are busy every day. We do not charge extra service fees, but the service quality is high. Your satisfaction is the greatest affirmation for us and we sincerely serve you. Our NP-Con-101 Exam Guide deliver the most important information in a simple, easy-to-understand language that you can learn efficiently learn with high quality. Whether you are a student or an in-service person, our NP-Con-101 exam torrent can adapt to your needs.
Salesforce Certified Nonprofit Success Pack Consultant Sample Questions (Q165-Q170):NEW QUESTION # 165
A nonprofit has a large volume of data across multiple objects in Salesforce and external databases. The nonprofit needs to quickly query data across its systems to get insights on any device about the impact it is having.
Which solution should the consultant recommend?
  • A. CRM Analytics
  • B. Salesforce Connect
  • C. External Objects
  • D. Salesforce Reports & Dashboards
To quickly query data across multiple systems and get insights on any device about the impact the nonprofit is having, the consultant should recommend:
CRM Analytics (formerly known as Tableau CRM or Einstein Analytics):
CRM Analytics allows for advanced data analysis, visualization, and reporting. It can integrate data from multiple Salesforce objects and external sources, providing comprehensive insights across systems. It is designed to work seamlessly on various devices, ensuring accessibility and usability.
NEW QUESTION # 166
A nonprofit organization created a custom Opportunity name for all organization donations.
Which two considerations should the consultant discuss with the organization? Choose 2 answers
  • A. The organization should only change existing Opportunities to the new naming convention by using the "Refresh Name" action.
  • B. The organization should change existing Opportunities to the new naming convention by using the "Refresh All Opportunity Names" button in Bulk Data Processes.
  • C. The custom naming convention only applies to new Opportunities of matching record types; it is not retroactive.
  • D. The organization should change existing Opportunities to the new naming convention through an upsert.
When a nonprofit organization creates a custom Opportunity name for all organization donations, the consultant should discuss the following considerations:
Using the "Refresh Name" Action (B):
The organization should use the "Refresh Name" action to change existing Opportunities to the new naming convention. This action ensures that the custom naming convention is applied correctly.
Navigate to the Opportunity record.
Click on the "Refresh Name" button to update the Opportunity name according to the new naming convention.
Using the "Refresh All Opportunity Names" Button in Bulk Data Processes (C):
For bulk updates, the organization should use the "Refresh All Opportunity Names" button available in Bulk Data Processes.
Go to NPSP Settings.
Under Bulk Data Processes, find the "Refresh All Opportunity Names" button.
Click on it to update all existing Opportunities to the new naming convention in bulk.
These methods ensure that the custom naming convention is applied consistently across all existing Opportunity records, maintaining data integrity and consistency within the Salesforce org.
NEW QUESTION # 167
A nonprofit fundraiser notices that some of the NPSP calculated donation summary fields on the Contact and Account records are displaying incorrect values when compared to the donations recorded for each donor.
What are three items the consultant should review to troubleshoot the issue?
Choose 3 answers
  • A. NPSP Health Check
  • B. Customizable Rollups
  • C. Opportunity Stages
  • D. Campaign Hierarchy
  • E. Salesforce Optimizer report
Answer: A,B,C
To troubleshoot incorrect values in the NPSP calculated donation summary fields on Contact and Account records, the consultant should review the following:
Customizable Rollups:
Verify the settings and configuration of Customizable Rollups in NPSP. Incorrect configurations or mappings can lead to inaccurate summary values.
Ensure that the rollups are set up correctly to calculate totals based on the desired criteria.
Opportunity Stages:
Check the Opportunity stages to ensure they are correctly defined and assigned. Only certain stages (e.g., "Closed Won") should be included in donation summaries.
Misconfigured or incorrect stages can result in inaccurate summary calculations.
NPSP Health Check:
Run the NPSP Health Check to identify any potential configuration issues or data integrity problems.
The Health Check provides insights and recommendations to address common issues within NPSP.
Salesforce Nonprofit Success Pack Documentation on Customizable Rollups Salesforce Opportunity Stages Configuration Guide NPSP Health Check Documentation
NEW QUESTION # 168
A nonprofit organization recently completed a migration to a NPSP Salesforce org. The consultant wants to ensure that all the migrated Accounts use the same account model. What action should the consultant take?
  • A. Run the NPSP Health Check Tool
  • B. Run the Salesforce Optimizer
  • C. Run the Lightning Readiness Assessment
  • D. Run the Data Quality Analysis Dashboard
After migrating to a Nonprofit Success Pack (NPSP) Salesforce org, it's essential to ensure that all migrated Accounts are consistent with the chosen account model. The Data Quality Analysis Dashboard is a vital tool for this purpose.
