[General] 100% Pass Quiz 2026 ANS-C01: AWS Certified Advanced Networking Specialty Exam¨CEf
85
¡¾General¡¿ 100% Pass Quiz 2026 ANS-C01: AWS Certified Advanced Networking Specialty Exam¨CEf
Posted at 2/19/2026 04:00:42      View£º109 | Replies£º0        Print      Only Author   [Copy Link] 1#
What's more, part of that Pass4Leader ANS-C01 dumps now are free: https://drive.google.com/open?id=1uLmTNFu5WJKzE0uH5-gCSn_R3wzgcdux
AWS Certified Advanced Networking Specialty Exam ANS-C01 exam dumps are available in an eBook and software format. Many people get burdened when they hear of preparing for a AWS Certified Advanced Networking Specialty Exam ANS-C01 examination with software. Amazon ANS-C01 Practice Exam software is easy to use. You don't need to have prior knowledge or training using our ANS-C01 exam questions. Amazon ANS-C01 exam dumps are user-friendly interfaces.
To pass the ANS-C01 Exam, candidates must demonstrate a strong understanding of advanced networking concepts and technologies, as well as the ability to apply this knowledge to real-world scenarios. ANS-C01 exam consists of multiple-choice and multiple-response questions, and candidates have 170 minutes to complete it. Passing the exam validates the candidate's technical expertise and opens up new opportunities for career growth in the field of cloud networking.
Dump ANS-C01 File & ANS-C01 Exam Guide MaterialsThe Amazon braindumps torrents available at Pass4Leader are the most recent ones and cover the difficulty of ANS-C01 test questions. Get your required exam dumps instantly in order to pass ANS-C01 actual test in your first attempt. Don't waste your time in doubts and fear; Our ANS-C01 Practice Exams are absolutely trustworthy and more than enough to obtain a brilliant result in real exam.
Amazon AWS Certified Advanced Networking Specialty Exam Sample Questions (Q287-Q292):NEW QUESTION # 287
A company uses a 4 Gbps AWS Direct Connect dedicated connection with a link aggregation group (LAG) bundle to connect to five VPCs that are deployed in the us-east-1 Region. Each VPC serves a different business unit and uses its own private VIF for connectivity to the on- premises environment. Users are reporting slowness when they access resources that are hosted on AWS. A network engineer finds that there are sudden increases in throughput and that the Direct Connect connection becomes saturated at the same time for about an hour each business day. The company wants to know which business unit is causing the sudden increase in throughput. The network engineer must find out this information and implement a solution to resolve the problem.
Which solution will meet these requirements?
  • A. Review the Amazon CloudWatch metrics for VirtualInterfaceBpsEgress and VirtualInterfaceBpsIngress to determine which VIF is sending the highest throughput during the period in which slowness is observed. Upgrade the bandwidth of the existing dedicated connection to 10 Gbps.
  • B. Review the Amazon CloudWatch metrics for ConnectionBpsIngress and ConnectionPpsEgress to determine which VIF is sending the highest throughput during the period in which slowness is observed. Create a new 10 Gbps dedicated connection. Shift traffic from the existing dedicated connection to the new dedicated connection.
  • C. Review the Amazon CloudWatch metrics for VirtualInterfaceBpsEgress and VirtualInterfaceBpsIngress to determine which VIF is sending the highest throughput during the period in which slowness is observed. Create a new 10 Gbps dedicated connection. Shift traffic from the existing dedicated connection to the new dedicated connection.
  • D. Review the Amazon CloudWatch metrics for ConnectionBpsIngress and ConnectionPpsEgress to determine which VIF is sending the highest throughput during the period in which slowness is observed. Upgrade the existing dedicated connection to a 5 Gbps hosted connection.
You cannot change the port speed after you create the connection request. To change the port speed, you must create and configure a new connection.
https://docs.aws.amazon.com/dire ... ted_connection.html
NEW QUESTION # 288
A company has a total of 30 VPCs. Three AWS Regions each contain 10 VPCs. The company has attached the VPCs in each Region to a transit gateway in that Region. The company also has set up inter-Region peering connections between the transit gateways.
The company wants to use AWS Direct Connect to provide access from its on-premises location for only four VPCs across the three Regions. The company has provisioned four Direct Connect connections at two Direct Connect locations.
Which combination of steps will meet these requirements MOST cost-effectively? (Select THREE.)
  • A. Create a Direct Connect gateway. Associate the four virtual private gateways with the Direct Connect gateway.
  • B. Create an association between the Direct Connect gateway and the transit gateways.
  • C. Create four transit VIFs on each Direct Connect connection. Associate the transit VIFs with the Direct Connect gateway.
  • D. Create four virtual private gateways. Attach the virtual private gateways to the four VPCs.
  • E. Create four transit VIFs on each Direct Connect connection. Associate the transit VIFs with the four virtual private gateways.
