Actual Oracle 1z0-1057-25 Exam Dumps–Pass Exam With Good Scores
Posted at 2/19/2026 05:09:40
P.S. Free 2026 Oracle 1z0-1057-25 dumps are available on Google Drive shared by ExamsReviews: https://drive.google.com/open?id=11_R_HdddgEZ3f--taJVjG5htPj44t0Jc
Are you still looking for 1z0-1057-25 exam materials? Don't worry about it, because you find us, which means that you've found a shortcut to pass 1z0-1057-25 certification exam. With research and development of IT certification test software for years, our ExamsReviews team had a very good reputation in the world. We provide the most comprehensive and effective help to those who are preparing for the important exams such as 1z0-1057-25 Exam.
Our services before, during and after the clients use our 1z0-1057-25 certification material are considerate. Before the purchase, the clients can download and try out our 1z0-1057-25 learning file freely. During the clients use our products they can contact our online customer service staff to consult the problems about our products. Our company gives priority to the satisfaction degree of the clients on our 1z0-1057-25 Exam Questions and puts the quality of the service in the first place. We also have free demo of our 1z0-1057-25 learning guide for you to check the quality before your payment.
Reliable 1z0-1057-25 Exam Dumps - Valid 1z0-1057-25 Test TopicsIt can almost be said that you can pass the 1z0-1057-25 exam only if you choose our 1z0-1057-25 exam braindumps. Our 1z0-1057-25 study materials will provide everything we can do to you. Only should you move the mouse to buy it can you enjoy our full range of thoughtful services. Having said that, why not give our 1z0-1057-25 Preparation materials a try instead of spending a lot of time and effort doing something that you may be not good at? Just give it to us and you will succeed easily.
Oracle Project Management Cloud 2025 Implementation Professional Sample Questions (Q79-Q84):NEW QUESTION # 79
Which two statements are true about a project in "Draft" status? (Choose two.)
- A. Team members cannot see the tasks from draft projects on the Team Member Dashboard or in the My Work area.
- B. Project managers can neither view draft projects on the Project Manager Dashboard nor use the projects for requirements planning.
- C. Project managers can view draft projects on the Project Manager Dashboard and use the projects for requirements planning.
- D. Team members can see the tasks from draft projects on the Team Member Dashboard or in the My Work area.
Reference https://docs.oracle.com/cloud/la ... EM/OAPEM1122096.htm The following table lists the project statuses and what you can do with projects in that status.
Project Status
What you can do?
Draft
* Project managers can view draft projects in the Project Manager Dashboard and use the projects for requirements planning.
* Team members can't see the tasks from draft projects on the Team Member Dashboard or in the My Work area.
Active
* Project managers can view active projects in the Project Manager Dashboard and use the projects for requirements planning, project execution, and reporting.
* Team members can view task assignments on active projects on the Team Member Dashboard and My Work area.
Pending Close
* Project managers can view pending projects in the Project Manager Dashboard and use the projects for project tracking, and reporting.
* Team members can view task assignments on pending projects on the Team Member Dashboard and My Work area.
Submitted
* Project managers can view submitted projects in the Project Manager Dashboard and use the projects for project tracking, and reporting.
* Team members can view task assignments on submitted projects on the Team Member Dashboard and My Work area Closed
* Project managers can't view closed projects in the Project Manager Dashboard or use the projects for requirements planning, project execution, and reporting.
* Team members can't view tasks of closed projects on the Team Member Dashboard or in the My Work area.
NEW QUESTION # 80
Your company creates a separate project for infrastructure services, so as to track these costs separately and then allocate to various projects that use the services of the infrastructure team. You want to allocate these costs by first attributing a fixed percentage of the source amount to each project and then spread it across tasks based on the actual labor hours charged to each task.
Which allocation basis method would you use to meet this requirement? (Choose the best answer.)
- A. target percentage and spread evenly
- B. prorate
- C. spread evenly
- D. target percentage and prorate
Ref: https://docs.oracle.com/en/cloud ... cate-project-costs.
html#OAPJC94831
* Spread Evenly
* The allocation rule divides the source pool amount equally among all the chargeable target tasks included in the rule. This is the most simple and direct basis method.
* Target Percentage and Spread Evenly
* Specify the percentage of the source pool that is required to allocate to each target line. The total specified target percentage must always equal 100 percent. The allocation rule calculates the amount to allocate to the target line, and then spreads the results evenly among the chargeable tasks.
* Prorate
* The allocation generation uses the attributes defined in the allocation rule to derive the rate at which the source pool amount is apportioned among the target projects and tasks. For this basis method, the allocation rule uses the basis attributes to apportion the source amount among all the tasks defined by the rule. The Prorate basis method provides precise control over how the rule distributes the source pool.
* Target Percentage and Prorate
* The allocation rule first uses the target percentage to calculate the amount to allocate to the line, and then apportions the results among all the tasks. The Target Percentage and Prorate basis method provides precise control over how the rule distributes the source pool.
NEW QUESTION # 81
Which four notification templates are predefined?
