[Hardware] Oracle 1z0-1065-25 Exam Registration & 1z0-1065-25 Valid Exam Online
98
Hardware Oracle 1z0-1065-25 Exam Registration & 1z0-1065-25 Valid Exam Online
Posted at 2/19/2026 04:13:45      View118 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of VerifiedDumps 1z0-1065-25 dumps for free: https://drive.google.com/open?id=1GwbD-ZpT1BJoWRp-9l1GoSzj-jofLhL7
The second format is a web-based format that can be accessed from browsers like Firefox, Microsoft Edge, Chrome, and Safari. It means you don't need to download or install any software or plugins to take the Oracle Fusion Cloud Procurement 2025 Implementation Professional practice test. The web-based format of the Oracle 1z0-1065-25 Certification Exams practice test supports all operating systems. The third and last format is desktop software format which can be accessed after installing the software on your Oracle Fusion Cloud Procurement 2025 Implementation Professional (1z0-1065-25) Windows Pc or Laptop. These formats are built especially for the students so they don't stop preparing for the Oracle Fusion Cloud Procurement 2025 Implementation Professional (1z0-1065-25) certification.
Do you want to prove your ability in IT field? Do you want to get more recognition and employment opportunities? So 1z0-1065-25 exam certification will be an important evidence to prove yourself. Almost all those who are working in the IT field know how important to get 1z0-1065-25 exam certification. As we know, everyone's energy is limited, if you want to pass the important 1z0-1065-25 Certification Exam in such short time, the exam software provided by our VerifiedDumps will be a good helper for your preparation for the exam. The complete questions and exam software created in accordance with the laws of the people's memory will help you succeed in the 1z0-1065-25 exam.
Quiz 2026 Oracle 1z0-1065-25 C Valid Exam RegistrationWe provide you the 1z0-1065-25 pratice materials, which include both the questions and answers, and you can improve your ability for the 1z0-1065-25 exam through practicing the materials. Furthermore the 1z0-1065-25 practice materials are of high quality, since they are compiled by the experienced experts, and the professionals will expect the exam dumps to guarantee the quality. At the same time, money back guarantee for your failure of the exam, free update for one year after purchasing the 1z0-1065-25exam.
Oracle Fusion Cloud Procurement 2025 Implementation Professional Sample Questions (Q28-Q33):NEW QUESTION # 28
You have the following business requirements when creating an implementation project:
You want to see the list of offerings and functional areas that are configured for the project.
You want to identify at which stage all offerings and functional areas are.
Which two fulfill these requirements?
  • A. You need the IT Security role to fulfill these requirements.
  • B. Select the Enable check box to specify the options.
  • C. After creating the implementation project, set the status of tasks to in Progress or Implemented.
  • D. Although the offering configuration can be changed at any time, the changes will influence any existing implementation task lists.
  • E. Change Provisioned to "No" to specify the offering that you want to select while creating an implementation project.
When you create an implementation project, you can select the offerings and functional areas that you want to implement by selecting the Enable check box for each option. This will generate a list of setup tasks for the selected options. You can also see the status of each offering and functional area, such as Provisioned, Enabled, or Not Enabled. After creating the implementation project, you can update the status of each task to indicate the progress of the implementation. You can set the status to In Progress, Implemented, or Not Applicable. This will help you to identify the stage of each offering and functional area in the implementation project.
How You Use Implementation Projects to Manage Setup
Oracle Fusion Applications Procurement Implementation Guide, Section 2.1: "Create Implementation Project"
NEW QUESTION # 29
To improve usability and reduce errors, you have set a default negotiation template for each document type when creating or editing a negotiation style.
This feature is always enabled but you do not always see the template that was set on the negotiation style defaulting in.
What could be two reasons for this?
  • A. The template is inactive at the time of creating the negotiation.
  • B. The template is active at the time of creating the negotiation.
  • C. It is a global template and the negotiation is created in the same BU as the template.
  • D. It is a private template where only the template owner can use it.
  • E. It is a public template.
The default negotiation template for each document type is only applied when creating or editing a negotiation style if the template is active and public. If the template is inactive or private, the template will not be defaulted in. Therefore, the two reasons why you do not always see the template that was set on the negotiation style defaulting in are:
* The template is inactive at the time of creating the negotiation. An inactive template cannot be used for creating or editing negotiations, and it will not be displayed in the list of available templates. You need to activate the template before you can use it as a default template.