  • F. Create four private VIFs on each Direct Connect connection to the Direct Connect gateway.
Answer: A,B,C
To connect to multiple VPCs across different Regions using Direct Connect, the best option is to use a Direct Connect gateway and transit gateways. A Direct Connect gateway allows you to associate multiple virtual private gateways and transit gateways with the same Direct Connect connection. A transit gateway acts as a network hub that connects multiple VPCs and on-premises networks. By creating inter-Region peering connections between the transit gateways, you can enable cross-Region communication. Therefore, the steps are:
*         Create four virtual private gateways and attach them to the four VPCs that need access from the on-premises location.
*         Create a Direct Connect gateway and associate it with the four virtual private gateways.
*         Create four transit VIFs on each Direct Connect connection and associate them with the Direct Connect gateway. A transit VIF allows you to connect to a Direct Connect gateway using a private ASN.
*         Create an association between the Direct Connect gateway and the transit gateways in each Region. This will enable the on-premises location to access the VPCs that are attached to the transit gateways.
NEW QUESTION # 289
An online retail company is running a web application in the us-west-2 Region and serves consumers in the United States. The company plans to expand across several countries in Europe and wants to provide low latency for all its users.
The application needs to identify the users' IP addresses and provide localized content based on the users' geographic location. The application uses HTTP GET and POST methods for its functionality. The company also needs to develop a failover mechanism that works for GET and POST methods and is based on health checks. The failover must occur in less than 1 minute for all clients.
  • A. Configure an Application Load Balancer (ALB) for the application in each environment in the new AWS Regions. Create Amazon Route 53 public hosted zones that have failover routing policies.
  • B. Configure a Network Load Balancer (NLB) for the application in each environment In the new AWS Regions. Create an AWS Global Accelerator accelerator that has endpoint groups that point to the NLBs in each Region.
  • C. Configure a Network Load Balancer (NLB) for the application in each environment in the new AWS Regions. Create an Amazon CloudFront distribution. Configure an origin group with origin failover options.
  • D. Configure an Application Load Balancer (ALB) for the application in each environment in the new AWS Regions. Create an AWS Global Accelerator accelerator that has endpoint groups that point to the ALBs in each Region.
NEW QUESTION # 290
You have just provisioned a new VPC a with a CIDR block of 172.16.12.0/24. The entire CIDR block is fully utilized by subdividing it into 6 subnets, we will refer to these as Subnet1 through to Subnet6. The first 2 subnets (Subnet1 and Subnet2) are the same size. The last 4 subnets (Subnet3, Subnet4, Subnet5, Subnet6) are also the same size. Subnet5 is half the size of Subnet2. The address space as occupied by the first two subnets is contiguous, as is the address space occupied by the last 4 subnets.
Within Subnet3 AWS reserves the address 172.16.12.129 for the VPC router. Select the correct IP address reserved by AWS for DNS in the Subnet2.
Response:
  • A. 172.16.64.65
  • B. 172.16.64.1
  • C. 172.16.12.64
  • D. 172.16.12.66
NEW QUESTION # 291
A network engineer is using AWS Direct Connect connections and MACsec to encrypt data from a corporate data center to the Direct Connect location. The network engineer learns that the MACsec secret key might have been compromised. The network engineer needs to update the connection with an uncompromised secure key.
Which solution will meet this requirement?
  • A. Create a new MACsec secret key that uses an AWS Key Management Service (AWS KMS) AWS managed key. Associate the new pre-shared key, Connection Key Name (CKN). and Connectivity Association Key (CAK) with the connection.
  • B. Modify the existing MACsec secret key. Associate the new pre-shared key. Connection Key Name (CKN). and Connectivity Association Key (CAK) with the connection.
  • C. Create a new MACsec secret key that uses an AWS Key Management Service (AWS KMS) customer managed key. Associate the new pre-shared key, Connection Key Name (CKN). and Connectivity Association Key (CAK) with the connection.
  • D. Modify the existing MACsec secret key. Re-associate the existing pre-shared key. Connection Key Name (CKN), and Connectivity Association Key (CAK) with the connection.
NEW QUESTION # 292
When it comes to the practice material, many writers did not think of the diversity of needs from exam candidates, and this was inconvenient for them. However, our ANS-C01 torrent prep respects your inclination and preference of practice materials. PDF version being legible to read and remember, support customers¡¯ printing request, and allow you to have a print and practice in papers. Software version of ANS-C01 Exam Questions supports simulation test system. Remember this version support Windows system users only.
Dump ANS-C01 File: https://www.pass4leader.com/Amazon/ANS-C01-exam.html
BTW, DOWNLOAD part of Pass4Leader ANS-C01 dumps from Cloud Storage: https://drive.google.com/open?id=1uLmTNFu5WJKzE0uH5-gCSn_R3wzgcdux