- A. New Account Manager Template
- B. Forgot Password Template
- C. New Account Template
- D. Forgot Username Template
- E. Password Reset Template
Answer: A,C,D,E
https://docs.oracle.com/en/cloud ... y.html#OSCUS2287154 Predefined Notification Templates Notification Template Description Password Expiry Warning Template Warns the user that a password is expiring soon and provides instructions for resetting the password.
Password Expiration Template
Notifies the user that a password has expired and provides instructions for resetting the password.
Forgot User Name Template
Sends the user name to a user who requested the reminder.
Password Generated Template
Notifies the user that a password has been generated automatically and provides instructions for resetting the password.
Sends a reset-password link to a user who requested a new password.
Users can request new passwords by selecting the Forgot Password link on the application Sign In page, or by selecting the Password option on the Preferences page (Settings and Actions > Set Preferences).
Password Reset Confirmation Template
Notifies the user when a password has been reset.
Notifies a user when a user account is created and provides a reset-password link.
Notifies the user's manager when a user account is created.
When you create a user category, it's associated automatically with the predefined notification templates, which are all enabled.
You can't edit the predefined templates. However, you can create templates and disable the predefined versions. Each predefined event can be associated with only one enabled notification template at a time.
NEW QUESTION # 82
Your customer has implemented Oracle Project Portfolio Management Cloud recently and they have hired new employees for their Professions Services business. These employees are set up in Oracle Human Capital Management Cloud, but the Project Administrators are unable to add them as resources in the Planning Resource Breakdown Structure.
What are three conditions for new employees to show up in the list? (Choose three.)
- A. All new employees created as persons must have an active supervisor.
- B. All new employees created as persons must have an active project role.
- C. All new employees created as persons must be assigned to a department.
- D. All new employees created as persons must have an active assignment.
- E. Current date is before the effective date of the resource, and you did not enable the "Include people with future-dated effective start dates" option during the search.
Answer: C,D,E
Ref: https://docs.oracle.com/en/cloud ... project-foundation- configuration-define-project-resource-breakdown-structures.html#OAPFM180158_2 Why can't I find persons in the list of resources when I enter team members, planning resources, or person rate schedules?
You can't find persons in the list of resources when you enter team members, planning resources, or person rate schedules in the following situations:
* The administrator didn't assign a department while creating users. Persons must have an active assignment and be assigned to a department in Oracle Fusion Human Capital Management before they can be added as team members or entered as resources on the planning resource breakdown structure or person rate schedule.
* The resource isn't active in Oracle Fusion Human Capital Management because the current date is before the effective date of the resource. If you want to include persons who will start in the future, select the Include people with future-dated effective start dates option when you search for the person.
* Persons assigned as project managers aren't active as of the project start date.
* The assignment of the person is terminated, and an appropriate value isn't set for the number of days to display people with terminated assignments. You can set the profile value appropriately at the site profile level using the Specify Number of Days to Display People with Terminated Assignments task in the Setup and Maintenance work area.
NEW QUESTION # 83
Your customer accounts revenue based on, product class category. Because all your customer's projects are funded by private and government institutions, they decide to classify all projects based on their funding source to accurately report on revenue in General Ledger. Accordingly, you create a new class category
"Funding Source" and assign it to all projects. However, you notice that the accounting is still happening based on product class category. Identify the reason for this problem. (Choose the best answer.)
- A. Funding source class category is not enabled for "available as accounting source".
- B. Product class category is not enabled for "available as accounting source".
- C. Funding source class category is enabled for "available as accounting source".
- D. Funding source class category is assigned to all project types.
Ref: https://docs.oracle.com/en/cloud ... project-foundation- configuration-define-types-and-categorizations.html#OAPFM222700 Topic - Manage Project Class Categories Setting Up Class Categories: Points to Consider Available as Accounting Source This option indicates if the class category is available as an accounting source so that Oracle Fusion Subledger Accounting can use the category to create mapping sets, account rules, journal line rules, and description rules.
Only one class category at a time is available as an accounting source in Oracle Fusion Subledger Accounting.
To change the class category that Oracle Fusion Subledger Accounting uses, deactivate the old class category and create a new one with a different date range.
NEW QUESTION # 84
Our 1z0-1057-25 practice materials not only reflect the authentic knowledge of this area, but contents the new changes happened these years. They are reflection of our experts’ authority. By assiduous working on them, they are dependable backup and academic uplift. So our experts’ team made the 1z0-1057-25 Guide dumps superior with their laborious effort. Of course the quality of our 1z0-1057-25 exam quiz is high.
Reliable 1z0-1057-25 Exam Dumps: https://www.examsreviews.com/1z0-1057-25-pass4sure-exam-review.html
Oracle 1z0-1057-25 Valid Test Testking It is available for examinees that who are used to studying on paper, Oracle 1z0-1057-25 Valid Test Testking Today, the fast developed society is full of chance and challenge, so all of us may face the problem how to get more qualified and competent, To achieve this objective the ExamsReviews is offering the top-rated and real 1z0-1057-25 exam questions in three different 1z0-1057-25 exam study material formats, We aim to build good relationship with every customer by providing best service; we pay attention to word-of-mouth of our 1z0-1057-25 practice exam, most of customers are recommended by their friends, colleagues or classmates.