* It is a private template where only the template owner can use it. A private template is only visible and accessible to the user who created it, and it will not be shared with other users. You need to make the template public if you want to use it as a default template for all users.
Create a Negotiation Template, section "Create a Negotiation Template", subsection "Default Negotiation Template".
Oracle Supplier Negotiations, section "Create Negotiations", subsection "Create Negotiations: Default Negotiation Template".
NEW QUESTION # 30
Which action is required to enable the supplier contacts of a parent company to respond to the negotiations of their subsidiaries?
  • A. The subsidiary supplier must forward the negotiation to the parent company to respond.
  • B. The parent supplier must be added to the negotiation.
  • C. The subsidiary supplier must request the parent supplier contact be added to the negotiation.
  • D. The parent supplier must be added to the subsidiary supplier profile.
To enable the supplier contacts of a parent company to respond to the negotiations of their subsidiaries, the parent supplier must be added to the negotiation as an invited supplier. This will allow the parent supplier contacts to access the negotiation through the Oracle Supplier Portal and submit responses on behalf of the subsidiary supplier. The parent supplier can also view and monitor the negotiation progress and status. The parent supplier must have an active supplier portal user account and the appropriate roles and privileges to participate in the negotiation.
How You Invite Suppliers to Negotiations1
Oracle Supplier Negotiations2
Response to Negotiations3
NEW QUESTION # 31
uring discussions your client indicates that as they are a contract manufacturer, they need to execute supply chain activities in the context of projects.
In which offering can you opt in to a feature that enables this?
  • A. Manufacturing and Supply Chain Materials Management
  • B. Project Financial Management
  • C. Project Execution Management
NEW QUESTION # 32
To opt in to Project-Driven Supply Chain (PDSC), you enable the feature in the Manufacturing and Supply Chain Materials Management offering.
What are two additional setup tasks that you must perform?
  • A. Manage Project Organization Classifications
  • B. Manage Item Organizations
  • C. Manage Project Attribute Defaults
  • D. Manage Inventory Organizations
NEW QUESTION # 33
If someone who can pass the exam, they can earn a high salary in a short time. If you decide to beat the exam, you must try our 1z0-1065-25 exam torrent, then, you will find that it is so easy to pass the exam. You only need little time and energy to review and prepare for the exam if you use our 1z0-1065-25 prep torrent as the studying materials. So it is worthy for them to buy our 1z0-1065-25 learning prep. We provide the free demo of our 1z0-1065-25 training guide so as to let you have a good understanding of our 1z0-1065-25 exam questions before your purchase.
1z0-1065-25 Valid Exam Online: https://www.verifieddumps.com/1z0-1065-25-valid-exam-braindumps.html
Oracle 1z0-1065-25 Exam Registration Do you want to improve your skills in a shorter time as soon as possible but lacking of proper training materials, Our 1z0-1065-25 valid study material embraces latest information, up-to-date knowledge and fresh ideas, encouraging the practice of thinking out of box rather than treading the same old path following a beaten track, We offer you the most accurate 1z0-1065-25 exam answers that will be your key to pass the certification exam in your first try.
So here we have a case in which these selectors, although 1z0-1065-25 valid syntactically, are connected to no elements whatsoever in browsers that correctly interpret them.
Our 1z0-1065-25 training materials: Oracle Fusion Cloud Procurement 2025 Implementation Professional are easy to understand with three versions of products: PDF & Software & APP version, Do you want to improve your skills 1z0-1065-25 Simulations Pdf in a shorter time as soon as possible but lacking of proper training materials?
Oracle 1z0-1065-25 Exam Questions are Available in 3 Easy-to-Understand FormatsOur 1z0-1065-25 valid study material embraces latest information, up-to-date knowledge and fresh ideas, encouraging the practice of thinking out of box rather than treading the same old path following a beaten track.
We offer you the most accurate 1z0-1065-25 exam answers that will be your key to pass the certification exam in your first try, Perhaps you still cannot believe in our Oracle 1z0-1065-25 study materials.
Let these tools provide you all the guidance and help for your certification.
BTW, DOWNLOAD part of VerifiedDumps 1z0-1065-25 dumps from Cloud Storage: https://drive.google.com/open?id=1GwbD-ZpT1BJoWRp-9l1GoSzj-jofLhL7