Data Quality Analysis Dashboard:
This dashboard provides comprehensive insights into data quality across the org.
It helps identify inconsistencies, missing data, and discrepancies in Account records.
Steps to Ensure Consistency:
Run the Data Quality Analysis Dashboard:
Navigate to NPSP Settings and select the Data Quality Analysis Dashboard.
Review the results to identify any Accounts that do not conform to the expected account model.
Address Identified Issues:
Correct any identified discrepancies by updating the Account records to align with the chosen model (e.g., Household Account Model).
Regular Monitoring:
Schedule regular runs of the Data Quality Analysis Dashboard to maintain data integrity over time.
Benefits of Consistency:
Ensures accurate reporting and analytics.
Improves data integrity and usability across the organization.
Facilitates better donor and constituent management.
Complementary Tools:
While the Data Quality Analysis Dashboard is primary, tools like the NPSP Health Check Tool and Salesforce Optimizer can provide additional insights into overall org health and performance.
CertGod Nonprofit Cloud Consultant study guide: "Run the Data Quality Analysis Dashboard".
NEW QUESTION # 169
A nonprofit organization is using Volunteers for Salesforce and wants its volunteers to be able to log their own volunteer hours.
Which two solutions should a consultant propose to meet this need? Choose 2 answers
  • A. Set up a Chatter Group for each volunteer job, add volunteers who are assigned to that job, and have the volunteers log their hours in the Chatter Group.
  • B. Set up a Log Volunteer Hours section on a page on your website and direct volunteers there to log their hours to the volunteer job or shift they worked on.
  • C. Set up the Volunteers Personal Site and direct the volunteer to record hours on the tab there.
  • D. Set up a workflow rule with a weekly email alert sent to all volunteers asking them to reply back and report their hours for the week and then a user will manually enter the hours in Salesforce.
To allow volunteers to log their own hours in Volunteers for Salesforce, the consultant should propose setting up the Volunteers Personal Site or adding a Log Volunteer Hours section on the nonprofit's website.
Volunteers Personal Site:
This site allows volunteers to log in and manage their hours directly within Salesforce.
Steps to Set Up:
Navigate to Setup > Sites.
Create a new site and configure it to use the Volunteers for Salesforce functionality.
Add the Volunteers Personal Site tab and configure the permissions.
Direct volunteers to use this site to log their hours.
Log Volunteer Hours Section on Website:
Create a section on the nonprofit's website where volunteers can log their hours.
Steps to Set Up:
Design a web form that captures the volunteer's job or shift and the hours worked.
Use Salesforce Web-to-Case or Web-to-Lead to capture this data and create records in Salesforce.
Direct volunteers to this section to submit their hours.
Both solutions provide a user-friendly way for volunteers to log their hours without requiring manual entry by staff.
NEW QUESTION # 170
Our NP-Con-101 test guide is suitable for you whichever level you are in right now. Whether you are in entry-level position or experienced exam candidates who have tried the exam before, this is the perfect chance to give a shot. A growing number of exam candidates are choosing our NP-Con-101 Exam Questions, why are you still hesitating? As long as you have make up your mind, our Salesforce Certified Nonprofit Success Pack Consultant study question is available in five minutes, so just begin your review now! This could be a pinnacle in your life.
NP-Con-101 Practice Questions: https://www.pass4guide.com/NP-Con-101-exam-guide-torrent.html
NP-Con-101 test questions have so many advantages that basically meet all the requirements of the user, I got them for my advanced solutions of Salesforce exch server 2013 NP-Con-101 exam and i passed it so well, You may find hundreds of online free courses for Salesforce NP-Con-101 exam preparation but such courses cannot guarantee your success, Salesforce NP-Con-101 Fresh Dumps We always put the information security in the first place.
This article by Ed Tittel and Mary Kyle provides NP-Con-101 Practice Questions you with a good understanding of key IT job roles and the kinds of skills and knowledge that go with them to help ensure the NP-Con-101 Valid Test Syllabus most positive experience for applicants, no matter what kind of IT work you are after.
Updated NP-Con-101 Fresh Dumps, Ensure to pass the NP-Con-101 ExamThe first set of impacts hit consumer facing industries, like travel, entertainment and dining, NP-Con-101 Test Questions have so many advantages that basically meet all the requirements of the user.
I got them for my advanced solutions of Salesforce exch server 2013 NP-Con-101 exam and i passed it so well, You may find hundreds of online free courses for Salesforce NP-Con-101 exam preparation but such courses cannot guarantee your success.
We always put the information security NP-Con-101 in the first place, All the features for the Salesforce exam were great.