Due to the rich media included in this enhanced eBook, you may experience longer than usual download times, Our Project Financials Management Cloud 1z0-1057-25 test review dumps concluded the useful lessons from successful experiences and lessons from failure, summarizes Reliable 1z0-1057-25 Exam Dumps the commonness training material and high frequency tests which can be a great help to passing the Oracle Project Management Cloud 2025 Implementation Professional actual test.
Free PDF Quiz 2026 High-quality Oracle 1z0-1057-25 Valid Test TestkingIt is available for examinees that who are used to studying on paper, Today, 1z0-1057-25 the fast developed society is full of chance and challenge, so all of us may face the problem how to get more qualified and competent.
Our 1z0-1057-25 study guide is known as instant download, once you finish your payment, we will send the downloading link and password to you, and you can get 1z0-1057-25 study guide within ten minutes.
- 100% Pass Unparalleled Oracle - 1z0-1057-25 - Oracle Project Management Cloud 2025 Implementation Professional Valid Test Testking 🔯 Search for [ 1z0-1057-25 ] and download it for free on ▛ [url]www.troytecdumps.com ▟ website 🦳1z0-1057-25 Exam Exercise[/url]
- 100% Pass Quiz 2026 Oracle High Hit-Rate 1z0-1057-25: Oracle Project Management Cloud 2025 Implementation Professional Valid Test Testking 🎯 Immediately open { [url]www.pdfvce.com } and search for ▛ 1z0-1057-25 ▟ to obtain a free download 👯Reliable 1z0-1057-25 Test Blueprint[/url]
- 100% Pass Quiz 2026 Oracle High Hit-Rate 1z0-1057-25: Oracle Project Management Cloud 2025 Implementation Professional Valid Test Testking 🌆 Search on ➤ [url]www.troytecdumps.com ⮘ for ➽ 1z0-1057-25 🢪 to obtain exam materials for free download 🐌1z0-1057-25 Exam Vce Format[/url]
- 1z0-1057-25 Valid Test Testking | Professional Reliable 1z0-1057-25 Exam Dumps: Oracle Project Management Cloud 2025 Implementation Professional 100% Pass 😛 ✔ [url]www.pdfvce.com ️✔️ is best website to obtain ▷ 1z0-1057-25 ◁ for free download 🧥1z0-1057-25 Valid Test Tutorial[/url]
- Valid 1z0-1057-25 Exam Sample 😮 Latest 1z0-1057-25 Exam Experience 👠 1z0-1057-25 Exam Exercise 🌈 Copy URL ▛ [url]www.practicevce.com ▟ open and search for ➤ 1z0-1057-25 ⮘ to download for free ☀New 1z0-1057-25 Braindumps Sheet[/url]
- Reliable 1z0-1057-25 Exam Voucher 😧 1z0-1057-25 Exam Vce Format 🚊 Latest 1z0-1057-25 Study Plan 🪔 Open website ⏩ [url]www.pdfvce.com ⏪ and search for ☀ 1z0-1057-25 ️☀️ for free download 👤1z0-1057-25 Exam Exercise[/url]
- Free PDF Quiz Fantastic Oracle - 1z0-1057-25 Valid Test Testking 🎳 Simply search for ▛ 1z0-1057-25 ▟ for free download on ➤ [url]www.pdfdumps.com ⮘ 💨1z0-1057-25 Valid Test Tutorial[/url]
- Free PDF Quiz 1z0-1057-25 - Perfect Oracle Project Management Cloud 2025 Implementation Professional Valid Test Testking 🖼 Copy URL ➠ [url]www.pdfvce.com 🠰 open and search for ( 1z0-1057-25 ) to download for free 🤟1z0-1057-25 Latest Materials[/url]
- Oracle 1z0-1057-25 Exam Questions Available At 25% Discount With Free Demo 🙀 Go to website ➠ [url]www.verifieddumps.com 🠰 open and search for ➠ 1z0-1057-25 🠰 to download for free 👙Reliable 1z0-1057-25 Exam Voucher[/url]
- 1z0-1057-25 Book Pdf ⛲ 1z0-1057-25 Accurate Test ⌨ Reliable 1z0-1057-25 Test Blueprint ⛪ Open 【 [url]www.pdfvce.com 】 enter ☀ 1z0-1057-25 ️☀️ and obtain a free download 🌝1z0-1057-25 Exam Vce Format[/url]
- Free PDF Quiz 1z0-1057-25 - Perfect Oracle Project Management Cloud 2025 Implementation Professional Valid Test Testking ⛷ Download ➥ 1z0-1057-25 🡄 for free by simply entering 【 [url]www.prepawayexam.com 】 website 👤New 1z0-1057-25 Braindumps Sheet[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, moqacademy.pk, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
2026 Latest ExamsReviews 1z0-1057-25 PDF Dumps and 1z0-1057-25 Exam Engine Free Share: https://drive.google.com/open?id=11_R_HdddgEZ3f--taJVjG5htPj44t0Jc
